| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: bsdfrbf.c,v 2.4 2013/03/20 01:00:22 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Radial basis function representation for BSDF data.
| 6 |
| 7 |
* G. Ward
| 8 |
| 9 |
| 10 |
#define _USE_MATH_DEFINES
| 11 |
#include <stdio.h>
| 12 |
#include <stdlib.h>
| 13 |
#include <string.h>
| 14 |
#include <math.h>
| 15 |
#include "bsdfrep.h"
| 16 |
| 17 |
#ifndef RSCA
| 18 |
#define RSCA 2.7 /* radius scaling factor (empirical) */
| 19 |
#endif
| 20 |
/* our loaded grid for this incident angle */
| 21 |
GRIDVAL dsf_grid[GRIDRES][GRIDRES];
| 22 |
| 23 |
/* Start new DSF input grid */
| 24 |
void
| 25 |
new_bsdf_data(double new_theta, double new_phi)
| 26 |
| 27 |
if (!new_input_direction(new_theta, new_phi))
| 28 |
exit(1);
| 29 |
memset(dsf_grid, 0, sizeof(dsf_grid));
| 30 |
| 31 |
| 32 |
/* Add BSDF data point */
| 33 |
void
| 34 |
add_bsdf_data(double theta_out, double phi_out, double val, int isDSF)
| 35 |
| 36 |
FVECT ovec;
| 37 |
int pos[2];
| 38 |
| 39 |
if (!output_orient) /* check output orientation */
| 40 |
output_orient = 1 - 2*(theta_out > 90.);
| 41 |
else if (output_orient > 0 ^ theta_out < 90.) {
| 42 |
fputs("Cannot handle output angles on both sides of surface\n",
| 43 |
stderr);
| 44 |
exit(1);
| 45 |
| 46 |
ovec[2] = sin((M_PI/180.)*theta_out);
| 47 |
ovec[0] = cos((M_PI/180.)*phi_out) * ovec[2];
| 48 |
ovec[1] = sin((M_PI/180.)*phi_out) * ovec[2];
| 49 |
ovec[2] = sqrt(1. - ovec[2]*ovec[2]);
| 50 |
| 51 |
if (!isDSF)
| 52 |
val *= ovec[2]; /* convert from BSDF to DSF */
| 53 |
| 54 |
/* update BSDF histogram */
| 55 |
if (val < BSDF2BIG*ovec[2] && val > BSDF2SML*ovec[2])
| 56 |
++bsdf_hist[histndx(val/ovec[2])];
| 57 |
| 58 |
pos_from_vec(pos, ovec);
| 59 |
| 60 |
dsf_grid[pos[0]][pos[1]].vsum += val;
| 61 |
dsf_grid[pos[0]][pos[1]].nval++;
| 62 |
| 63 |
| 64 |
/* Compute radii for non-empty bins */
| 65 |
/* (distance to furthest empty bin for which non-empty bin is the closest) */
| 66 |
static void
| 67 |
compute_radii(void)
| 68 |
| 69 |
unsigned int fill_grid[GRIDRES][GRIDRES];
| 70 |
unsigned short fill_cnt[GRIDRES][GRIDRES];
| 71 |
FVECT ovec0, ovec1;
| 72 |
double ang2, lastang2;
| 73 |
int r, i, j, jn, ii, jj, inear, jnear;
| 74 |
| 75 |
r = GRIDRES/2; /* proceed in zig-zag */
| 76 |
for (i = 0; i < GRIDRES; i++)
| 77 |
for (jn = 0; jn < GRIDRES; jn++) {
| 78 |
j = (i&1) ? jn : GRIDRES-1-jn;
| 79 |
if (dsf_grid[i][j].nval) /* find empty grid pos. */
| 80 |
continue;
| 81 |
ovec_from_pos(ovec0, i, j);
| 82 |
inear = jnear = -1; /* find nearest non-empty */
| 83 |
lastang2 = M_PI*M_PI;
| 84 |
for (ii = i-r; ii <= i+r; ii++) {
| 85 |
if (ii < 0) continue;
| 86 |
if (ii >= GRIDRES) break;
| 87 |
for (jj = j-r; jj <= j+r; jj++) {
| 88 |
if (jj < 0) continue;
| 89 |
if (jj >= GRIDRES) break;
| 90 |
if (!dsf_grid[ii][jj].nval)
| 91 |
continue;
| 92 |
ovec_from_pos(ovec1, ii, jj);
| 93 |
ang2 = 2. - 2.*DOT(ovec0,ovec1);
| 94 |
if (ang2 >= lastang2)
| 95 |
continue;
| 96 |
lastang2 = ang2;
| 97 |
inear = ii; jnear = jj;
| 98 |
| 99 |
| 100 |
if (inear < 0) {
| 101 |
fprintf(stderr,
| 102 |
"%s: Could not find non-empty neighbor!\n",
| 103 |
progname);
| 104 |
exit(1);
| 105 |
| 106 |
ang2 = sqrt(lastang2);
| 107 |
r = ANG2R(ang2); /* record if > previous */
| 108 |
if (r > dsf_grid[inear][jnear].crad)
| 109 |
dsf_grid[inear][jnear].crad = r;
| 110 |
/* next search radius */
| 111 |
r = ang2*(2.*GRIDRES/M_PI) + 3;
| 112 |
| 113 |
/* blur radii over hemisphere */
| 114 |
memset(fill_grid, 0, sizeof(fill_grid));
| 115 |
memset(fill_cnt, 0, sizeof(fill_cnt));
| 116 |
| 117 |
for (j = 0; j < GRIDRES; j++) {
| 118 |
if (!dsf_grid[i][j].crad)
| 119 |
continue; /* missing distance */
| 120 |
r = R2ANG(dsf_grid[i][j].crad)*(2.*RSCA*GRIDRES/M_PI);
| 121 |
| 122 |
| 123 |
| 124 |
| 125 |
| 126 |
| 127 |
if ((ii-i)*(ii-i) + (jj-j)*(jj-j) > r*r)
| 128 |
continue;
| 129 |
fill_grid[ii][jj] += dsf_grid[i][j].crad;
| 130 |
fill_cnt[ii][jj]++;
| 131 |
| 132 |
| 133 |
| 134 |
/* copy back blurred radii */
| 135 |
| 136 |
| 137 |
if (fill_cnt[i][j])
| 138 |
dsf_grid[i][j].crad = fill_grid[i][j]/fill_cnt[i][j];
| 139 |
| 140 |
| 141 |
/* Cull points for more uniform distribution, leave all nval 0 or 1 */
| 142 |
static void
| 143 |
cull_values(void)
| 144 |
| 145 |
FVECT ovec0, ovec1;
| 146 |
double maxang, maxang2;
| 147 |
int i, j, ii, jj, r;
| 148 |
/* simple greedy algorithm */
| 149 |
| 150 |
| 151 |
if (!dsf_grid[i][j].nval)
| 152 |
continue;
| 153 |
| 154 |
continue; /* shouldn't happen */
| 155 |
| 156 |
maxang = 2.*R2ANG(dsf_grid[i][j].crad);
| 157 |
if (maxang > ovec0[2]) /* clamp near horizon */
| 158 |
maxang = ovec0[2];
| 159 |
r = maxang*(2.*GRIDRES/M_PI) + 1;
| 160 |
maxang2 = maxang*maxang;
| 161 |
| 162 |
| 163 |
| 164 |
| 165 |
| 166 |
| 167 |
| 168 |
continue;
| 169 |
if ((ii == i) & (jj == j))
| 170 |
continue; /* don't get self-absorbed */
| 171 |
| 172 |
if (2. - 2.*DOT(ovec0,ovec1) >= maxang2)
| 173 |
continue;
| 174 |
/* absorb sum */
| 175 |
dsf_grid[i][j].vsum += dsf_grid[ii][jj].vsum;
| 176 |
dsf_grid[i][j].nval += dsf_grid[ii][jj].nval;
| 177 |
/* keep value, though */
| 178 |
dsf_grid[ii][jj].vsum /= (float)dsf_grid[ii][jj].nval;
| 179 |
dsf_grid[ii][jj].nval = 0;
| 180 |
| 181 |
| 182 |
| 183 |
/* final averaging pass */
| 184 |
| 185 |
| 186 |
if (dsf_grid[i][j].nval > 1) {
| 187 |
dsf_grid[i][j].vsum /= (float)dsf_grid[i][j].nval;
| 188 |
dsf_grid[i][j].nval = 1;
| 189 |
| 190 |
| 191 |
| 192 |
/* Compute minimum BSDF from histogram and clear it */
| 193 |
static void
| 194 |
comp_bsdf_min()
| 195 |
| 196 |
int cnt;
| 197 |
int i, target;
| 198 |
| 199 |
cnt = 0;
| 200 |
for (i = HISTLEN; i--; )
| 201 |
cnt += bsdf_hist[i];
| 202 |
if (!cnt) { /* shouldn't happen */
| 203 |
bsdf_min = 0;
| 204 |
return;
| 205 |
| 206 |
target = cnt/100; /* ignore bottom 1% */
| 207 |
cnt = 0;
| 208 |
for (i = 0; cnt <= target; i++)
| 209 |
| 210 |
bsdf_min = histval(i-1);
| 211 |
memset(bsdf_hist, 0, sizeof(bsdf_hist));
| 212 |
| 213 |
| 214 |
/* Count up filled nodes and build RBF representation from current grid */
| 215 |
RBFNODE *
| 216 |
make_rbfrep(void)
| 217 |
| 218 |
int niter = 16;
| 219 |
double lastVar, thisVar = 100.;
| 220 |
int nn;
| 221 |
RBFNODE *newnode;
| 222 |
RBFVAL *itera;
| 223 |
int i, j;
| 224 |
/* compute RBF radii */
| 225 |
compute_radii();
| 226 |
/* coagulate lobes */
| 227 |
cull_values();
| 228 |
nn = 0; /* count selected bins */
| 229 |
| 230 |
| 231 |
nn += dsf_grid[i][j].nval;
| 232 |
/* compute minimum BSDF */
| 233 |
comp_bsdf_min();
| 234 |
/* allocate RBF array */
| 235 |
newnode = (RBFNODE *)malloc(sizeof(RBFNODE) + sizeof(RBFVAL)*(nn-1));
| 236 |
if (newnode == NULL)
| 237 |
goto memerr;
| 238 |
newnode->ord = -1;
| 239 |
newnode->next = NULL;
| 240 |
newnode->ejl = NULL;
| 241 |
newnode->invec[2] = sin((M_PI/180.)*theta_in_deg);
| 242 |
newnode->invec[0] = cos((M_PI/180.)*phi_in_deg)*newnode->invec[2];
| 243 |
newnode->invec[1] = sin((M_PI/180.)*phi_in_deg)*newnode->invec[2];
| 244 |
newnode->invec[2] = input_orient*sqrt(1. - newnode->invec[2]*newnode->invec[2]);
| 245 |
newnode->vtotal = 0;
| 246 |
newnode->nrbf = nn;
| 247 |
nn = 0; /* fill RBF array */
| 248 |
| 249 |
| 250 |
if (dsf_grid[i][j].nval) {
| 251 |
newnode->rbfa[nn].peak = dsf_grid[i][j].vsum;
| 252 |
newnode->rbfa[nn].crad = RSCA*dsf_grid[i][j].crad + .5;
| 253 |
newnode->rbfa[nn].gx = i;
| 254 |
newnode->rbfa[nn].gy = j;
| 255 |
++nn;
| 256 |
| 257 |
/* iterate to improve interpolation accuracy */
| 258 |
itera = (RBFVAL *)malloc(sizeof(RBFVAL)*newnode->nrbf);
| 259 |
if (itera == NULL)
| 260 |
goto memerr;
| 261 |
memcpy(itera, newnode->rbfa, sizeof(RBFVAL)*newnode->nrbf);
| 262 |
do {
| 263 |
double dsum = 0, dsum2 = 0;
| 264 |
nn = 0;
| 265 |
| 266 |
| 267 |
| 268 |
FVECT odir;
| 269 |
double corr;
| 270 |
ovec_from_pos(odir, i, j);
| 271 |
itera[nn++].peak *= corr =
| 272 |
| 273 |
eval_rbfrep(newnode, odir);
| 274 |
dsum += 1. - corr;
| 275 |
dsum2 += (1.-corr)*(1.-corr);
| 276 |
| 277 |
memcpy(newnode->rbfa, itera, sizeof(RBFVAL)*newnode->nrbf);
| 278 |
lastVar = thisVar;
| 279 |
thisVar = dsum2/(double)nn;
| 280 |
#ifdef DEBUG
| 281 |
fprintf(stderr, "Avg., RMS error: %.1f%% %.1f%%\n",
| 282 |
100.*dsum/(double)nn,
| 283 |
100.*sqrt(thisVar));
| 284 |
#endif
| 285 |
} while (--niter > 0 && lastVar-thisVar > 0.02*lastVar);
| 286 |
| 287 |
free(itera);
| 288 |
nn = 0; /* compute sum for normalization */
| 289 |
while (nn < newnode->nrbf)
| 290 |
newnode->vtotal += rbf_volume(&newnode->rbfa[nn++]);
| 291 |
#ifdef DEBUG
| 292 |
fprintf(stderr, "Integrated DSF at (%.1f,%.1f) deg. is %.2f\n",
| 293 |
get_theta180(newnode->invec), get_phi360(newnode->invec),
| 294 |
newnode->vtotal);
| 295 |
#endif
| 296 |
insert_dsf(newnode);
| 297 |
| 298 |
return(newnode);
| 299 |
memerr:
| 300 |
fprintf(stderr, "%s: Out of memory in make_rbfrep()\n", progname);
| 301 |
exit(1);
| 302 |
