root/radiance/ray/src/cv/bsdfrbf.c
Revision: 2.10
Committed: Fri Oct 18 02:49:30 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.9: +49 -9 lines
Fixed bug for transmission and improved culling in uniform regions
2 static const char RCSid[] = "$Id: bsdfrbf.c,v 2.9 2013/10/17 19:09:11 greg Exp $";
5 * Radial basis function representation for BSDF data.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdio.h>
12 #include <stdlib.h>
13 #include <string.h>
14 #include <math.h>
15 #include "bsdfrep.h"
16
17 #ifndef MINRSCA
18 #define MINRSCA 0.5 /* minimum radius scaling factor */
19 #endif
20 #ifndef MAXRSCA
21 #define MAXRSCA 2.7 /* maximum radius scaling factor */
22 #endif
23 #ifndef DIFFTHRESH
24 #define DIFFTHRESH 0.2 /* culling difference threshold */
25 #endif
26 #ifndef MAXFRAC
27 #define MAXFRAC 0.5 /* maximum contribution to neighbor */
28 #endif
29 #ifndef NNEIGH
30 #define NNEIGH 10 /* number of neighbors to consider */
31 #endif
32 /* our loaded grid for this incident angle */
33 GRIDVAL dsf_grid[GRIDRES][GRIDRES];
34
35 /* Start new DSF input grid */
36 void
37 new_bsdf_data(double new_theta, double new_phi)
38 {
39 if (!new_input_direction(new_theta, new_phi))
40 exit(1);
41 memset(dsf_grid, 0, sizeof(dsf_grid));
42 }
43
44 /* Add BSDF data point */
45 void
46 add_bsdf_data(double theta_out, double phi_out, double val, int isDSF)
47 {
48 FVECT ovec;
49 int pos[2];
50
51 if (!output_orient) /* check output orientation */
52 output_orient = 1 - 2*(theta_out > 90.);
53 else if (output_orient > 0 ^ theta_out < 90.) {
54 fputs("Cannot handle output angles on both sides of surface\n",
55 stderr);
56 exit(1);
57 }
58 ovec[2] = sin((M_PI/180.)*theta_out);
59 ovec[0] = cos((M_PI/180.)*phi_out) * ovec[2];
60 ovec[1] = sin((M_PI/180.)*phi_out) * ovec[2];
61 ovec[2] = sqrt(1. - ovec[2]*ovec[2]);
62
63 if (val <= 0) /* truncate to zero */
64 val = 0;
65 else if (!isDSF)
66 val *= ovec[2]; /* convert from BSDF to DSF */
67
68 /* update BSDF histogram */
69 if (val < BSDF2BIG*ovec[2] && val > BSDF2SML*ovec[2])
70 ++bsdf_hist[histndx(val/ovec[2])];
71
72 pos_from_vec(pos, ovec);
73
74 dsf_grid[pos[0]][pos[1]].vsum += val;
75 dsf_grid[pos[0]][pos[1]].nval++;
76 }
77
78 /* Check if the two DSF values are significantly different */
79 static int
80 big_diff(double ref, double tst)
81 {
82 if (ref > 0) {
83 tst = tst/ref - 1.;
84 if (tst < 0) tst = -tst;
85 } else
86 tst *= 50.;
87 return(tst > DIFFTHRESH);
88 }
89
90 /* Compute radii for non-empty bins */
91 /* (distance to furthest empty bin for which non-empty test bin is closest) */
92 static void
93 compute_radii(void)
94 {
95 const int cradmin = ANG2R(.5*M_PI/GRIDRES);
96 unsigned int fill_grid[GRIDRES][GRIDRES];
97 unsigned short fill_cnt[GRIDRES][GRIDRES];
98 FVECT ovec0, ovec1;
99 double ang2, lastang2;
100 int r, i, j, jn, ii, jj, inear, jnear;
101
102 r = GRIDRES/2; /* proceed in zig-zag */
103 for (i = 0; i < GRIDRES; i++)
104 for (jn = 0; jn < GRIDRES; jn++) {
105 j = (i&1) ? jn : GRIDRES-1-jn;
106 if (dsf_grid[i][j].nval) /* find empty grid pos. */
107 continue;
108 ovec_from_pos(ovec0, i, j);
109 inear = jnear = -1; /* find nearest non-empty */
110 lastang2 = M_PI*M_PI;
111 for (ii = i-r; ii <= i+r; ii++) {
112 if (ii < 0) continue;
113 if (ii >= GRIDRES) break;
114 for (jj = j-r; jj <= j+r; jj++) {
115 if (jj < 0) continue;
116 if (jj >= GRIDRES) break;
117 if (!dsf_grid[ii][jj].nval)
118 continue;
119 ovec_from_pos(ovec1, ii, jj);
120 ang2 = 2. - 2.*DOT(ovec0,ovec1);
121 if (ang2 >= lastang2)
122 continue;
123 lastang2 = ang2;
124 inear = ii; jnear = jj;
125 }
126 }
127 if (inear < 0) {
128 fprintf(stderr,
129 "%s: Could not find non-empty neighbor!\n",
130 progname);
131 exit(1);
132 }
133 ang2 = sqrt(lastang2);
134 r = ANG2R(ang2); /* record if > previous */
135 if (r > dsf_grid[inear][jnear].crad)
136 dsf_grid[inear][jnear].crad = r;
137 /* next search radius */
138 r = ang2*(2.*GRIDRES/M_PI) + 3;
139 }
140 for (i = 0; i < GRIDRES; i++) /* grow radii where uniform */
141 for (j = 0; j < GRIDRES; j++) {
142 double midmean;
143 if (!dsf_grid[i][j].nval)
144 continue;
145 midmean = dsf_grid[i][j].vsum / (double)dsf_grid[i][j].nval;
146 r = R2ANG(dsf_grid[i][j].crad)*(MAXRSCA*GRIDRES/M_PI);
147 while (++r < GRIDRES) { /* attempt to grow perimeter */
148 for (ii = i-r; ii <= i+r; ii++) {
149 int jstep = 1;
150 if (ii < 0) continue;
151 if (ii >= GRIDRES) break;
152 if ((i-r < ii) & (ii < i+r))
153 jstep = r<<1;
154 for (jj = j-r; jj <= j+r; jj += jstep) {
155 if (jj < 0) continue;
156 if (jj >= GRIDRES) break;
157 if (dsf_grid[ii][jj].nval && big_diff(midmean,
158 dsf_grid[ii][jj].vsum /
159 (double)dsf_grid[ii][jj].nval))
160 goto hit_diff;
161 }
162 }
163 }
164 hit_diff: --r;
165 dsf_grid[i][j].crad = ANG2R(r*(M_PI/MAXRSCA/GRIDRES));
166 if (dsf_grid[i][j].crad < cradmin)
167 dsf_grid[i][j].crad = cradmin;
168 }
169 /* blur radii over hemisphere */
170 memset(fill_grid, 0, sizeof(fill_grid));
171 memset(fill_cnt, 0, sizeof(fill_cnt));
172 for (i = 0; i < GRIDRES; i++)
173 for (j = 0; j < GRIDRES; j++) {
174 if (!dsf_grid[i][j].nval)
175 continue; /* not part of this */
176 r = R2ANG(dsf_grid[i][j].crad)*(2.*MAXRSCA*GRIDRES/M_PI);
177 for (ii = i-r; ii <= i+r; ii++) {
178 if (ii < 0) continue;
179 if (ii >= GRIDRES) break;
180 for (jj = j-r; jj <= j+r; jj++) {
181 if (jj < 0) continue;
182 if (jj >= GRIDRES) break;
183 if ((ii-i)*(ii-i) + (jj-j)*(jj-j) > r*r)
184 continue;
185 fill_grid[ii][jj] += dsf_grid[i][j].crad;
186 fill_cnt[ii][jj]++;
187 }
188 }
189 }
190 /* copy back blurred radii */
191 for (i = 0; i < GRIDRES; i++)
192 for (j = 0; j < GRIDRES; j++)
193 if (fill_cnt[i][j])
194 dsf_grid[i][j].crad = fill_grid[i][j]/fill_cnt[i][j];
195 }
196
197 /* Cull points for more uniform distribution, leave all nval 0 or 1 */
198 static void
199 cull_values(void)
200 {
201 FVECT ovec0, ovec1;
202 double maxang, maxang2;
203 int i, j, ii, jj, r;
204 /* simple greedy algorithm */
205 for (i = 0; i < GRIDRES; i++)
206 for (j = 0; j < GRIDRES; j++) {
207 if (!dsf_grid[i][j].nval)
208 continue;
209 if (!dsf_grid[i][j].crad)
210 continue; /* shouldn't happen */
211 ovec_from_pos(ovec0, i, j);
212 maxang = 2.*R2ANG(dsf_grid[i][j].crad);
213 /* clamp near horizon */
214 if (maxang > output_orient*ovec0[2])
215 maxang = output_orient*ovec0[2];
216 r = maxang*(2.*GRIDRES/M_PI) + 1;
217 maxang2 = maxang*maxang;
218 for (ii = i-r; ii <= i+r; ii++) {
219 if (ii < 0) continue;
220 if (ii >= GRIDRES) break;
221 for (jj = j-r; jj <= j+r; jj++) {
222 if ((ii == i) & (jj == j))
223 continue; /* don't get self-absorbed */
224 if (jj < 0) continue;
225 if (jj >= GRIDRES) break;
226 if (!dsf_grid[ii][jj].nval)
227 continue;
228 ovec_from_pos(ovec1, ii, jj);
229 if (2. - 2.*DOT(ovec0,ovec1) >= maxang2)
230 continue;
231 /* absorb sum */
232 dsf_grid[i][j].vsum += dsf_grid[ii][jj].vsum;
233 dsf_grid[i][j].nval += dsf_grid[ii][jj].nval;
234 /* keep value, though */
235 dsf_grid[ii][jj].vsum /= (float)dsf_grid[ii][jj].nval;
236 dsf_grid[ii][jj].nval = 0;
237 }
238 }
239 }
240 /* final averaging pass */
241 for (i = 0; i < GRIDRES; i++)
242 for (j = 0; j < GRIDRES; j++)
243 if (dsf_grid[i][j].nval > 1) {
244 dsf_grid[i][j].vsum /= (float)dsf_grid[i][j].nval;
245 dsf_grid[i][j].nval = 1;
246 }
247 }
248
249 /* Compute minimum BSDF from histogram and clear it */
250 static void
251 comp_bsdf_min()
252 {
253 int cnt;
254 int i, target;
255
256 cnt = 0;
257 for (i = HISTLEN; i--; )
258 cnt += bsdf_hist[i];
259 if (!cnt) { /* shouldn't happen */
260 bsdf_min = 0;
261 return;
262 }
263 target = cnt/100; /* ignore bottom 1% */
264 cnt = 0;
265 for (i = 0; cnt <= target; i++)
266 cnt += bsdf_hist[i];
267 bsdf_min = histval(i-1);
268 memset(bsdf_hist, 0, sizeof(bsdf_hist));
269 }
270
271 /* Find n nearest sub-sampled neighbors to the given grid position */
272 static int
273 get_neighbors(int neigh[][2], int n, const int i, const int j)
274 {
275 int k = 0;
276 int r;
277 /* search concentric squares */
278 for (r = 1; r < GRIDRES; r++) {
279 int ii, jj;
280 for (ii = i-r; ii <= i+r; ii++) {
281 int jstep = 1;
282 if (ii < 0) continue;
283 if (ii >= GRIDRES) break;
284 if ((i-r < ii) & (ii < i+r))
285 jstep = r<<1;
286 for (jj = j-r; jj <= j+r; jj += jstep) {
287 if (jj < 0) continue;
288 if (jj >= GRIDRES) break;
289 if (dsf_grid[ii][jj].nval) {
290 neigh[k][0] = ii;
291 neigh[k][1] = jj;
292 if (++k >= n)
293 return(n);
294 }
295 }
296 }
297 }
298 return(k);
299 }
300
301 /* Adjust coded radius for the given grid position based on neighborhood */
302 static int
303 adj_coded_radius(const int i, const int j)
304 {
305 const double rad0 = R2ANG(dsf_grid[i][j].crad);
306 const double minrad = MINRSCA * rad0;
307 double currad = MAXRSCA * rad0;
308 int neigh[NNEIGH][2];
309 int n;
310 FVECT our_dir;
311
312 ovec_from_pos(our_dir, i, j);
313 n = get_neighbors(neigh, NNEIGH, i, j);
314 while (n--) {
315 FVECT their_dir;
316 double max_ratio, rad_ok2;
317 /* check our value at neighbor */
318 ovec_from_pos(their_dir, neigh[n][0], neigh[n][1]);
319 max_ratio = MAXFRAC * dsf_grid[neigh[n][0]][neigh[n][1]].vsum
320 / dsf_grid[i][j].vsum;
321 if (max_ratio >= 1)
322 continue;
323 rad_ok2 = (DOT(their_dir,our_dir) - 1.)/log(max_ratio);
324 if (rad_ok2 >= currad*currad)
325 continue; /* value fraction OK */
326 currad = sqrt(rad_ok2); /* else reduce lobe radius */
327 if (currad <= minrad) /* limit how small we'll go */
328 return(ANG2R(minrad));
329 }
330 return(ANG2R(currad)); /* encode selected radius */
331 }
332
333 /* Count up filled nodes and build RBF representation from current grid */
334 RBFNODE *
335 make_rbfrep(void)
336 {
337 long cradsum = 0, ocradsum = 0;
338 int niter = 16;
339 double lastVar, thisVar = 100.;
340 int nn;
341 RBFNODE *newnode;
342 RBFVAL *itera;
343 int i, j;
344
345 #ifdef DEBUG
346 {
347 int maxcnt = 0, nempty = 0;
348 long cntsum = 0;
349 for (i = 0; i < GRIDRES; i++)
350 for (j = 0; j < GRIDRES; j++)
351 if (!dsf_grid[i][j].nval) {
352 ++nempty;
353 } else {
354 if (dsf_grid[i][j].nval > maxcnt)
355 maxcnt = dsf_grid[i][j].nval;
356 cntsum += dsf_grid[i][j].nval;
357 }
358 fprintf(stderr, "Average, maximum bin count: %d, %d (%.1f%% empty)\n",
359 (int)(cntsum/((GRIDRES*GRIDRES)-nempty)), maxcnt,
360 100./(GRIDRES*GRIDRES)*nempty);
361 }
362 #endif
363 /* compute RBF radii */
364 compute_radii();
365 /* coagulate lobes */
366 cull_values();
367 nn = 0; /* count selected bins */
368 for (i = 0; i < GRIDRES; i++)
369 for (j = 0; j < GRIDRES; j++)
370 nn += dsf_grid[i][j].nval;
371 /* compute minimum BSDF */
372 comp_bsdf_min();
373 /* allocate RBF array */
374 newnode = (RBFNODE *)malloc(sizeof(RBFNODE) + sizeof(RBFVAL)*(nn-1));
375 if (newnode == NULL)
376 goto memerr;
377 newnode->ord = -1;
378 newnode->next = NULL;
379 newnode->ejl = NULL;
380 newnode->invec[2] = sin((M_PI/180.)*theta_in_deg);
381 newnode->invec[0] = cos((M_PI/180.)*phi_in_deg)*newnode->invec[2];
382 newnode->invec[1] = sin((M_PI/180.)*phi_in_deg)*newnode->invec[2];
383 newnode->invec[2] = input_orient*sqrt(1. - newnode->invec[2]*newnode->invec[2]);
384 newnode->vtotal = 0;
385 newnode->nrbf = nn;
386 nn = 0; /* fill RBF array */
387 for (i = 0; i < GRIDRES; i++)
388 for (j = 0; j < GRIDRES; j++)
389 if (dsf_grid[i][j].nval) {
390 newnode->rbfa[nn].peak = dsf_grid[i][j].vsum;
391 ocradsum += dsf_grid[i][j].crad;
392 cradsum +=
393 newnode->rbfa[nn].crad = adj_coded_radius(i, j);
394 newnode->rbfa[nn].gx = i;
395 newnode->rbfa[nn].gy = j;
396 ++nn;
397 }
398 #ifdef DEBUG
399 fprintf(stderr,
400 "Average radius reduced from %.2f to %.2f degrees for %d lobes\n",
401 180./M_PI*MAXRSCA*R2ANG(ocradsum/newnode->nrbf),
402 180./M_PI*R2ANG(cradsum/newnode->nrbf), newnode->nrbf);
403 #endif
404 /* iterate to improve interpolation accuracy */
405 itera = (RBFVAL *)malloc(sizeof(RBFVAL)*newnode->nrbf);
406 if (itera == NULL)
407 goto memerr;
408 memcpy(itera, newnode->rbfa, sizeof(RBFVAL)*newnode->nrbf);
409 do {
410 double dsum = 0, dsum2 = 0;
411 nn = 0;
412 for (i = 0; i < GRIDRES; i++)
413 for (j = 0; j < GRIDRES; j++)
414 if (dsf_grid[i][j].nval) {
415 FVECT odir;
416 double corr;
417 ovec_from_pos(odir, i, j);
418 itera[nn++].peak *= corr =
419 dsf_grid[i][j].vsum /
420 eval_rbfrep(newnode, odir);
421 dsum += 1. - corr;
422 dsum2 += (1.-corr)*(1.-corr);
423 }
424 memcpy(newnode->rbfa, itera, sizeof(RBFVAL)*newnode->nrbf);
425 lastVar = thisVar;
426 thisVar = dsum2/(double)nn;
427 #ifdef DEBUG
428 fprintf(stderr, "Avg., RMS error: %.1f%% %.1f%%\n",
429 100.*dsum/(double)nn,
430 100.*sqrt(thisVar));
431 #endif
432 } while (--niter > 0 && lastVar-thisVar > 0.02*lastVar);
433
434 free(itera);
435 nn = 0; /* compute sum for normalization */
436 while (nn < newnode->nrbf)
437 newnode->vtotal += rbf_volume(&newnode->rbfa[nn++]);
438 #ifdef DEBUG
439 fprintf(stderr, "Integrated DSF at (%.1f,%.1f) deg. is %.2f\n",
440 get_theta180(newnode->invec), get_phi360(newnode->invec),
441 newnode->vtotal);
442 #endif
443 insert_dsf(newnode);
444
445 return(newnode);
446 memerr:
447 fprintf(stderr, "%s: Out of memory in make_rbfrep()\n", progname);
448 exit(1);
449 }
