1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* Radial basis function representation for BSDF data. |
6 |
7 |
* G. Ward |
8 |
9 |
10 |
#define _USE_MATH_DEFINES |
11 |
#include <stdio.h> |
12 |
#include <stdlib.h> |
13 |
#include <string.h> |
14 |
#include <math.h> |
15 |
#include "bsdfrep.h" |
16 |
17 |
#ifndef RSCA |
18 |
#define RSCA 2.7 /* radius scaling factor (empirical) */ |
19 |
#endif |
20 |
/* our loaded grid for this incident angle */ |
21 |
GRIDVAL dsf_grid[GRIDRES][GRIDRES]; |
22 |
23 |
/* Start new DSF input grid */ |
24 |
void |
25 |
new_bsdf_data(double new_theta, double new_phi) |
26 |
27 |
if (!new_input_direction(new_theta, new_phi)) |
28 |
exit(1); |
29 |
memset(dsf_grid, 0, sizeof(dsf_grid)); |
30 |
31 |
32 |
/* Add BSDF data point */ |
33 |
void |
34 |
add_bsdf_data(double theta_out, double phi_out, double val, int isDSF) |
35 |
36 |
FVECT ovec; |
37 |
int pos[2]; |
38 |
39 |
if (!output_orient) /* check output orientation */ |
40 |
output_orient = 1 - 2*(theta_out > 90.); |
41 |
else if (output_orient > 0 ^ theta_out < 90.) { |
42 |
fputs("Cannot handle output angles on both sides of surface\n", |
43 |
stderr); |
44 |
exit(1); |
45 |
46 |
ovec[2] = sin((M_PI/180.)*theta_out); |
47 |
ovec[0] = cos((M_PI/180.)*phi_out) * ovec[2]; |
48 |
ovec[1] = sin((M_PI/180.)*phi_out) * ovec[2]; |
49 |
ovec[2] = sqrt(1. - ovec[2]*ovec[2]); |
50 |
51 |
if (!isDSF) |
52 |
val *= ovec[2]; /* convert from BSDF to DSF */ |
53 |
54 |
pos_from_vec(pos, ovec); |
55 |
56 |
dsf_grid[pos[0]][pos[1]].vsum += val; |
57 |
dsf_grid[pos[0]][pos[1]].nval++; |
58 |
59 |
60 |
/* Compute radii for non-empty bins */ |
61 |
/* (distance to furthest empty bin for which non-empty bin is the closest) */ |
62 |
static void |
63 |
compute_radii(void) |
64 |
65 |
unsigned int fill_grid[GRIDRES][GRIDRES]; |
66 |
unsigned short fill_cnt[GRIDRES][GRIDRES]; |
67 |
FVECT ovec0, ovec1; |
68 |
double ang2, lastang2; |
69 |
int r, i, j, jn, ii, jj, inear, jnear; |
70 |
71 |
r = GRIDRES/2; /* proceed in zig-zag */ |
72 |
for (i = 0; i < GRIDRES; i++) |
73 |
for (jn = 0; jn < GRIDRES; jn++) { |
74 |
j = (i&1) ? jn : GRIDRES-1-jn; |
75 |
if (dsf_grid[i][j].nval) /* find empty grid pos. */ |
76 |
continue; |
77 |
ovec_from_pos(ovec0, i, j); |
78 |
inear = jnear = -1; /* find nearest non-empty */ |
79 |
lastang2 = M_PI*M_PI; |
80 |
for (ii = i-r; ii <= i+r; ii++) { |
81 |
if (ii < 0) continue; |
82 |
if (ii >= GRIDRES) break; |
83 |
for (jj = j-r; jj <= j+r; jj++) { |
84 |
if (jj < 0) continue; |
85 |
if (jj >= GRIDRES) break; |
86 |
if (!dsf_grid[ii][jj].nval) |
87 |
continue; |
88 |
ovec_from_pos(ovec1, ii, jj); |
89 |
ang2 = 2. - 2.*DOT(ovec0,ovec1); |
90 |
if (ang2 >= lastang2) |
91 |
continue; |
92 |
lastang2 = ang2; |
93 |
inear = ii; jnear = jj; |
94 |
95 |
96 |
if (inear < 0) { |
97 |
fprintf(stderr, |
98 |
"%s: Could not find non-empty neighbor!\n", |
99 |
progname); |
100 |
exit(1); |
101 |
102 |
ang2 = sqrt(lastang2); |
103 |
r = ANG2R(ang2); /* record if > previous */ |
104 |
if (r > dsf_grid[inear][jnear].crad) |
105 |
dsf_grid[inear][jnear].crad = r; |
106 |
/* next search radius */ |
107 |
r = ang2*(2.*GRIDRES/M_PI) + 3; |
108 |
109 |
/* blur radii over hemisphere */ |
110 |
memset(fill_grid, 0, sizeof(fill_grid)); |
111 |
memset(fill_cnt, 0, sizeof(fill_cnt)); |
112 |
113 |
for (j = 0; j < GRIDRES; j++) { |
114 |
if (!dsf_grid[i][j].crad) |
115 |
continue; /* missing distance */ |
116 |
r = R2ANG(dsf_grid[i][j].crad)*(2.*RSCA*GRIDRES/M_PI); |
117 |
118 |
119 |
120 |
121 |
122 |
123 |
if ((ii-i)*(ii-i) + (jj-j)*(jj-j) > r*r) |
124 |
continue; |
125 |
fill_grid[ii][jj] += dsf_grid[i][j].crad; |
126 |
fill_cnt[ii][jj]++; |
127 |
128 |
129 |
130 |
/* copy back blurred radii */ |
131 |
132 |
for (j = 0; j < GRIDRES; j++) |
133 |
if (fill_cnt[i][j]) |
134 |
dsf_grid[i][j].crad = fill_grid[i][j]/fill_cnt[i][j]; |
135 |
136 |
137 |
/* Cull points for more uniform distribution, leave all nval 0 or 1 */ |
138 |
static void |
139 |
cull_values(void) |
140 |
141 |
142 |
double maxang, maxang2; |
143 |
int i, j, ii, jj, r; |
144 |
/* simple greedy algorithm */ |
145 |
146 |
147 |
if (!dsf_grid[i][j].nval) |
148 |
continue; |
149 |
150 |
continue; /* shouldn't happen */ |
151 |
152 |
maxang = 2.*R2ANG(dsf_grid[i][j].crad); |
153 |
if (maxang > ovec0[2]) /* clamp near horizon */ |
154 |
maxang = ovec0[2]; |
155 |
r = maxang*(2.*GRIDRES/M_PI) + 1; |
156 |
maxang2 = maxang*maxang; |
157 |
158 |
159 |
160 |
161 |
162 |
163 |
164 |
continue; |
165 |
if ((ii == i) & (jj == j)) |
166 |
continue; /* don't get self-absorbed */ |
167 |
168 |
if (2. - 2.*DOT(ovec0,ovec1) >= maxang2) |
169 |
continue; |
170 |
/* absorb sum */ |
171 |
dsf_grid[i][j].vsum += dsf_grid[ii][jj].vsum; |
172 |
dsf_grid[i][j].nval += dsf_grid[ii][jj].nval; |
173 |
/* keep value, though */ |
174 |
dsf_grid[ii][jj].vsum /= (float)dsf_grid[ii][jj].nval; |
175 |
dsf_grid[ii][jj].nval = 0; |
176 |
177 |
178 |
179 |
/* final averaging pass */ |
180 |
181 |
182 |
if (dsf_grid[i][j].nval > 1) { |
183 |
dsf_grid[i][j].vsum /= (float)dsf_grid[i][j].nval; |
184 |
dsf_grid[i][j].nval = 1; |
185 |
186 |
187 |
188 |
/* Count up filled nodes and build RBF representation from current grid */ |
189 |
RBFNODE * |
190 |
make_rbfrep(void) |
191 |
192 |
int niter = 16; |
193 |
double lastVar, thisVar = 100.; |
194 |
int nn; |
195 |
RBFNODE *newnode; |
196 |
int i, j; |
197 |
/* compute RBF radii */ |
198 |
compute_radii(); |
199 |
/* coagulate lobes */ |
200 |
cull_values(); |
201 |
nn = 0; /* count selected bins */ |
202 |
203 |
204 |
nn += dsf_grid[i][j].nval; |
205 |
/* allocate RBF array */ |
206 |
newnode = (RBFNODE *)malloc(sizeof(RBFNODE) + sizeof(RBFVAL)*(nn-1)); |
207 |
if (newnode == NULL) { |
208 |
fprintf(stderr, "%s: Out of memory in make_rbfrep()\n", progname); |
209 |
exit(1); |
210 |
211 |
newnode->ord = -1; |
212 |
newnode->next = NULL; |
213 |
newnode->ejl = NULL; |
214 |
newnode->invec[2] = sin((M_PI/180.)*theta_in_deg); |
215 |
newnode->invec[0] = cos((M_PI/180.)*phi_in_deg)*newnode->invec[2]; |
216 |
newnode->invec[1] = sin((M_PI/180.)*phi_in_deg)*newnode->invec[2]; |
217 |
newnode->invec[2] = input_orient*sqrt(1. - newnode->invec[2]*newnode->invec[2]); |
218 |
newnode->vtotal = 0; |
219 |
newnode->nrbf = nn; |
220 |
nn = 0; /* fill RBF array */ |
221 |
222 |
223 |
if (dsf_grid[i][j].nval) { |
224 |
newnode->rbfa[nn].peak = dsf_grid[i][j].vsum; |
225 |
newnode->rbfa[nn].crad = RSCA*dsf_grid[i][j].crad + .5; |
226 |
newnode->rbfa[nn].gx = i; |
227 |
newnode->rbfa[nn].gy = j; |
228 |
++nn; |
229 |
230 |
/* iterate to improve interpolation accuracy */ |
231 |
do { |
232 |
double dsum = 0, dsum2 = 0; |
233 |
nn = 0; |
234 |
235 |
236 |
237 |
FVECT odir; |
238 |
double corr; |
239 |
ovec_from_pos(odir, i, j); |
240 |
newnode->rbfa[nn++].peak *= corr = |
241 |
dsf_grid[i][j].vsum / |
242 |
eval_rbfrep(newnode, odir); |
243 |
dsum += corr - 1.; |
244 |
dsum2 += (corr-1.)*(corr-1.); |
245 |
246 |
lastVar = thisVar; |
247 |
thisVar = dsum2/(double)nn; |
248 |
#ifdef DEBUG |
249 |
fprintf(stderr, "Avg., RMS error: %.1f%% %.1f%%\n", |
250 |
100.*dsum/(double)nn, |
251 |
100.*sqrt(thisVar)); |
252 |
#endif |
253 |
} while (--niter > 0 && lastVar-thisVar > 0.02*lastVar); |
254 |
255 |
nn = 0; /* compute sum for normalization */ |
256 |
while (nn < newnode->nrbf) |
257 |
newnode->vtotal += rbf_volume(&newnode->rbfa[nn++]); |
258 |
259 |
insert_dsf(newnode); |
260 |
261 |
return(newnode); |
262 |
