--- ray/src/cv/bsdfrbf.c 2014/03/15 19:47:16 2.21 +++ ray/src/cv/bsdfrbf.c 2019/04/09 22:39:33 2.32 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdfrbf.c,v 2.21 2014/03/15 19:47:16 greg Exp $"; +static const char RCSid[] = "$Id: bsdfrbf.c,v 2.32 2019/04/09 22:39:33 greg Exp $"; #endif /* * Radial basis function representation for BSDF data. @@ -29,21 +29,68 @@ static const char RCSid[] = "$Id: bsdfrbf.c,v 2.21 201 #include "bsdfrep.h" #ifndef RSCA -#define RSCA 2.2 /* radius scaling factor (empirical) */ +#define RSCA 2.0 /* radius scaling factor (empirical) */ #endif +#ifndef MAXSLOPE +#define MAXSLOPE 200.0 /* maximum slope for smooth region */ +#endif #ifndef SMOOTH_MSE #define SMOOTH_MSE 5e-5 /* acceptable mean squared error */ #endif #ifndef SMOOTH_MSER -#define SMOOTH_MSER 0.03 /* acceptable relative MSE */ +#define SMOOTH_MSER 0.0025 /* acceptable relative MSE */ #endif #define MAX_RAD (GRIDRES/8) /* maximum lobe radius */ #define RBFALLOCB 10 /* RBF allocation block size */ - /* our loaded grid or comparison DSFs */ + /* loaded grid or comparison DSFs */ GRIDVAL dsf_grid[GRIDRES][GRIDRES]; + /* allocated chrominance sums if any */ +float (*spec_grid)[GRIDRES][GRIDRES]; +int nspec_grid = 0; +/* Set up visible spectrum sampling */ +void +set_spectral_samples(int nspec) +{ + if (rbf_colorimetry == RBCunknown) { + if (nspec_grid > 0) { + free(spec_grid); + spec_grid = NULL; + nspec_grid = 0; + } + if (nspec == 1) { + rbf_colorimetry = RBCphotopic; + return; + } + if (nspec == 3) { + rbf_colorimetry = RBCtristimulus; + spec_grid = (float (*)[GRIDRES][GRIDRES])calloc( + 2*GRIDRES*GRIDRES, sizeof(float) ); + if (spec_grid == NULL) + goto mem_error; + nspec_grid = 2; + return; + } + fprintf(stderr, + "%s: only 1 or 3 spectral samples currently supported\n", + progname); + exit(1); + } + if (nspec != nspec_grid+1) { + fprintf(stderr, + "%s: number of spectral samples cannot be changed\n", + progname); + exit(1); + } + return; +mem_error: + fprintf(stderr, "%s: out of memory in set_spectral_samples()\n", + progname); + exit(1); +} + /* Start new DSF input grid */ void new_bsdf_data(double new_theta, double new_phi) @@ -51,38 +98,51 @@ new_bsdf_data(double new_theta, double new_phi) if (!new_input_direction(new_theta, new_phi)) exit(1); memset(dsf_grid, 0, sizeof(dsf_grid)); + if (nspec_grid > 0) + memset(spec_grid, 0, sizeof(float)*GRIDRES*GRIDRES*nspec_grid); } /* Add BSDF data point */ void -add_bsdf_data(double theta_out, double phi_out, double val, int isDSF) +add_bsdf_data(double theta_out, double phi_out, const double val[], int isDSF) { FVECT ovec; + double cfact, Yval; int pos[2]; + if (nspec_grid > 2) { + fprintf(stderr, "%s: unsupported color space\n", progname); + exit(1); + } if (!output_orient) /* check output orientation */ output_orient = 1 - 2*(theta_out > 90.); else if (output_orient > 0 ^ theta_out < 90.) { - fputs("Cannot handle output angles on both sides of surface\n", - stderr); + fprintf(stderr, + "%s: cannot handle output angles on both sides of surface\n", + progname); exit(1); } ovec[2] = sin((M_PI/180.)*theta_out); ovec[0] = cos((M_PI/180.)*phi_out) * ovec[2]; ovec[1] = sin((M_PI/180.)*phi_out) * ovec[2]; ovec[2] = sqrt(1. - ovec[2]*ovec[2]); + /* BSDF to DSF correction */ + cfact = isDSF ? 1. : ovec[2]; - if (!isDSF) - val *= ovec[2]; /* convert from BSDF to DSF */ - + Yval = cfact * val[rbf_colorimetry==RBCtristimulus]; /* update BSDF histogram */ - if (val < BSDF2BIG*ovec[2] && val > BSDF2SML*ovec[2]) - ++bsdf_hist[histndx(val/ovec[2])]; + if (BSDF2SML*ovec[2] < Yval && Yval < BSDF2BIG*ovec[2]) + ++bsdf_hist[histndx(Yval/ovec[2])]; pos_from_vec(pos, ovec); - dsf_grid[pos[0]][pos[1]].sum.v += val; + dsf_grid[pos[0]][pos[1]].sum.v += Yval; dsf_grid[pos[0]][pos[1]].sum.n++; + /* add in X and Z values */ + if (rbf_colorimetry == RBCtristimulus) { + spec_grid[0][pos[0]][pos[1]] += cfact * val[0]; + spec_grid[1][pos[0]][pos[1]] += cfact * val[2]; + } } /* Compute minimum BSDF from histogram (does not clear) */ @@ -152,6 +212,8 @@ smooth_region(int x0, int x1, int y0, int y1) return(1); /* colinear values */ A = DOT(rMtx[0], xvec); B = DOT(rMtx[1], xvec); + if (A*A + B*B > MAXSLOPE*MAXSLOPE) /* too steep? */ + return(0); C = DOT(rMtx[2], xvec); sqerr = 0.0; /* compute mean squared error */ for (x = x0; x < x1; x++) @@ -171,15 +233,31 @@ static int create_lobe(RBFVAL *rvp, int x0, int x1, int y0, int y1) { double vtot = 0.0; + double CIEXtot = 0.0, CIEZtot = 0.0; int nv = 0; + double wxsum = 0.0, wysum = 0.0, wtsum = 0.0; double rad; int x, y; /* compute average for region */ for (x = x0; x < x1; x++) - for (y = y0; y < y1; y++) { - vtot += dsf_grid[x][y].sum.v; - nv += dsf_grid[x][y].sum.n; - } + for (y = y0; y < y1; y++) + if (dsf_grid[x][y].sum.n) { + const double v = dsf_grid[x][y].sum.v; + const int n = dsf_grid[x][y].sum.n; + + if (v > 0) { + const double wt = v / (double)n; + wxsum += wt * x; + wysum += wt * y; + wtsum += wt; + } + vtot += v; + nv += n; + if (rbf_colorimetry == RBCtristimulus) { + CIEXtot += spec_grid[0][x][y]; + CIEZtot += spec_grid[1][x][y]; + } + } if (!nv) { fprintf(stderr, "%s: internal - missing samples in create_lobe\n", progname); @@ -187,13 +265,21 @@ create_lobe(RBFVAL *rvp, int x0, int x1, int y0, int y } if (vtot <= 0) /* only create positive lobes */ return(0); + /* assign color */ + if (rbf_colorimetry == RBCtristimulus) { + const double df = 1.0 / (CIEXtot + vtot + CIEZtot); + C_COLOR cclr; + c_cset(&cclr, CIEXtot*df, vtot*df); + rvp->chroma = c_encodeChroma(&cclr); + } else + rvp->chroma = c_dfchroma; /* peak value based on integral */ vtot *= (x1-x0)*(y1-y0)*(2.*M_PI/GRIDRES/GRIDRES)/(double)nv; rad = (RSCA/(double)GRIDRES)*(x1-x0); rvp->peak = vtot / ((2.*M_PI) * rad*rad); - rvp->crad = ANG2R(rad); - rvp->gx = (x0+x1)>>1; - rvp->gy = (y0+y1)>>1; + rvp->crad = ANG2R(rad); /* put peak at centroid */ + rvp->gx = (int)(wxsum/wtsum + .5); + rvp->gy = (int)(wysum/wtsum + .5); return(1); } @@ -262,8 +348,14 @@ make_rbfrep() comp_bsdf_min(); /* create RBF node list */ rbfarr = NULL; nn = 0; - if (build_rbfrep(&rbfarr, &nn, 0, GRIDRES, 0, GRIDRES) <= 0) - goto memerr; + if (build_rbfrep(&rbfarr, &nn, 0, GRIDRES, 0, GRIDRES) <= 0) { + if (nn) + goto memerr; + fprintf(stderr, + "%s: warning - skipping bad incidence (%.1f,%.1f)\n", + progname, theta_in_deg, phi_in_deg); + return(NULL); + } /* (re)allocate RBF array */ newnode = (RBFNODE *)realloc(rbfarr, sizeof(RBFNODE) + sizeof(RBFVAL)*(nn-1)); @@ -290,7 +382,6 @@ make_rbfrep() newnode->vtotal); #endif insert_dsf(newnode); - return(newnode); memerr: fprintf(stderr, "%s: Out of memory in make_rbfrep()\n", progname);
