root/radiance/ray/src/cv/bsdfrbf.c
Revision: 2.34
Committed: Wed Jun 29 15:52:07 2022 UTC (3 years, 1 month ago) by greg
CVS Tags: rad5R4, rad6R0, HEAD
Changes since 2.33: +3 -2 lines
fix: Added missing check in make_rbfrep() for failure to add RBF
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.34 static const char RCSid[] = "$Id: bsdfrbf.c,v 2.33 2019/05/08 16:38:19 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Radial basis function representation for BSDF data.
6     *
7     * G. Ward
8     */
9
10 greg 2.13 /****************************************************************
11     1) Collect samples into a grid using the Shirley-Chiu
12     angular mapping from a hemisphere to a square.
13
14     2) Compute an adaptive quadtree by subdividing the grid so that
15     each leaf node has at least one sample up to as many
16     samples as fit nicely on a plane to within a certain
17     MSE tolerance.
18
19     3) Place one Gaussian lobe at each leaf node in the quadtree,
20     sizing it to have a radius equal to the leaf size and
21     a volume equal to the energy in that node.
22     *****************************************************************/
23
24 greg 2.1 #define _USE_MATH_DEFINES
25     #include <stdio.h>
26     #include <stdlib.h>
27     #include <string.h>
28     #include <math.h>
29     #include "bsdfrep.h"
30
31 greg 2.12 #ifndef RSCA
32 greg 2.25 #define RSCA 2.0 /* radius scaling factor (empirical) */
33 greg 2.9 #endif
34 greg 2.29 #ifndef MAXSLOPE
35 greg 2.30 #define MAXSLOPE 200.0 /* maximum slope for smooth region */
36 greg 2.29 #endif
37 greg 2.12 #ifndef SMOOTH_MSE
38 greg 2.19 #define SMOOTH_MSE 5e-5 /* acceptable mean squared error */
39 greg 2.1 #endif
40 greg 2.12 #ifndef SMOOTH_MSER
41 greg 2.33 #define SMOOTH_MSER 0.0016 /* acceptable relative MSE */
42 greg 2.7 #endif
43 greg 2.12 #define MAX_RAD (GRIDRES/8) /* maximum lobe radius */
44
45     #define RBFALLOCB 10 /* RBF allocation block size */
46
47 greg 2.25 /* loaded grid or comparison DSFs */
48 greg 2.1 GRIDVAL dsf_grid[GRIDRES][GRIDRES];
49 greg 2.27 /* allocated chrominance sums if any */
50     float (*spec_grid)[GRIDRES][GRIDRES];
51     int nspec_grid = 0;
52
53     /* Set up visible spectrum sampling */
54     void
55     set_spectral_samples(int nspec)
56     {
57     if (rbf_colorimetry == RBCunknown) {
58     if (nspec_grid > 0) {
59     free(spec_grid);
60     spec_grid = NULL;
61     nspec_grid = 0;
62     }
63     if (nspec == 1) {
64     rbf_colorimetry = RBCphotopic;
65     return;
66     }
67     if (nspec == 3) {
68     rbf_colorimetry = RBCtristimulus;
69     spec_grid = (float (*)[GRIDRES][GRIDRES])calloc(
70     2*GRIDRES*GRIDRES, sizeof(float) );
71     if (spec_grid == NULL)
72     goto mem_error;
73     nspec_grid = 2;
74     return;
75     }
76     fprintf(stderr,
77     "%s: only 1 or 3 spectral samples currently supported\n",
78     progname);
79     exit(1);
80     }
81     if (nspec != nspec_grid+1) {
82     fprintf(stderr,
83     "%s: number of spectral samples cannot be changed\n",
84     progname);
85     exit(1);
86     }
87     return;
88     mem_error:
89     fprintf(stderr, "%s: out of memory in set_spectral_samples()\n",
90     progname);
91     exit(1);
92     }
93 greg 2.1
94     /* Start new DSF input grid */
95     void
96     new_bsdf_data(double new_theta, double new_phi)
97     {
98     if (!new_input_direction(new_theta, new_phi))
99     exit(1);
100     memset(dsf_grid, 0, sizeof(dsf_grid));
101 greg 2.27 if (nspec_grid > 0)
102     memset(spec_grid, 0, sizeof(float)*GRIDRES*GRIDRES*nspec_grid);
103 greg 2.1 }
104
105     /* Add BSDF data point */
106     void
107 greg 2.27 add_bsdf_data(double theta_out, double phi_out, const double val[], int isDSF)
108 greg 2.1 {
109     FVECT ovec;
110 greg 2.27 double cfact, Yval;
111 greg 2.1 int pos[2];
112
113 greg 2.27 if (nspec_grid > 2) {
114     fprintf(stderr, "%s: unsupported color space\n", progname);
115     exit(1);
116     }
117 greg 2.1 if (!output_orient) /* check output orientation */
118     output_orient = 1 - 2*(theta_out > 90.);
119     else if (output_orient > 0 ^ theta_out < 90.) {
120 greg 2.27 fprintf(stderr,
121     "%s: cannot handle output angles on both sides of surface\n",
122     progname);
123 greg 2.1 exit(1);
124     }
125     ovec[2] = sin((M_PI/180.)*theta_out);
126     ovec[0] = cos((M_PI/180.)*phi_out) * ovec[2];
127     ovec[1] = sin((M_PI/180.)*phi_out) * ovec[2];
128     ovec[2] = sqrt(1. - ovec[2]*ovec[2]);
129 greg 2.27 /* BSDF to DSF correction */
130     cfact = isDSF ? 1. : ovec[2];
131 greg 2.1
132 greg 2.27 Yval = cfact * val[rbf_colorimetry==RBCtristimulus];
133 greg 2.4 /* update BSDF histogram */
134 greg 2.27 if (BSDF2SML*ovec[2] < Yval && Yval < BSDF2BIG*ovec[2])
135     ++bsdf_hist[histndx(Yval/ovec[2])];
136 greg 2.4
137 greg 2.1 pos_from_vec(pos, ovec);
138
139 greg 2.27 dsf_grid[pos[0]][pos[1]].sum.v += Yval;
140 greg 2.20 dsf_grid[pos[0]][pos[1]].sum.n++;
141 greg 2.27 /* add in X and Z values */
142     if (rbf_colorimetry == RBCtristimulus) {
143 greg 2.28 spec_grid[0][pos[0]][pos[1]] += cfact * val[0];
144     spec_grid[1][pos[0]][pos[1]] += cfact * val[2];
145 greg 2.27 }
146 greg 2.1 }
147
148 greg 2.11 /* Compute minimum BSDF from histogram (does not clear) */
149 greg 2.5 static void
150     comp_bsdf_min()
151     {
152 greg 2.17 unsigned long cnt, target;
153     int i;
154 greg 2.5
155     cnt = 0;
156     for (i = HISTLEN; i--; )
157     cnt += bsdf_hist[i];
158     if (!cnt) { /* shouldn't happen */
159     bsdf_min = 0;
160     return;
161     }
162     target = cnt/100; /* ignore bottom 1% */
163     cnt = 0;
164     for (i = 0; cnt <= target; i++)
165     cnt += bsdf_hist[i];
166     bsdf_min = histval(i-1);
167     }
168
169 greg 2.12 /* Determine if the given region is empty of grid samples */
170 greg 2.6 static int
171 greg 2.12 empty_region(int x0, int x1, int y0, int y1)
172 greg 2.6 {
173 greg 2.12 int x, y;
174
175     for (x = x0; x < x1; x++)
176     for (y = y0; y < y1; y++)
177 greg 2.20 if (dsf_grid[x][y].sum.n)
178 greg 2.12 return(0);
179     return(1);
180     }
181
182     /* Determine if the given region is smooth enough to be a single lobe */
183     static int
184     smooth_region(int x0, int x1, int y0, int y1)
185     {
186     RREAL rMtx[3][3];
187     FVECT xvec;
188     double A, B, C, nvs, sqerr;
189     int x, y, n;
190     /* compute planar regression */
191     memset(rMtx, 0, sizeof(rMtx));
192     memset(xvec, 0, sizeof(xvec));
193     for (x = x0; x < x1; x++)
194     for (y = y0; y < y1; y++)
195 greg 2.20 if ((n = dsf_grid[x][y].sum.n) > 0) {
196     double z = dsf_grid[x][y].sum.v;
197 greg 2.13 rMtx[0][0] += x*x*(double)n;
198     rMtx[0][1] += x*y*(double)n;
199     rMtx[0][2] += x*(double)n;
200     rMtx[1][1] += y*y*(double)n;
201     rMtx[1][2] += y*(double)n;
202     rMtx[2][2] += (double)n;
203 greg 2.12 xvec[0] += x*z;
204     xvec[1] += y*z;
205     xvec[2] += z;
206     }
207     rMtx[1][0] = rMtx[0][1];
208 greg 2.15 rMtx[2][0] = rMtx[0][2];
209 greg 2.12 rMtx[2][1] = rMtx[1][2];
210     nvs = rMtx[2][2];
211     if (SDinvXform(rMtx, rMtx) != SDEnone)
212 greg 2.16 return(1); /* colinear values */
213 greg 2.12 A = DOT(rMtx[0], xvec);
214     B = DOT(rMtx[1], xvec);
215 greg 2.29 if (A*A + B*B > MAXSLOPE*MAXSLOPE) /* too steep? */
216     return(0);
217 greg 2.12 C = DOT(rMtx[2], xvec);
218     sqerr = 0.0; /* compute mean squared error */
219     for (x = x0; x < x1; x++)
220     for (y = y0; y < y1; y++)
221 greg 2.20 if ((n = dsf_grid[x][y].sum.n) > 0) {
222     double d = A*x + B*y + C - dsf_grid[x][y].sum.v/n;
223 greg 2.12 sqerr += n*d*d;
224 greg 2.6 }
225 greg 2.12 if (sqerr <= nvs*SMOOTH_MSE) /* below absolute MSE threshold? */
226     return(1);
227 greg 2.13 /* OR below relative MSE threshold? */
228 greg 2.12 return(sqerr*nvs <= xvec[2]*xvec[2]*SMOOTH_MSER);
229     }
230
231     /* Create new lobe based on integrated samples in region */
232 greg 2.21 static int
233 greg 2.12 create_lobe(RBFVAL *rvp, int x0, int x1, int y0, int y1)
234     {
235     double vtot = 0.0;
236 greg 2.27 double CIEXtot = 0.0, CIEZtot = 0.0;
237 greg 2.12 int nv = 0;
238 greg 2.25 double wxsum = 0.0, wysum = 0.0, wtsum = 0.0;
239 greg 2.12 double rad;
240     int x, y;
241     /* compute average for region */
242     for (x = x0; x < x1; x++)
243 greg 2.25 for (y = y0; y < y1; y++)
244     if (dsf_grid[x][y].sum.n) {
245     const double v = dsf_grid[x][y].sum.v;
246     const int n = dsf_grid[x][y].sum.n;
247
248     if (v > 0) {
249 greg 2.27 const double wt = v / (double)n;
250 greg 2.25 wxsum += wt * x;
251     wysum += wt * y;
252     wtsum += wt;
253     }
254     vtot += v;
255     nv += n;
256 greg 2.27 if (rbf_colorimetry == RBCtristimulus) {
257     CIEXtot += spec_grid[0][x][y];
258     CIEZtot += spec_grid[1][x][y];
259     }
260 greg 2.25 }
261 greg 2.12 if (!nv) {
262     fprintf(stderr, "%s: internal - missing samples in create_lobe\n",
263     progname);
264     exit(1);
265 greg 2.6 }
266 greg 2.21 if (vtot <= 0) /* only create positive lobes */
267     return(0);
268 greg 2.27 /* assign color */
269     if (rbf_colorimetry == RBCtristimulus) {
270     const double df = 1.0 / (CIEXtot + vtot + CIEZtot);
271     C_COLOR cclr;
272     c_cset(&cclr, CIEXtot*df, vtot*df);
273     rvp->chroma = c_encodeChroma(&cclr);
274     } else
275     rvp->chroma = c_dfchroma;
276 greg 2.12 /* peak value based on integral */
277     vtot *= (x1-x0)*(y1-y0)*(2.*M_PI/GRIDRES/GRIDRES)/(double)nv;
278     rad = (RSCA/(double)GRIDRES)*(x1-x0);
279     rvp->peak = vtot / ((2.*M_PI) * rad*rad);
280 greg 2.25 rvp->crad = ANG2R(rad); /* put peak at centroid */
281     rvp->gx = (int)(wxsum/wtsum + .5);
282     rvp->gy = (int)(wysum/wtsum + .5);
283 greg 2.21 return(1);
284 greg 2.6 }
285
286 greg 2.12 /* Recursive function to build radial basis function representation */
287 greg 2.6 static int
288 greg 2.12 build_rbfrep(RBFVAL **arp, int *np, int x0, int x1, int y0, int y1)
289 greg 2.6 {
290 greg 2.12 int xmid = (x0+x1)>>1;
291     int ymid = (y0+y1)>>1;
292     int branched[4];
293     int nadded, nleaves;
294     /* need to make this a leaf? */
295     if (empty_region(x0, xmid, y0, ymid) ||
296     empty_region(xmid, x1, y0, ymid) ||
297     empty_region(x0, xmid, ymid, y1) ||
298     empty_region(xmid, x1, ymid, y1))
299     return(0);
300     /* add children (branches+leaves) */
301     if ((branched[0] = build_rbfrep(arp, np, x0, xmid, y0, ymid)) < 0)
302     return(-1);
303     if ((branched[1] = build_rbfrep(arp, np, xmid, x1, y0, ymid)) < 0)
304     return(-1);
305     if ((branched[2] = build_rbfrep(arp, np, x0, xmid, ymid, y1)) < 0)
306     return(-1);
307     if ((branched[3] = build_rbfrep(arp, np, xmid, x1, ymid, y1)) < 0)
308     return(-1);
309     nadded = branched[0] + branched[1] + branched[2] + branched[3];
310     nleaves = !branched[0] + !branched[1] + !branched[2] + !branched[3];
311     if (!nleaves) /* nothing but branches? */
312     return(nadded);
313     /* combine 4 leaves into 1? */
314 greg 2.14 if ((nleaves == 4) & (x1-x0 <= MAX_RAD) &&
315     smooth_region(x0, x1, y0, y1))
316 greg 2.12 return(0);
317     /* need more array space? */
318     if ((*np+nleaves-1)>>RBFALLOCB != (*np-1)>>RBFALLOCB) {
319     *arp = (RBFVAL *)realloc(*arp,
320     sizeof(RBFVAL)*(*np+nleaves-1+(1<<RBFALLOCB)));
321     if (*arp == NULL)
322     return(-1);
323 greg 2.6 }
324 greg 2.12 /* create lobes for leaves */
325 greg 2.21 if (!branched[0] && create_lobe(*arp+*np, x0, xmid, y0, ymid)) {
326     ++(*np); ++nadded;
327     }
328     if (!branched[1] && create_lobe(*arp+*np, xmid, x1, y0, ymid)) {
329     ++(*np); ++nadded;
330     }
331     if (!branched[2] && create_lobe(*arp+*np, x0, xmid, ymid, y1)) {
332     ++(*np); ++nadded;
333     }
334     if (!branched[3] && create_lobe(*arp+*np, xmid, x1, ymid, y1)) {
335     ++(*np); ++nadded;
336     }
337 greg 2.12 return(nadded);
338 greg 2.6 }
339
340 greg 2.1 /* Count up filled nodes and build RBF representation from current grid */
341     RBFNODE *
342 greg 2.12 make_rbfrep()
343 greg 2.1 {
344 greg 2.12 RBFNODE *newnode;
345     RBFVAL *rbfarr;
346 greg 2.1 int nn;
347 greg 2.5 /* compute minimum BSDF */
348     comp_bsdf_min();
349 greg 2.12 /* create RBF node list */
350     rbfarr = NULL; nn = 0;
351 greg 2.22 if (build_rbfrep(&rbfarr, &nn, 0, GRIDRES, 0, GRIDRES) <= 0) {
352     if (nn)
353     goto memerr;
354 greg 2.24 fprintf(stderr,
355     "%s: warning - skipping bad incidence (%.1f,%.1f)\n",
356     progname, theta_in_deg, phi_in_deg);
357     return(NULL);
358 greg 2.22 }
359 greg 2.12 /* (re)allocate RBF array */
360     newnode = (RBFNODE *)realloc(rbfarr,
361     sizeof(RBFNODE) + sizeof(RBFVAL)*(nn-1));
362 greg 2.2 if (newnode == NULL)
363     goto memerr;
364 greg 2.12 /* copy computed lobes into RBF node */
365     memmove(newnode->rbfa, newnode, sizeof(RBFVAL)*nn);
366 greg 2.1 newnode->ord = -1;
367     newnode->next = NULL;
368     newnode->ejl = NULL;
369     newnode->invec[2] = sin((M_PI/180.)*theta_in_deg);
370     newnode->invec[0] = cos((M_PI/180.)*phi_in_deg)*newnode->invec[2];
371     newnode->invec[1] = sin((M_PI/180.)*phi_in_deg)*newnode->invec[2];
372     newnode->invec[2] = input_orient*sqrt(1. - newnode->invec[2]*newnode->invec[2]);
373 greg 2.12 newnode->vtotal = .0;
374 greg 2.1 newnode->nrbf = nn;
375 greg 2.12 /* compute sum for normalization */
376     while (nn-- > 0)
377     newnode->vtotal += rbf_volume(&newnode->rbfa[nn]);
378 greg 2.3 #ifdef DEBUG
379 greg 2.12 fprintf(stderr, "Built RBF with %d lobes\n", newnode->nrbf);
380 greg 2.3 fprintf(stderr, "Integrated DSF at (%.1f,%.1f) deg. is %.2f\n",
381     get_theta180(newnode->invec), get_phi360(newnode->invec),
382     newnode->vtotal);
383     #endif
384 greg 2.34 if (insert_dsf(newnode) < 0)
385     return(NULL);
386 greg 2.1 return(newnode);
387 greg 2.2 memerr:
388     fprintf(stderr, "%s: Out of memory in make_rbfrep()\n", progname);
389     exit(1);
390 greg 2.1 }
