root/radiance/ray/src/cv/bsdfrbf.c
Wed Jun 29 15:52:07 2022 UTC (3 years, 1 month ago) by greg
Changes since 2.33: +3 -2 lines
Diff to previous 2.33 , to selected 2.22
fix: Added missing check in make_rbfrep() for failure to add RBF
Wed May 8 16:38:19 2019 UTC (6 years, 3 months ago) by greg
Diff to previous 2.32 , to selected 2.22
Further tuned relative error for better agreement to integrated values
Tue Apr 9 22:39:33 2019 UTC (6 years, 4 months ago) by greg
Diff to previous 2.31 , to selected 2.22
Reduced relative error tolerance to 1/4 what it was after finding issues
Wed Aug 1 17:00:22 2018 UTC (7 years ago) by greg
Diff to previous 2.30 , to selected 2.22
Reduced relative error tolerance value
Tue Dec 6 23:39:54 2016 UTC (8 years, 8 months ago) by greg
Diff to previous 2.29 , to selected 2.22
Decreased slope limit to be more conservative
Tue Dec 6 23:19:50 2016 UTC (8 years, 8 months ago) by greg
Changes since 2.28: +6 -1 lines
Diff to previous 2.28 , to selected 2.22
Improved behavior around peaks by limiting slope of accepted smooth regions
Wed Feb 3 18:42:13 2016 UTC (9 years, 6 months ago) by greg
Diff to previous 2.27 , to selected 2.22
Added missing factor affecting BSDF color
Fri Jan 29 16:21:55 2016 UTC (9 years, 6 months ago) by greg
Changes since 2.26: +81 -11 lines
Diff to previous 2.26 , to selected 2.22
Fri Aug 22 05:38:44 2014 UTC (10 years, 11 months ago) by greg
Diff to previous 2.25 , to selected 2.22
Sun Mar 30 00:19:09 2014 UTC (11 years, 4 months ago) by greg
CVS Tags: rad4R2
Changes since 2.24: +21 -10 lines
Diff to previous 2.24 , to selected 2.22
Changed RBF lobe creation to put peak at centroid of quadtree leaf
Fri Mar 21 01:04:42 2014 UTC (11 years, 4 months ago) by greg
Diff to previous 2.23 , to selected 2.22
Changed behavior so bad incident directions are skipped rather than dying
Fri Mar 21 00:42:46 2014 UTC (11 years, 4 months ago) by greg
Diff to previous 2.22
Forgot to call exit(1)
Revision 2.22 - (view) (download) (annotate) - [selected]
Fri Mar 21 00:27:39 2014 UTC (11 years, 4 months ago) by greg
Changes since 2.21: +8 -3 lines
Diff to previous 2.21
Improved error reporting (slightly)
Sat Mar 15 19:47:16 2014 UTC (11 years, 4 months ago) by greg
Changes since 2.20: +18 -14 lines
Diff to previous 2.20 , to selected 2.22
Allow averaging of negative values, but avoid creating zero or negative lobes
Sat Mar 8 18:16:49 2014 UTC (11 years, 5 months ago) by greg
Changes since 2.19: +11 -11 lines
Diff to previous 2.19 , to selected 2.22
Added neighborhood difference to distance metric for better lobe shaping
Sun Mar 2 01:56:03 2014 UTC (11 years, 5 months ago) by greg
Diff to previous 2.18 , to selected 2.22
Went back to earlier absolute threshold
Tue Feb 18 16:42:16 2014 UTC (11 years, 5 months ago) by greg
Diff to previous 2.17 , to selected 2.22
Reduced error thresholds to improve lobe sampling
Mon Feb 17 21:56:22 2014 UTC (11 years, 5 months ago) by greg
Diff to previous 2.16 , to selected 2.22
Fri Nov 8 23:49:07 2013 UTC (11 years, 9 months ago) by greg
Diff to previous 2.15 , to selected 2.22
Changed return value for singular matrix (colinear values)
Fri Nov 8 23:32:54 2013 UTC (11 years, 9 months ago) by greg
Diff to previous 2.14 , to selected 2.22
Mon Oct 21 22:03:03 2013 UTC (11 years, 9 months ago) by greg
Changes since 2.13: +3 -2 lines
Diff to previous 2.13 , to selected 2.22
Minor correction
Mon Oct 21 21:48:42 2013 UTC (11 years, 9 months ago) by greg
Changes since 2.12: +22 -8 lines
Diff to previous 2.12 , to selected 2.22
Fixed potential bug in smoothness criterion
Mon Oct 21 18:33:15 2013 UTC (11 years, 9 months ago) by greg
Changes since 2.11: +154 -352 lines
Diff to previous 2.11 , to selected 2.22
Sat Oct 19 00:11:50 2013 UTC (11 years, 9 months ago) by greg
Changes since 2.10: +61 -34 lines
Diff to previous 2.10 , to selected 2.22
Fri Oct 18 02:49:30 2013 UTC (11 years, 9 months ago) by greg
Changes since 2.9: +49 -9 lines
Diff to previous 2.9 , to selected 2.22
Fixed bug for transmission and improved culling in uniform regions
Thu Oct 17 19:09:11 2013 UTC (11 years, 9 months ago) by greg
Changes since 2.8: +50 -12 lines
Diff to previous 2.8 , to selected 2.22
Fixed bug for closely-space sample points that caused poor convergence
Wed Oct 2 20:38:26 2013 UTC (11 years, 10 months ago) by greg
Changes since 2.7: +4 -2 lines
Diff to previous 2.7 , to selected 2.22
Added test to prevent tally of negative BSDF values
Wed Sep 25 17:42:45 2013 UTC (11 years, 10 months ago) by greg
Changes since 2.6: +10 -5 lines
Diff to previous 2.6 , to selected 2.22
Adjusted maximum fraction for neighbor contribution upwards a bit
Wed Sep 25 05:03:10 2013 UTC (11 years, 10 months ago) by greg
Changes since 2.5: +64 -2 lines
Diff to previous 2.5 , to selected 2.22
Put limit on lobe radius based on neighbor values
Fri Jun 28 23:18:51 2013 UTC (12 years, 1 month ago) by greg
Changes since 2.4: +25 -1 lines
Diff to previous 2.4 , to selected 2.22
Fixed calculation of bsdf_min
Wed Mar 20 01:00:22 2013 UTC (12 years, 4 months ago) by greg
Diff to previous 2.3 , to selected 2.22
Thu Nov 22 06:07:17 2012 UTC (12 years, 8 months ago) by greg
Changes since 2.2: +6 -2 lines
Diff to previous 2.2 , to selected 2.22
Tue Nov 13 04:23:38 2012 UTC (12 years, 8 months ago) by greg
Changes since 2.1: +16 -8 lines
Diff to previous 2.1 , to selected 2.22
Tried to improve convergence of RBF fit
Fri Oct 19 04:14:29 2012 UTC (12 years, 9 months ago) by greg
Diff to selected 2.22
