Reduced relative error tolerance value
Decreased slope limit to be more conservative
Improved behavior around peaks by limiting slope of accepted smooth regions
Added missing factor affecting BSDF color
Changed RBF lobe creation to put peak at centroid of quadtree leaf
Changed behavior so bad incident directions are skipped rather than dying
Forgot to call exit(1)
Improved error reporting (slightly)
Allow averaging of negative values, but avoid creating zero or negative lobes
Added neighborhood difference to distance metric for better lobe shaping
Went back to earlier absolute threshold
Reduced error thresholds to improve lobe sampling
Changed return value for singular matrix (colinear values)
Minor correction
Fixed potential bug in smoothness criterion
Fixed bug for transmission and improved culling in uniform regions
Fixed bug for closely-space sample points that caused poor convergence
Added test to prevent tally of negative BSDF values
Adjusted maximum fraction for neighbor contribution upwards a bit
Put limit on lobe radius based on neighbor values
Fixed calculation of bsdf_min
Tried to improve convergence of RBF fit
