--- ray/src/cv/bsdfrbf.c 2012/11/22 06:07:17 2.3 +++ ray/src/cv/bsdfrbf.c 2014/03/08 18:16:49 2.20 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdfrbf.c,v 2.3 2012/11/22 06:07:17 greg Exp $"; +static const char RCSid[] = "$Id: bsdfrbf.c,v 2.20 2014/03/08 18:16:49 greg Exp $"; #endif /* * Radial basis function representation for BSDF data. @@ -7,6 +7,20 @@ static const char RCSid[] = "$Id: bsdfrbf.c,v 2.3 2012 * G. Ward */ +/**************************************************************** +1) Collect samples into a grid using the Shirley-Chiu + angular mapping from a hemisphere to a square. + +2) Compute an adaptive quadtree by subdividing the grid so that + each leaf node has at least one sample up to as many + samples as fit nicely on a plane to within a certain + MSE tolerance. + +3) Place one Gaussian lobe at each leaf node in the quadtree, + sizing it to have a radius equal to the leaf size and + a volume equal to the energy in that node. +*****************************************************************/ + #define _USE_MATH_DEFINES #include #include @@ -15,9 +29,19 @@ static const char RCSid[] = "$Id: bsdfrbf.c,v 2.3 2012 #include "bsdfrep.h" #ifndef RSCA -#define RSCA 2.7 /* radius scaling factor (empirical) */ +#define RSCA 2.2 /* radius scaling factor (empirical) */ #endif - /* our loaded grid for this incident angle */ +#ifndef SMOOTH_MSE +#define SMOOTH_MSE 5e-5 /* acceptable mean squared error */ +#endif +#ifndef SMOOTH_MSER +#define SMOOTH_MSER 0.03 /* acceptable relative MSE */ +#endif +#define MAX_RAD (GRIDRES/8) /* maximum lobe radius */ + +#define RBFALLOCB 10 /* RBF allocation block size */ + + /* our loaded grid or comparison DSFs */ GRIDVAL dsf_grid[GRIDRES][GRIDRES]; /* Start new DSF input grid */ @@ -48,165 +72,201 @@ add_bsdf_data(double theta_out, double phi_out, double ovec[1] = sin((M_PI/180.)*phi_out) * ovec[2]; ovec[2] = sqrt(1. - ovec[2]*ovec[2]); - if (!isDSF) + if (val <= 0) /* truncate to zero */ + val = 0; + else if (!isDSF) val *= ovec[2]; /* convert from BSDF to DSF */ + /* update BSDF histogram */ + if (val < BSDF2BIG*ovec[2] && val > BSDF2SML*ovec[2]) + ++bsdf_hist[histndx(val/ovec[2])]; + pos_from_vec(pos, ovec); - dsf_grid[pos[0]][pos[1]].vsum += val; - dsf_grid[pos[0]][pos[1]].nval++; + dsf_grid[pos[0]][pos[1]].sum.v += val; + dsf_grid[pos[0]][pos[1]].sum.n++; } -/* Compute radii for non-empty bins */ -/* (distance to furthest empty bin for which non-empty bin is the closest) */ +/* Compute minimum BSDF from histogram (does not clear) */ static void -compute_radii(void) +comp_bsdf_min() { - unsigned int fill_grid[GRIDRES][GRIDRES]; - unsigned short fill_cnt[GRIDRES][GRIDRES]; - FVECT ovec0, ovec1; - double ang2, lastang2; - int r, i, j, jn, ii, jj, inear, jnear; + unsigned long cnt, target; + int i; - r = GRIDRES/2; /* proceed in zig-zag */ - for (i = 0; i < GRIDRES; i++) - for (jn = 0; jn < GRIDRES; jn++) { - j = (i&1) ? jn : GRIDRES-1-jn; - if (dsf_grid[i][j].nval) /* find empty grid pos. */ - continue; - ovec_from_pos(ovec0, i, j); - inear = jnear = -1; /* find nearest non-empty */ - lastang2 = M_PI*M_PI; - for (ii = i-r; ii <= i+r; ii++) { - if (ii < 0) continue; - if (ii >= GRIDRES) break; - for (jj = j-r; jj <= j+r; jj++) { - if (jj < 0) continue; - if (jj >= GRIDRES) break; - if (!dsf_grid[ii][jj].nval) - continue; - ovec_from_pos(ovec1, ii, jj); - ang2 = 2. - 2.*DOT(ovec0,ovec1); - if (ang2 >= lastang2) - continue; - lastang2 = ang2; - inear = ii; jnear = jj; - } + cnt = 0; + for (i = HISTLEN; i--; ) + cnt += bsdf_hist[i]; + if (!cnt) { /* shouldn't happen */ + bsdf_min = 0; + return; + } + target = cnt/100; /* ignore bottom 1% */ + cnt = 0; + for (i = 0; cnt <= target; i++) + cnt += bsdf_hist[i]; + bsdf_min = histval(i-1); +} + +/* Determine if the given region is empty of grid samples */ +static int +empty_region(int x0, int x1, int y0, int y1) +{ + int x, y; + + for (x = x0; x < x1; x++) + for (y = y0; y < y1; y++) + if (dsf_grid[x][y].sum.n) + return(0); + return(1); +} + +/* Determine if the given region is smooth enough to be a single lobe */ +static int +smooth_region(int x0, int x1, int y0, int y1) +{ + RREAL rMtx[3][3]; + FVECT xvec; + double A, B, C, nvs, sqerr; + int x, y, n; + /* compute planar regression */ + memset(rMtx, 0, sizeof(rMtx)); + memset(xvec, 0, sizeof(xvec)); + for (x = x0; x < x1; x++) + for (y = y0; y < y1; y++) + if ((n = dsf_grid[x][y].sum.n) > 0) { + double z = dsf_grid[x][y].sum.v; + rMtx[0][0] += x*x*(double)n; + rMtx[0][1] += x*y*(double)n; + rMtx[0][2] += x*(double)n; + rMtx[1][1] += y*y*(double)n; + rMtx[1][2] += y*(double)n; + rMtx[2][2] += (double)n; + xvec[0] += x*z; + xvec[1] += y*z; + xvec[2] += z; } - if (inear < 0) { - fprintf(stderr, - "%s: Could not find non-empty neighbor!\n", - progname); - exit(1); + rMtx[1][0] = rMtx[0][1]; + rMtx[2][0] = rMtx[0][2]; + rMtx[2][1] = rMtx[1][2]; + nvs = rMtx[2][2]; + if (SDinvXform(rMtx, rMtx) != SDEnone) + return(1); /* colinear values */ + A = DOT(rMtx[0], xvec); + B = DOT(rMtx[1], xvec); + C = DOT(rMtx[2], xvec); + sqerr = 0.0; /* compute mean squared error */ + for (x = x0; x < x1; x++) + for (y = y0; y < y1; y++) + if ((n = dsf_grid[x][y].sum.n) > 0) { + double d = A*x + B*y + C - dsf_grid[x][y].sum.v/n; + sqerr += n*d*d; } - ang2 = sqrt(lastang2); - r = ANG2R(ang2); /* record if > previous */ - if (r > dsf_grid[inear][jnear].crad) - dsf_grid[inear][jnear].crad = r; - /* next search radius */ - r = ang2*(2.*GRIDRES/M_PI) + 3; - } - /* blur radii over hemisphere */ - memset(fill_grid, 0, sizeof(fill_grid)); - memset(fill_cnt, 0, sizeof(fill_cnt)); - for (i = 0; i < GRIDRES; i++) - for (j = 0; j < GRIDRES; j++) { - if (!dsf_grid[i][j].crad) - continue; /* missing distance */ - r = R2ANG(dsf_grid[i][j].crad)*(2.*RSCA*GRIDRES/M_PI); - for (ii = i-r; ii <= i+r; ii++) { - if (ii < 0) continue; - if (ii >= GRIDRES) break; - for (jj = j-r; jj <= j+r; jj++) { - if (jj < 0) continue; - if (jj >= GRIDRES) break; - if ((ii-i)*(ii-i) + (jj-j)*(jj-j) > r*r) - continue; - fill_grid[ii][jj] += dsf_grid[i][j].crad; - fill_cnt[ii][jj]++; - } - } - } - /* copy back blurred radii */ - for (i = 0; i < GRIDRES; i++) - for (j = 0; j < GRIDRES; j++) - if (fill_cnt[i][j]) - dsf_grid[i][j].crad = fill_grid[i][j]/fill_cnt[i][j]; + if (sqerr <= nvs*SMOOTH_MSE) /* below absolute MSE threshold? */ + return(1); + /* OR below relative MSE threshold? */ + return(sqerr*nvs <= xvec[2]*xvec[2]*SMOOTH_MSER); } -/* Cull points for more uniform distribution, leave all nval 0 or 1 */ +/* Create new lobe based on integrated samples in region */ static void -cull_values(void) +create_lobe(RBFVAL *rvp, int x0, int x1, int y0, int y1) { - FVECT ovec0, ovec1; - double maxang, maxang2; - int i, j, ii, jj, r; - /* simple greedy algorithm */ - for (i = 0; i < GRIDRES; i++) - for (j = 0; j < GRIDRES; j++) { - if (!dsf_grid[i][j].nval) - continue; - if (!dsf_grid[i][j].crad) - continue; /* shouldn't happen */ - ovec_from_pos(ovec0, i, j); - maxang = 2.*R2ANG(dsf_grid[i][j].crad); - if (maxang > ovec0[2]) /* clamp near horizon */ - maxang = ovec0[2]; - r = maxang*(2.*GRIDRES/M_PI) + 1; - maxang2 = maxang*maxang; - for (ii = i-r; ii <= i+r; ii++) { - if (ii < 0) continue; - if (ii >= GRIDRES) break; - for (jj = j-r; jj <= j+r; jj++) { - if (jj < 0) continue; - if (jj >= GRIDRES) break; - if (!dsf_grid[ii][jj].nval) - continue; - if ((ii == i) & (jj == j)) - continue; /* don't get self-absorbed */ - ovec_from_pos(ovec1, ii, jj); - if (2. - 2.*DOT(ovec0,ovec1) >= maxang2) - continue; - /* absorb sum */ - dsf_grid[i][j].vsum += dsf_grid[ii][jj].vsum; - dsf_grid[i][j].nval += dsf_grid[ii][jj].nval; - /* keep value, though */ - dsf_grid[ii][jj].vsum /= (float)dsf_grid[ii][jj].nval; - dsf_grid[ii][jj].nval = 0; - } - } + double vtot = 0.0; + int nv = 0; + double rad; + int x, y; + /* compute average for region */ + for (x = x0; x < x1; x++) + for (y = y0; y < y1; y++) { + vtot += dsf_grid[x][y].sum.v; + nv += dsf_grid[x][y].sum.n; } - /* final averaging pass */ - for (i = 0; i < GRIDRES; i++) - for (j = 0; j < GRIDRES; j++) - if (dsf_grid[i][j].nval > 1) { - dsf_grid[i][j].vsum /= (float)dsf_grid[i][j].nval; - dsf_grid[i][j].nval = 1; - } + if (!nv) { + fprintf(stderr, "%s: internal - missing samples in create_lobe\n", + progname); + exit(1); + } + /* peak value based on integral */ + vtot *= (x1-x0)*(y1-y0)*(2.*M_PI/GRIDRES/GRIDRES)/(double)nv; + rad = (RSCA/(double)GRIDRES)*(x1-x0); + rvp->peak = vtot / ((2.*M_PI) * rad*rad); + rvp->crad = ANG2R(rad); + rvp->gx = (x0+x1)>>1; + rvp->gy = (y0+y1)>>1; } +/* Recursive function to build radial basis function representation */ +static int +build_rbfrep(RBFVAL **arp, int *np, int x0, int x1, int y0, int y1) +{ + int xmid = (x0+x1)>>1; + int ymid = (y0+y1)>>1; + int branched[4]; + int nadded, nleaves; + /* need to make this a leaf? */ + if (empty_region(x0, xmid, y0, ymid) || + empty_region(xmid, x1, y0, ymid) || + empty_region(x0, xmid, ymid, y1) || + empty_region(xmid, x1, ymid, y1)) + return(0); + /* add children (branches+leaves) */ + if ((branched[0] = build_rbfrep(arp, np, x0, xmid, y0, ymid)) < 0) + return(-1); + if ((branched[1] = build_rbfrep(arp, np, xmid, x1, y0, ymid)) < 0) + return(-1); + if ((branched[2] = build_rbfrep(arp, np, x0, xmid, ymid, y1)) < 0) + return(-1); + if ((branched[3] = build_rbfrep(arp, np, xmid, x1, ymid, y1)) < 0) + return(-1); + nadded = branched[0] + branched[1] + branched[2] + branched[3]; + nleaves = !branched[0] + !branched[1] + !branched[2] + !branched[3]; + if (!nleaves) /* nothing but branches? */ + return(nadded); + /* combine 4 leaves into 1? */ + if ((nleaves == 4) & (x1-x0 <= MAX_RAD) && + smooth_region(x0, x1, y0, y1)) + return(0); + /* need more array space? */ + if ((*np+nleaves-1)>>RBFALLOCB != (*np-1)>>RBFALLOCB) { + *arp = (RBFVAL *)realloc(*arp, + sizeof(RBFVAL)*(*np+nleaves-1+(1<rbfa, newnode, sizeof(RBFVAL)*nn); newnode->ord = -1; newnode->next = NULL; newnode->ejl = NULL; @@ -214,53 +274,13 @@ make_rbfrep(void) newnode->invec[0] = cos((M_PI/180.)*phi_in_deg)*newnode->invec[2]; newnode->invec[1] = sin((M_PI/180.)*phi_in_deg)*newnode->invec[2]; newnode->invec[2] = input_orient*sqrt(1. - newnode->invec[2]*newnode->invec[2]); - newnode->vtotal = 0; + newnode->vtotal = .0; newnode->nrbf = nn; - nn = 0; /* fill RBF array */ - for (i = 0; i < GRIDRES; i++) - for (j = 0; j < GRIDRES; j++) - if (dsf_grid[i][j].nval) { - newnode->rbfa[nn].peak = dsf_grid[i][j].vsum; - newnode->rbfa[nn].crad = RSCA*dsf_grid[i][j].crad + .5; - newnode->rbfa[nn].gx = i; - newnode->rbfa[nn].gy = j; - ++nn; - } - /* iterate to improve interpolation accuracy */ - itera = (RBFVAL *)malloc(sizeof(RBFVAL)*newnode->nrbf); - if (itera == NULL) - goto memerr; - memcpy(itera, newnode->rbfa, sizeof(RBFVAL)*newnode->nrbf); - do { - double dsum = 0, dsum2 = 0; - nn = 0; - for (i = 0; i < GRIDRES; i++) - for (j = 0; j < GRIDRES; j++) - if (dsf_grid[i][j].nval) { - FVECT odir; - double corr; - ovec_from_pos(odir, i, j); - itera[nn++].peak *= corr = - dsf_grid[i][j].vsum / - eval_rbfrep(newnode, odir); - dsum += 1. - corr; - dsum2 += (1.-corr)*(1.-corr); - } - memcpy(newnode->rbfa, itera, sizeof(RBFVAL)*newnode->nrbf); - lastVar = thisVar; - thisVar = dsum2/(double)nn; + /* compute sum for normalization */ + while (nn-- > 0) + newnode->vtotal += rbf_volume(&newnode->rbfa[nn]); #ifdef DEBUG - fprintf(stderr, "Avg., RMS error: %.1f%% %.1f%%\n", - 100.*dsum/(double)nn, - 100.*sqrt(thisVar)); -#endif - } while (--niter > 0 && lastVar-thisVar > 0.02*lastVar); - - free(itera); - nn = 0; /* compute sum for normalization */ - while (nn < newnode->nrbf) - newnode->vtotal += rbf_volume(&newnode->rbfa[nn++]); -#ifdef DEBUG + fprintf(stderr, "Built RBF with %d lobes\n", newnode->nrbf); fprintf(stderr, "Integrated DSF at (%.1f,%.1f) deg. is %.2f\n", get_theta180(newnode->invec), get_phi360(newnode->invec), newnode->vtotal);
