root/Development/ray/src/cv/bsdfrbf.c
Revision: 2.27
Committed: Fri Jan 29 16:21:55 2016 UTC (9 years, 10 months ago) by greg
Changes since 2.26: +81 -11 lines
2 static const char RCSid[] = "$Id: bsdfrbf.c,v 2.26 2014/08/22 05:38:44 greg Exp $";
5 * Radial basis function representation for BSDF data.
6 *
7 * G. Ward
8 */
9
10 /****************************************************************
11 1) Collect samples into a grid using the Shirley-Chiu
12 angular mapping from a hemisphere to a square.
13
14 2) Compute an adaptive quadtree by subdividing the grid so that
15 each leaf node has at least one sample up to as many
16 samples as fit nicely on a plane to within a certain
17 MSE tolerance.
18
19 3) Place one Gaussian lobe at each leaf node in the quadtree,
20 sizing it to have a radius equal to the leaf size and
21 a volume equal to the energy in that node.
22 *****************************************************************/
23
24 #define _USE_MATH_DEFINES
25 #include <stdio.h>
26 #include <stdlib.h>
27 #include <string.h>
28 #include <math.h>
29 #include "bsdfrep.h"
30
31 #ifndef RSCA
32 #define RSCA 2.0 /* radius scaling factor (empirical) */
33 #endif
34 #ifndef SMOOTH_MSE
35 #define SMOOTH_MSE 5e-5 /* acceptable mean squared error */
36 #endif
37 #ifndef SMOOTH_MSER
38 #define SMOOTH_MSER 0.03 /* acceptable relative MSE */
39 #endif
40 #define MAX_RAD (GRIDRES/8) /* maximum lobe radius */
41
42 #define RBFALLOCB 10 /* RBF allocation block size */
43
44 /* loaded grid or comparison DSFs */
45 GRIDVAL dsf_grid[GRIDRES][GRIDRES];
46 /* allocated chrominance sums if any */
47 float (*spec_grid)[GRIDRES][GRIDRES];
48 int nspec_grid = 0;
49
50 /* Set up visible spectrum sampling */
51 void
52 set_spectral_samples(int nspec)
53 {
54 if (rbf_colorimetry == RBCunknown) {
55 if (nspec_grid > 0) {
56 free(spec_grid);
57 spec_grid = NULL;
58 nspec_grid = 0;
59 }
60 if (nspec == 1) {
61 rbf_colorimetry = RBCphotopic;
62 return;
63 }
64 if (nspec == 3) {
65 rbf_colorimetry = RBCtristimulus;
66 spec_grid = (float (*)[GRIDRES][GRIDRES])calloc(
67 2*GRIDRES*GRIDRES, sizeof(float) );
68 if (spec_grid == NULL)
69 goto mem_error;
70 nspec_grid = 2;
71 return;
72 }
73 fprintf(stderr,
74 "%s: only 1 or 3 spectral samples currently supported\n",
75 progname);
76 exit(1);
77 }
78 if (nspec != nspec_grid+1) {
79 fprintf(stderr,
80 "%s: number of spectral samples cannot be changed\n",
81 progname);
82 exit(1);
83 }
84 return;
85 mem_error:
86 fprintf(stderr, "%s: out of memory in set_spectral_samples()\n",
87 progname);
88 exit(1);
89 }
90
91 /* Start new DSF input grid */
92 void
93 new_bsdf_data(double new_theta, double new_phi)
94 {
95 if (!new_input_direction(new_theta, new_phi))
96 exit(1);
97 memset(dsf_grid, 0, sizeof(dsf_grid));
98 if (nspec_grid > 0)
99 memset(spec_grid, 0, sizeof(float)*GRIDRES*GRIDRES*nspec_grid);
100 }
101
102 /* Add BSDF data point */
103 void
104 add_bsdf_data(double theta_out, double phi_out, const double val[], int isDSF)
105 {
106 FVECT ovec;
107 double cfact, Yval;
108 int pos[2];
109
110 if (nspec_grid > 2) {
111 fprintf(stderr, "%s: unsupported color space\n", progname);
112 exit(1);
113 }
114 if (!output_orient) /* check output orientation */
115 output_orient = 1 - 2*(theta_out > 90.);
116 else if (output_orient > 0 ^ theta_out < 90.) {
117 fprintf(stderr,
118 "%s: cannot handle output angles on both sides of surface\n",
119 progname);
120 exit(1);
121 }
122 ovec[2] = sin((M_PI/180.)*theta_out);
123 ovec[0] = cos((M_PI/180.)*phi_out) * ovec[2];
124 ovec[1] = sin((M_PI/180.)*phi_out) * ovec[2];
125 ovec[2] = sqrt(1. - ovec[2]*ovec[2]);
126 /* BSDF to DSF correction */
127 cfact = isDSF ? 1. : ovec[2];
128
129 Yval = cfact * val[rbf_colorimetry==RBCtristimulus];
130 /* update BSDF histogram */
131 if (BSDF2SML*ovec[2] < Yval && Yval < BSDF2BIG*ovec[2])
132 ++bsdf_hist[histndx(Yval/ovec[2])];
133
134 pos_from_vec(pos, ovec);
135
136 dsf_grid[pos[0]][pos[1]].sum.v += Yval;
137 dsf_grid[pos[0]][pos[1]].sum.n++;
138 /* add in X and Z values */
139 if (rbf_colorimetry == RBCtristimulus) {
140 spec_grid[0][pos[0]][pos[1]] += val[0];
141 spec_grid[1][pos[0]][pos[1]] += val[2];
142 }
143 }
144
145 /* Compute minimum BSDF from histogram (does not clear) */
146 static void
147 comp_bsdf_min()
148 {
149 unsigned long cnt, target;
150 int i;
151
152 cnt = 0;
153 for (i = HISTLEN; i--; )
154 cnt += bsdf_hist[i];
155 if (!cnt) { /* shouldn't happen */
156 bsdf_min = 0;
157 return;
158 }
159 target = cnt/100; /* ignore bottom 1% */
160 cnt = 0;
161 for (i = 0; cnt <= target; i++)
162 cnt += bsdf_hist[i];
163 bsdf_min = histval(i-1);
164 }
165
166 /* Determine if the given region is empty of grid samples */
167 static int
168 empty_region(int x0, int x1, int y0, int y1)
169 {
170 int x, y;
171
172 for (x = x0; x < x1; x++)
173 for (y = y0; y < y1; y++)
174 if (dsf_grid[x][y].sum.n)
175 return(0);
176 return(1);
177 }
178
179 /* Determine if the given region is smooth enough to be a single lobe */
180 static int
181 smooth_region(int x0, int x1, int y0, int y1)
182 {
183 RREAL rMtx[3][3];
184 FVECT xvec;
185 double A, B, C, nvs, sqerr;
186 int x, y, n;
187 /* compute planar regression */
188 memset(rMtx, 0, sizeof(rMtx));
189 memset(xvec, 0, sizeof(xvec));
190 for (x = x0; x < x1; x++)
191 for (y = y0; y < y1; y++)
192 if ((n = dsf_grid[x][y].sum.n) > 0) {
193 double z = dsf_grid[x][y].sum.v;
194 rMtx[0][0] += x*x*(double)n;
195 rMtx[0][1] += x*y*(double)n;
196 rMtx[0][2] += x*(double)n;
197 rMtx[1][1] += y*y*(double)n;
198 rMtx[1][2] += y*(double)n;
199 rMtx[2][2] += (double)n;
200 xvec[0] += x*z;
201 xvec[1] += y*z;
202 xvec[2] += z;
203 }
204 rMtx[1][0] = rMtx[0][1];
205 rMtx[2][0] = rMtx[0][2];
206 rMtx[2][1] = rMtx[1][2];
207 nvs = rMtx[2][2];
208 if (SDinvXform(rMtx, rMtx) != SDEnone)
209 return(1); /* colinear values */
210 A = DOT(rMtx[0], xvec);
211 B = DOT(rMtx[1], xvec);
212 C = DOT(rMtx[2], xvec);
213 sqerr = 0.0; /* compute mean squared error */
214 for (x = x0; x < x1; x++)
215 for (y = y0; y < y1; y++)
216 if ((n = dsf_grid[x][y].sum.n) > 0) {
217 double d = A*x + B*y + C - dsf_grid[x][y].sum.v/n;
218 sqerr += n*d*d;
219 }
220 if (sqerr <= nvs*SMOOTH_MSE) /* below absolute MSE threshold? */
221 return(1);
222 /* OR below relative MSE threshold? */
223 return(sqerr*nvs <= xvec[2]*xvec[2]*SMOOTH_MSER);
224 }
225
226 /* Create new lobe based on integrated samples in region */
227 static int
228 create_lobe(RBFVAL *rvp, int x0, int x1, int y0, int y1)
229 {
230 double vtot = 0.0;
231 double CIEXtot = 0.0, CIEZtot = 0.0;
232 int nv = 0;
233 double wxsum = 0.0, wysum = 0.0, wtsum = 0.0;
234 double rad;
235 int x, y;
236 /* compute average for region */
237 for (x = x0; x < x1; x++)
238 for (y = y0; y < y1; y++)
239 if (dsf_grid[x][y].sum.n) {
240 const double v = dsf_grid[x][y].sum.v;
241 const int n = dsf_grid[x][y].sum.n;
242
243 if (v > 0) {
244 const double wt = v / (double)n;
245 wxsum += wt * x;
246 wysum += wt * y;
247 wtsum += wt;
248 }
249 vtot += v;
250 nv += n;
251 if (rbf_colorimetry == RBCtristimulus) {
252 CIEXtot += spec_grid[0][x][y];
253 CIEZtot += spec_grid[1][x][y];
254 }
255 }
256 if (!nv) {
257 fprintf(stderr, "%s: internal - missing samples in create_lobe\n",
258 progname);
259 exit(1);
260 }
261 if (vtot <= 0) /* only create positive lobes */
262 return(0);
263 /* assign color */
264 if (rbf_colorimetry == RBCtristimulus) {
265 const double df = 1.0 / (CIEXtot + vtot + CIEZtot);
266 C_COLOR cclr;
267 c_cset(&cclr, CIEXtot*df, vtot*df);
268 rvp->chroma = c_encodeChroma(&cclr);
269 } else
270 rvp->chroma = c_dfchroma;
271 /* peak value based on integral */
272 vtot *= (x1-x0)*(y1-y0)*(2.*M_PI/GRIDRES/GRIDRES)/(double)nv;
273 rad = (RSCA/(double)GRIDRES)*(x1-x0);
274 rvp->peak = vtot / ((2.*M_PI) * rad*rad);
275 rvp->crad = ANG2R(rad); /* put peak at centroid */
276 rvp->gx = (int)(wxsum/wtsum + .5);
277 rvp->gy = (int)(wysum/wtsum + .5);
278 return(1);
279 }
280
281 /* Recursive function to build radial basis function representation */
282 static int
283 build_rbfrep(RBFVAL **arp, int *np, int x0, int x1, int y0, int y1)
284 {
285 int xmid = (x0+x1)>>1;
286 int ymid = (y0+y1)>>1;
287 int branched[4];
288 int nadded, nleaves;
289 /* need to make this a leaf? */
290 if (empty_region(x0, xmid, y0, ymid) ||
291 empty_region(xmid, x1, y0, ymid) ||
292 empty_region(x0, xmid, ymid, y1) ||
293 empty_region(xmid, x1, ymid, y1))
294 return(0);
295 /* add children (branches+leaves) */
296 if ((branched[0] = build_rbfrep(arp, np, x0, xmid, y0, ymid)) < 0)
297 return(-1);
298 if ((branched[1] = build_rbfrep(arp, np, xmid, x1, y0, ymid)) < 0)
299 return(-1);
300 if ((branched[2] = build_rbfrep(arp, np, x0, xmid, ymid, y1)) < 0)
301 return(-1);
302 if ((branched[3] = build_rbfrep(arp, np, xmid, x1, ymid, y1)) < 0)
303 return(-1);
304 nadded = branched[0] + branched[1] + branched[2] + branched[3];
305 nleaves = !branched[0] + !branched[1] + !branched[2] + !branched[3];
306 if (!nleaves) /* nothing but branches? */
307 return(nadded);
308 /* combine 4 leaves into 1? */
309 if ((nleaves == 4) & (x1-x0 <= MAX_RAD) &&
310 smooth_region(x0, x1, y0, y1))
311 return(0);
312 /* need more array space? */
313 if ((*np+nleaves-1)>>RBFALLOCB != (*np-1)>>RBFALLOCB) {
314 *arp = (RBFVAL *)realloc(*arp,
315 sizeof(RBFVAL)*(*np+nleaves-1+(1<<RBFALLOCB)));
316 if (*arp == NULL)
317 return(-1);
318 }
319 /* create lobes for leaves */
320 if (!branched[0] && create_lobe(*arp+*np, x0, xmid, y0, ymid)) {
321 ++(*np); ++nadded;
322 }
323 if (!branched[1] && create_lobe(*arp+*np, xmid, x1, y0, ymid)) {
324 ++(*np); ++nadded;
325 }
326 if (!branched[2] && create_lobe(*arp+*np, x0, xmid, ymid, y1)) {
327 ++(*np); ++nadded;
328 }
329 if (!branched[3] && create_lobe(*arp+*np, xmid, x1, ymid, y1)) {
330 ++(*np); ++nadded;
331 }
332 return(nadded);
333 }
334
335 /* Count up filled nodes and build RBF representation from current grid */
336 RBFNODE *
337 make_rbfrep()
338 {
339 RBFNODE *newnode;
340 RBFVAL *rbfarr;
341 int nn;
342 /* compute minimum BSDF */
343 comp_bsdf_min();
344 /* create RBF node list */
345 rbfarr = NULL; nn = 0;
346 if (build_rbfrep(&rbfarr, &nn, 0, GRIDRES, 0, GRIDRES) <= 0) {
347 if (nn)
348 goto memerr;
349 fprintf(stderr,
350 "%s: warning - skipping bad incidence (%.1f,%.1f)\n",
351 progname, theta_in_deg, phi_in_deg);
352 return(NULL);
353 }
354 /* (re)allocate RBF array */
355 newnode = (RBFNODE *)realloc(rbfarr,
356 sizeof(RBFNODE) + sizeof(RBFVAL)*(nn-1));
357 if (newnode == NULL)
358 goto memerr;
359 /* copy computed lobes into RBF node */
360 memmove(newnode->rbfa, newnode, sizeof(RBFVAL)*nn);
361 newnode->ord = -1;
362 newnode->next = NULL;
363 newnode->ejl = NULL;
364 newnode->invec[2] = sin((M_PI/180.)*theta_in_deg);
365 newnode->invec[0] = cos((M_PI/180.)*phi_in_deg)*newnode->invec[2];
366 newnode->invec[1] = sin((M_PI/180.)*phi_in_deg)*newnode->invec[2];
367 newnode->invec[2] = input_orient*sqrt(1. - newnode->invec[2]*newnode->invec[2]);
368 newnode->vtotal = .0;
369 newnode->nrbf = nn;
370 /* compute sum for normalization */
371 while (nn-- > 0)
372 newnode->vtotal += rbf_volume(&newnode->rbfa[nn]);
373 #ifdef DEBUG
374 fprintf(stderr, "Built RBF with %d lobes\n", newnode->nrbf);
375 fprintf(stderr, "Integrated DSF at (%.1f,%.1f) deg. is %.2f\n",
376 get_theta180(newnode->invec), get_phi360(newnode->invec),
377 newnode->vtotal);
378 #endif
379 insert_dsf(newnode);
380 return(newnode);
381 memerr:
382 fprintf(stderr, "%s: Out of memory in make_rbfrep()\n", progname);
383 exit(1);
384 }
