root/radiance/ray/src/cv/bsdfquery.c
Fri Mar 26 22:01:44 2021 UTC (3 years, 1 month ago) by greg
CVS Tags: HEAD, rad5R4
style: removed stray character
Sat Dec 28 18:05:14 2019 UTC (4 years, 4 months ago) by greg
Changes since 2.10: +1 -3 lines
Tue Jun 11 16:09:40 2019 UTC (4 years, 11 months ago) by greg
Changes since 2.9: +8 -2 lines
Added -u option for unbuffered output
Thu Apr 13 00:14:36 2017 UTC (7 years, 1 month ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.8: +5 -4 lines
Added value flushing to bsdfquery and put in standard build
Mon Feb 6 23:21:32 2017 UTC (7 years, 3 months ago) by greg
Changes since 2.7: +1 -3 lines
Removed unnecessary call
Thu Aug 18 00:52:48 2016 UTC (7 years, 9 months ago) by greg
Changes since 2.6: +8 -7 lines
Sat Jan 30 17:34:17 2016 UTC (8 years, 3 months ago) by greg
Changes since 2.5: +56 -19 lines
Added -c option to output XYZ color
Wed Jan 20 19:43:34 2016 UTC (8 years, 3 months ago) by greg
Changes since 2.4: +3 -5 lines
Fix for SMLFLT
Thu Aug 21 10:33:48 2014 UTC (9 years, 8 months ago) by greg
Fri Apr 11 20:27:23 2014 UTC (10 years, 1 month ago) by greg
CVS Tags: rad4R2
Made reading of vectors more consistent with FVFORMAT macro
Fri Nov 22 00:00:27 2013 UTC (10 years, 5 months ago) by greg
Fixed command argument check
Thu Nov 21 23:57:28 2013 UTC (10 years, 5 months ago) by greg
Created bsdfquery program for evaluating BSDF representations
