root/radiance/ray/src/cv/bsdfquery.c
Revision: 2.4
Committed: Thu Aug 21 10:33:48 2014 UTC (9 years, 8 months ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad4R2P1
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.4 static const char RCSid[] = "$Id: bsdfquery.c,v 2.3 2014/04/11 20:27:23 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Query values from the given BSDF (scattering interpolant or XML repres.)
6     * Input query is incident and exiting vectors directed away from surface.
7     * We normalize. Output is a BSDF value for the vector pair.
8     * It is wise to sort the input directions to keep identical ones together
9     * when using a scattering interpolant representation.
10     */
11
12     #define _USE_MATH_DEFINES
13     #include <stdio.h>
14     #include <string.h>
15     #include <stdlib.h>
16     #include "rtmath.h"
17     #include "bsdfrep.h"
18
19     char *progname;
20
21     /* Read in a vector pair */
22     static int
23     readIOdir(FVECT idir, FVECT odir, FILE *fp, int fmt)
24     {
25     double dvec[6];
26     float fvec[6];
27
28     switch (fmt) {
29     case 'a':
30 greg 2.3 if (fscanf(fp, FVFORMAT, dvec, dvec+1, dvec+2) != 3 ||
31     fscanf(fp, FVFORMAT, dvec+3, dvec+4, dvec+5) != 3)
32 greg 2.1 return(0);
33     VCOPY(idir, dvec);
34     VCOPY(odir, dvec+3);
35     break;
36     case 'd':
37     if (fread(dvec, sizeof(double), 6, fp) != 6)
38     return(0);
39     VCOPY(idir, dvec);
40     VCOPY(odir, dvec+3);
41     break;
42     case 'f':
43     if (fread(fvec, sizeof(float), 6, fp) != 6)
44     return(0);
45     VCOPY(idir, fvec);
46     VCOPY(odir, fvec+3);
47     break;
48     }
49     if ((normalize(idir) == 0) | (normalize(odir) == 0)) {
50     fprintf(stderr, "%s: zero input vector!\n", progname);
51     return(0);
52     }
53     return(1);
54     }
55
56     /* Get BSDF values for the input and output directions given on stdin */
57     int
58     main(int argc, char *argv[])
59     {
60     int inpXML = -1;
61     int inpfmt = 'a';
62     int outfmt = 'a';
63     RBFNODE *rbf = NULL;
64     int32 prevInpDir = 0;
65     SDData myBSDF;
66     FVECT idir, odir;
67     int n;
68     /* check arguments */
69     progname = argv[0];
70     if (argc > 2 && argv[1][0] == '-' && argv[1][1] == 'f' &&
71     argv[1][2] && strchr("afd", argv[1][2]) != NULL) {
72     inpfmt = outfmt = argv[1][2];
73     if (argv[1][3] && strchr("afd", argv[1][3]) != NULL)
74     outfmt = argv[1][3];
75     ++argv; --argc;
76     }
77 greg 2.2 if (argc > 1 && (n = strlen(argv[1])-4) > 0) {
78 greg 2.1 if (!strcasecmp(argv[1]+n, ".xml"))
79     inpXML = 1;
80     else if (!strcasecmp(argv[1]+n, ".sir"))
81     inpXML = 0;
82     }
83 greg 2.2 if ((argc != 2) | (inpXML < 0)) {
84 greg 2.1 fprintf(stderr, "Usage: %s [-fio] bsdf.{sir|xml}\n", progname);
85     return(1);
86     }
87     /* load BSDF representation */
88     if (inpXML) {
89     SDclearBSDF(&myBSDF, argv[1]);
90     if (SDreportError(SDloadFile(&myBSDF, argv[1]), stderr))
91     return(1);
92     } else {
93     FILE *fp = fopen(argv[1], "rb");
94     if (fp == NULL) {
95     fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
96     progname, argv[1]);
97     return(1);
98     }
99     if (!load_bsdf_rep(fp))
100     return(1);
101     fclose(fp);
102     }
103     /* query BSDF values */
104     while (readIOdir(idir, odir, stdin, inpfmt)) {
105     double bsdf;
106     float fval;
107     if (inpXML) {
108     SDValue sval;
109     if (SDreportError(SDevalBSDF(&sval, odir,
110     idir, &myBSDF), stderr))
111     return(1);
112     bsdf = sval.cieY;
113     } else {
114     int32 inpDir = encodedir(idir);
115     if (inpDir != prevInpDir) {
116     if (idir[2] > 0 ^ input_orient > 0) {
117     fprintf(stderr, "%s: input hemisphere error\n",
118     progname);
119     return(1);
120     }
121     if (rbf != NULL) free(rbf);
122     rbf = advect_rbf(idir, 15000);
123     prevInpDir = inpDir;
124     }
125     if (odir[2] > 0 ^ output_orient > 0) {
126     fprintf(stderr, "%s: output hemisphere error\n",
127     progname);
128     return(1);
129     }
130 greg 2.4 bsdf = eval_rbfrep(rbf, odir);
131 greg 2.1 }
132     switch (outfmt) { /* write to stdout */
133     case 'a':
134     printf("%.6e\n", bsdf);
135     break;
136     case 'd':
137     fwrite(&bsdf, sizeof(double), 1, stdout);
138     break;
139     case 'f':
140     fval = bsdf;
141     fwrite(&fval, sizeof(float), 1, stdout);
142     break;
143     }
144     }
145     return(0);
146     }
