root/radiance/ray/src/cv/bsdfquery.c
Revision: 2.4
Committed: Thu Aug 21 10:33:48 2014 UTC (10 years, 8 months ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad4R2P1
2 static const char RCSid[] = "$Id: bsdfquery.c,v 2.3 2014/04/11 20:27:23 greg Exp $";
5 * Query values from the given BSDF (scattering interpolant or XML repres.)
6 * Input query is incident and exiting vectors directed away from surface.
7 * We normalize. Output is a BSDF value for the vector pair.
8 * It is wise to sort the input directions to keep identical ones together
9 * when using a scattering interpolant representation.
10 */
11
12 #define _USE_MATH_DEFINES
13 #include <stdio.h>
14 #include <string.h>
15 #include <stdlib.h>
16 #include "rtmath.h"
17 #include "bsdfrep.h"
18
19 char *progname;
20
21 /* Read in a vector pair */
22 static int
23 readIOdir(FVECT idir, FVECT odir, FILE *fp, int fmt)
24 {
25 double dvec[6];
26 float fvec[6];
27
28 switch (fmt) {
29 case 'a':
30 if (fscanf(fp, FVFORMAT, dvec, dvec+1, dvec+2) != 3 ||
31 fscanf(fp, FVFORMAT, dvec+3, dvec+4, dvec+5) != 3)
32 return(0);
33 VCOPY(idir, dvec);
34 VCOPY(odir, dvec+3);
35 break;
36 case 'd':
37 if (fread(dvec, sizeof(double), 6, fp) != 6)
38 return(0);
39 VCOPY(idir, dvec);
40 VCOPY(odir, dvec+3);
41 break;
42 case 'f':
43 if (fread(fvec, sizeof(float), 6, fp) != 6)
44 return(0);
45 VCOPY(idir, fvec);
46 VCOPY(odir, fvec+3);
47 break;
48 }
49 if ((normalize(idir) == 0) | (normalize(odir) == 0)) {
50 fprintf(stderr, "%s: zero input vector!\n", progname);
51 return(0);
52 }
53 return(1);
54 }
55
56 /* Get BSDF values for the input and output directions given on stdin */
57 int
58 main(int argc, char *argv[])
59 {
60 int inpXML = -1;
61 int inpfmt = 'a';
62 int outfmt = 'a';
63 RBFNODE *rbf = NULL;
64 int32 prevInpDir = 0;
65 SDData myBSDF;
66 FVECT idir, odir;
67 int n;
68 /* check arguments */
69 progname = argv[0];
70 if (argc > 2 && argv[1][0] == '-' && argv[1][1] == 'f' &&
71 argv[1][2] && strchr("afd", argv[1][2]) != NULL) {
72 inpfmt = outfmt = argv[1][2];
73 if (argv[1][3] && strchr("afd", argv[1][3]) != NULL)
74 outfmt = argv[1][3];
75 ++argv; --argc;
76 }
77 if (argc > 1 && (n = strlen(argv[1])-4) > 0) {
78 if (!strcasecmp(argv[1]+n, ".xml"))
79 inpXML = 1;
80 else if (!strcasecmp(argv[1]+n, ".sir"))
81 inpXML = 0;
82 }
83 if ((argc != 2) | (inpXML < 0)) {
84 fprintf(stderr, "Usage: %s [-fio] bsdf.{sir|xml}\n", progname);
85 return(1);
86 }
87 /* load BSDF representation */
88 if (inpXML) {
89 SDclearBSDF(&myBSDF, argv[1]);
90 if (SDreportError(SDloadFile(&myBSDF, argv[1]), stderr))
91 return(1);
92 } else {
93 FILE *fp = fopen(argv[1], "rb");
94 if (fp == NULL) {
95 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
96 progname, argv[1]);
97 return(1);
98 }
99 if (!load_bsdf_rep(fp))
100 return(1);
101 fclose(fp);
102 }
103 /* query BSDF values */
104 while (readIOdir(idir, odir, stdin, inpfmt)) {
105 double bsdf;
106 float fval;
107 if (inpXML) {
108 SDValue sval;
109 if (SDreportError(SDevalBSDF(&sval, odir,
110 idir, &myBSDF), stderr))
111 return(1);
112 bsdf = sval.cieY;
113 } else {
114 int32 inpDir = encodedir(idir);
115 if (inpDir != prevInpDir) {
116 if (idir[2] > 0 ^ input_orient > 0) {
117 fprintf(stderr, "%s: input hemisphere error\n",
118 progname);
119 return(1);
120 }
121 if (rbf != NULL) free(rbf);
122 rbf = advect_rbf(idir, 15000);
123 prevInpDir = inpDir;
124 }
125 if (odir[2] > 0 ^ output_orient > 0) {
126 fprintf(stderr, "%s: output hemisphere error\n",
127 progname);
128 return(1);
129 }
130 bsdf = eval_rbfrep(rbf, odir);
131 }
132 switch (outfmt) { /* write to stdout */
133 case 'a':
134 printf("%.6e\n", bsdf);
135 break;
136 case 'd':
137 fwrite(&bsdf, sizeof(double), 1, stdout);
138 break;
139 case 'f':
140 fval = bsdf;
141 fwrite(&fval, sizeof(float), 1, stdout);
142 break;
143 }
144 }
145 return(0);
146 }
