| 1 | #ifndef lint |
| 2 | static const char RCSid[] = "$Id: bsdfquery.c,v 2.13 2025/06/03 21:31:51 greg Exp $"; |
| 3 | #endif |
| 4 | /* |
| 5 | *  Query values from the given BSDF (scattering interpolant or XML repres.) |
| 6 | *  Input query is incident and exiting vectors directed away from surface. |
| 7 | *  We normalize.  Output is a BSDF value for the vector pair. |
| 8 | *  A zero length in or out vector is ignored, causing output to be flushed. |
| 9 | *  It is wise to sort the input directions to keep identical ones together |
| 10 | *  when using a scattering interpolant representation. |
| 11 | */ |
| 12 |  |
| 13 | #define _USE_MATH_DEFINES |
| 14 | #include <stdlib.h> |
| 15 | #include "rtmath.h" |
| 16 | #include "rtio.h" |
| 17 | #include "bsdfrep.h" |
| 18 |  |
| 19 | /* Read in a vector pair */ |
| 20 | static int |
| 21 | readIOdir(FVECT idir, FVECT odir, FILE *fp, int fmt) |
| 22 | { |
| 23 | double  dvec[6]; |
| 24 | float   fvec[6]; |
| 25 | tryagain: |
| 26 | switch (fmt) { |
| 27 | case 'a': |
| 28 | if (fscanf(fp, FVFORMAT, &idir[0], &idir[1], &idir[2]) != 3 || |
| 29 | fscanf(fp, FVFORMAT, &odir[0], &odir[1], &odir[2]) != 3) |
| 30 | return(0); |
| 31 | break; |
| 32 | case 'd': |
| 33 | if (getbinary(dvec, sizeof(double), 6, fp) != 6) |
| 34 | return(0); |
| 35 | VCOPY(idir, dvec); |
| 36 | VCOPY(odir, dvec+3); |
| 37 | break; |
| 38 | case 'f': |
| 39 | if (getbinary(fvec, sizeof(float), 6, fp) != 6) |
| 40 | return(0); |
| 41 | VCOPY(idir, fvec); |
| 42 | VCOPY(odir, fvec+3); |
| 43 | break; |
| 44 | } |
| 45 | if ((normalize(idir) == 0) | (normalize(odir) == 0)) { |
| 46 | fflush(stdout);         /* desired side-effect? */ |
| 47 | goto tryagain; |
| 48 | } |
| 49 | return(1); |
| 50 | } |
| 51 |  |
| 52 | /* Get BSDF values for the input and output directions given on stdin */ |
| 53 | int |
| 54 | main(int argc, char *argv[]) |
| 55 | { |
| 56 | int     unbuffered = 0; |
| 57 | int     repXYZ = 0; |
| 58 | int     inpXML = -1; |
| 59 | int     inpfmt = 'a'; |
| 60 | int     outfmt = 'a'; |
| 61 | RBFNODE *rbf = NULL; |
| 62 | int32   prevInpDir = 0; |
| 63 | SDData  myBSDF; |
| 64 | FVECT   idir, odir; |
| 65 | int     n; |
| 66 | /* set global progname */ |
| 67 | fixargv0(argv[0]); |
| 68 | /* check arguments */ |
| 69 | while (argc > 2 && argv[1][0] == '-') { |
| 70 | switch (argv[1][1]) { |
| 71 | case 'u':                       /* unbuffered output */ |
| 72 | unbuffered = 1; |
| 73 | break; |
| 74 | case 'c':                       /* color output */ |
| 75 | repXYZ = 1; |
| 76 | break; |
| 77 | case 'f':                       /* i/o format */ |
| 78 | if (!argv[1][2] || strchr("afd", argv[1][2]) == NULL) |
| 79 | goto userr; |
| 80 | inpfmt = outfmt = argv[1][2]; |
| 81 | if (argv[1][3] && strchr("afd", argv[1][3]) != NULL) |
| 82 | outfmt = argv[1][3]; |
| 83 | break; |
| 84 | default: |
| 85 | goto userr; |
| 86 | } |
| 87 | ++argv; --argc; |
| 88 | } |
| 89 | if (argc > 1 && (n = strlen(argv[1])-4) > 0) { |
| 90 | if (!strcasecmp(argv[1]+n, ".xml")) |
| 91 | inpXML = 1; |
| 92 | else if (!strcasecmp(argv[1]+n, ".sir")) |
| 93 | inpXML = 0; |
| 94 | } |
| 95 | if ((argc != 2) | (inpXML < 0)) |
| 96 | goto userr; |
| 97 | /* load BSDF representation */ |
| 98 | if (inpXML) { |
| 99 | SDclearBSDF(&myBSDF, argv[1]); |
| 100 | if (SDreportError(SDloadFile(&myBSDF, argv[1]), stderr)) |
| 101 | return(1); |
| 102 | } else { |
| 103 | FILE    *fp = fopen(argv[1], "rb"); |
| 104 | if (fp == NULL) { |
| 105 | fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n", |
| 106 | progname, argv[1]); |
| 107 | return(1); |
| 108 | } |
| 109 | if (!load_bsdf_rep(fp)) |
| 110 | return(1); |
| 111 | fclose(fp); |
| 112 | } |
| 113 | /* query BSDF values */ |
| 114 | while (readIOdir(idir, odir, stdin, inpfmt)) { |
| 115 | SDValue sval; |
| 116 | if (inpXML) { |
| 117 | if (SDreportError(SDevalBSDF(&sval, odir, |
| 118 | idir, &myBSDF), stderr)) |
| 119 | return(1); |
| 120 | } else { |
| 121 | int32   inpDir = encodedir(idir); |
| 122 | if (inpDir != prevInpDir) { |
| 123 | if (idir[2] > 0 ^ input_orient > 0) { |
| 124 | fprintf(stderr, "%s: input hemisphere error\n", |
| 125 | progname); |
| 126 | return(1); |
| 127 | } |
| 128 | if (rbf != NULL) free(rbf); |
| 129 | rbf = advect_rbf(idir, 15000); |
| 130 | prevInpDir = inpDir; |
| 131 | } |
| 132 | if (odir[2] > 0 ^ output_orient > 0) { |
| 133 | fprintf(stderr, "%s: output hemisphere error\n", |
| 134 | progname); |
| 135 | return(1); |
| 136 | } |
| 137 | if (SDreportError(eval_rbfcol(&sval, rbf, odir), stderr)) |
| 138 | return(1); |
| 139 | } |
| 140 |  |
| 141 | switch (outfmt) {               /* write to stdout */ |
| 142 | case 'a': |
| 143 | if (repXYZ) { |
| 144 | double  cieX = sval.spec.cx/sval.spec.cy*sval.cieY; |
| 145 | double  cieZ = (1. - sval.spec.cx - sval.spec.cy) / |
| 146 | sval.spec.cy * sval.cieY; |
| 147 | printf("%.6e %.6e %.6e\n", cieX, sval.cieY, cieZ); |
| 148 | } else |
| 149 | printf("%.6e\n", sval.cieY); |
| 150 | break; |
| 151 | case 'd': |
| 152 | if (repXYZ) { |
| 153 | double  cieXYZ[3]; |
| 154 | cieXYZ[0] = sval.spec.cx/sval.spec.cy*sval.cieY; |
| 155 | cieXYZ[1] = sval.cieY; |
| 156 | cieXYZ[2] = (1. - sval.spec.cx - sval.spec.cy) / |
| 157 | sval.spec.cy * sval.cieY; |
| 158 | putbinary(cieXYZ, sizeof(double), 3, stdout); |
| 159 | } else |
| 160 | putbinary(&sval.cieY, sizeof(double), 1, stdout); |
| 161 | break; |
| 162 | case 'f': |
| 163 | if (repXYZ) { |
| 164 | float   cieXYZ[3]; |
| 165 | cieXYZ[0] = sval.spec.cx/sval.spec.cy*sval.cieY; |
| 166 | cieXYZ[1] = sval.cieY; |
| 167 | cieXYZ[2] = (1. - sval.spec.cx - sval.spec.cy) / |
| 168 | sval.spec.cy * sval.cieY; |
| 169 | putbinary(cieXYZ, sizeof(float), 3, stdout); |
| 170 | } else { |
| 171 | float   cieY = sval.cieY; |
| 172 | putbinary(&cieY, sizeof(float), 1, stdout); |
| 173 | } |
| 174 | break; |
| 175 | } |
| 176 | if (unbuffered) |
| 177 | fflush(stdout); |
| 178 | } |
| 179 | /* if (rbf != NULL) free(rbf); */ |
| 180 | return(0); |
| 181 | userr: |
| 182 | fprintf(stderr, "Usage: %s [-u][-c][-fio] bsdf.{sir|xml}\n", progname); |
| 183 | return(1); |
| 184 | } |
