root/Development/ray/src/cv/bsdfquery.c
Revision: 2.12
Committed: Fri Mar 26 22:01:44 2021 UTC (4 years, 8 months ago) by greg
style: removed stray character
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.12 static const char RCSid[] = "$Id: bsdfquery.c,v 2.11 2019/12/28 18:05:14 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Query values from the given BSDF (scattering interpolant or XML repres.)
6     * Input query is incident and exiting vectors directed away from surface.
7     * We normalize. Output is a BSDF value for the vector pair.
8 greg 2.9 * A zero length in or out vector is ignored, causing output to be flushed.
9 greg 2.1 * It is wise to sort the input directions to keep identical ones together
10     * when using a scattering interpolant representation.
11     */
12
13     #define _USE_MATH_DEFINES
14     #include <stdlib.h>
15     #include "rtmath.h"
16 greg 2.7 #include "rtio.h"
17 greg 2.1 #include "bsdfrep.h"
18
19     char *progname;
20
21     /* Read in a vector pair */
22     static int
23     readIOdir(FVECT idir, FVECT odir, FILE *fp, int fmt)
24     {
25     double dvec[6];
26     float fvec[6];
27 greg 2.9 tryagain:
28 greg 2.1 switch (fmt) {
29     case 'a':
30 greg 2.5 if (fscanf(fp, FVFORMAT, &idir[0], &idir[1], &idir[2]) != 3 ||
31     fscanf(fp, FVFORMAT, &odir[0], &odir[1], &odir[2]) != 3)
32 greg 2.1 return(0);
33     break;
34     case 'd':
35 greg 2.7 if (getbinary(dvec, sizeof(double), 6, fp) != 6)
36 greg 2.1 return(0);
37     VCOPY(idir, dvec);
38     VCOPY(odir, dvec+3);
39     break;
40     case 'f':
41 greg 2.7 if (getbinary(fvec, sizeof(float), 6, fp) != 6)
42 greg 2.1 return(0);
43     VCOPY(idir, fvec);
44     VCOPY(odir, fvec+3);
45     break;
46     }
47     if ((normalize(idir) == 0) | (normalize(odir) == 0)) {
48 greg 2.9 fflush(stdout); /* desired side-effect? */
49     goto tryagain;
50 greg 2.1 }
51     return(1);
52     }
53
54     /* Get BSDF values for the input and output directions given on stdin */
55     int
56     main(int argc, char *argv[])
57     {
58 greg 2.10 int unbuffered = 0;
59 greg 2.6 int repXYZ = 0;
60 greg 2.1 int inpXML = -1;
61     int inpfmt = 'a';
62     int outfmt = 'a';
63     RBFNODE *rbf = NULL;
64     int32 prevInpDir = 0;
65     SDData myBSDF;
66     FVECT idir, odir;
67     int n;
68     /* check arguments */
69     progname = argv[0];
70 greg 2.6 while (argc > 2 && argv[1][0] == '-') {
71     switch (argv[1][1]) {
72 greg 2.12 case 'u': /* unbuffered output */
73 greg 2.10 unbuffered = 1;
74     break;
75 greg 2.6 case 'c': /* color output */
76     repXYZ = 1;
77     break;
78     case 'f': /* i/o format */
79     if (!argv[1][2] || strchr("afd", argv[1][2]) == NULL)
80     goto userr;
81     inpfmt = outfmt = argv[1][2];
82     if (argv[1][3] && strchr("afd", argv[1][3]) != NULL)
83     outfmt = argv[1][3];
84     break;
85     default:
86     goto userr;
87     }
88 greg 2.1 ++argv; --argc;
89     }
90 greg 2.2 if (argc > 1 && (n = strlen(argv[1])-4) > 0) {
91 greg 2.1 if (!strcasecmp(argv[1]+n, ".xml"))
92     inpXML = 1;
93     else if (!strcasecmp(argv[1]+n, ".sir"))
94     inpXML = 0;
95     }
96 greg 2.6 if ((argc != 2) | (inpXML < 0))
97     goto userr;
98 greg 2.1 /* load BSDF representation */
99     if (inpXML) {
100     SDclearBSDF(&myBSDF, argv[1]);
101     if (SDreportError(SDloadFile(&myBSDF, argv[1]), stderr))
102     return(1);
103     } else {
104     FILE *fp = fopen(argv[1], "rb");
105     if (fp == NULL) {
106     fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
107     progname, argv[1]);
108     return(1);
109     }
110     if (!load_bsdf_rep(fp))
111     return(1);
112     fclose(fp);
113     }
114     /* query BSDF values */
115     while (readIOdir(idir, odir, stdin, inpfmt)) {
116 greg 2.6 SDValue sval;
117 greg 2.1 if (inpXML) {
118     if (SDreportError(SDevalBSDF(&sval, odir,
119     idir, &myBSDF), stderr))
120     return(1);
121     } else {
122     int32 inpDir = encodedir(idir);
123     if (inpDir != prevInpDir) {
124     if (idir[2] > 0 ^ input_orient > 0) {
125     fprintf(stderr, "%s: input hemisphere error\n",
126     progname);
127     return(1);
128     }
129     if (rbf != NULL) free(rbf);
130     rbf = advect_rbf(idir, 15000);
131     prevInpDir = inpDir;
132     }
133     if (odir[2] > 0 ^ output_orient > 0) {
134     fprintf(stderr, "%s: output hemisphere error\n",
135     progname);
136     return(1);
137     }
138 greg 2.6 if (SDreportError(eval_rbfcol(&sval, rbf, odir), stderr))
139     return(1);
140 greg 2.1 }
141 greg 2.6
142 greg 2.1 switch (outfmt) { /* write to stdout */
143     case 'a':
144 greg 2.6 if (repXYZ) {
145     double cieX = sval.spec.cx/sval.spec.cy*sval.cieY;
146     double cieZ = (1. - sval.spec.cx - sval.spec.cy) /
147     sval.spec.cy * sval.cieY;
148     printf("%.6e %.6e %.6e\n", cieX, sval.cieY, cieZ);
149     } else
150     printf("%.6e\n", sval.cieY);
151 greg 2.1 break;
152     case 'd':
153 greg 2.6 if (repXYZ) {
154     double cieXYZ[3];
155     cieXYZ[0] = sval.spec.cx/sval.spec.cy*sval.cieY;
156     cieXYZ[1] = sval.cieY;
157     cieXYZ[2] = (1. - sval.spec.cx - sval.spec.cy) /
158     sval.spec.cy * sval.cieY;
159 greg 2.7 putbinary(cieXYZ, sizeof(double), 3, stdout);
160 greg 2.6 } else
161 greg 2.7 putbinary(&sval.cieY, sizeof(double), 1, stdout);
162 greg 2.1 break;
163     case 'f':
164 greg 2.6 if (repXYZ) {
165     float cieXYZ[3];
166     cieXYZ[0] = sval.spec.cx/sval.spec.cy*sval.cieY;
167     cieXYZ[1] = sval.cieY;
168     cieXYZ[2] = (1. - sval.spec.cx - sval.spec.cy) /
169     sval.spec.cy * sval.cieY;
170 greg 2.7 putbinary(cieXYZ, sizeof(float), 3, stdout);
171 greg 2.6 } else {
172     float cieY = sval.cieY;
173 greg 2.7 putbinary(&cieY, sizeof(float), 1, stdout);
174 greg 2.6 }
175 greg 2.1 break;
176     }
177 greg 2.10 if (unbuffered)
178     fflush(stdout);
179 greg 2.1 }
180 greg 2.6 /* if (rbf != NULL) free(rbf); */
181 greg 2.1 return(0);
182 greg 2.6 userr:
183 greg 2.10 fprintf(stderr, "Usage: %s [-u][-c][-fio] bsdf.{sir|xml}\n", progname);
184 greg 2.6 return(1);
185 greg 2.1 }
