root/Development/ray/src/cv/bsdfquery.c
Revision: 2.12
Committed: Fri Mar 26 22:01:44 2021 UTC (4 years, 7 months ago) by greg
style: removed stray character
2 static const char RCSid[] = "$Id: bsdfquery.c,v 2.11 2019/12/28 18:05:14 greg Exp $";
5 * Query values from the given BSDF (scattering interpolant or XML repres.)
6 * Input query is incident and exiting vectors directed away from surface.
7 * We normalize. Output is a BSDF value for the vector pair.
8 * A zero length in or out vector is ignored, causing output to be flushed.
9 * It is wise to sort the input directions to keep identical ones together
10 * when using a scattering interpolant representation.
11 */
12
13 #define _USE_MATH_DEFINES
14 #include <stdlib.h>
15 #include "rtmath.h"
16 #include "rtio.h"
17 #include "bsdfrep.h"
18
19 char *progname;
20
21 /* Read in a vector pair */
22 static int
23 readIOdir(FVECT idir, FVECT odir, FILE *fp, int fmt)
24 {
25 double dvec[6];
26 float fvec[6];
27 tryagain:
28 switch (fmt) {
29 case 'a':
30 if (fscanf(fp, FVFORMAT, &idir[0], &idir[1], &idir[2]) != 3 ||
31 fscanf(fp, FVFORMAT, &odir[0], &odir[1], &odir[2]) != 3)
32 return(0);
33 break;
34 case 'd':
35 if (getbinary(dvec, sizeof(double), 6, fp) != 6)
36 return(0);
37 VCOPY(idir, dvec);
38 VCOPY(odir, dvec+3);
39 break;
40 case 'f':
41 if (getbinary(fvec, sizeof(float), 6, fp) != 6)
42 return(0);
43 VCOPY(idir, fvec);
44 VCOPY(odir, fvec+3);
45 break;
46 }
47 if ((normalize(idir) == 0) | (normalize(odir) == 0)) {
48 fflush(stdout); /* desired side-effect? */
49 goto tryagain;
50 }
51 return(1);
52 }
53
54 /* Get BSDF values for the input and output directions given on stdin */
55 int
56 main(int argc, char *argv[])
57 {
58 int unbuffered = 0;
59 int repXYZ = 0;
60 int inpXML = -1;
61 int inpfmt = 'a';
62 int outfmt = 'a';
63 RBFNODE *rbf = NULL;
64 int32 prevInpDir = 0;
65 SDData myBSDF;
66 FVECT idir, odir;
67 int n;
68 /* check arguments */
69 progname = argv[0];
70 while (argc > 2 && argv[1][0] == '-') {
71 switch (argv[1][1]) {
72 case 'u': /* unbuffered output */
73 unbuffered = 1;
74 break;
75 case 'c': /* color output */
76 repXYZ = 1;
77 break;
78 case 'f': /* i/o format */
79 if (!argv[1][2] || strchr("afd", argv[1][2]) == NULL)
80 goto userr;
81 inpfmt = outfmt = argv[1][2];
82 if (argv[1][3] && strchr("afd", argv[1][3]) != NULL)
83 outfmt = argv[1][3];
84 break;
85 default:
86 goto userr;
87 }
88 ++argv; --argc;
89 }
90 if (argc > 1 && (n = strlen(argv[1])-4) > 0) {
91 if (!strcasecmp(argv[1]+n, ".xml"))
92 inpXML = 1;
93 else if (!strcasecmp(argv[1]+n, ".sir"))
94 inpXML = 0;
95 }
96 if ((argc != 2) | (inpXML < 0))
97 goto userr;
98 /* load BSDF representation */
99 if (inpXML) {
100 SDclearBSDF(&myBSDF, argv[1]);
101 if (SDreportError(SDloadFile(&myBSDF, argv[1]), stderr))
102 return(1);
103 } else {
104 FILE *fp = fopen(argv[1], "rb");
105 if (fp == NULL) {
106 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
107 progname, argv[1]);
108 return(1);
109 }
110 if (!load_bsdf_rep(fp))
111 return(1);
112 fclose(fp);
113 }
114 /* query BSDF values */
115 while (readIOdir(idir, odir, stdin, inpfmt)) {
116 SDValue sval;
117 if (inpXML) {
118 if (SDreportError(SDevalBSDF(&sval, odir,
119 idir, &myBSDF), stderr))
120 return(1);
121 } else {
122 int32 inpDir = encodedir(idir);
123 if (inpDir != prevInpDir) {
124 if (idir[2] > 0 ^ input_orient > 0) {
125 fprintf(stderr, "%s: input hemisphere error\n",
126 progname);
127 return(1);
128 }
129 if (rbf != NULL) free(rbf);
130 rbf = advect_rbf(idir, 15000);
131 prevInpDir = inpDir;
132 }
133 if (odir[2] > 0 ^ output_orient > 0) {
134 fprintf(stderr, "%s: output hemisphere error\n",
135 progname);
136 return(1);
137 }
138 if (SDreportError(eval_rbfcol(&sval, rbf, odir), stderr))
139 return(1);
140 }
141
142 switch (outfmt) { /* write to stdout */
143 case 'a':
144 if (repXYZ) {
145 double cieX = sval.spec.cx/sval.spec.cy*sval.cieY;
146 double cieZ = (1. - sval.spec.cx - sval.spec.cy) /
147 sval.spec.cy * sval.cieY;
148 printf("%.6e %.6e %.6e\n", cieX, sval.cieY, cieZ);
149 } else
150 printf("%.6e\n", sval.cieY);
151 break;
152 case 'd':
153 if (repXYZ) {
154 double cieXYZ[3];
155 cieXYZ[0] = sval.spec.cx/sval.spec.cy*sval.cieY;
156 cieXYZ[1] = sval.cieY;
157 cieXYZ[2] = (1. - sval.spec.cx - sval.spec.cy) /
158 sval.spec.cy * sval.cieY;
159 putbinary(cieXYZ, sizeof(double), 3, stdout);
160 } else
161 putbinary(&sval.cieY, sizeof(double), 1, stdout);
162 break;
163 case 'f':
164 if (repXYZ) {
165 float cieXYZ[3];
166 cieXYZ[0] = sval.spec.cx/sval.spec.cy*sval.cieY;
167 cieXYZ[1] = sval.cieY;
168 cieXYZ[2] = (1. - sval.spec.cx - sval.spec.cy) /
169 sval.spec.cy * sval.cieY;
170 putbinary(cieXYZ, sizeof(float), 3, stdout);
171 } else {
172 float cieY = sval.cieY;
173 putbinary(&cieY, sizeof(float), 1, stdout);
174 }
175 break;
176 }
177 if (unbuffered)
178 fflush(stdout);
179 }
180 /* if (rbf != NULL) free(rbf); */
181 return(0);
182 userr:
183 fprintf(stderr, "Usage: %s [-u][-c][-fio] bsdf.{sir|xml}\n", progname);
184 return(1);
185 }
