| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: bsdfquery.c,v 2.1 2013/11/21 23:57:28 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Query values from the given BSDF (scattering interpolant or XML repres.)
| 6 |
* Input query is incident and exiting vectors directed away from surface.
| 7 |
* We normalize. Output is a BSDF value for the vector pair.
| 8 |
* It is wise to sort the input directions to keep identical ones together
| 9 |
* when using a scattering interpolant representation.
| 10 |
| 11 |
| 12 |
#define _USE_MATH_DEFINES
| 13 |
#include <stdio.h>
| 14 |
#include <string.h>
| 15 |
#include <stdlib.h>
| 16 |
#include "rtmath.h"
| 17 |
#include "bsdfrep.h"
| 18 |
| 19 |
char *progname;
| 20 |
| 21 |
/* Read in a vector pair */
| 22 |
static int
| 23 |
readIOdir(FVECT idir, FVECT odir, FILE *fp, int fmt)
| 24 |
| 25 |
double dvec[6];
| 26 |
float fvec[6];
| 27 |
| 28 |
switch (fmt) {
| 29 |
case 'a':
| 30 |
if (fscanf(fp, "%lf %lf %lf %lf %lf %lf",
| 31 |
dvec, dvec+1, dvec+2, dvec+3, dvec+4, dvec+5) != 6)
| 32 |
return(0);
| 33 |
VCOPY(idir, dvec);
| 34 |
VCOPY(odir, dvec+3);
| 35 |
break;
| 36 |
case 'd':
| 37 |
if (fread(dvec, sizeof(double), 6, fp) != 6)
| 38 |
return(0);
| 39 |
VCOPY(idir, dvec);
| 40 |
| 41 |
break;
| 42 |
case 'f':
| 43 |
if (fread(fvec, sizeof(float), 6, fp) != 6)
| 44 |
return(0);
| 45 |
VCOPY(idir, fvec);
| 46 |
VCOPY(odir, fvec+3);
| 47 |
break;
| 48 |
| 49 |
if ((normalize(idir) == 0) | (normalize(odir) == 0)) {
| 50 |
fprintf(stderr, "%s: zero input vector!\n", progname);
| 51 |
return(0);
| 52 |
| 53 |
return(1);
| 54 |
| 55 |
| 56 |
/* Get BSDF values for the input and output directions given on stdin */
| 57 |
int
| 58 |
main(int argc, char *argv[])
| 59 |
| 60 |
int inpXML = -1;
| 61 |
int inpfmt = 'a';
| 62 |
int outfmt = 'a';
| 63 |
RBFNODE *rbf = NULL;
| 64 |
int32 prevInpDir = 0;
| 65 |
SDData myBSDF;
| 66 |
FVECT idir, odir;
| 67 |
int n;
| 68 |
/* check arguments */
| 69 |
progname = argv[0];
| 70 |
if (argc > 2 && argv[1][0] == '-' && argv[1][1] == 'f' &&
| 71 |
argv[1][2] && strchr("afd", argv[1][2]) != NULL) {
| 72 |
inpfmt = outfmt = argv[1][2];
| 73 |
if (argv[1][3] && strchr("afd", argv[1][3]) != NULL)
| 74 |
outfmt = argv[1][3];
| 75 |
++argv; --argc;
| 76 |
| 77 |
if (argc > 1 && (n = strlen(argv[1])-4) > 0) {
| 78 |
if (!strcasecmp(argv[1]+n, ".xml"))
| 79 |
inpXML = 1;
| 80 |
else if (!strcasecmp(argv[1]+n, ".sir"))
| 81 |
inpXML = 0;
| 82 |
| 83 |
if ((argc != 2) | (inpXML < 0)) {
| 84 |
fprintf(stderr, "Usage: %s [-fio] bsdf.{sir|xml}\n", progname);
| 85 |
return(1);
| 86 |
| 87 |
/* load BSDF representation */
| 88 |
if (inpXML) {
| 89 |
SDclearBSDF(&myBSDF, argv[1]);
| 90 |
if (SDreportError(SDloadFile(&myBSDF, argv[1]), stderr))
| 91 |
return(1);
| 92 |
} else {
| 93 |
FILE *fp = fopen(argv[1], "rb");
| 94 |
if (fp == NULL) {
| 95 |
fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
| 96 |
progname, argv[1]);
| 97 |
return(1);
| 98 |
| 99 |
if (!load_bsdf_rep(fp))
| 100 |
return(1);
| 101 |
fclose(fp);
| 102 |
| 103 |
/* query BSDF values */
| 104 |
while (readIOdir(idir, odir, stdin, inpfmt)) {
| 105 |
double bsdf;
| 106 |
float fval;
| 107 |
if (inpXML) {
| 108 |
SDValue sval;
| 109 |
if (SDreportError(SDevalBSDF(&sval, odir,
| 110 |
idir, &myBSDF), stderr))
| 111 |
return(1);
| 112 |
bsdf = sval.cieY;
| 113 |
} else {
| 114 |
int32 inpDir = encodedir(idir);
| 115 |
if (inpDir != prevInpDir) {
| 116 |
if (idir[2] > 0 ^ input_orient > 0) {
| 117 |
fprintf(stderr, "%s: input hemisphere error\n",
| 118 |
progname);
| 119 |
return(1);
| 120 |
| 121 |
if (rbf != NULL) free(rbf);
| 122 |
rbf = advect_rbf(idir, 15000);
| 123 |
prevInpDir = inpDir;
| 124 |
| 125 |
if (odir[2] > 0 ^ output_orient > 0) {
| 126 |
fprintf(stderr, "%s: output hemisphere error\n",
| 127 |
progname);
| 128 |
return(1);
| 129 |
| 130 |
bsdf = eval_rbfrep(rbf, odir)/(output_orient*odir[2]);
| 131 |
| 132 |
switch (outfmt) { /* write to stdout */
| 133 |
case 'a':
| 134 |
printf("%.6e\n", bsdf);
| 135 |
break;
| 136 |
case 'd':
| 137 |
fwrite(&bsdf, sizeof(double), 1, stdout);
| 138 |
break;
| 139 |
case 'f':
| 140 |
fval = bsdf;
| 141 |
fwrite(&fval, sizeof(float), 1, stdout);
| 142 |
break;
| 143 |
| 144 |
| 145 |
return(0);
| 146 |
