root/radiance/ray/src/cv/bsdfquery.c
Revision: 2.10
Committed: Tue Jun 11 16:09:40 2019 UTC (5 years, 11 months ago) by greg
Changes since 2.9: +8 -2 lines
Added -u option for unbuffered output
2 static const char RCSid[] = "$Id: bsdfquery.c,v 2.9 2017/04/13 00:14:36 greg Exp $";
5 * Query values from the given BSDF (scattering interpolant or XML repres.)
6 * Input query is incident and exiting vectors directed away from surface.
7 * We normalize. Output is a BSDF value for the vector pair.
8 * A zero length in or out vector is ignored, causing output to be flushed.
9 * It is wise to sort the input directions to keep identical ones together
10 * when using a scattering interpolant representation.
11 */
12
13 #define _USE_MATH_DEFINES
14 #include <stdio.h>
15 #include <string.h>
16 #include <stdlib.h>
17 #include "rtmath.h"
18 #include "rtio.h"
19 #include "bsdfrep.h"
20
21 char *progname;
22
23 /* Read in a vector pair */
24 static int
25 readIOdir(FVECT idir, FVECT odir, FILE *fp, int fmt)
26 {
27 double dvec[6];
28 float fvec[6];
29 tryagain:
30 switch (fmt) {
31 case 'a':
32 if (fscanf(fp, FVFORMAT, &idir[0], &idir[1], &idir[2]) != 3 ||
33 fscanf(fp, FVFORMAT, &odir[0], &odir[1], &odir[2]) != 3)
34 return(0);
35 break;
36 case 'd':
37 if (getbinary(dvec, sizeof(double), 6, fp) != 6)
38 return(0);
39 VCOPY(idir, dvec);
40 VCOPY(odir, dvec+3);
41 break;
42 case 'f':
43 if (getbinary(fvec, sizeof(float), 6, fp) != 6)
44 return(0);
45 VCOPY(idir, fvec);
46 VCOPY(odir, fvec+3);
47 break;
48 }
49 if ((normalize(idir) == 0) | (normalize(odir) == 0)) {
50 fflush(stdout); /* desired side-effect? */
51 goto tryagain;
52 }
53 return(1);
54 }
55
56 /* Get BSDF values for the input and output directions given on stdin */
57 int
58 main(int argc, char *argv[])
59 {
60 int unbuffered = 0;
61 int repXYZ = 0;
62 int inpXML = -1;
63 int inpfmt = 'a';
64 int outfmt = 'a';
65 RBFNODE *rbf = NULL;
66 int32 prevInpDir = 0;
67 SDData myBSDF;
68 FVECT idir, odir;
69 int n;
70 /* check arguments */
71 progname = argv[0];
72 while (argc > 2 && argv[1][0] == '-') {
73 switch (argv[1][1]) {
74 case 'u': /* unbuffered output */\
75 unbuffered = 1;
76 break;
77 case 'c': /* color output */
78 repXYZ = 1;
79 break;
80 case 'f': /* i/o format */
81 if (!argv[1][2] || strchr("afd", argv[1][2]) == NULL)
82 goto userr;
83 inpfmt = outfmt = argv[1][2];
84 if (argv[1][3] && strchr("afd", argv[1][3]) != NULL)
85 outfmt = argv[1][3];
86 break;
87 default:
88 goto userr;
89 }
90 ++argv; --argc;
91 }
92 if (argc > 1 && (n = strlen(argv[1])-4) > 0) {
93 if (!strcasecmp(argv[1]+n, ".xml"))
94 inpXML = 1;
95 else if (!strcasecmp(argv[1]+n, ".sir"))
96 inpXML = 0;
97 }
98 if ((argc != 2) | (inpXML < 0))
99 goto userr;
100 /* load BSDF representation */
101 if (inpXML) {
102 SDclearBSDF(&myBSDF, argv[1]);
103 if (SDreportError(SDloadFile(&myBSDF, argv[1]), stderr))
104 return(1);
105 } else {
106 FILE *fp = fopen(argv[1], "rb");
107 if (fp == NULL) {
108 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
109 progname, argv[1]);
110 return(1);
111 }
112 if (!load_bsdf_rep(fp))
113 return(1);
114 fclose(fp);
115 }
116 /* query BSDF values */
117 while (readIOdir(idir, odir, stdin, inpfmt)) {
118 SDValue sval;
119 if (inpXML) {
120 if (SDreportError(SDevalBSDF(&sval, odir,
121 idir, &myBSDF), stderr))
122 return(1);
123 } else {
124 int32 inpDir = encodedir(idir);
125 if (inpDir != prevInpDir) {
126 if (idir[2] > 0 ^ input_orient > 0) {
127 fprintf(stderr, "%s: input hemisphere error\n",
128 progname);
129 return(1);
130 }
131 if (rbf != NULL) free(rbf);
132 rbf = advect_rbf(idir, 15000);
133 prevInpDir = inpDir;
134 }
135 if (odir[2] > 0 ^ output_orient > 0) {
136 fprintf(stderr, "%s: output hemisphere error\n",
137 progname);
138 return(1);
139 }
140 if (SDreportError(eval_rbfcol(&sval, rbf, odir), stderr))
141 return(1);
142 }
143
144 switch (outfmt) { /* write to stdout */
145 case 'a':
146 if (repXYZ) {
147 double cieX = sval.spec.cx/sval.spec.cy*sval.cieY;
148 double cieZ = (1. - sval.spec.cx - sval.spec.cy) /
149 sval.spec.cy * sval.cieY;
150 printf("%.6e %.6e %.6e\n", cieX, sval.cieY, cieZ);
151 } else
152 printf("%.6e\n", sval.cieY);
153 break;
154 case 'd':
155 if (repXYZ) {
156 double cieXYZ[3];
157 cieXYZ[0] = sval.spec.cx/sval.spec.cy*sval.cieY;
158 cieXYZ[1] = sval.cieY;
159 cieXYZ[2] = (1. - sval.spec.cx - sval.spec.cy) /
160 sval.spec.cy * sval.cieY;
161 putbinary(cieXYZ, sizeof(double), 3, stdout);
162 } else
163 putbinary(&sval.cieY, sizeof(double), 1, stdout);
164 break;
165 case 'f':
166 if (repXYZ) {
167 float cieXYZ[3];
168 cieXYZ[0] = sval.spec.cx/sval.spec.cy*sval.cieY;
169 cieXYZ[1] = sval.cieY;
170 cieXYZ[2] = (1. - sval.spec.cx - sval.spec.cy) /
171 sval.spec.cy * sval.cieY;
172 putbinary(cieXYZ, sizeof(float), 3, stdout);
173 } else {
174 float cieY = sval.cieY;
175 putbinary(&cieY, sizeof(float), 1, stdout);
176 }
177 break;
178 }
179 if (unbuffered)
180 fflush(stdout);
181 }
182 /* if (rbf != NULL) free(rbf); */
183 return(0);
184 userr:
185 fprintf(stderr, "Usage: %s [-u][-c][-fio] bsdf.{sir|xml}\n", progname);
186 return(1);
187 }
