root/radiance/ray/src/cv/bsdfquery.c
Revision: 2.14
Committed: Sat Jun 7 05:09:45 2025 UTC (8 weeks, 2 days ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.13: +1 -2 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.14 static const char RCSid[] = "$Id: bsdfquery.c,v 2.13 2025/06/03 21:31:51 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Query values from the given BSDF (scattering interpolant or XML repres.)
6     * Input query is incident and exiting vectors directed away from surface.
7     * We normalize. Output is a BSDF value for the vector pair.
8 greg 2.9 * A zero length in or out vector is ignored, causing output to be flushed.
9 greg 2.1 * It is wise to sort the input directions to keep identical ones together
10     * when using a scattering interpolant representation.
11     */
12
13     #define _USE_MATH_DEFINES
14     #include <stdlib.h>
15     #include "rtmath.h"
16 greg 2.7 #include "rtio.h"
17 greg 2.1 #include "bsdfrep.h"
18
19     /* Read in a vector pair */
20     static int
21     readIOdir(FVECT idir, FVECT odir, FILE *fp, int fmt)
22     {
23     double dvec[6];
24     float fvec[6];
25 greg 2.9 tryagain:
26 greg 2.1 switch (fmt) {
27     case 'a':
28 greg 2.5 if (fscanf(fp, FVFORMAT, &idir[0], &idir[1], &idir[2]) != 3 ||
29     fscanf(fp, FVFORMAT, &odir[0], &odir[1], &odir[2]) != 3)
30 greg 2.1 return(0);
31     break;
32     case 'd':
33 greg 2.7 if (getbinary(dvec, sizeof(double), 6, fp) != 6)
34 greg 2.1 return(0);
35     VCOPY(idir, dvec);
36     VCOPY(odir, dvec+3);
37     break;
38     case 'f':
39 greg 2.7 if (getbinary(fvec, sizeof(float), 6, fp) != 6)
40 greg 2.1 return(0);
41     VCOPY(idir, fvec);
42     VCOPY(odir, fvec+3);
43     break;
44     }
45     if ((normalize(idir) == 0) | (normalize(odir) == 0)) {
46 greg 2.9 fflush(stdout); /* desired side-effect? */
47     goto tryagain;
48 greg 2.1 }
49     return(1);
50     }
51
52     /* Get BSDF values for the input and output directions given on stdin */
53     int
54     main(int argc, char *argv[])
55     {
56 greg 2.10 int unbuffered = 0;
57 greg 2.6 int repXYZ = 0;
58 greg 2.1 int inpXML = -1;
59     int inpfmt = 'a';
60     int outfmt = 'a';
61     RBFNODE *rbf = NULL;
62     int32 prevInpDir = 0;
63     SDData myBSDF;
64     FVECT idir, odir;
65     int n;
66 greg 2.13 /* set global progname */
67     fixargv0(argv[0]);
68 greg 2.1 /* check arguments */
69 greg 2.6 while (argc > 2 && argv[1][0] == '-') {
70     switch (argv[1][1]) {
71 greg 2.12 case 'u': /* unbuffered output */
72 greg 2.10 unbuffered = 1;
73     break;
74 greg 2.6 case 'c': /* color output */
75     repXYZ = 1;
76     break;
77     case 'f': /* i/o format */
78     if (!argv[1][2] || strchr("afd", argv[1][2]) == NULL)
79     goto userr;
80     inpfmt = outfmt = argv[1][2];
81     if (argv[1][3] && strchr("afd", argv[1][3]) != NULL)
82     outfmt = argv[1][3];
83     break;
84     default:
85     goto userr;
86     }
87 greg 2.1 ++argv; --argc;
88     }
89 greg 2.2 if (argc > 1 && (n = strlen(argv[1])-4) > 0) {
90 greg 2.1 if (!strcasecmp(argv[1]+n, ".xml"))
91     inpXML = 1;
92     else if (!strcasecmp(argv[1]+n, ".sir"))
93     inpXML = 0;
94     }
95 greg 2.6 if ((argc != 2) | (inpXML < 0))
96     goto userr;
97 greg 2.1 /* load BSDF representation */
98     if (inpXML) {
99     SDclearBSDF(&myBSDF, argv[1]);
100     if (SDreportError(SDloadFile(&myBSDF, argv[1]), stderr))
101     return(1);
102     } else {
103     FILE *fp = fopen(argv[1], "rb");
104     if (fp == NULL) {
105     fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
106     progname, argv[1]);
107     return(1);
108     }
109     if (!load_bsdf_rep(fp))
110     return(1);
111     fclose(fp);
112     }
113     /* query BSDF values */
114     while (readIOdir(idir, odir, stdin, inpfmt)) {
115 greg 2.6 SDValue sval;
116 greg 2.1 if (inpXML) {
117     if (SDreportError(SDevalBSDF(&sval, odir,
118     idir, &myBSDF), stderr))
119     return(1);
120     } else {
121     int32 inpDir = encodedir(idir);
122     if (inpDir != prevInpDir) {
123     if (idir[2] > 0 ^ input_orient > 0) {
124     fprintf(stderr, "%s: input hemisphere error\n",
125     progname);
126     return(1);
127     }
128     if (rbf != NULL) free(rbf);
129     rbf = advect_rbf(idir, 15000);
130     prevInpDir = inpDir;
131     }
132     if (odir[2] > 0 ^ output_orient > 0) {
133     fprintf(stderr, "%s: output hemisphere error\n",
134     progname);
135     return(1);
136     }
137 greg 2.6 if (SDreportError(eval_rbfcol(&sval, rbf, odir), stderr))
138     return(1);
139 greg 2.1 }
140 greg 2.6
141 greg 2.1 switch (outfmt) { /* write to stdout */
142     case 'a':
143 greg 2.6 if (repXYZ) {
144     double cieX = sval.spec.cx/sval.spec.cy*sval.cieY;
145     double cieZ = (1. - sval.spec.cx - sval.spec.cy) /
146     sval.spec.cy * sval.cieY;
147     printf("%.6e %.6e %.6e\n", cieX, sval.cieY, cieZ);
148     } else
149     printf("%.6e\n", sval.cieY);
150 greg 2.1 break;
151     case 'd':
152 greg 2.6 if (repXYZ) {
153     double cieXYZ[3];
154     cieXYZ[0] = sval.spec.cx/sval.spec.cy*sval.cieY;
155     cieXYZ[1] = sval.cieY;
156     cieXYZ[2] = (1. - sval.spec.cx - sval.spec.cy) /
157     sval.spec.cy * sval.cieY;
158 greg 2.7 putbinary(cieXYZ, sizeof(double), 3, stdout);
159 greg 2.6 } else
160 greg 2.7 putbinary(&sval.cieY, sizeof(double), 1, stdout);
161 greg 2.1 break;
162     case 'f':
163 greg 2.6 if (repXYZ) {
164     float cieXYZ[3];
165     cieXYZ[0] = sval.spec.cx/sval.spec.cy*sval.cieY;
166     cieXYZ[1] = sval.cieY;
167     cieXYZ[2] = (1. - sval.spec.cx - sval.spec.cy) /
168     sval.spec.cy * sval.cieY;
169 greg 2.7 putbinary(cieXYZ, sizeof(float), 3, stdout);
170 greg 2.6 } else {
171     float cieY = sval.cieY;
172 greg 2.7 putbinary(&cieY, sizeof(float), 1, stdout);
173 greg 2.6 }
174 greg 2.1 break;
175     }
176 greg 2.10 if (unbuffered)
177     fflush(stdout);
178 greg 2.1 }
179 greg 2.6 /* if (rbf != NULL) free(rbf); */
180 greg 2.1 return(0);
181 greg 2.6 userr:
182 greg 2.10 fprintf(stderr, "Usage: %s [-u][-c][-fio] bsdf.{sir|xml}\n", progname);
183 greg 2.6 return(1);
184 greg 2.1 }
