root/radiance/ray/src/cv/bsdfquery.c
Revision: 2.9
Committed: Thu Apr 13 00:14:36 2017 UTC (8 years, 2 months ago) by greg
CVS Tags: rad5R2, rad5R1
Changes since 2.8: +5 -4 lines
Added value flushing to bsdfquery and put in standard build
2 static const char RCSid[] = "$Id: bsdfquery.c,v 2.8 2017/02/06 23:21:32 greg Exp $";
5 * Query values from the given BSDF (scattering interpolant or XML repres.)
6 * Input query is incident and exiting vectors directed away from surface.
7 * We normalize. Output is a BSDF value for the vector pair.
8 * A zero length in or out vector is ignored, causing output to be flushed.
9 * It is wise to sort the input directions to keep identical ones together
10 * when using a scattering interpolant representation.
11 */
12
13 #define _USE_MATH_DEFINES
14 #include <stdio.h>
15 #include <string.h>
16 #include <stdlib.h>
17 #include "rtmath.h"
18 #include "rtio.h"
19 #include "bsdfrep.h"
20
21 char *progname;
22
23 /* Read in a vector pair */
24 static int
25 readIOdir(FVECT idir, FVECT odir, FILE *fp, int fmt)
26 {
27 double dvec[6];
28 float fvec[6];
29 tryagain:
30 switch (fmt) {
31 case 'a':
32 if (fscanf(fp, FVFORMAT, &idir[0], &idir[1], &idir[2]) != 3 ||
33 fscanf(fp, FVFORMAT, &odir[0], &odir[1], &odir[2]) != 3)
34 return(0);
35 break;
36 case 'd':
37 if (getbinary(dvec, sizeof(double), 6, fp) != 6)
38 return(0);
39 VCOPY(idir, dvec);
40 VCOPY(odir, dvec+3);
41 break;
42 case 'f':
43 if (getbinary(fvec, sizeof(float), 6, fp) != 6)
44 return(0);
45 VCOPY(idir, fvec);
46 VCOPY(odir, fvec+3);
47 break;
48 }
49 if ((normalize(idir) == 0) | (normalize(odir) == 0)) {
50 fflush(stdout); /* desired side-effect? */
51 goto tryagain;
52 }
53 return(1);
54 }
55
56 /* Get BSDF values for the input and output directions given on stdin */
57 int
58 main(int argc, char *argv[])
59 {
60 int repXYZ = 0;
61 int inpXML = -1;
62 int inpfmt = 'a';
63 int outfmt = 'a';
64 RBFNODE *rbf = NULL;
65 int32 prevInpDir = 0;
66 SDData myBSDF;
67 FVECT idir, odir;
68 int n;
69 /* check arguments */
70 progname = argv[0];
71 while (argc > 2 && argv[1][0] == '-') {
72 switch (argv[1][1]) {
73 case 'c': /* color output */
74 repXYZ = 1;
75 break;
76 case 'f': /* i/o format */
77 if (!argv[1][2] || strchr("afd", argv[1][2]) == NULL)
78 goto userr;
79 inpfmt = outfmt = argv[1][2];
80 if (argv[1][3] && strchr("afd", argv[1][3]) != NULL)
81 outfmt = argv[1][3];
82 break;
83 default:
84 goto userr;
85 }
86 ++argv; --argc;
87 }
88 if (argc > 1 && (n = strlen(argv[1])-4) > 0) {
89 if (!strcasecmp(argv[1]+n, ".xml"))
90 inpXML = 1;
91 else if (!strcasecmp(argv[1]+n, ".sir"))
92 inpXML = 0;
93 }
94 if ((argc != 2) | (inpXML < 0))
95 goto userr;
96 /* load BSDF representation */
97 if (inpXML) {
98 SDclearBSDF(&myBSDF, argv[1]);
99 if (SDreportError(SDloadFile(&myBSDF, argv[1]), stderr))
100 return(1);
101 } else {
102 FILE *fp = fopen(argv[1], "rb");
103 if (fp == NULL) {
104 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
105 progname, argv[1]);
106 return(1);
107 }
108 if (!load_bsdf_rep(fp))
109 return(1);
110 fclose(fp);
111 }
112 /* query BSDF values */
113 while (readIOdir(idir, odir, stdin, inpfmt)) {
114 SDValue sval;
115 if (inpXML) {
116 if (SDreportError(SDevalBSDF(&sval, odir,
117 idir, &myBSDF), stderr))
118 return(1);
119 } else {
120 int32 inpDir = encodedir(idir);
121 if (inpDir != prevInpDir) {
122 if (idir[2] > 0 ^ input_orient > 0) {
123 fprintf(stderr, "%s: input hemisphere error\n",
124 progname);
125 return(1);
126 }
127 if (rbf != NULL) free(rbf);
128 rbf = advect_rbf(idir, 15000);
129 prevInpDir = inpDir;
130 }
131 if (odir[2] > 0 ^ output_orient > 0) {
132 fprintf(stderr, "%s: output hemisphere error\n",
133 progname);
134 return(1);
135 }
136 if (SDreportError(eval_rbfcol(&sval, rbf, odir), stderr))
137 return(1);
138 }
139
140 switch (outfmt) { /* write to stdout */
141 case 'a':
142 if (repXYZ) {
143 double cieX = sval.spec.cx/sval.spec.cy*sval.cieY;
144 double cieZ = (1. - sval.spec.cx - sval.spec.cy) /
145 sval.spec.cy * sval.cieY;
146 printf("%.6e %.6e %.6e\n", cieX, sval.cieY, cieZ);
147 } else
148 printf("%.6e\n", sval.cieY);
149 break;
150 case 'd':
151 if (repXYZ) {
152 double cieXYZ[3];
153 cieXYZ[0] = sval.spec.cx/sval.spec.cy*sval.cieY;
154 cieXYZ[1] = sval.cieY;
155 cieXYZ[2] = (1. - sval.spec.cx - sval.spec.cy) /
156 sval.spec.cy * sval.cieY;
157 putbinary(cieXYZ, sizeof(double), 3, stdout);
158 } else
159 putbinary(&sval.cieY, sizeof(double), 1, stdout);
160 break;
161 case 'f':
162 if (repXYZ) {
163 float cieXYZ[3];
164 cieXYZ[0] = sval.spec.cx/sval.spec.cy*sval.cieY;
165 cieXYZ[1] = sval.cieY;
166 cieXYZ[2] = (1. - sval.spec.cx - sval.spec.cy) /
167 sval.spec.cy * sval.cieY;
168 putbinary(cieXYZ, sizeof(float), 3, stdout);
169 } else {
170 float cieY = sval.cieY;
171 putbinary(&cieY, sizeof(float), 1, stdout);
172 }
173 break;
174 }
175 }
176 /* if (rbf != NULL) free(rbf); */
177 return(0);
178 userr:
179 fprintf(stderr, "Usage: %s [-c][-fio] bsdf.{sir|xml}\n", progname);
180 return(1);
181 }
