root/radiance/ray/src/cv/bsdfpeaks.c
Revision: 2.6
Committed: Sat Jun 7 05:09:45 2025 UTC (8 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.5: +1 -2 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.6 static const char RCSid[] = "$Id: bsdfpeaks.c,v 2.5 2025/06/03 21:31:51 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Compute minimum FWHM peak for each incident direction in SIR input.
6     * Report FWHM of corresponding peaks in XML representations if provided.
7     */
8
9     #define _USE_MATH_DEFINES
10     #include <stdio.h>
11     #include <stdlib.h>
12     #include <math.h>
13     #include "bsdfrep.h"
14
15     typedef struct {
16 greg 2.3 float peakv; /* peak BSDF value */
17     float width; /* smallest FWHM (deg) */
18     const RBFNODE *rbs; /* incident system */
19     int ndx; /* peak index for RBFVAL */
20 greg 2.1 } FWHM; /* struct to hold peak value */
21
22 greg 2.2 typedef double eval_f(const FVECT vin, const FVECT vout, const void *p);
23 greg 2.1
24     /* Comparison function to put larger peaks first */
25     int
26     cmpFWHM(const void *p0, const void *p1)
27     {
28     float diff = (*(const FWHM *)p0).peakv -
29     (*(const FWHM *)p1).peakv;
30
31     if (diff > 0) return(-1);
32     if (diff < 0) return(1);
33     return(0);
34     }
35
36     /* BSDF evaluation function for RBF system */
37     double
38 greg 2.2 rbf_eval(const FVECT vin, const FVECT vout, const void *p)
39 greg 2.1 {
40     /* XXX verify vin == p->invec ? */
41 greg 2.2 return(eval_rbfrep((const RBFNODE *)p, vout));
42 greg 2.1 }
43
44     /* BSDF evaluation for XML input */
45     double
46 greg 2.2 bsdf_eval(const FVECT vin, const FVECT vout, const void *p)
47 greg 2.1 {
48     SDValue sv;
49
50     if (SDreportError(
51 greg 2.2 SDevalBSDF(&sv, vin, vout, (const SDData *)p),
52 greg 2.1 stderr))
53     exit(1);
54
55     return(sv.cieY);
56     }
57
58     /* Find full-width, half-maximum in radians around BSDF direction */
59     double
60 greg 2.2 getFWHM(const FVECT vin, const FVECT vc, double rad0, eval_f *ev, const void *p)
61 greg 2.1 {
62     const double peakv = (*ev)(vin, vc, p);
63     double rad1 = rad0; /* current radii */
64
65     while (rad0 < M_PI/2.) { /* look for FWHM */
66     FVECT v0, vt;
67     double phi;
68     v0[0] = 1; v0[1] = v0[2] = 0;
69     geodesic(v0, vc, v0, rad0, GEOD_RAD); /* use vc as pivot */
70     for (phi = 0; phi < 2.*M_PI; phi += M_PI/18.) {
71     spinvector(vt, v0, vc, phi);
72     if ((*ev)(vin, vt, p) <= .5*peakv) { /* found one side? */
73     FVECT vt1;
74 greg 2.2 while (rad1 < M_PI/2.) { /* bracket peak */
75 greg 2.1 geodesic(vt1, vt, vc, rad0+rad1, GEOD_RAD);
76     if ((*ev)(vin, vt1, p) <= .5*peakv)
77     return(rad0+rad1); /* got both! */
78     rad1 *= 1.05; /* else bump rad1 */
79     }
80     }
81     }
82     rad1 = rad0 *= 1.05; /* or expand search */
83     }
84     return(M_PI); /* failure return */
85     }
86
87     /* Get outgoing direction for the given FWHM record */
88     void
89     getOutDir(FVECT vo, FWHM *dp)
90     {
91 greg 2.3 const RBFVAL *vp = dp->rbs->rbfa + dp->ndx;
92 greg 2.1
93     ovec_from_pos(vo, vp->gx, vp->gy);
94     }
95
96     /* Assign FWHM record for specified RBF system */
97     void
98 greg 2.3 assignFWHM(FWHM *dp, const RBFNODE *rbf)
99 greg 2.1 {
100     FVECT vo;
101     int j;
102     double rad;
103
104     dp->rbs = rbf;
105     dp->ndx = 0; /* find peak outgoing */
106     for (j = rbf->nrbf; --j; )
107     if (rbf->rbfa[j].peak > rbf->rbfa[dp->ndx].peak)
108     dp->ndx = j;
109     /* record peak */
110     getOutDir(vo, dp);
111     dp->peakv = eval_rbfrep(rbf, vo);
112     /* get FWHM angle in degrees */
113     dp->width = 180./M_PI * getFWHM(rbf->invec, vo,
114     R2ANG(rbf->rbfa[dp->ndx].crad),
115     rbf_eval, rbf);
116     }
117
118     /* Evaluate FWHM for each incident direction recorded in SIR */
119     int
120     main(int argc, char *argv[])
121     {
122 greg 2.3 const RBFNODE *rbf;
123     SDData *sdp;
124     FILE *fp;
125     int ndirs;
126     FWHM *peaka;
127     int i;
128 greg 2.5 /* set global progname */
129     fixargv0(argv[0]);
130 greg 2.1 if (argc < 2)
131     goto userr;
132
133     fp = fopen(argv[1], "rb"); /* load SIR input */
134     if (fp == NULL) {
135     fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
136     progname, argv[1]);
137     return(1);
138     }
139     if (!load_bsdf_rep(fp))
140     return(1);
141     fclose(fp);
142     for (i = 2; i < argc; i++) /* check/load any XMLs */
143     if (SDcacheFile(argv[i]) == NULL)
144     return(1);
145     ndirs = 0; /* count input directions */
146     for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) {
147     if (rbf->nrbf <= 0) {
148     ndirs = 0;
149     break;
150     }
151     ++ndirs;
152     }
153     if (!ndirs) {
154     fprintf(stderr, "%s: missing/bad RBFs in '%s'\n", progname, argv[1]);
155     return(1);
156     }
157     /* print output header */
158     printf("%d incident directions in '%s': %s -> %s\n", ndirs, argv[1],
159     input_orient>0 ? "Front" : "Back",
160     output_orient>0 ? "Front" : "Back");
161     fputs("Incident (theta, phi)\tExiting (theta, phi)\tPeak\tFWHM", stdout);
162     for (i = 2; i < argc; i++)
163     printf("\t'%s'", argv[i]);
164     fputc('\n', stdout);
165     /* find SIR peaks */
166     peaka = (FWHM *)malloc(sizeof(FWHM)*ndirs);
167     if (peaka == NULL) return(1);
168     for (i = 0, rbf = dsf_list; i < ndirs; i++, rbf = rbf->next)
169     assignFWHM(&peaka[i], rbf);
170     /* sort strong to weak */
171     qsort(peaka, ndirs, sizeof(FWHM), cmpFWHM);
172
173     for (i = 0; i < ndirs; i++) { /* report FWHM for each incidence */
174     FVECT vout;
175     int j;
176     getOutDir(vout, &peaka[i]);
177     printf("%.0f %.0f\t%.0f %.0f", get_theta180(peaka[i].rbs->invec),
178     get_phi360(peaka[i].rbs->invec),
179     get_theta180(vout), get_phi360(vout));
180     /* peak and FWHM from SIR */
181     printf("\t%.2e\t%.1f", peaka[i].peakv, peaka[i].width);
182     /* FWHM for each XML */
183     for (j = 2; j < argc; j++) {
184     const SDData *sd = SDcacheFile(argv[j]);
185     double psa;
186     if (SDreportError(
187     SDsizeBSDF(&psa, peaka[i].rbs->invec,
188     NULL, SDqueryMin, sd),
189     stderr))
190     return(1);
191
192     printf("\t%.1f", 180./M_PI * getFWHM(peaka[i].rbs->invec,
193     vout, sqrt(psa/M_PI),
194 greg 2.2 bsdf_eval, sd));
195 greg 2.4 SDfreeCache(sd);
196 greg 2.1 }
197     fputc('\n', stdout);
198     }
199 greg 2.4 /* we're exiting, anyway...
200     SDfreeCache(NULL);
201     clear_bsdf_rep();
202     */
203 greg 2.1 return(0);
204     userr:
205     fprintf(stderr, "Usage: %s bsdf.sir [bsdfrep1.xml ..]\n", progname);
206     return(1);
207     }
