root/radiance/ray/src/cv/bsdfpeaks.c
Revision: 2.5
Committed: Tue Jun 3 21:31:51 2025 UTC (3 days, 22 hours ago) by greg
Changes since 2.4: +4 -5 lines
2 static const char RCSid[] = "$Id: bsdfpeaks.c,v 2.4 2025/05/25 17:41:10 greg Exp $";
5 * Compute minimum FWHM peak for each incident direction in SIR input.
6 * Report FWHM of corresponding peaks in XML representations if provided.
7 */
8
9 #define _USE_MATH_DEFINES
10 #include <stdio.h>
11 #include <stdlib.h>
12 #include <math.h>
13 #include "paths.h"
14 #include "bsdfrep.h"
15
16 typedef struct {
17 float peakv; /* peak BSDF value */
18 float width; /* smallest FWHM (deg) */
19 const RBFNODE *rbs; /* incident system */
20 int ndx; /* peak index for RBFVAL */
21 } FWHM; /* struct to hold peak value */
22
23 typedef double eval_f(const FVECT vin, const FVECT vout, const void *p);
24
25 /* Comparison function to put larger peaks first */
26 int
27 cmpFWHM(const void *p0, const void *p1)
28 {
29 float diff = (*(const FWHM *)p0).peakv -
30 (*(const FWHM *)p1).peakv;
31
32 if (diff > 0) return(-1);
33 if (diff < 0) return(1);
34 return(0);
35 }
36
37 /* BSDF evaluation function for RBF system */
38 double
39 rbf_eval(const FVECT vin, const FVECT vout, const void *p)
40 {
41 /* XXX verify vin == p->invec ? */
42 return(eval_rbfrep((const RBFNODE *)p, vout));
43 }
44
45 /* BSDF evaluation for XML input */
46 double
47 bsdf_eval(const FVECT vin, const FVECT vout, const void *p)
48 {
49 SDValue sv;
50
51 if (SDreportError(
52 SDevalBSDF(&sv, vin, vout, (const SDData *)p),
53 stderr))
54 exit(1);
55
56 return(sv.cieY);
57 }
58
59 /* Find full-width, half-maximum in radians around BSDF direction */
60 double
61 getFWHM(const FVECT vin, const FVECT vc, double rad0, eval_f *ev, const void *p)
62 {
63 const double peakv = (*ev)(vin, vc, p);
64 double rad1 = rad0; /* current radii */
65
66 while (rad0 < M_PI/2.) { /* look for FWHM */
67 FVECT v0, vt;
68 double phi;
69 v0[0] = 1; v0[1] = v0[2] = 0;
70 geodesic(v0, vc, v0, rad0, GEOD_RAD); /* use vc as pivot */
71 for (phi = 0; phi < 2.*M_PI; phi += M_PI/18.) {
72 spinvector(vt, v0, vc, phi);
73 if ((*ev)(vin, vt, p) <= .5*peakv) { /* found one side? */
74 FVECT vt1;
75 while (rad1 < M_PI/2.) { /* bracket peak */
76 geodesic(vt1, vt, vc, rad0+rad1, GEOD_RAD);
77 if ((*ev)(vin, vt1, p) <= .5*peakv)
78 return(rad0+rad1); /* got both! */
79 rad1 *= 1.05; /* else bump rad1 */
80 }
81 }
82 }
83 rad1 = rad0 *= 1.05; /* or expand search */
84 }
85 return(M_PI); /* failure return */
86 }
87
88 /* Get outgoing direction for the given FWHM record */
89 void
90 getOutDir(FVECT vo, FWHM *dp)
91 {
92 const RBFVAL *vp = dp->rbs->rbfa + dp->ndx;
93
94 ovec_from_pos(vo, vp->gx, vp->gy);
95 }
96
97 /* Assign FWHM record for specified RBF system */
98 void
99 assignFWHM(FWHM *dp, const RBFNODE *rbf)
100 {
101 FVECT vo;
102 int j;
103 double rad;
104
105 dp->rbs = rbf;
106 dp->ndx = 0; /* find peak outgoing */
107 for (j = rbf->nrbf; --j; )
108 if (rbf->rbfa[j].peak > rbf->rbfa[dp->ndx].peak)
109 dp->ndx = j;
110 /* record peak */
111 getOutDir(vo, dp);
112 dp->peakv = eval_rbfrep(rbf, vo);
113 /* get FWHM angle in degrees */
114 dp->width = 180./M_PI * getFWHM(rbf->invec, vo,
115 R2ANG(rbf->rbfa[dp->ndx].crad),
116 rbf_eval, rbf);
117 }
118
119 /* Evaluate FWHM for each incident direction recorded in SIR */
120 int
121 main(int argc, char *argv[])
122 {
123 const RBFNODE *rbf;
124 SDData *sdp;
125 FILE *fp;
126 int ndirs;
127 FWHM *peaka;
128 int i;
129 /* set global progname */
130 fixargv0(argv[0]);
131 if (argc < 2)
132 goto userr;
133
134 fp = fopen(argv[1], "rb"); /* load SIR input */
135 if (fp == NULL) {
136 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
137 progname, argv[1]);
138 return(1);
139 }
140 if (!load_bsdf_rep(fp))
141 return(1);
142 fclose(fp);
143 for (i = 2; i < argc; i++) /* check/load any XMLs */
144 if (SDcacheFile(argv[i]) == NULL)
145 return(1);
146 ndirs = 0; /* count input directions */
147 for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) {
148 if (rbf->nrbf <= 0) {
149 ndirs = 0;
150 break;
151 }
152 ++ndirs;
153 }
154 if (!ndirs) {
155 fprintf(stderr, "%s: missing/bad RBFs in '%s'\n", progname, argv[1]);
156 return(1);
157 }
158 /* print output header */
159 printf("%d incident directions in '%s': %s -> %s\n", ndirs, argv[1],
160 input_orient>0 ? "Front" : "Back",
161 output_orient>0 ? "Front" : "Back");
162 fputs("Incident (theta, phi)\tExiting (theta, phi)\tPeak\tFWHM", stdout);
163 for (i = 2; i < argc; i++)
164 printf("\t'%s'", argv[i]);
165 fputc('\n', stdout);
166 /* find SIR peaks */
167 peaka = (FWHM *)malloc(sizeof(FWHM)*ndirs);
168 if (peaka == NULL) return(1);
169 for (i = 0, rbf = dsf_list; i < ndirs; i++, rbf = rbf->next)
170 assignFWHM(&peaka[i], rbf);
171 /* sort strong to weak */
172 qsort(peaka, ndirs, sizeof(FWHM), cmpFWHM);
173
174 for (i = 0; i < ndirs; i++) { /* report FWHM for each incidence */
175 FVECT vout;
176 int j;
177 getOutDir(vout, &peaka[i]);
178 printf("%.0f %.0f\t%.0f %.0f", get_theta180(peaka[i].rbs->invec),
179 get_phi360(peaka[i].rbs->invec),
180 get_theta180(vout), get_phi360(vout));
181 /* peak and FWHM from SIR */
182 printf("\t%.2e\t%.1f", peaka[i].peakv, peaka[i].width);
183 /* FWHM for each XML */
184 for (j = 2; j < argc; j++) {
185 const SDData *sd = SDcacheFile(argv[j]);
186 double psa;
187 if (SDreportError(
188 SDsizeBSDF(&psa, peaka[i].rbs->invec,
189 NULL, SDqueryMin, sd),
190 stderr))
191 return(1);
192
193 printf("\t%.1f", 180./M_PI * getFWHM(peaka[i].rbs->invec,
194 vout, sqrt(psa/M_PI),
195 bsdf_eval, sd));
196 SDfreeCache(sd);
197 }
198 fputc('\n', stdout);
199 }
200 /* we're exiting, anyway...
201 SDfreeCache(NULL);
202 clear_bsdf_rep();
203 */
204 return(0);
205 userr:
206 fprintf(stderr, "Usage: %s bsdf.sir [bsdfrep1.xml ..]\n", progname);
207 return(1);
208 }
