--- ray/src/cv/bsdfmesh.c 2012/11/09 02:16:29 2.6 +++ ray/src/cv/bsdfmesh.c 2014/08/21 19:31:23 2.32 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdfmesh.c,v 2.6 2012/11/09 02:16:29 greg Exp $"; +static const char RCSid[] = "$Id: bsdfmesh.c,v 2.32 2014/08/21 19:31:23 greg Exp $"; #endif /* * Create BSDF advection mesh from radial basis functions. @@ -18,20 +18,110 @@ static const char RCSid[] = "$Id: bsdfmesh.c,v 2.6 201 #include #include #include "bsdfrep.h" + +#ifndef NEIGH_FACT2 +#define NEIGH_FACT2 0.1 /* empirical neighborhood distance weight */ +#endif /* number of processes to run */ int nprocs = 1; /* number of children (-1 in child) */ static int nchild = 0; -typedef struct { - int nrows, ncols; /* array size (matches migration) */ - float *price; /* migration prices */ - short *sord; /* sort for each row, low to high */ -} PRICEMAT; /* sorted pricing matrix */ +/* Compute average DSF value at the given radius from central vector */ +static double +eval_DSFsurround(const RBFNODE *rbf, const FVECT outvec, const double rad) +{ + const int ninc = 12; + const double phinc = 2.*M_PI/ninc; + double sum = 0; + int n = 0; + FVECT tvec; + int i; + /* compute initial vector */ + if (output_orient*outvec[2] >= 1.-FTINY) { + tvec[0] = tvec[2] = 0; + tvec[1] = 1; + } else { + tvec[0] = tvec[1] = 0; + tvec[2] = 1; + } + geodesic(tvec, outvec, tvec, rad, GEOD_RAD); + /* average surrounding DSF */ + for (i = 0; i < ninc; i++) { + if (i) spinvector(tvec, tvec, outvec, phinc); + if (tvec[2] > 0 ^ output_orient > 0) + continue; + sum += eval_rbfrep(rbf, tvec) * output_orient*tvec[2]; + ++n; + } + if (n < 2) /* should never happen! */ + return(sum); + return(sum/(double)n); +} -#define pricerow(p,i) ((p)->price + (i)*(p)->ncols) -#define psortrow(p,i) ((p)->sord + (i)*(p)->ncols) +/* Estimate single-lobe radius for DSF at the given outgoing angle */ +static double +est_DSFrad(const RBFNODE *rbf, const FVECT outvec) +{ + const double rad_epsilon = 0.03; + const double DSFtarget = 0.60653066 * eval_rbfrep(rbf,outvec) + * output_orient*outvec[2]; + double inside_rad = rad_epsilon; + double outside_rad = 0.5; + double DSFinside = eval_DSFsurround(rbf, outvec, inside_rad); + double DSFoutside = eval_DSFsurround(rbf, outvec, outside_rad); +#define interp_rad inside_rad + (outside_rad-inside_rad) * \ + (DSFtarget-DSFinside) / (DSFoutside-DSFinside) + /* Newton's method (sort of) */ + do { + double test_rad = interp_rad; + double DSFtest; + if (test_rad >= outside_rad) + return(test_rad); + if (test_rad <= inside_rad) + return(test_rad*(test_rad>0)); + DSFtest = eval_DSFsurround(rbf, outvec, test_rad); + if (DSFtest > DSFtarget) { + inside_rad = test_rad; + DSFinside = DSFtest; + } else { + outside_rad = test_rad; + DSFoutside = DSFtest; + } + if (DSFoutside >= DSFinside) + return(test_rad); + } while (outside_rad-inside_rad > rad_epsilon); + return(interp_rad); +#undef interp_rad +} +/* Compute average BSDF peak from current DSF's */ +static void +comp_bsdf_spec(void) +{ + double peak_sum = 0; + double rad_sum = 0; + int n = 0; + RBFNODE *rbf; + FVECT sdv; + + if (dsf_list == NULL) { + bsdf_spec_peak = 0; + bsdf_spec_rad = 0; + return; + } + for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) { + sdv[0] = -rbf->invec[0]; + sdv[1] = -rbf->invec[1]; + sdv[2] = rbf->invec[2]*(2*(input_orient==output_orient) - 1); + peak_sum += eval_rbfrep(rbf, sdv); + rad_sum += est_DSFrad(rbf, sdv); + ++n; + } + bsdf_spec_peak = peak_sum/(double)n; + bsdf_spec_rad = rad_sum/(double)n; +} + /* Create a new migration holder (sharing memory for multiprocessing) */ static MIGRATION * new_migration(RBFNODE *from_rbf, RBFNODE *to_rbf) @@ -134,153 +224,72 @@ run_subprocess(void) #endif /* ! _WIN32 */ -/* Comparison routine needed for sorting price row */ -static int -msrt_cmp(void *b, const void *p1, const void *p2) -{ - PRICEMAT *pm = (PRICEMAT *)b; - int ri = ((const short *)p1 - pm->sord) / pm->ncols; - float c1 = pricerow(pm,ri)[*(const short *)p1]; - float c2 = pricerow(pm,ri)[*(const short *)p2]; - - if (c1 > c2) return(1); - if (c1 < c2) return(-1); - return(0); -} - -/* Compute (and allocate) migration price matrix for optimization */ +/* Compute normalized distribution scattering functions for comparison */ static void -price_routes(PRICEMAT *pm, const RBFNODE *from_rbf, const RBFNODE *to_rbf) +compute_nDSFs(const RBFNODE *rbf0, const RBFNODE *rbf1) { - FVECT *vto = (FVECT *)malloc(sizeof(FVECT) * to_rbf->nrbf); - int i, j; + const double nf0 = (GRIDRES*GRIDRES) / rbf0->vtotal; + const double nf1 = (GRIDRES*GRIDRES) / rbf1->vtotal; + int x, y; + FVECT dv; - pm->nrows = from_rbf->nrbf; - pm->ncols = to_rbf->nrbf; - pm->price = (float *)malloc(sizeof(float) * pm->nrows*pm->ncols); - pm->sord = (short *)malloc(sizeof(short) * pm->nrows*pm->ncols); - - if ((pm->price == NULL) | (pm->sord == NULL) | (vto == NULL)) { - fprintf(stderr, "%s: Out of memory in migration_costs()\n", - progname); - exit(1); - } - for (j = to_rbf->nrbf; j--; ) /* save repetitive ops. */ - ovec_from_pos(vto[j], to_rbf->rbfa[j].gx, to_rbf->rbfa[j].gy); - - for (i = from_rbf->nrbf; i--; ) { - const double from_ang = R2ANG(from_rbf->rbfa[i].crad); - FVECT vfrom; - ovec_from_pos(vfrom, from_rbf->rbfa[i].gx, from_rbf->rbfa[i].gy); - for (j = to_rbf->nrbf; j--; ) { - pricerow(pm,i)[j] = acos(DOT(vfrom, vto[j])) + - fabs(R2ANG(to_rbf->rbfa[j].crad) - from_ang); - psortrow(pm,i)[j] = j; + for (x = GRIDRES; x--; ) + for (y = GRIDRES; y--; ) { + ovec_from_pos(dv, x, y); /* cube root (brightness) */ + dsf_grid[x][y].val[0] = pow(nf0*eval_rbfrep(rbf0, dv), .3333); + dsf_grid[x][y].val[1] = pow(nf1*eval_rbfrep(rbf1, dv), .3333); } - qsort_r(psortrow(pm,i), pm->ncols, sizeof(short), pm, &msrt_cmp); - } - free(vto); -} +} -/* Free price matrix */ -static void -free_routes(PRICEMAT *pm) -{ - free(pm->price); pm->price = NULL; - free(pm->sord); pm->sord = NULL; -} - -/* Compute minimum (optimistic) cost for moving the given source material */ +/* Compute neighborhood distance-squared (dissimilarity) */ static double -min_cost(double amt2move, const double *avail, const PRICEMAT *pm, int s) +neighborhood_dist2(int x0, int y0, int x1, int y1) { - double total_cost = 0; - int j; - - if (amt2move <= FTINY) /* pre-emptive check */ - return(.0); - /* move cheapest first */ - for (j = 0; j < pm->ncols && amt2move > FTINY; j++) { - int d = psortrow(pm,s)[j]; - double amt = (amt2move < avail[d]) ? amt2move : avail[d]; - - total_cost += amt * pricerow(pm,s)[d]; - amt2move -= amt; + int rad = GRIDRES>>5; + double sum2 = 0.; + double d; + int p[4]; + int i, j; + /* check radius */ + p[0] = x0; p[1] = y0; p[2] = x1; p[3] = y1; + for (i = 4; i--; ) { + if (p[i] < rad) rad = p[i]; + if (GRIDRES-1-p[i] < rad) rad = GRIDRES-1-p[i]; } - return(total_cost); + for (i = -rad; i <= rad; i++) + for (j = -rad; j <= rad; j++) { + d = dsf_grid[x0+i][y0+j].val[0] - + dsf_grid[x1+i][y1+j].val[1]; + sum2 += d*d; + } + return(sum2 / (4*rad*(rad+1) + 1)); } -/* Take a step in migration by choosing optimal bucket to transfer */ -static double -migration_step(MIGRATION *mig, double *src_rem, double *dst_rem, const PRICEMAT *pm) +/* Compute distance between two RBF lobes */ +double +lobe_distance(RBFVAL *rbf1, RBFVAL *rbf2) { - const double maxamt = 1./(double)pm->ncols; - const double minamt = maxamt*5e-6; - double *src_cost; - struct { - int s, d; /* source and destination */ - double price; /* price estimate per amount moved */ - double amt; /* amount we can move */ - } cur, best; - int i; - /* allocate cost array */ - src_cost = (double *)malloc(sizeof(double)*pm->nrows); - if (src_cost == NULL) { - fprintf(stderr, "%s: Out of memory in migration_step()\n", - progname); - exit(1); - } - for (i = pm->nrows; i--; ) /* starting costs for diff. */ - src_cost[i] = min_cost(src_rem[i], dst_rem, pm, i); - - /* find best source & dest. */ - best.s = best.d = -1; best.price = FHUGE; best.amt = 0; - for (cur.s = pm->nrows; cur.s--; ) { - double cost_others = 0; - - if (src_rem[cur.s] <= minamt) - continue; - /* examine cheapest dest. */ - for (i = 0; i < pm->ncols; i++) - if (dst_rem[ cur.d = psortrow(pm,cur.s)[i] ] > minamt) - break; - if (i >= pm->ncols) - break; - if ((cur.price = pricerow(pm,cur.s)[cur.d]) >= best.price) - continue; /* no point checking further */ - cur.amt = (src_rem[cur.s] < dst_rem[cur.d]) ? - src_rem[cur.s] : dst_rem[cur.d]; - if (cur.amt > maxamt) cur.amt = maxamt; - dst_rem[cur.d] -= cur.amt; /* add up differential costs */ - for (i = pm->nrows; i--; ) - if (i != cur.s) - cost_others += min_cost(src_rem[i], dst_rem, pm, i) - - src_cost[i]; - dst_rem[cur.d] += cur.amt; /* undo trial move */ - cur.price += cost_others/cur.amt; /* adjust effective price */ - if (cur.price < best.price) /* are we better than best? */ - best = cur; - } - free(src_cost); /* finish up */ - - if ((best.s < 0) | (best.d < 0)) /* nothing left to move? */ - return(.0); - /* else make the actual move */ - mtx_coef(mig,best.s,best.d) += best.amt; - src_rem[best.s] -= best.amt; - dst_rem[best.d] -= best.amt; - return(best.amt); + FVECT vfrom, vto; + double d, res; + /* quadratic cost function */ + ovec_from_pos(vfrom, rbf1->gx, rbf1->gy); + ovec_from_pos(vto, rbf2->gx, rbf2->gy); + d = Acos(DOT(vfrom, vto)); + res = d*d; + d = R2ANG(rbf2->crad) - R2ANG(rbf1->crad); + res += d*d; + /* neighborhood difference */ + res += NEIGH_FACT2 * neighborhood_dist2( rbf1->gx, rbf1->gy, + rbf2->gx, rbf2->gy ); + return(res); } + /* Compute and insert migration along directed edge (may fork child) */ static MIGRATION * create_migration(RBFNODE *from_rbf, RBFNODE *to_rbf) { - const double end_thresh = 5e-6; - PRICEMAT pmtx; MIGRATION *newmig; - double *src_rem, *dst_rem; - double total_rem = 1., move_amt; int i, j; /* check if exists already */ for (newmig = from_rbf->ejl; newmig != NULL; @@ -288,37 +297,22 @@ create_migration(RBFNODE *from_rbf, RBFNODE *to_rbf) if (newmig->rbfv[1] == to_rbf) return(NULL); /* else allocate */ - newmig = new_migration(from_rbf, to_rbf); - if (run_subprocess()) - return(newmig); /* child continues */ - price_routes(&pmtx, from_rbf, to_rbf); - src_rem = (double *)malloc(sizeof(double)*from_rbf->nrbf); - dst_rem = (double *)malloc(sizeof(double)*to_rbf->nrbf); - if ((src_rem == NULL) | (dst_rem == NULL)) { - fprintf(stderr, "%s: Out of memory in create_migration()\n", - progname); - exit(1); - } #ifdef DEBUG - fprintf(stderr, "Building path from (theta,phi) (%.0f,%.0f) ", + fprintf(stderr, "Building path from (theta,phi) (%.1f,%.1f) ", get_theta180(from_rbf->invec), get_phi360(from_rbf->invec)); - fprintf(stderr, "to (%.0f,%.0f) with %d x %d matrix\n", + fprintf(stderr, "to (%.1f,%.1f) with %d x %d matrix\n", get_theta180(to_rbf->invec), get_phi360(to_rbf->invec), from_rbf->nrbf, to_rbf->nrbf); #endif - /* starting quantities */ - memset(newmig->mtx, 0, sizeof(float)*from_rbf->nrbf*to_rbf->nrbf); - for (i = from_rbf->nrbf; i--; ) - src_rem[i] = rbf_volume(&from_rbf->rbfa[i]) / from_rbf->vtotal; - for (j = to_rbf->nrbf; j--; ) - dst_rem[j] = rbf_volume(&to_rbf->rbfa[j]) / to_rbf->vtotal; + newmig = new_migration(from_rbf, to_rbf); + if (run_subprocess()) + return(newmig); /* child continues */ - do { /* move a bit at a time */ - move_amt = migration_step(newmig, src_rem, dst_rem, &pmtx); - total_rem -= move_amt; - } while ((total_rem > end_thresh) & (move_amt > 0)); + /* compute transport plan */ + compute_nDSFs(from_rbf, to_rbf); + plan_transport(newmig); for (i = from_rbf->nrbf; i--; ) { /* normalize final matrix */ double nf = rbf_volume(&from_rbf->rbfa[i]); @@ -328,9 +322,6 @@ create_migration(RBFNODE *from_rbf, RBFNODE *to_rbf) mtx_coef(newmig,i,j) *= nf; /* row now sums to 1.0 */ } end_subprocess(); /* exit here if subprocess */ - free_routes(&pmtx); /* free working arrays */ - free(src_rem); - free(dst_rem); return(newmig); } @@ -360,7 +351,7 @@ overlaps_tri(const RBFNODE *bv0, const RBFNODE *bv1, c return(vother[im_rev] != NULL); } -/* Find context hull vertex to complete triangle (oriented call) */ +/* Find convex hull vertex to complete triangle (oriented call) */ static RBFNODE * find_chull_vert(const RBFNODE *rbf0, const RBFNODE *rbf1) { @@ -381,7 +372,7 @@ find_chull_vert(const RBFNODE *rbf0, const RBFNODE *rb if (DOT(vp, vmid) <= FTINY) continue; /* wrong orientation */ area2 = .25*DOT(vp,vp); - VSUB(vp, rbf->invec, rbf0->invec); + VSUB(vp, rbf->invec, vmid); dprod = -DOT(vp, vejn); VSUM(vp, vp, vejn, dprod); /* above guarantees non-zero */ dprod = DOT(vp, vmid) / VLEN(vp); @@ -420,8 +411,10 @@ mesh_from_edge(MIGRATION *edge) ej1 = create_migration(tvert[0], edge->rbfv[1]); mesh_from_edge(ej0); mesh_from_edge(ej1); + return; } - } else if (tvert[1] == NULL) { /* grow mesh on left */ + } + if (tvert[1] == NULL) { /* grow mesh on left */ tvert[1] = find_chull_vert(edge->rbfv[1], edge->rbfv[0]); if (tvert[1] != NULL) { if (tvert[1]->ord > edge->rbfv[0]->ord) @@ -437,6 +430,79 @@ mesh_from_edge(MIGRATION *edge) } } } + +/* Add normal direction if missing */ +static void +check_normal_incidence(void) +{ + static FVECT norm_vec = {.0, .0, 1.}; + const int saved_nprocs = nprocs; + RBFNODE *near_rbf, *mir_rbf, *rbf; + double bestd; + int n; + + if (dsf_list == NULL) + return; /* XXX should be error? */ + near_rbf = dsf_list; + bestd = input_orient*near_rbf->invec[2]; + if (single_plane_incident) { /* ordered plane incidence? */ + if (bestd >= 1.-2.*FTINY) + return; /* already have normal */ + } else { + switch (inp_coverage) { + case INP_QUAD1: + case INP_QUAD2: + case INP_QUAD3: + case INP_QUAD4: + break; /* quadrilateral symmetry? */ + default: + return; /* else we can interpolate */ + } + for (rbf = near_rbf->next; rbf != NULL; rbf = rbf->next) { + const double d = input_orient*rbf->invec[2]; + if (d >= 1.-2.*FTINY) + return; /* seems we have normal */ + if (d > bestd) { + near_rbf = rbf; + bestd = d; + } + } + } + if (mig_list != NULL) { /* need to be called first */ + fprintf(stderr, "%s: Late call to check_normal_incidence()\n", + progname); + exit(1); + } +#ifdef DEBUG + fprintf(stderr, "Interpolating normal incidence by mirroring (%.1f,%.1f)\n", + get_theta180(near_rbf->invec), get_phi360(near_rbf->invec)); +#endif + /* mirror nearest incidence */ + n = sizeof(RBFNODE) + sizeof(RBFVAL)*(near_rbf->nrbf-1); + mir_rbf = (RBFNODE *)malloc(n); + if (mir_rbf == NULL) + goto memerr; + memcpy(mir_rbf, near_rbf, n); + mir_rbf->ord = near_rbf->ord - 1; /* not used, I think */ + mir_rbf->next = NULL; + mir_rbf->ejl = NULL; + rev_rbf_symmetry(mir_rbf, MIRROR_X|MIRROR_Y); + nprocs = 1; /* compute migration matrix */ + if (create_migration(mir_rbf, near_rbf) == NULL) + exit(1); /* XXX should never happen! */ + norm_vec[2] = input_orient; /* interpolate normal dist. */ + rbf = e_advect_rbf(mig_list, norm_vec, 0); + nprocs = saved_nprocs; /* final clean-up */ + free(mir_rbf); + free(mig_list); + mig_list = near_rbf->ejl = NULL; + insert_dsf(rbf); /* insert interpolated normal */ + return; +memerr: + fprintf(stderr, "%s: Out of memory in check_normal_incidence()\n", + progname); + exit(1); +} /* Build our triangle mesh from recorded RBFs */ void @@ -445,6 +511,10 @@ build_mesh(void) double best2 = M_PI*M_PI; RBFNODE *shrt_edj[2]; RBFNODE *rbf0, *rbf1; + /* average specular peak */ + comp_bsdf_spec(); + /* add normal if needed */ + check_normal_incidence(); /* check if isotropic */ if (single_plane_incident) { for (rbf0 = dsf_list; rbf0 != NULL; rbf0 = rbf0->next)
