--- ray/src/cv/bsdfmesh.c 2014/03/26 22:29:08 2.28 +++ ray/src/cv/bsdfmesh.c 2014/08/21 10:33:48 2.30 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdfmesh.c,v 2.28 2014/03/26 22:29:08 greg Exp $"; +static const char RCSid[] = "$Id: bsdfmesh.c,v 2.30 2014/08/21 10:33:48 greg Exp $"; #endif /* * Create BSDF advection mesh from radial basis functions. @@ -27,6 +27,94 @@ int nprocs = 1; /* number of children (-1 in child) */ static int nchild = 0; +/* Compute average DSF value at the given radius from central vector */ +static double +eval_DSFsurround(const RBFNODE *rbf, const FVECT outvec, const double rad) +{ + const int ninc = 12; + const double phinc = 2.*M_PI/ninc; + double sum = 0; + int n = 0; + FVECT tvec; + int i; + /* compute initial vector */ + if (output_orient*outvec[2] >= 1.-FTINY) { + tvec[0] = tvec[2] = 0; + tvec[1] = 1; + } else { + tvec[0] = tvec[1] = 0; + tvec[2] = 1; + } + geodesic(tvec, outvec, tvec, rad, GEOD_RAD); + /* average surrounding DSF */ + for (i = 0; i < ninc; i++) { + if (i) spinvector(tvec, tvec, outvec, phinc); + if (tvec[2] > 0 ^ output_orient > 0) + continue; + sum += eval_rbfrep(rbf, tvec) * output_orient*tvec[2]; + ++n; + } + if (n < 2) /* should never happen! */ + return(sum); + return(sum/(double)n); +} + +/* Estimate single-lobe radius for DSF at the given outgoing angle */ +static double +est_DSFrad(const RBFNODE *rbf, const FVECT outvec) +{ + const double rad_epsilon = 0.03; + const double DSFtarget = 0.60653066 * eval_rbfrep(rbf,outvec) + * output_orient*outvec[2]; + double inside_rad = rad_epsilon; + double outside_rad = 0.5; + double DSFinside = eval_DSFsurround(rbf, outvec, inside_rad); + double DSFoutside = eval_DSFsurround(rbf, outvec, outside_rad); +#define interp_rad inside_rad + (outside_rad-inside_rad) * \ + (DSFtarget-DSFinside) / (DSFoutside-DSFinside) + /* interpolation search */ + while (outside_rad-inside_rad > rad_epsilon) { + double test_rad = interp_rad; + double DSFtest = eval_DSFsurround(rbf, outvec, test_rad); + if (DSFtarget < DSFtest) { + inside_rad = test_rad; + DSFinside = DSFtest; + } else { + outside_rad = test_rad; + DSFoutside = DSFtest; + } + } + return(interp_rad); +#undef interp_rad +} + +/* Compute average BSDF peak from current DSF's */ +static void +comp_bsdf_spec(void) +{ + double peak_sum = 0; + double rad_sum = 0; + int n = 0; + RBFNODE *rbf; + FVECT sdv; + + if (dsf_list == NULL) { + bsdf_spec_peak = 0; + bsdf_spec_crad = 0; + return; + } + for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) { + sdv[0] = -rbf->invec[0]; + sdv[1] = -rbf->invec[1]; + sdv[2] = rbf->invec[2]*(2*(input_orient==output_orient) - 1); + peak_sum += eval_rbfrep(rbf, sdv); + rad_sum += est_DSFrad(rbf, sdv); + ++n; + } + bsdf_spec_peak = peak_sum/(double)n; + bsdf_spec_crad = ANG2R( rad_sum/(double)n ); +} + /* Create a new migration holder (sharing memory for multiprocessing) */ static MIGRATION * new_migration(RBFNODE *from_rbf, RBFNODE *to_rbf) @@ -396,7 +484,7 @@ check_normal_incidence(void) if (create_migration(mir_rbf, near_rbf) == NULL) exit(1); /* XXX should never happen! */ norm_vec[2] = input_orient; /* interpolate normal dist. */ - rbf = e_advect_rbf(mig_list, norm_vec, 2*near_rbf->nrbf); + rbf = e_advect_rbf(mig_list, norm_vec, 0); nprocs = saved_nprocs; /* final clean-up */ free(mir_rbf); free(mig_list); @@ -416,6 +504,8 @@ build_mesh(void) double best2 = M_PI*M_PI; RBFNODE *shrt_edj[2]; RBFNODE *rbf0, *rbf1; + /* average specular peak */ + comp_bsdf_spec(); /* add normal if needed */ check_normal_incidence(); /* check if isotropic */
