--- ray/src/cv/bsdfmesh.c 2013/11/08 03:42:13 2.14 +++ ray/src/cv/bsdfmesh.c 2014/03/26 00:11:30 2.26 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdfmesh.c,v 2.14 2013/11/08 03:42:13 greg Exp $"; +static const char RCSid[] = "$Id: bsdfmesh.c,v 2.26 2014/03/26 00:11:30 greg Exp $"; #endif /* * Create BSDF advection mesh from radial basis functions. @@ -18,6 +18,10 @@ static const char RCSid[] = "$Id: bsdfmesh.c,v 2.14 20 #include #include #include "bsdfrep.h" + +#ifndef NEIGH_FACT2 +#define NEIGH_FACT2 0.1 /* empirical neighborhood distance weight */ +#endif /* number of processes to run */ int nprocs = 1; /* number of children (-1 in child) */ @@ -135,6 +139,47 @@ run_subprocess(void) #endif /* ! _WIN32 */ +/* Compute normalized distribution scattering functions for comparison */ +static void +compute_nDSFs(const RBFNODE *rbf0, const RBFNODE *rbf1) +{ + const double nf0 = (GRIDRES*GRIDRES) / rbf0->vtotal; + const double nf1 = (GRIDRES*GRIDRES) / rbf1->vtotal; + int x, y; + FVECT dv; + + for (x = GRIDRES; x--; ) + for (y = GRIDRES; y--; ) { + ovec_from_pos(dv, x, y); /* cube root (brightness) */ + dsf_grid[x][y].val[0] = pow(nf0*eval_rbfrep(rbf0, dv), .3333); + dsf_grid[x][y].val[1] = pow(nf1*eval_rbfrep(rbf1, dv), .3333); + } +} + +/* Compute neighborhood distance-squared (dissimilarity) */ +static double +neighborhood_dist2(int x0, int y0, int x1, int y1) +{ + int rad = GRIDRES>>5; + double sum2 = 0.; + double d; + int p[4]; + int i, j; + /* check radius */ + p[0] = x0; p[1] = y0; p[2] = x1; p[3] = y1; + for (i = 4; i--; ) { + if (p[i] < rad) rad = p[i]; + if (GRIDRES-1-p[i] < rad) rad = GRIDRES-1-p[i]; + } + for (i = -rad; i <= rad; i++) + for (j = -rad; j <= rad; j++) { + d = dsf_grid[x0+i][y0+j].val[0] - + dsf_grid[x1+i][y1+j].val[1]; + sum2 += d*d; + } + return(sum2 / (4*rad*(rad+1) + 1)); +} + /* Comparison routine needed for sorting price row */ static int msrt_cmp(void *b, const void *p1, const void *p2) @@ -155,6 +200,7 @@ price_routes(PRICEMAT *pm, const RBFNODE *from_rbf, co FVECT *vto = (FVECT *)malloc(sizeof(FVECT) * to_rbf->nrbf); int i, j; + compute_nDSFs(from_rbf, to_rbf); pm->nrows = from_rbf->nrbf; pm->ncols = to_rbf->nrbf; pm->price = (float *)malloc(sizeof(float) * pm->nrows*pm->ncols); @@ -176,12 +222,15 @@ price_routes(PRICEMAT *pm, const RBFNODE *from_rbf, co pm->prow = pricerow(pm,i); srow = psortrow(pm,i); for (j = to_rbf->nrbf; j--; ) { - double d; /* quadratic cost function */ - d = DOT(vfrom, vto[j]); - d = (d >= 1.) ? .0 : acos(d); + double d; /* quadratic cost function */ + d = Acos(DOT(vfrom, vto[j])); pm->prow[j] = d*d; d = R2ANG(to_rbf->rbfa[j].crad) - from_ang; - pm->prow[j] += d*d; + pm->prow[j] += d*d; + /* neighborhood difference */ + pm->prow[j] += NEIGH_FACT2 * neighborhood_dist2( + from_rbf->rbfa[i].gx, from_rbf->rbfa[i].gy, + to_rbf->rbfa[j].gx, to_rbf->rbfa[j].gy ); srow[j] = j; } qsort_r(srow, pm->ncols, sizeof(short), pm, &msrt_cmp); @@ -216,18 +265,24 @@ min_cost(double amt2move, const double *avail, const P return(total_cost); } -/* Compare entries by moving price */ +typedef struct { + short s, d; /* source and destination */ + float dc; /* discount to push inventory */ +} ROWSENT; /* row sort entry */ + +/* Compare entries by discounted moving price */ static int rmovcmp(void *b, const void *p1, const void *p2) { PRICEMAT *pm = (PRICEMAT *)b; - const short *ij1 = (const short *)p1; - const short *ij2 = (const short *)p2; - float price_diff; + const ROWSENT *re1 = (const ROWSENT *)p1; + const ROWSENT *re2 = (const ROWSENT *)p2; + double price_diff; - if (ij1[1] < 0) return(ij2[1] >= 0); - if (ij2[1] < 0) return(-1); - price_diff = pricerow(pm,ij1[0])[ij1[1]] - pricerow(pm,ij2[0])[ij2[1]]; + if (re1->d < 0) return(re2->d >= 0); + if (re2->d < 0) return(-1); + price_diff = re1->dc*pricerow(pm,re1->s)[re1->d] - + re2->dc*pricerow(pm,re2->s)[re2->d]; if (price_diff > 0) return(1); if (price_diff < 0) return(-1); return(0); @@ -241,10 +296,10 @@ migration_step(MIGRATION *mig, double *src_rem, double const double maxamt = 1./(double)pm->ncols; const double minamt = maxamt*1e-4; double *src_cost; - short (*rord)[2]; + ROWSENT *rord; struct { int s, d; /* source and destination */ - double price; /* price estimate per amount moved */ + double price; /* cost per amount moved */ double amt; /* amount we can move */ } cur, best; int r2check, i, ri; @@ -253,26 +308,32 @@ migration_step(MIGRATION *mig, double *src_rem, double * destination price implies that another source is closer, so * we can hold off considering more expensive options until * some other (hopefully better) moves have been made. + * A discount based on source remaining is supposed to prioritize + * movement from large lobes, but it doesn't seem to do much, + * so we have it set to 1.0 at the moment. */ +#define discount(qr) 1.0 /* most promising row order */ - rord = (short (*)[2])malloc(sizeof(short)*2*pm->nrows); + rord = (ROWSENT *)malloc(sizeof(ROWSENT)*pm->nrows); if (rord == NULL) goto memerr; for (ri = pm->nrows; ri--; ) { - rord[ri][0] = ri; - rord[ri][1] = -1; + rord[ri].s = ri; + rord[ri].d = -1; + rord[ri].dc = 1.f; if (src_rem[ri] <= minamt) /* enough source material? */ continue; for (i = 0; i < pm->ncols; i++) - if (dst_rem[ rord[ri][1] = psortrow(pm,ri)[i] ] > minamt) + if (dst_rem[ rord[ri].d = psortrow(pm,ri)[i] ] > minamt) break; if (i >= pm->ncols) { /* moved all we can? */ free(rord); return(.0); } + rord[ri].dc = discount(src_rem[ri]); } if (pm->nrows > max2check) /* sort if too many sources */ - qsort_r(rord, pm->nrows, sizeof(short)*2, pm, &rmovcmp); + qsort_r(rord, pm->nrows, sizeof(ROWSENT), pm, &rmovcmp); /* allocate cost array */ src_cost = (double *)malloc(sizeof(double)*pm->nrows); if (src_cost == NULL) @@ -285,9 +346,9 @@ migration_step(MIGRATION *mig, double *src_rem, double r2check = max2check; /* put a limit on search */ for (ri = 0; ri < r2check; ri++) { /* check each source row */ double cost_others = 0; - cur.s = rord[ri][0]; - if ((cur.d = rord[ri][1]) < 0 || - (cur.price = pricerow(pm,cur.s)[cur.d]) >= best.price) { + cur.s = rord[ri].s; + if ((cur.d = rord[ri].d) < 0 || + rord[ri].dc*pricerow(pm,cur.s)[cur.d] >= best.price) { if (pm->nrows > max2check) break; /* sorted end */ continue; /* else skip this one */ } @@ -301,7 +362,9 @@ migration_step(MIGRATION *mig, double *src_rem, double cost_others += min_cost(src_rem[i], dst_rem, pm, i) - src_cost[i]; dst_rem[cur.d] += cur.amt; /* undo trial move */ - cur.price += cost_others/cur.amt; /* adjust effective price */ + /* discount effective price */ + cur.price = ( pricerow(pm,cur.s)[cur.d] + cost_others/cur.amt ) * + rord[ri].dc; if (cur.price < best.price) /* are we better than best? */ best = cur; } @@ -317,8 +380,45 @@ migration_step(MIGRATION *mig, double *src_rem, double memerr: fprintf(stderr, "%s: Out of memory in migration_step()\n", progname); exit(1); +#undef discount } +#ifdef DUMP_MATRIX +/* Dump transport plan and corresponding price matrix to a text file */ +static void +dump_matrix(const MIGRATION *me, const PRICEMAT *pm) +{ + char fname[256]; + FILE *fp; + int i, j; + + sprintf(fname, "edge_%d-%d.txt", me->rbfv[0]->ord, me->rbfv[1]->ord); + if ((fp = fopen(fname, "w")) == NULL) + return; + for (j = 0; j < 2; j++) { + fprintf(fp, "Available from %d source RBF lobes in node %d:\n", + me->rbfv[j]->nrbf, me->rbfv[j]->ord); + for (i = 0; i < me->rbfv[j]->nrbf; i++) + fprintf(fp, " %.4e", rbf_volume(&me->rbfv[j]->rbfa[i]) / + me->rbfv[j]->vtotal); + fputc('\n', fp); + } + fprintf(fp, "Price (quadratic distance metric) matrix:\n"); + for (i = 0; i < pm->nrows; i++) { + for (j = 0; j < pm->ncols; j++) + fprintf(fp, " %.4e", pricerow(pm,i)[j]); + fputc('\n', fp); + } + fprintf(fp, "Solution matrix (transport plan):\n"); + for (i = 0; i < mtx_nrows(me); i++) { + for (j = 0; j < mtx_ncols(me); j++) + fprintf(fp, " %.4e", mtx_coef(me,i,j)); + fputc('\n', fp); + } + fclose(fp); +} +#endif + /* Compute and insert migration along directed edge (may fork child) */ static MIGRATION * create_migration(RBFNODE *from_rbf, RBFNODE *to_rbf) @@ -374,6 +474,9 @@ create_migration(RBFNODE *from_rbf, RBFNODE *to_rbf) for (j = to_rbf->nrbf; j--; ) mtx_coef(newmig,i,j) *= nf; /* row now sums to 1.0 */ } +#ifdef DUMP_MATRIX + dump_matrix(newmig, &pmtx); +#endif end_subprocess(); /* exit here if subprocess */ free_routes(&pmtx); /* free working arrays */ free(src_rem); @@ -484,6 +587,79 @@ mesh_from_edge(MIGRATION *edge) } } } + +/* Add normal direction if missing */ +static void +check_normal_incidence(void) +{ + static FVECT norm_vec = {.0, .0, 1.}; + const int saved_nprocs = nprocs; + RBFNODE *near_rbf, *mir_rbf, *rbf; + double bestd; + int n; + + if (dsf_list == NULL) + return; /* XXX should be error? */ + near_rbf = dsf_list; + bestd = input_orient*near_rbf->invec[2]; + if (single_plane_incident) { /* ordered plane incidence? */ + if (bestd >= 1.-2.*FTINY) + return; /* already have normal */ + } else { + switch (inp_coverage) { + case INP_QUAD1: + case INP_QUAD2: + case INP_QUAD3: + case INP_QUAD4: + break; /* quadrilateral symmetry? */ + default: + return; /* else we can interpolate */ + } + for (rbf = near_rbf->next; rbf != NULL; rbf = rbf->next) { + const double d = input_orient*rbf->invec[2]; + if (d >= 1.-2.*FTINY) + return; /* seems we have normal */ + if (d > bestd) { + near_rbf = rbf; + bestd = d; + } + } + } + if (mig_list != NULL) { /* need to be called first */ + fprintf(stderr, "%s: Late call to check_normal_incidence()\n", + progname); + exit(1); + } +#ifdef DEBUG + fprintf(stderr, "Interpolating normal incidence by mirroring (%.1f,%.1f)\n", + get_theta180(near_rbf->invec), get_phi360(near_rbf->invec)); +#endif + /* mirror nearest incidence */ + n = sizeof(RBFNODE) + sizeof(RBFVAL)*(near_rbf->nrbf-1); + mir_rbf = (RBFNODE *)malloc(n); + if (mir_rbf == NULL) + goto memerr; + memcpy(mir_rbf, near_rbf, n); + mir_rbf->ord = near_rbf->ord - 1; /* not used, I think */ + mir_rbf->next = NULL; + mir_rbf->ejl = NULL; + rev_rbf_symmetry(mir_rbf, MIRROR_X|MIRROR_Y); + nprocs = 1; /* compute migration matrix */ + if (create_migration(mir_rbf, near_rbf) == NULL) + exit(1); /* XXX should never happen! */ + norm_vec[2] = input_orient; /* interpolate normal dist. */ + rbf = e_advect_rbf(mig_list, norm_vec, 2*near_rbf->nrbf); + nprocs = saved_nprocs; /* final clean-up */ + free(mir_rbf); + free(mig_list); + mig_list = near_rbf->ejl = NULL; + insert_dsf(rbf); /* insert interpolated normal */ + return; +memerr: + fprintf(stderr, "%s: Out of memory in check_normal_incidence()\n", + progname); + exit(1); +} /* Build our triangle mesh from recorded RBFs */ void @@ -492,6 +668,8 @@ build_mesh(void) double best2 = M_PI*M_PI; RBFNODE *shrt_edj[2]; RBFNODE *rbf0, *rbf1; + /* add normal if needed */ + check_normal_incidence(); /* check if isotropic */ if (single_plane_incident) { for (rbf0 = dsf_list; rbf0 != NULL; rbf0 = rbf0->next)
