--- ray/src/cv/bsdfmesh.c 2012/11/08 23:11:41 2.4 +++ ray/src/cv/bsdfmesh.c 2013/10/24 16:11:37 2.11 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdfmesh.c,v 2.4 2012/11/08 23:11:41 greg Exp $"; +static const char RCSid[] = "$Id: bsdfmesh.c,v 2.11 2013/10/24 16:11:37 greg Exp $"; #endif /* * Create BSDF advection mesh from radial basis functions. @@ -27,6 +27,7 @@ typedef struct { int nrows, ncols; /* array size (matches migration) */ float *price; /* migration prices */ short *sord; /* sort for each row, low to high */ + float *prow; /* current price row */ } PRICEMAT; /* sorted pricing matrix */ #define pricerow(p,i) ((p)->price + (i)*(p)->ncols) @@ -119,6 +120,7 @@ run_subprocess(void) if (pid < 0) { fprintf(stderr, "%s: cannot fork subprocess\n", progname); + await_children(nchild); exit(1); } ++nchild; /* subprocess started */ @@ -138,9 +140,8 @@ static int msrt_cmp(void *b, const void *p1, const void *p2) { PRICEMAT *pm = (PRICEMAT *)b; - int ri = ((const short *)p1 - pm->sord) / pm->ncols; - float c1 = pricerow(pm,ri)[*(const short *)p1]; - float c2 = pricerow(pm,ri)[*(const short *)p2]; + float c1 = pm->prow[*(const short *)p1]; + float c2 = pm->prow[*(const short *)p2]; if (c1 > c2) return(1); if (c1 < c2) return(-1); @@ -170,13 +171,17 @@ price_routes(PRICEMAT *pm, const RBFNODE *from_rbf, co for (i = from_rbf->nrbf; i--; ) { const double from_ang = R2ANG(from_rbf->rbfa[i].crad); FVECT vfrom; + short *srow; ovec_from_pos(vfrom, from_rbf->rbfa[i].gx, from_rbf->rbfa[i].gy); + pm->prow = pricerow(pm,i); + srow = psortrow(pm,i); for (j = to_rbf->nrbf; j--; ) { - pricerow(pm,i)[j] = acos(DOT(vfrom, vto[j])) + + double dprod = DOT(vfrom, vto[j]); + pm->prow[j] = ((dprod >= 1.) ? .0 : acos(dprod)) + fabs(R2ANG(to_rbf->rbfa[j].crad) - from_ang); - psortrow(pm,i)[j] = j; + srow[j] = j; } - qsort_r(psortrow(pm,i), pm->ncols, sizeof(short), pm, &msrt_cmp); + qsort_r(srow, pm->ncols, sizeof(short), pm, &msrt_cmp); } free(vto); } @@ -193,102 +198,124 @@ free_routes(PRICEMAT *pm) static double min_cost(double amt2move, const double *avail, const PRICEMAT *pm, int s) { + const short *srow = psortrow(pm,s); + const float *prow = pricerow(pm,s); double total_cost = 0; int j; - - if (amt2move <= FTINY) /* pre-emptive check */ - return(0.); /* move cheapest first */ - for (j = 0; j < pm->ncols && amt2move > FTINY; j++) { - int d = psortrow(pm,s)[j]; + for (j = 0; (j < pm->ncols) & (amt2move > FTINY); j++) { + int d = srow[j]; double amt = (amt2move < avail[d]) ? amt2move : avail[d]; - total_cost += amt * pricerow(pm,s)[d]; + total_cost += amt * prow[d]; amt2move -= amt; } return(total_cost); } -/* Take a step in migration by choosing optimal bucket to transfer */ +/* Compare entries by moving price */ +static int +rmovcmp(void *b, const void *p1, const void *p2) +{ + PRICEMAT *pm = (PRICEMAT *)b; + const short *ij1 = (const short *)p1; + const short *ij2 = (const short *)p2; + float price_diff; + + if (ij1[1] < 0) return(ij2[1] >= 0); + if (ij2[1] < 0) return(-1); + price_diff = pricerow(pm,ij1[0])[ij1[1]] - pricerow(pm,ij2[0])[ij2[1]]; + if (price_diff > 0) return(1); + if (price_diff < 0) return(-1); + return(0); +} + +/* Take a step in migration by choosing reasonable bucket to transfer */ static double -migration_step(MIGRATION *mig, double *src_rem, double *dst_rem, const PRICEMAT *pm) +migration_step(MIGRATION *mig, double *src_rem, double *dst_rem, PRICEMAT *pm) { + const int max2check = 100; const double maxamt = 1./(double)pm->ncols; const double minamt = maxamt*5e-6; - static double *src_cost = NULL; - static int n_alloc = 0; + double *src_cost; + short (*rord)[2]; struct { int s, d; /* source and destination */ double price; /* price estimate per amount moved */ double amt; /* amount we can move */ } cur, best; - int i; - - if (pm->nrows > n_alloc) { /* allocate cost array */ - if (n_alloc) - free(src_cost); - src_cost = (double *)malloc(sizeof(double)*pm->nrows); - if (src_cost == NULL) { - fprintf(stderr, "%s: Out of memory in migration_step()\n", - progname); - exit(1); - } - n_alloc = pm->nrows; + int r2check, i, ri; + /* + * Check cheapest available routes only -- a higher adjusted + * destination price implies that another source is closer, so + * we can hold off considering more expensive options until + * some other (hopefully better) moves have been made. + */ + /* most promising row order */ + rord = (short (*)[2])malloc(sizeof(short)*2*pm->nrows); + if (rord == NULL) + goto memerr; + for (ri = pm->nrows; ri--; ) { + rord[ri][0] = ri; + rord[ri][1] = -1; + if (src_rem[ri] <= minamt) /* enough source material? */ + continue; + for (i = 0; i < pm->ncols; i++) + if (dst_rem[ rord[ri][1] = psortrow(pm,ri)[i] ] > minamt) + break; + if (i >= pm->ncols) { /* moved all we can? */ + free(rord); + return(.0); + } } + if (pm->nrows > max2check) /* sort if too many sources */ + qsort_r(rord, pm->nrows, sizeof(short)*2, pm, &rmovcmp); + /* allocate cost array */ + src_cost = (double *)malloc(sizeof(double)*pm->nrows); + if (src_cost == NULL) + goto memerr; for (i = pm->nrows; i--; ) /* starting costs for diff. */ src_cost[i] = min_cost(src_rem[i], dst_rem, pm, i); - /* find best source & dest. */ best.s = best.d = -1; best.price = FHUGE; best.amt = 0; - for (cur.s = pm->nrows; cur.s--; ) { + if ((r2check = pm->nrows) > max2check) + r2check = max2check; /* put a limit on search */ + for (ri = 0; ri < r2check; ri++) { /* check each source row */ double cost_others = 0; - if (src_rem[cur.s] <= minamt) - continue; - /* examine cheapest dest. */ - for (i = 0; i < pm->ncols; i++) - if (dst_rem[cur.d = psortrow(pm,cur.s)[i]] > minamt) - break; - if (i >= pm->ncols) - return(.0); - if ((cur.price = pricerow(pm,cur.s)[cur.d]) >= best.price) - continue; /* no point checking further */ + cur.s = rord[ri][0]; + if ((cur.d = rord[ri][1]) < 0 || + (cur.price = pricerow(pm,cur.s)[cur.d]) >= best.price) { + if (pm->nrows > max2check) break; /* sorted end */ + continue; /* else skip this one */ + } cur.amt = (src_rem[cur.s] < dst_rem[cur.d]) ? src_rem[cur.s] : dst_rem[cur.d]; - if (cur.amt > maxamt) cur.amt = maxamt; - dst_rem[cur.d] -= cur.amt; /* add up differential costs */ + /* don't just leave smidgen */ + if (cur.amt > maxamt*1.02) cur.amt = maxamt; + dst_rem[cur.d] -= cur.amt; /* add up opportunity costs */ for (i = pm->nrows; i--; ) if (i != cur.s) - cost_others += min_cost(src_rem[i], dst_rem, pm, i) + cost_others += min_cost(src_rem[i], dst_rem, pm, i) - src_cost[i]; dst_rem[cur.d] += cur.amt; /* undo trial move */ cur.price += cost_others/cur.amt; /* adjust effective price */ if (cur.price < best.price) /* are we better than best? */ - best = cur; + best = cur; } - if ((best.s < 0) | (best.d < 0)) + free(src_cost); /* clean up */ + free(rord); + if ((best.s < 0) | (best.d < 0)) /* nothing left to move? */ return(.0); - /* make the actual move */ + /* else make the actual move */ mtx_coef(mig,best.s,best.d) += best.amt; src_rem[best.s] -= best.amt; dst_rem[best.d] -= best.amt; return(best.amt); +memerr: + fprintf(stderr, "%s: Out of memory in migration_step()\n", progname); + exit(1); } -#ifdef DEBUG -static char * -thetaphi(const FVECT v) -{ - static char buf[128]; - double theta, phi; - - theta = 180./M_PI*acos(v[2]); - phi = 180./M_PI*atan2(v[1],v[0]); - sprintf(buf, "(%.0f,%.0f)", theta, phi); - - return(buf); -} -#endif - /* Compute and insert migration along directed edge (may fork child) */ static MIGRATION * create_migration(RBFNODE *from_rbf, RBFNODE *to_rbf) @@ -298,13 +325,22 @@ create_migration(RBFNODE *from_rbf, RBFNODE *to_rbf) MIGRATION *newmig; double *src_rem, *dst_rem; double total_rem = 1., move_amt; - int i; + int i, j; /* check if exists already */ for (newmig = from_rbf->ejl; newmig != NULL; newmig = nextedge(from_rbf,newmig)) if (newmig->rbfv[1] == to_rbf) return(NULL); /* else allocate */ +#ifdef DEBUG + fprintf(stderr, "Building path from (theta,phi) (%.0f,%.0f) ", + get_theta180(from_rbf->invec), + get_phi360(from_rbf->invec)); + fprintf(stderr, "to (%.0f,%.0f) with %d x %d matrix\n", + get_theta180(to_rbf->invec), + get_phi360(to_rbf->invec), + from_rbf->nrbf, to_rbf->nrbf); +#endif newmig = new_migration(from_rbf, to_rbf); if (run_subprocess()) return(newmig); /* child continues */ @@ -316,38 +352,24 @@ create_migration(RBFNODE *from_rbf, RBFNODE *to_rbf) progname); exit(1); } -#ifdef DEBUG - fprintf(stderr, "Building path from (theta,phi) %s ", - thetaphi(from_rbf->invec)); - fprintf(stderr, "to %s with %d x %d matrix\n", - thetaphi(to_rbf->invec), - from_rbf->nrbf, to_rbf->nrbf); -#endif /* starting quantities */ memset(newmig->mtx, 0, sizeof(float)*from_rbf->nrbf*to_rbf->nrbf); for (i = from_rbf->nrbf; i--; ) src_rem[i] = rbf_volume(&from_rbf->rbfa[i]) / from_rbf->vtotal; - for (i = to_rbf->nrbf; i--; ) - dst_rem[i] = rbf_volume(&to_rbf->rbfa[i]) / to_rbf->vtotal; + for (j = to_rbf->nrbf; j--; ) + dst_rem[j] = rbf_volume(&to_rbf->rbfa[j]) / to_rbf->vtotal; + do { /* move a bit at a time */ move_amt = migration_step(newmig, src_rem, dst_rem, &pmtx); total_rem -= move_amt; -#ifdef DEBUG - if (!nchild) - fprintf(stderr, "\r%.9f remaining...", total_rem); -#endif } while ((total_rem > end_thresh) & (move_amt > 0)); -#ifdef DEBUG - if (!nchild) fputs("done.\n", stderr); - else fprintf(stderr, "finished with %.9f remaining\n", total_rem); -#endif + for (i = from_rbf->nrbf; i--; ) { /* normalize final matrix */ - float nf = rbf_volume(&from_rbf->rbfa[i]); - int j; + double nf = rbf_volume(&from_rbf->rbfa[i]); if (nf <= FTINY) continue; nf = from_rbf->vtotal / nf; for (j = to_rbf->nrbf; j--; ) - mtx_coef(newmig,i,j) *= nf; + mtx_coef(newmig,i,j) *= nf; /* row now sums to 1.0 */ } end_subprocess(); /* exit here if subprocess */ free_routes(&pmtx); /* free working arrays */
