root/radiance/ray/src/cv/bsdfmesh.c
Fri Aug 22 05:38:44 2014 UTC (9 years, 7 months ago) by greg
Changes since 2.32: +4 -4 lines
Diff to previous 2.32 , to selected 2.23
Thu Aug 21 19:31:23 2014 UTC (9 years, 7 months ago) by greg
Changes since 2.31: +13 -6 lines
Diff to previous 2.31 , to selected 2.23
Fixing potential problems with radius estimation
Thu Aug 21 13:44:05 2014 UTC (9 years, 7 months ago) by greg
Diff to previous 2.30 , to selected 2.23
Minor changes should not affect results
Thu Aug 21 10:33:48 2014 UTC (9 years, 7 months ago) by greg
Changes since 2.29: +91 -1 lines
Diff to previous 2.29 , to selected 2.23
Thu Mar 27 03:49:14 2014 UTC (10 years ago) by greg
CVS Tags: rad4R2
Diff to previous 2.28 , to selected 2.23
Minor fixes
Wed Mar 26 22:29:08 2014 UTC (10 years ago) by greg
Changes since 2.27: +4 -2 lines
Diff to previous 2.27 , to selected 2.23
Fixed major bug in incident mesh triangulation code
Wed Mar 26 02:52:31 2014 UTC (10 years ago) by greg
Changes since 2.26: +22 -276 lines
Diff to previous 2.26 , to selected 2.23
Wed Mar 26 00:11:30 2014 UTC (10 years ago) by greg
Changes since 2.25: +40 -1 lines
Diff to previous 2.25 , to selected 2.23
Added routine to dump transport plan for debugging
Mon Mar 24 06:07:46 2014 UTC (10 years ago) by greg
Changes since 2.24: +3 -4 lines
Diff to previous 2.24 , to selected 2.23
Minor fixes
Sat Mar 15 18:11:37 2014 UTC (10 years ago) by greg
Changes since 2.23: +1 -4 lines
Diff to previous 2.23
Removed improper exception for zero-distance neighborhood dissimilarity
Wed Mar 12 00:39:43 2014 UTC (10 years ago) by greg
Changes since 2.22: +1 -3 lines
Diff to previous 2.22
Removed stray debugging statement
Mon Mar 10 20:58:29 2014 UTC (10 years ago) by greg
Changes since 2.21: +6 -2 lines
Fixed evaluation order bug -- first time I've done that!
Sun Mar 9 01:51:48 2014 UTC (10 years ago) by greg
Tuned neighborhood factor down until it seemed to make the right difference
Sat Mar 8 21:06:14 2014 UTC (10 years ago) by greg
Changes since 2.19: +6 -6 lines
Changed to cube-root of DSF to improve stability for some distributions
Sat Mar 8 18:16:48 2014 UTC (10 years ago) by greg
Changes since 2.18: +55 -2 lines
Added neighborhood difference to distance metric for better lobe shaping
Thu Mar 6 00:40:37 2014 UTC (10 years ago) by greg
Changes since 2.17: +2 -3 lines
Switched to calling Acos() wherever appropriate
Wed Mar 5 22:47:16 2014 UTC (10 years ago) by greg
Changes since 2.16: +35 -20 lines
Failed attempt to improve results by prioritizing displacement of large lobes
Wed Feb 19 05:16:06 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.15: +8 -44 lines
Eliminated redundant code added in last change to bsdfmesh.c
Tue Feb 18 16:06:51 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.14: +111 -1 lines
Added normal incidence interpolation for quadrilateral and radial symmetry
Fri Nov 8 03:42:13 2013 UTC (10 years, 4 months ago) by greg
Changes since 2.13: +5 -5 lines
Minor changes that shouldn't affect operations
Fri Nov 1 18:23:50 2013 UTC (10 years, 4 months ago) by greg
Changes since 2.12: +7 -4 lines
Switched to quadratic cost function -- does not seem to matter much
Sun Oct 27 20:16:06 2013 UTC (10 years, 5 months ago) by greg
Changed minimum step size to speed convergence in problem cases
Thu Oct 24 16:11:37 2013 UTC (10 years, 5 months ago) by greg
Changes since 2.10: +74 -34 lines
Sped up convergence on large systems by almost 3x
Thu Sep 26 14:57:18 2013 UTC (10 years, 6 months ago) by greg
Changes since 2.9: +10 -7 lines
Fixed bug related to qsort_r() allocating its own sorting memory
Fri Jun 28 23:18:51 2013 UTC (10 years, 9 months ago) by greg
Changes since 2.8: +1 -22 lines
Fixed calculation of bsdf_min
Wed Mar 20 01:00:22 2013 UTC (11 years ago) by greg
Changes since 2.7: +22 -1 lines
Sat Nov 10 19:47:42 2012 UTC (11 years, 4 months ago) by greg
Changes since 2.6: +12 -11 lines
Minor bug fixes
Fri Nov 9 02:16:29 2012 UTC (11 years, 4 months ago) by greg
Changes since 2.5: +15 -34 lines
Added data to complete XML file output
Thu Nov 8 23:32:30 2012 UTC (11 years, 4 months ago) by greg
Changes since 2.4: +17 -20 lines
Made migration_step() re-entrant
Thu Nov 8 23:11:41 2012 UTC (11 years, 4 months ago) by greg
Changes since 2.3: +8 -10 lines
Further efficiency improvement (more modest this time)
Thu Nov 8 22:05:04 2012 UTC (11 years, 4 months ago) by greg
Changes since 2.2: +62 -57 lines
Took sort out so it is done only once
Sat Oct 20 07:02:00 2012 UTC (11 years, 5 months ago) by greg
Changes since 2.1: +113 -116 lines
Bug fixes and minor improvements
Fri Oct 19 04:14:29 2012 UTC (11 years, 5 months ago) by greg
Diff to selected 2.23
