root/Development/ray/src/cv/bsdfmesh.c
Revision: 2.29
Committed: Thu Mar 27 03:49:14 2014 UTC (11 years, 8 months ago) by greg
CVS Tags: rad4R2
Minor fixes
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.29 static const char RCSid[] = "$Id: bsdfmesh.c,v 2.28 2014/03/26 22:29:08 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Create BSDF advection mesh from radial basis functions.
6     *
7     * G. Ward
8     */
9
10     #ifndef _WIN32
11     #include <unistd.h>
12     #include <sys/wait.h>
13     #include <sys/mman.h>
14     #endif
15     #define _USE_MATH_DEFINES
16     #include <stdio.h>
17     #include <stdlib.h>
18     #include <string.h>
19     #include <math.h>
20     #include "bsdfrep.h"
21 greg 2.19
22     #ifndef NEIGH_FACT2
23 greg 2.21 #define NEIGH_FACT2 0.1 /* empirical neighborhood distance weight */
24 greg 2.19 #endif
25 greg 2.1 /* number of processes to run */
26     int nprocs = 1;
27     /* number of children (-1 in child) */
28     static int nchild = 0;
29
30 greg 2.2 /* Create a new migration holder (sharing memory for multiprocessing) */
31     static MIGRATION *
32     new_migration(RBFNODE *from_rbf, RBFNODE *to_rbf)
33     {
34     size_t memlen = sizeof(MIGRATION) +
35     sizeof(float)*(from_rbf->nrbf*to_rbf->nrbf - 1);
36     MIGRATION *newmig;
37     #ifdef _WIN32
38     if (nprocs > 1)
39     fprintf(stderr, "%s: warning - multiprocessing not supported\n",
40     progname);
41     nprocs = 1;
42     newmig = (MIGRATION *)malloc(memlen);
43     #else
44     if (nprocs <= 1) { /* single process? */
45     newmig = (MIGRATION *)malloc(memlen);
46     } else { /* else need to share memory */
47     newmig = (MIGRATION *)mmap(NULL, memlen, PROT_READ|PROT_WRITE,
48     MAP_ANON|MAP_SHARED, -1, 0);
49     if ((void *)newmig == MAP_FAILED)
50     newmig = NULL;
51     }
52     #endif
53     if (newmig == NULL) {
54     fprintf(stderr, "%s: cannot allocate new migration\n", progname);
55     exit(1);
56     }
57     newmig->rbfv[0] = from_rbf;
58     newmig->rbfv[1] = to_rbf;
59     /* insert in edge lists */
60     newmig->enxt[0] = from_rbf->ejl;
61     from_rbf->ejl = newmig;
62     newmig->enxt[1] = to_rbf->ejl;
63     to_rbf->ejl = newmig;
64     newmig->next = mig_list; /* push onto global list */
65     return(mig_list = newmig);
66     }
67
68     #ifdef _WIN32
69     #define await_children(n) (void)(n)
70     #define run_subprocess() 0
71     #define end_subprocess() (void)0
72     #else
73
74     /* Wait for the specified number of child processes to complete */
75     static void
76     await_children(int n)
77     {
78     int exit_status = 0;
79
80     if (n > nchild)
81     n = nchild;
82     while (n-- > 0) {
83     int status;
84     if (wait(&status) < 0) {
85     fprintf(stderr, "%s: missing child(ren)!\n", progname);
86     nchild = 0;
87     break;
88     }
89     --nchild;
90     if (status) { /* something wrong */
91     if ((status = WEXITSTATUS(status)))
92     exit_status = status;
93     else
94     exit_status += !exit_status;
95     fprintf(stderr, "%s: subprocess died\n", progname);
96     n = nchild; /* wait for the rest */
97     }
98     }
99     if (exit_status)
100     exit(exit_status);
101     }
102
103     /* Start child process if multiprocessing selected */
104     static pid_t
105     run_subprocess(void)
106     {
107     int status;
108     pid_t pid;
109
110     if (nprocs <= 1) /* any children requested? */
111     return(0);
112     await_children(nchild + 1 - nprocs); /* free up child process */
113     if ((pid = fork())) {
114     if (pid < 0) {
115     fprintf(stderr, "%s: cannot fork subprocess\n",
116     progname);
117 greg 2.6 await_children(nchild);
118 greg 2.2 exit(1);
119     }
120     ++nchild; /* subprocess started */
121     return(pid);
122     }
123     nchild = -1;
124     return(0); /* put child to work */
125     }
126
127     /* If we are in subprocess, call exit */
128     #define end_subprocess() if (nchild < 0) _exit(0); else
129
130     #endif /* ! _WIN32 */
131
132 greg 2.19 /* Compute normalized distribution scattering functions for comparison */
133     static void
134     compute_nDSFs(const RBFNODE *rbf0, const RBFNODE *rbf1)
135     {
136     const double nf0 = (GRIDRES*GRIDRES) / rbf0->vtotal;
137     const double nf1 = (GRIDRES*GRIDRES) / rbf1->vtotal;
138     int x, y;
139     FVECT dv;
140
141     for (x = GRIDRES; x--; )
142     for (y = GRIDRES; y--; ) {
143 greg 2.20 ovec_from_pos(dv, x, y); /* cube root (brightness) */
144     dsf_grid[x][y].val[0] = pow(nf0*eval_rbfrep(rbf0, dv), .3333);
145     dsf_grid[x][y].val[1] = pow(nf1*eval_rbfrep(rbf1, dv), .3333);
146 greg 2.19 }
147     }
148
149     /* Compute neighborhood distance-squared (dissimilarity) */
150     static double
151     neighborhood_dist2(int x0, int y0, int x1, int y1)
152     {
153     int rad = GRIDRES>>5;
154     double sum2 = 0.;
155     double d;
156     int p[4];
157     int i, j;
158     /* check radius */
159     p[0] = x0; p[1] = y0; p[2] = x1; p[3] = y1;
160     for (i = 4; i--; ) {
161     if (p[i] < rad) rad = p[i];
162     if (GRIDRES-1-p[i] < rad) rad = GRIDRES-1-p[i];
163     }
164     for (i = -rad; i <= rad; i++)
165     for (j = -rad; j <= rad; j++) {
166     d = dsf_grid[x0+i][y0+j].val[0] -
167     dsf_grid[x1+i][y1+j].val[1];
168     sum2 += d*d;
169     }
170     return(sum2 / (4*rad*(rad+1) + 1));
171     }
172
173 greg 2.27 /* Compute distance between two RBF lobes */
174     double
175     lobe_distance(RBFVAL *rbf1, RBFVAL *rbf2)
176     {
177     FVECT vfrom, vto;
178     double d, res;
179     /* quadratic cost function */
180     ovec_from_pos(vfrom, rbf1->gx, rbf1->gy);
181     ovec_from_pos(vto, rbf2->gx, rbf2->gy);
182     d = Acos(DOT(vfrom, vto));
183     res = d*d;
184     d = R2ANG(rbf2->crad) - R2ANG(rbf1->crad);
185     res += d*d;
186     /* neighborhood difference */
187     res += NEIGH_FACT2 * neighborhood_dist2( rbf1->gx, rbf1->gy,
188     rbf2->gx, rbf2->gy );
189     return(res);
190 greg 2.1 }
191
192 greg 2.26
193 greg 2.1 /* Compute and insert migration along directed edge (may fork child) */
194     static MIGRATION *
195     create_migration(RBFNODE *from_rbf, RBFNODE *to_rbf)
196     {
197     MIGRATION *newmig;
198 greg 2.6 int i, j;
199 greg 2.1 /* check if exists already */
200     for (newmig = from_rbf->ejl; newmig != NULL;
201     newmig = nextedge(from_rbf,newmig))
202     if (newmig->rbfv[1] == to_rbf)
203     return(NULL);
204     /* else allocate */
205 greg 2.7 #ifdef DEBUG
206 greg 2.14 fprintf(stderr, "Building path from (theta,phi) (%.1f,%.1f) ",
207 greg 2.7 get_theta180(from_rbf->invec),
208     get_phi360(from_rbf->invec));
209 greg 2.14 fprintf(stderr, "to (%.1f,%.1f) with %d x %d matrix\n",
210 greg 2.7 get_theta180(to_rbf->invec),
211     get_phi360(to_rbf->invec),
212     from_rbf->nrbf, to_rbf->nrbf);
213     #endif
214 greg 2.1 newmig = new_migration(from_rbf, to_rbf);
215     if (run_subprocess())
216     return(newmig); /* child continues */
217 greg 2.27
218     /* compute transport plan */
219     compute_nDSFs(from_rbf, to_rbf);
220     plan_transport(newmig);
221 greg 2.6
222 greg 2.1 for (i = from_rbf->nrbf; i--; ) { /* normalize final matrix */
223 greg 2.6 double nf = rbf_volume(&from_rbf->rbfa[i]);
224 greg 2.1 if (nf <= FTINY) continue;
225     nf = from_rbf->vtotal / nf;
226     for (j = to_rbf->nrbf; j--; )
227 greg 2.6 mtx_coef(newmig,i,j) *= nf; /* row now sums to 1.0 */
228 greg 2.1 }
229     end_subprocess(); /* exit here if subprocess */
230     return(newmig);
231     }
232
233     /* Check if prospective vertex would create overlapping triangle */
234     static int
235     overlaps_tri(const RBFNODE *bv0, const RBFNODE *bv1, const RBFNODE *pv)
236     {
237     const MIGRATION *ej;
238     RBFNODE *vother[2];
239     int im_rev;
240     /* find shared edge in mesh */
241     for (ej = pv->ejl; ej != NULL; ej = nextedge(pv,ej)) {
242     const RBFNODE *tv = opp_rbf(pv,ej);
243     if (tv == bv0) {
244     im_rev = is_rev_tri(ej->rbfv[0]->invec,
245     ej->rbfv[1]->invec, bv1->invec);
246     break;
247     }
248     if (tv == bv1) {
249     im_rev = is_rev_tri(ej->rbfv[0]->invec,
250     ej->rbfv[1]->invec, bv0->invec);
251     break;
252     }
253     }
254     if (!get_triangles(vother, ej)) /* triangle on same side? */
255     return(0);
256     return(vother[im_rev] != NULL);
257     }
258
259 greg 2.14 /* Find convex hull vertex to complete triangle (oriented call) */
260 greg 2.1 static RBFNODE *
261     find_chull_vert(const RBFNODE *rbf0, const RBFNODE *rbf1)
262     {
263     FVECT vmid, vejn, vp;
264     RBFNODE *rbf, *rbfbest = NULL;
265     double dprod, area2, bestarea2 = FHUGE, bestdprod = -.5;
266
267     VSUB(vejn, rbf1->invec, rbf0->invec);
268     VADD(vmid, rbf0->invec, rbf1->invec);
269     if (normalize(vejn) == 0 || normalize(vmid) == 0)
270     return(NULL);
271     /* XXX exhaustive search */
272     /* Find triangle with minimum rotation from perpendicular */
273     for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) {
274     if ((rbf == rbf0) | (rbf == rbf1))
275     continue;
276     tri_orient(vp, rbf0->invec, rbf1->invec, rbf->invec);
277     if (DOT(vp, vmid) <= FTINY)
278     continue; /* wrong orientation */
279     area2 = .25*DOT(vp,vp);
280 greg 2.14 VSUB(vp, rbf->invec, vmid);
281 greg 2.1 dprod = -DOT(vp, vejn);
282     VSUM(vp, vp, vejn, dprod); /* above guarantees non-zero */
283     dprod = DOT(vp, vmid) / VLEN(vp);
284     if (dprod <= bestdprod + FTINY*(1 - 2*(area2 < bestarea2)))
285     continue; /* found better already */
286     if (overlaps_tri(rbf0, rbf1, rbf))
287     continue; /* overlaps another triangle */
288     rbfbest = rbf;
289     bestdprod = dprod; /* new one to beat */
290     bestarea2 = area2;
291     }
292     return(rbfbest);
293     }
294
295     /* Create new migration edge and grow mesh recursively around it */
296     static void
297     mesh_from_edge(MIGRATION *edge)
298     {
299     MIGRATION *ej0, *ej1;
300     RBFNODE *tvert[2];
301
302     if (edge == NULL)
303     return;
304     /* triangle on either side? */
305     get_triangles(tvert, edge);
306     if (tvert[0] == NULL) { /* grow mesh on right */
307     tvert[0] = find_chull_vert(edge->rbfv[0], edge->rbfv[1]);
308     if (tvert[0] != NULL) {
309     if (tvert[0]->ord > edge->rbfv[0]->ord)
310     ej0 = create_migration(edge->rbfv[0], tvert[0]);
311     else
312     ej0 = create_migration(tvert[0], edge->rbfv[0]);
313     if (tvert[0]->ord > edge->rbfv[1]->ord)
314     ej1 = create_migration(edge->rbfv[1], tvert[0]);
315     else
316     ej1 = create_migration(tvert[0], edge->rbfv[1]);
317     mesh_from_edge(ej0);
318     mesh_from_edge(ej1);
319 greg 2.28 return;
320 greg 2.1 }
321 greg 2.28 }
322     if (tvert[1] == NULL) { /* grow mesh on left */
323 greg 2.1 tvert[1] = find_chull_vert(edge->rbfv[1], edge->rbfv[0]);
324     if (tvert[1] != NULL) {
325     if (tvert[1]->ord > edge->rbfv[0]->ord)
326     ej0 = create_migration(edge->rbfv[0], tvert[1]);
327     else
328     ej0 = create_migration(tvert[1], edge->rbfv[0]);
329     if (tvert[1]->ord > edge->rbfv[1]->ord)
330     ej1 = create_migration(edge->rbfv[1], tvert[1]);
331     else
332     ej1 = create_migration(tvert[1], edge->rbfv[1]);
333     mesh_from_edge(ej0);
334     mesh_from_edge(ej1);
335     }
336     }
337     }
338 greg 2.15
339     /* Add normal direction if missing */
340     static void
341     check_normal_incidence(void)
342     {
343 greg 2.25 static FVECT norm_vec = {.0, .0, 1.};
344 greg 2.16 const int saved_nprocs = nprocs;
345     RBFNODE *near_rbf, *mir_rbf, *rbf;
346     double bestd;
347     int n;
348 greg 2.15
349     if (dsf_list == NULL)
350     return; /* XXX should be error? */
351     near_rbf = dsf_list;
352     bestd = input_orient*near_rbf->invec[2];
353     if (single_plane_incident) { /* ordered plane incidence? */
354     if (bestd >= 1.-2.*FTINY)
355     return; /* already have normal */
356     } else {
357     switch (inp_coverage) {
358     case INP_QUAD1:
359     case INP_QUAD2:
360     case INP_QUAD3:
361     case INP_QUAD4:
362     break; /* quadrilateral symmetry? */
363     default:
364     return; /* else we can interpolate */
365     }
366     for (rbf = near_rbf->next; rbf != NULL; rbf = rbf->next) {
367     const double d = input_orient*rbf->invec[2];
368     if (d >= 1.-2.*FTINY)
369     return; /* seems we have normal */
370     if (d > bestd) {
371     near_rbf = rbf;
372     bestd = d;
373     }
374     }
375     }
376     if (mig_list != NULL) { /* need to be called first */
377     fprintf(stderr, "%s: Late call to check_normal_incidence()\n",
378     progname);
379     exit(1);
380     }
381     #ifdef DEBUG
382     fprintf(stderr, "Interpolating normal incidence by mirroring (%.1f,%.1f)\n",
383     get_theta180(near_rbf->invec), get_phi360(near_rbf->invec));
384     #endif
385     /* mirror nearest incidence */
386     n = sizeof(RBFNODE) + sizeof(RBFVAL)*(near_rbf->nrbf-1);
387     mir_rbf = (RBFNODE *)malloc(n);
388     if (mir_rbf == NULL)
389     goto memerr;
390     memcpy(mir_rbf, near_rbf, n);
391     mir_rbf->ord = near_rbf->ord - 1; /* not used, I think */
392     mir_rbf->next = NULL;
393 greg 2.22 mir_rbf->ejl = NULL;
394 greg 2.15 rev_rbf_symmetry(mir_rbf, MIRROR_X|MIRROR_Y);
395     nprocs = 1; /* compute migration matrix */
396 greg 2.22 if (create_migration(mir_rbf, near_rbf) == NULL)
397 greg 2.15 exit(1); /* XXX should never happen! */
398 greg 2.25 norm_vec[2] = input_orient; /* interpolate normal dist. */
399 greg 2.29 rbf = e_advect_rbf(mig_list, norm_vec, 0);
400 greg 2.15 nprocs = saved_nprocs; /* final clean-up */
401     free(mir_rbf);
402     free(mig_list);
403     mig_list = near_rbf->ejl = NULL;
404     insert_dsf(rbf); /* insert interpolated normal */
405     return;
406     memerr:
407     fprintf(stderr, "%s: Out of memory in check_normal_incidence()\n",
408     progname);
409     exit(1);
410     }
411 greg 2.1
412     /* Build our triangle mesh from recorded RBFs */
413     void
414     build_mesh(void)
415     {
416     double best2 = M_PI*M_PI;
417     RBFNODE *shrt_edj[2];
418     RBFNODE *rbf0, *rbf1;
419 greg 2.15 /* add normal if needed */
420     check_normal_incidence();
421 greg 2.1 /* check if isotropic */
422     if (single_plane_incident) {
423     for (rbf0 = dsf_list; rbf0 != NULL; rbf0 = rbf0->next)
424     if (rbf0->next != NULL)
425     create_migration(rbf0, rbf0->next);
426     await_children(nchild);
427     return;
428     }
429     shrt_edj[0] = shrt_edj[1] = NULL; /* start w/ shortest edge */
430     for (rbf0 = dsf_list; rbf0 != NULL; rbf0 = rbf0->next)
431     for (rbf1 = rbf0->next; rbf1 != NULL; rbf1 = rbf1->next) {
432     double dist2 = 2. - 2.*DOT(rbf0->invec,rbf1->invec);
433     if (dist2 < best2) {
434     shrt_edj[0] = rbf0;
435     shrt_edj[1] = rbf1;
436     best2 = dist2;
437     }
438     }
439     if (shrt_edj[0] == NULL) {
440     fprintf(stderr, "%s: Cannot find shortest edge\n", progname);
441     exit(1);
442     }
443     /* build mesh from this edge */
444     if (shrt_edj[0]->ord < shrt_edj[1]->ord)
445     mesh_from_edge(create_migration(shrt_edj[0], shrt_edj[1]));
446     else
447     mesh_from_edge(create_migration(shrt_edj[1], shrt_edj[0]));
448     /* complete migrations */
449     await_children(nchild);
450     }
