--- ray/src/cv/bsdfmesh.c 2014/08/22 05:38:44 2.33 +++ ray/src/cv/bsdfmesh.c 2016/01/30 17:34:00 2.36 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdfmesh.c,v 2.33 2014/08/22 05:38:44 greg Exp $"; +static const char RCSid[] = "$Id: bsdfmesh.c,v 2.36 2016/01/30 17:34:00 greg Exp $"; #endif /* * Create BSDF advection mesh from radial basis functions. @@ -95,31 +95,64 @@ est_DSFrad(const RBFNODE *rbf, const FVECT outvec) #undef interp_rad } -/* Compute average BSDF peak from current DSF's */ +static int +dbl_cmp(const void *p1, const void *p2) +{ + double d1 = *(const double *)p1; + double d2 = *(const double *)p2; + + if (d1 > d2) return(1); + if (d1 < d2) return(-1); + return(0); +} + +/* Conservative estimate of average BSDF value from current DSF's */ static void comp_bsdf_spec(void) { - double peak_sum = 0; + double vmod_sum = 0; double rad_sum = 0; int n = 0; + double *cost_list = NULL; + double max_cost = 1.; RBFNODE *rbf; FVECT sdv; - - if (dsf_list == NULL) { - bsdf_spec_peak = 0; + /* sort by incident altitude */ + for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) + n++; + if (n >= 10) + cost_list = (double *)malloc(sizeof(double)*n); + if (cost_list == NULL) { + bsdf_spec_val = 0; bsdf_spec_rad = 0; return; } + n = 0; + for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) + cost_list[n++] = rbf->invec[2]*input_orient; + qsort(cost_list, n, sizeof(double), dbl_cmp); + max_cost = cost_list[(n+3)/4]; /* accept 25% nearest grazing */ + free(cost_list); + n = 0; for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) { + double this_rad, cosfact, vest; + if (rbf->invec[2]*input_orient > max_cost) + continue; sdv[0] = -rbf->invec[0]; sdv[1] = -rbf->invec[1]; sdv[2] = rbf->invec[2]*(2*(input_orient==output_orient) - 1); - peak_sum += eval_rbfrep(rbf, sdv); - rad_sum += est_DSFrad(rbf, sdv); + cosfact = COSF(sdv[2]); + this_rad = est_DSFrad(rbf, sdv); + vest = eval_rbfrep(rbf, sdv) * cosfact * + (2.*M_PI) * this_rad*this_rad; + if (vest > rbf->vtotal) /* don't over-estimate energy */ + vest = rbf->vtotal; + vmod_sum += vest / cosfact; /* remove cosine factor */ + rad_sum += this_rad; ++n; } - bsdf_spec_peak = peak_sum/(double)n; bsdf_spec_rad = rad_sum/(double)n; + bsdf_spec_val = vmod_sum/(2.*M_PI*n*bsdf_spec_rad*bsdf_spec_rad); } /* Create a new migration holder (sharing memory for multiprocessing) */
