root/radiance/ray/src/cv/bsdfinterp.c
Revision: 2.9
Committed: Fri Dec 14 22:41:44 2012 UTC (12 years, 6 months ago) by greg
Changes since 2.8: +40 -26 lines
Fixed missing interpolation value bug
2 static const char RCSid[] = "$Id: bsdfinterp.c,v 2.8 2012/12/12 04:49:59 greg Exp $";
5 * Interpolate BSDF data from radial basis functions in advection mesh.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdio.h>
12 #include <stdlib.h>
13 #include <string.h>
14 #include <math.h>
15 #include "bsdfrep.h"
16
17 /* Insert vertex in ordered list */
18 static void
19 insert_vert(RBFNODE **vlist, RBFNODE *v)
20 {
21 int i, j;
22
23 for (i = 0; vlist[i] != NULL; i++) {
24 if (v == vlist[i])
25 return;
26 if (v->ord < vlist[i]->ord)
27 break;
28 }
29 for (j = i; vlist[j] != NULL; j++)
30 ;
31 while (j > i) {
32 vlist[j] = vlist[j-1];
33 --j;
34 }
35 vlist[i] = v;
36 }
37
38 /* Sort triangle edges in standard order */
39 static int
40 order_triangle(MIGRATION *miga[3])
41 {
42 RBFNODE *vert[7];
43 MIGRATION *ord[3];
44 int i;
45 /* order vertices, first */
46 memset(vert, 0, sizeof(vert));
47 for (i = 3; i--; ) {
48 if (miga[i] == NULL)
49 return(0);
50 insert_vert(vert, miga[i]->rbfv[0]);
51 insert_vert(vert, miga[i]->rbfv[1]);
52 }
53 /* should be just 3 vertices */
54 if ((vert[2] == NULL) | (vert[3] != NULL))
55 return(0);
56 /* identify edge 0 */
57 for (i = 3; i--; )
58 if (miga[i]->rbfv[0] == vert[0] &&
59 miga[i]->rbfv[1] == vert[1]) {
60 ord[0] = miga[i];
61 break;
62 }
63 if (i < 0)
64 return(0);
65 /* identify edge 1 */
66 for (i = 3; i--; )
67 if (miga[i]->rbfv[0] == vert[1] &&
68 miga[i]->rbfv[1] == vert[2]) {
69 ord[1] = miga[i];
70 break;
71 }
72 if (i < 0)
73 return(0);
74 /* identify edge 2 */
75 for (i = 3; i--; )
76 if (miga[i]->rbfv[0] == vert[0] &&
77 miga[i]->rbfv[1] == vert[2]) {
78 ord[2] = miga[i];
79 break;
80 }
81 if (i < 0)
82 return(0);
83 /* reassign order */
84 miga[0] = ord[0]; miga[1] = ord[1]; miga[2] = ord[2];
85 return(1);
86 }
87
88 /* Determine if we are close enough to an edge */
89 static int
90 on_edge(const MIGRATION *ej, const FVECT ivec)
91 {
92 double cos_a, cos_b, cos_c, cos_aplusb;
93 /* use triangle inequality */
94 cos_a = DOT(ej->rbfv[0]->invec, ivec);
95 if (cos_a <= 0)
96 return(0);
97
98 cos_b = DOT(ej->rbfv[1]->invec, ivec);
99 if (cos_b <= 0)
100 return(0);
101
102 cos_aplusb = cos_a*cos_b - sqrt((1.-cos_a*cos_a)*(1.-cos_b*cos_b));
103 if (cos_aplusb <= 0)
104 return(0);
105
106 cos_c = DOT(ej->rbfv[0]->invec, ej->rbfv[1]->invec);
107
108 return(cos_c - cos_aplusb < .001);
109 }
110
111 /* Determine if we are inside the given triangle */
112 static int
113 in_tri(const RBFNODE *v1, const RBFNODE *v2, const RBFNODE *v3, const FVECT p)
114 {
115 FVECT vc;
116 int sgn1, sgn2, sgn3;
117 /* signed volume test */
118 VCROSS(vc, v1->invec, v2->invec);
119 sgn1 = (DOT(p, vc) > 0);
120 VCROSS(vc, v2->invec, v3->invec);
121 sgn2 = (DOT(p, vc) > 0);
122 if (sgn1 != sgn2)
123 return(0);
124 VCROSS(vc, v3->invec, v1->invec);
125 sgn3 = (DOT(p, vc) > 0);
126 return(sgn2 == sgn3);
127 }
128
129 /* Test (and set) bitmap for edge */
130 static int
131 check_edge(unsigned char *emap, int nedges, const MIGRATION *mig, int mark)
132 {
133 int ejndx, bit2check;
134
135 if (mig->rbfv[0]->ord > mig->rbfv[1]->ord)
136 ejndx = mig->rbfv[1]->ord + (nedges-1)*mig->rbfv[0]->ord;
137 else
138 ejndx = mig->rbfv[0]->ord + (nedges-1)*mig->rbfv[1]->ord;
139
140 bit2check = 1<<(ejndx&07);
141
142 if (emap[ejndx>>3] & bit2check)
143 return(0);
144 if (mark)
145 emap[ejndx>>3] |= bit2check;
146 return(1);
147 }
148
149 /* Compute intersection with the given position over remaining mesh */
150 static int
151 in_mesh(MIGRATION *miga[3], unsigned char *emap, int nedges,
152 const FVECT ivec, MIGRATION *mig)
153 {
154 RBFNODE *tv[2];
155 MIGRATION *sej[2], *dej[2];
156 int i;
157 /* check visitation record */
158 if (!check_edge(emap, nedges, mig, 1))
159 return(0);
160 if (on_edge(mig, ivec)) {
161 miga[0] = mig; /* close enough to edge */
162 return(1);
163 }
164 if (!get_triangles(tv, mig)) /* do triangles either side? */
165 return(0);
166 for (i = 2; i--; ) { /* identify edges to check */
167 MIGRATION *ej;
168 sej[i] = dej[i] = NULL;
169 if (tv[i] == NULL)
170 continue;
171 for (ej = tv[i]->ejl; ej != NULL; ej = nextedge(tv[i],ej)) {
172 RBFNODE *rbfop = opp_rbf(tv[i],ej);
173 if (rbfop == mig->rbfv[0]) {
174 if (check_edge(emap, nedges, ej, 0))
175 sej[i] = ej;
176 } else if (rbfop == mig->rbfv[1]) {
177 if (check_edge(emap, nedges, ej, 0))
178 dej[i] = ej;
179 }
180 }
181 }
182 for (i = 2; i--; ) { /* check triangles just once */
183 if (sej[i] != NULL && in_mesh(miga, emap, nedges, ivec, sej[i]))
184 return(1);
185 if (dej[i] != NULL && in_mesh(miga, emap, nedges, ivec, dej[i]))
186 return(1);
187 if ((sej[i] == NULL) | (dej[i] == NULL))
188 continue;
189 if (in_tri(mig->rbfv[0], mig->rbfv[1], tv[i], ivec)) {
190 miga[0] = mig;
191 miga[1] = sej[i];
192 miga[2] = dej[i];
193 return(1);
194 }
195 }
196 return(0); /* not near this edge */
197 }
198
199 /* Find edge(s) for interpolating the given vector, applying symmetry */
200 int
201 get_interp(MIGRATION *miga[3], FVECT invec)
202 {
203 miga[0] = miga[1] = miga[2] = NULL;
204 if (single_plane_incident) { /* isotropic BSDF? */
205 RBFNODE *rbf; /* find edge we're on */
206 for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) {
207 if (input_orient*rbf->invec[2] < input_orient*invec[2])
208 break;
209 if (rbf->next != NULL &&
210 input_orient*rbf->next->invec[2] <
211 input_orient*invec[2]) {
212 for (miga[0] = rbf->ejl; miga[0] != NULL;
213 miga[0] = nextedge(rbf,miga[0]))
214 if (opp_rbf(rbf,miga[0]) == rbf->next) {
215 double nf = 1.-rbf->invec[2]*rbf->invec[2];
216 if (nf > FTINY) {
217 nf = sqrt((1.-invec[2]*invec[2])/nf);
218 invec[0] = nf*rbf->invec[0];
219 invec[1] = nf*rbf->invec[1];
220 }
221 return(0);
222 }
223 break;
224 }
225 }
226 return(-1); /* outside range! */
227 }
228 { /* else use triangle mesh */
229 int sym = use_symmetry(invec);
230 int nedges = 0;
231 MIGRATION *mep;
232 unsigned char *emap;
233 /* clear visitation map */
234 for (mep = mig_list; mep != NULL; mep = mep->next)
235 ++nedges;
236 emap = (unsigned char *)calloc((nedges*(nedges-1) + 7)>>3, 1);
237 if (emap == NULL) {
238 fprintf(stderr, "%s: Out of memory in get_interp()\n",
239 progname);
240 exit(1);
241 }
242 /* identify intersection */
243 if (!in_mesh(miga, emap, nedges, invec, mig_list)) {
244 #ifdef DEBUG
245 fprintf(stderr,
246 "Incident angle (%.1f,%.1f) deg. outside mesh\n",
247 get_theta180(invec), get_phi360(invec));
248 #endif
249 sym = -1; /* outside mesh */
250 } else if (miga[1] != NULL &&
251 (miga[2] == NULL || !order_triangle(miga))) {
252 #ifdef DEBUG
253 fputs("Munged triangle in get_interp()\n", stderr);
254 #endif
255 sym = -1;
256 }
257 free(emap);
258 return(sym); /* return in standard order */
259 }
260 }
261
262 /* Advect and allocate new RBF along edge */
263 static RBFNODE *
264 e_advect_rbf(const MIGRATION *mig, const FVECT invec)
265 {
266 RBFNODE *rbf;
267 int n, i, j;
268 double t, full_dist;
269 /* get relative position */
270 t = acos(DOT(invec, mig->rbfv[0]->invec));
271 if (t < M_PI/grid_res) { /* near first DSF */
272 n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[0]->nrbf-1);
273 rbf = (RBFNODE *)malloc(n);
274 if (rbf == NULL)
275 goto memerr;
276 memcpy(rbf, mig->rbfv[0], n); /* just duplicate */
277 rbf->next = NULL; rbf->ejl = NULL;
278 return(rbf);
279 }
280 full_dist = acos(DOT(mig->rbfv[0]->invec, mig->rbfv[1]->invec));
281 if (t > full_dist-M_PI/grid_res) { /* near second DSF */
282 n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[1]->nrbf-1);
283 rbf = (RBFNODE *)malloc(n);
284 if (rbf == NULL)
285 goto memerr;
286 memcpy(rbf, mig->rbfv[1], n); /* just duplicate */
287 rbf->next = NULL; rbf->ejl = NULL;
288 return(rbf);
289 }
290 t /= full_dist;
291 n = 0; /* count migrating particles */
292 for (i = 0; i < mtx_nrows(mig); i++)
293 for (j = 0; j < mtx_ncols(mig); j++)
294 n += (mtx_coef(mig,i,j) > FTINY);
295 #ifdef DEBUG
296 fprintf(stderr, "Input RBFs have %d, %d nodes -> output has %d\n",
297 mig->rbfv[0]->nrbf, mig->rbfv[1]->nrbf, n);
298 #endif
299 rbf = (RBFNODE *)malloc(sizeof(RBFNODE) + sizeof(RBFVAL)*(n-1));
300 if (rbf == NULL)
301 goto memerr;
302 rbf->next = NULL; rbf->ejl = NULL;
303 VCOPY(rbf->invec, invec);
304 rbf->nrbf = n;
305 rbf->vtotal = 1.-t + t*mig->rbfv[1]->vtotal/mig->rbfv[0]->vtotal;
306 n = 0; /* advect RBF lobes */
307 for (i = 0; i < mtx_nrows(mig); i++) {
308 const RBFVAL *rbf0i = &mig->rbfv[0]->rbfa[i];
309 const float peak0 = rbf0i->peak;
310 const double rad0 = R2ANG(rbf0i->crad);
311 FVECT v0;
312 float mv;
313 ovec_from_pos(v0, rbf0i->gx, rbf0i->gy);
314 for (j = 0; j < mtx_ncols(mig); j++)
315 if ((mv = mtx_coef(mig,i,j)) > FTINY) {
316 const RBFVAL *rbf1j = &mig->rbfv[1]->rbfa[j];
317 double rad1 = R2ANG(rbf1j->crad);
318 FVECT v;
319 int pos[2];
320 rbf->rbfa[n].peak = peak0 * mv * rbf->vtotal;
321 rbf->rbfa[n].crad = ANG2R(sqrt(rad0*rad0*(1.-t) +
322 rad1*rad1*t));
323 ovec_from_pos(v, rbf1j->gx, rbf1j->gy);
324 geodesic(v, v0, v, t, GEOD_REL);
325 pos_from_vec(pos, v);
326 rbf->rbfa[n].gx = pos[0];
327 rbf->rbfa[n].gy = pos[1];
328 ++n;
329 }
330 }
331 rbf->vtotal *= mig->rbfv[0]->vtotal; /* turn ratio into actual */
332 return(rbf);
333 memerr:
334 fprintf(stderr, "%s: Out of memory in e_advect_rbf()\n", progname);
335 exit(1);
336 return(NULL); /* pro forma return */
337 }
338
339 /* Partially advect between recorded incident angles and allocate new RBF */
340 RBFNODE *
341 advect_rbf(const FVECT invec)
342 {
343 FVECT sivec;
344 MIGRATION *miga[3];
345 RBFNODE *rbf;
346 int sym;
347 float mbfact, mcfact;
348 int n, i, j, k;
349 FVECT v0, v1, v2;
350 double s, t;
351
352 VCOPY(sivec, invec); /* find triangle/edge */
353 sym = get_interp(miga, sivec);
354 if (sym < 0) /* can't interpolate? */
355 return(NULL);
356 if (miga[1] == NULL) { /* advect along edge? */
357 rbf = e_advect_rbf(miga[0], sivec);
358 if (single_plane_incident)
359 rotate_rbf(rbf, invec);
360 else
361 rev_rbf_symmetry(rbf, sym);
362 return(rbf);
363 }
364 #ifdef DEBUG
365 if (miga[0]->rbfv[0] != miga[2]->rbfv[0] |
366 miga[0]->rbfv[1] != miga[1]->rbfv[0] |
367 miga[1]->rbfv[1] != miga[2]->rbfv[1]) {
368 fprintf(stderr, "%s: Triangle vertex screw-up!\n", progname);
369 exit(1);
370 }
371 #endif
372 /* figure out position */
373 fcross(v0, miga[2]->rbfv[0]->invec, miga[2]->rbfv[1]->invec);
374 normalize(v0);
375 fcross(v2, miga[1]->rbfv[0]->invec, miga[1]->rbfv[1]->invec);
376 normalize(v2);
377 fcross(v1, sivec, miga[1]->rbfv[1]->invec);
378 normalize(v1);
379 s = acos(DOT(v0,v1)) / acos(DOT(v0,v2));
380 geodesic(v1, miga[0]->rbfv[0]->invec, miga[0]->rbfv[1]->invec,
381 s, GEOD_REL);
382 t = acos(DOT(v1,sivec)) / acos(DOT(v1,miga[1]->rbfv[1]->invec));
383 n = 0; /* count migrating particles */
384 for (i = 0; i < mtx_nrows(miga[0]); i++)
385 for (j = 0; j < mtx_ncols(miga[0]); j++)
386 for (k = (mtx_coef(miga[0],i,j) > FTINY) *
387 mtx_ncols(miga[2]); k--; )
388 n += (mtx_coef(miga[2],i,k) > FTINY ||
389 mtx_coef(miga[1],j,k) > FTINY);
390 #ifdef DEBUG
391 fprintf(stderr, "Input RBFs have %d, %d, %d nodes -> output has %d\n",
392 miga[0]->rbfv[0]->nrbf, miga[0]->rbfv[1]->nrbf,
393 miga[2]->rbfv[1]->nrbf, n);
394 #endif
395 rbf = (RBFNODE *)malloc(sizeof(RBFNODE) + sizeof(RBFVAL)*(n-1));
396 if (rbf == NULL) {
397 fprintf(stderr, "%s: Out of memory in advect_rbf()\n", progname);
398 exit(1);
399 }
400 rbf->next = NULL; rbf->ejl = NULL;
401 VCOPY(rbf->invec, sivec);
402 rbf->nrbf = n;
403 n = 0; /* compute RBF lobes */
404 mbfact = s * miga[0]->rbfv[1]->vtotal/miga[0]->rbfv[0]->vtotal *
405 (1.-t + t*miga[1]->rbfv[1]->vtotal/miga[1]->rbfv[0]->vtotal);
406 mcfact = (1.-s) *
407 (1.-t + t*miga[2]->rbfv[1]->vtotal/miga[2]->rbfv[0]->vtotal);
408 for (i = 0; i < mtx_nrows(miga[0]); i++) {
409 const RBFVAL *rbf0i = &miga[0]->rbfv[0]->rbfa[i];
410 const float w0i = rbf0i->peak;
411 const double rad0i = R2ANG(rbf0i->crad);
412 ovec_from_pos(v0, rbf0i->gx, rbf0i->gy);
413 for (j = 0; j < mtx_ncols(miga[0]); j++) {
414 const float ma = mtx_coef(miga[0],i,j);
415 const RBFVAL *rbf1j;
416 double rad1j, srad2;
417 if (ma <= FTINY)
418 continue;
419 rbf1j = &miga[0]->rbfv[1]->rbfa[j];
420 rad1j = R2ANG(rbf1j->crad);
421 srad2 = (1.-s)*(1.-t)*rad0i*rad0i + s*(1.-t)*rad1j*rad1j;
422 ovec_from_pos(v1, rbf1j->gx, rbf1j->gy);
423 geodesic(v1, v0, v1, s, GEOD_REL);
424 for (k = 0; k < mtx_ncols(miga[2]); k++) {
425 float mb = mtx_coef(miga[1],j,k);
426 float mc = mtx_coef(miga[2],i,k);
427 const RBFVAL *rbf2k;
428 double rad2k;
429 int pos[2];
430 if ((mb <= FTINY) & (mc <= FTINY))
431 continue;
432 rbf2k = &miga[2]->rbfv[1]->rbfa[k];
433 rbf->rbfa[n].peak = w0i * ma * (mb*mbfact + mc*mcfact);
434 rad2k = R2ANG(rbf2k->crad);
435 rbf->rbfa[n].crad = ANG2R(sqrt(srad2 + t*rad2k*rad2k));
436 ovec_from_pos(v2, rbf2k->gx, rbf2k->gy);
437 geodesic(v2, v1, v2, t, GEOD_REL);
438 pos_from_vec(pos, v2);
439 rbf->rbfa[n].gx = pos[0];
440 rbf->rbfa[n].gy = pos[1];
441 ++n;
442 }
443 }
444 }
445 rbf->vtotal = miga[0]->rbfv[0]->vtotal * (mbfact + mcfact);
446 rev_rbf_symmetry(rbf, sym);
447 return(rbf);
448 }
