--- ray/src/cv/bsdfinterp.c 2012/10/23 05:10:42 2.3 +++ ray/src/cv/bsdfinterp.c 2012/11/08 00:31:17 2.5 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdfinterp.c,v 2.3 2012/10/23 05:10:42 greg Exp $"; +static const char RCSid[] = "$Id: bsdfinterp.c,v 2.5 2012/11/08 00:31:17 greg Exp $"; #endif /* * Interpolate BSDF data from radial basis functions in advection mesh. @@ -51,7 +51,7 @@ order_triangle(MIGRATION *miga[3]) insert_vert(vert, miga[i]->rbfv[1]); } /* should be just 3 vertices */ - if ((vert[3] == NULL) | (vert[4] != NULL)) + if ((vert[2] == NULL) | (vert[3] != NULL)) return(0); /* identify edge 0 */ for (i = 3; i--; ) @@ -85,17 +85,27 @@ order_triangle(MIGRATION *miga[3]) return(1); } -/* Determine if we are close enough to the given edge */ +/* Determine if we are close enough to an edge */ static int on_edge(const MIGRATION *ej, const FVECT ivec) { - double cos_a = DOT(ej->rbfv[0]->invec, ivec); - double cos_b = DOT(ej->rbfv[1]->invec, ivec); - double cos_c = DOT(ej->rbfv[0]->invec, ej->rbfv[1]->invec); - double cos_aplusb = cos_a*cos_b - - sqrt((1.-cos_a*cos_a)*(1.-cos_b*cos_b)); + double cos_a, cos_b, cos_c, cos_aplusb; + /* use triangle inequality */ + cos_a = DOT(ej->rbfv[0]->invec, ivec); + if (cos_a <= 0) + return(0); - return(cos_aplusb - cos_c < .01); + cos_b = DOT(ej->rbfv[1]->invec, ivec); + if (cos_b <= 0) + return(0); + + cos_aplusb = cos_a*cos_b - sqrt((1.-cos_a*cos_a)*(1.-cos_b*cos_b)); + if (cos_aplusb <= 0) + return(0); + + cos_c = DOT(ej->rbfv[0]->invec, ej->rbfv[1]->invec); + + return(cos_c - cos_aplusb < .001); } /* Determine if we are inside the given triangle */ @@ -116,6 +126,26 @@ in_tri(const RBFNODE *v1, const RBFNODE *v2, const RBF return(sgn2 == sgn3); } +/* Test and set for edge */ +static int +check_edge(unsigned char *emap, int nedges, const MIGRATION *mig, int mark) +{ + int ejndx, bit2check; + + if (mig->rbfv[0]->ord > mig->rbfv[1]->ord) + ejndx = mig->rbfv[1]->ord + (nedges-1)*mig->rbfv[0]->ord; + else + ejndx = mig->rbfv[0]->ord + (nedges-1)*mig->rbfv[1]->ord; + + bit2check = 1<<(ejndx&07); + + if (emap[ejndx>>3] & bit2check) + return(0); + if (mark) + emap[ejndx>>3] |= bit2check; + return(1); +} + /* Compute intersection with the given position over remaining mesh */ static int in_mesh(MIGRATION *miga[3], unsigned char *emap, int nedges, @@ -123,15 +153,9 @@ in_mesh(MIGRATION *miga[3], unsigned char *emap, int n { MIGRATION *ej1, *ej2; RBFNODE *tv; - int ejndx; /* check visitation record */ - if (mig->rbfv[0]->ord > mig->rbfv[1]->ord) - ejndx = mig->rbfv[1]->ord + (nedges-1)*mig->rbfv[0]->ord; - else - ejndx = mig->rbfv[0]->ord + (nedges-1)*mig->rbfv[1]->ord; - if (emap[ejndx>>3] & 1<<(ejndx&07)) /* tested already? */ + if (!check_edge(emap, nedges, mig, 1)) return(0); - emap[ejndx>>3] |= 1<<(ejndx&07); /* else mark & test it */ if (on_edge(mig, ivec)) { miga[0] = mig; /* close enough to edge */ return(1); @@ -139,25 +163,28 @@ in_mesh(MIGRATION *miga[3], unsigned char *emap, int n /* do triangles either side */ for (ej1 = mig->rbfv[0]->ejl; ej1 != NULL; ej1 = nextedge(mig->rbfv[0],ej1)) { - if (ej1 == mig) - continue; - tv = opp_rbf(mig->rbfv[0],ej1); - for (ej2 = tv->ejl; ej2 != NULL; ej2 = nextedge(tv,ej2)) - if (opp_rbf(tv,ej2) == mig->rbfv[1]) { - if (in_mesh(miga, emap, nedges, ivec, ej1)) - return(1); - if (in_mesh(miga, emap, nedges, ivec, ej2)) - return(1); - if (in_tri(mig->rbfv[0], mig->rbfv[1], - tv, ivec)) { - miga[0] = mig; - miga[1] = ej1; - miga[2] = ej2; - return(1); - } + if (ej1 == mig) + continue; + tv = opp_rbf(mig->rbfv[0],ej1); + for (ej2 = tv->ejl; ej2 != NULL; ej2 = nextedge(tv,ej2)) + if (opp_rbf(tv,ej2) == mig->rbfv[1]) { + int do_ej1 = check_edge(emap, nedges, ej1, 0); + int do_ej2 = check_edge(emap, nedges, ej2, 0); + if (do_ej1 && in_mesh(miga, emap, nedges, ivec, ej1)) + return(1); + if (do_ej2 && in_mesh(miga, emap, nedges, ivec, ej2)) + return(1); + /* check just once */ + if (do_ej1 & do_ej2 && in_tri(mig->rbfv[0], + mig->rbfv[1], tv, ivec)) { + miga[0] = mig; + miga[1] = ej1; + miga[2] = ej2; + return(1); } + } } - return(0); + return(0); /* not near this edge */ } /* Find edge(s) for interpolating the given vector, applying symmetry */ @@ -175,8 +202,15 @@ get_interp(MIGRATION *miga[3], FVECT invec) input_orient*invec[2]) { for (miga[0] = rbf->ejl; miga[0] != NULL; miga[0] = nextedge(rbf,miga[0])) - if (opp_rbf(rbf,miga[0]) == rbf->next) + if (opp_rbf(rbf,miga[0]) == rbf->next) { + double nf = 1.-rbf->invec[2]*rbf->invec[2]; + if (nf > FTINY) { + nf = sqrt((1.-invec[2]*invec[2])/nf); + invec[0] = nf*rbf->invec[0]; + invec[1] = nf*rbf->invec[1]; + } return(0); + } break; } } @@ -220,7 +254,7 @@ e_advect_rbf(const MIGRATION *mig, const FVECT invec) double t, full_dist; /* get relative position */ t = acos(DOT(invec, mig->rbfv[0]->invec)); - if (t < M_PI/GRIDRES) { /* near first DSF */ + if (t < M_PI/grid_res) { /* near first DSF */ n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[0]->nrbf-1); rbf = (RBFNODE *)malloc(n); if (rbf == NULL) @@ -229,7 +263,7 @@ e_advect_rbf(const MIGRATION *mig, const FVECT invec) return(rbf); } full_dist = acos(DOT(mig->rbfv[0]->invec, mig->rbfv[1]->invec)); - if (t > full_dist-M_PI/GRIDRES) { /* near second DSF */ + if (t > full_dist-M_PI/grid_res) { /* near second DSF */ n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[1]->nrbf-1); rbf = (RBFNODE *)malloc(n); if (rbf == NULL) @@ -305,7 +339,10 @@ advect_rbf(const FVECT invec) return(NULL); if (miga[1] == NULL) { /* advect along edge? */ rbf = e_advect_rbf(miga[0], sivec); - rev_rbf_symmetry(rbf, sym); + if (single_plane_incident) + rotate_rbf(rbf, invec); + else + rev_rbf_symmetry(rbf, sym); return(rbf); } #ifdef DEBUG @@ -332,7 +369,7 @@ advect_rbf(const FVECT invec) for (j = 0; j < mtx_ncols(miga[0]); j++) for (k = (mtx_coef(miga[0],i,j) > FTINY) * mtx_ncols(miga[2]); k--; ) - n += (mtx_coef(miga[2],i,k) > FTINY && + n += (mtx_coef(miga[2],i,k) > FTINY || mtx_coef(miga[1],j,k) > FTINY); #ifdef DEBUG fprintf(stderr, "Input RBFs have %d, %d, %d nodes -> output has %d\n", @@ -375,7 +412,7 @@ advect_rbf(const FVECT invec) double rad2k; FVECT vout; int pos[2]; - if ((mb <= FTINY) | (mc <= FTINY)) + if ((mb <= FTINY) & (mc <= FTINY)) continue; rbf2k = &miga[2]->rbfv[1]->rbfa[k]; rbf->rbfa[n].peak = w0i * ma * (mb*mbfact + mc*mcfact);
