--- ray/src/cv/bsdfinterp.c 2013/10/23 03:41:39 2.15 +++ ray/src/cv/bsdfinterp.c 2014/03/24 17:22:33 2.18 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdfinterp.c,v 2.15 2013/10/23 03:41:39 greg Exp $"; +static const char RCSid[] = "$Id: bsdfinterp.c,v 2.18 2014/03/24 17:22:33 greg Exp $"; #endif /* * Interpolate BSDF data from radial basis functions in advection mesh. @@ -208,20 +208,21 @@ get_interp(MIGRATION *miga[3], FVECT invec) if (single_plane_incident) { /* isotropic BSDF? */ RBFNODE *rbf; /* find edge we're on */ for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) { - if (input_orient*rbf->invec[2] < input_orient*invec[2]) + if (input_orient*rbf->invec[2] < input_orient*invec[2]-FTINY) break; if (rbf->next != NULL && input_orient*rbf->next->invec[2] < - input_orient*invec[2]) { + input_orient*invec[2]+FTINY) { for (miga[0] = rbf->ejl; miga[0] != NULL; miga[0] = nextedge(rbf,miga[0])) if (opp_rbf(rbf,miga[0]) == rbf->next) { - double nf = 1. - rbf->invec[2]*rbf->invec[2]; + double nf = 1. - + rbf->next->invec[2]*rbf->next->invec[2]; if (nf > FTINY) { /* rotate to match */ nf = sqrt((1.-invec[2]*invec[2])/nf); - invec[0] = nf*rbf->invec[0]; - invec[1] = nf*rbf->invec[1]; + invec[0] = nf*rbf->next->invec[0]; + invec[1] = nf*rbf->next->invec[1]; } - return(0); + return(0); /* rotational symmetry */ } break; } @@ -262,93 +263,7 @@ get_interp(MIGRATION *miga[3], FVECT invec) } } -/* Advect and allocate new RBF along edge */ -static RBFNODE * -e_advect_rbf(const MIGRATION *mig, const FVECT invec, int lobe_lim) -{ - double cthresh = FTINY; - RBFNODE *rbf; - int n, i, j; - double t, full_dist; - /* get relative position */ - t = Acos(DOT(invec, mig->rbfv[0]->invec)); - if (t < M_PI/grid_res) { /* near first DSF */ - n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[0]->nrbf-1); - rbf = (RBFNODE *)malloc(n); - if (rbf == NULL) - goto memerr; - memcpy(rbf, mig->rbfv[0], n); /* just duplicate */ - rbf->next = NULL; rbf->ejl = NULL; - return(rbf); - } - full_dist = acos(DOT(mig->rbfv[0]->invec, mig->rbfv[1]->invec)); - if (t > full_dist-M_PI/grid_res) { /* near second DSF */ - n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[1]->nrbf-1); - rbf = (RBFNODE *)malloc(n); - if (rbf == NULL) - goto memerr; - memcpy(rbf, mig->rbfv[1], n); /* just duplicate */ - rbf->next = NULL; rbf->ejl = NULL; - return(rbf); - } - t /= full_dist; -tryagain: - n = 0; /* count migrating particles */ - for (i = 0; i < mtx_nrows(mig); i++) - for (j = 0; j < mtx_ncols(mig); j++) - n += (mtx_coef(mig,i,j) > cthresh); - /* are we over our limit? */ - if ((lobe_lim > 0) & (n > lobe_lim)) { - cthresh = cthresh*2. + 10.*FTINY; - goto tryagain; - } -#ifdef DEBUG - fprintf(stderr, "Input RBFs have %d, %d nodes -> output has %d\n", - mig->rbfv[0]->nrbf, mig->rbfv[1]->nrbf, n); -#endif - rbf = (RBFNODE *)malloc(sizeof(RBFNODE) + sizeof(RBFVAL)*(n-1)); - if (rbf == NULL) - goto memerr; - rbf->next = NULL; rbf->ejl = NULL; - VCOPY(rbf->invec, invec); - rbf->nrbf = n; - rbf->vtotal = 1.-t + t*mig->rbfv[1]->vtotal/mig->rbfv[0]->vtotal; - n = 0; /* advect RBF lobes */ - for (i = 0; i < mtx_nrows(mig); i++) { - const RBFVAL *rbf0i = &mig->rbfv[0]->rbfa[i]; - const float peak0 = rbf0i->peak; - const double rad0 = R2ANG(rbf0i->crad); - FVECT v0; - float mv; - ovec_from_pos(v0, rbf0i->gx, rbf0i->gy); - for (j = 0; j < mtx_ncols(mig); j++) - if ((mv = mtx_coef(mig,i,j)) > cthresh) { - const RBFVAL *rbf1j = &mig->rbfv[1]->rbfa[j]; - double rad2; - FVECT v; - int pos[2]; - rad2 = R2ANG(rbf1j->crad); - rad2 = rad0*rad0*(1.-t) + rad2*rad2*t; - rbf->rbfa[n].peak = peak0 * mv * rbf->vtotal * - rad0*rad0/rad2; - rbf->rbfa[n].crad = ANG2R(sqrt(rad2)); - ovec_from_pos(v, rbf1j->gx, rbf1j->gy); - geodesic(v, v0, v, t, GEOD_REL); - pos_from_vec(pos, v); - rbf->rbfa[n].gx = pos[0]; - rbf->rbfa[n].gy = pos[1]; - ++n; - } - } - rbf->vtotal *= mig->rbfv[0]->vtotal; /* turn ratio into actual */ - return(rbf); -memerr: - fprintf(stderr, "%s: Out of memory in e_advect_rbf()\n", progname); - exit(1); - return(NULL); /* pro forma return */ -} - -/* Partially advect between recorded incident angles and allocate new RBF */ +/* Advect between recorded incident angles and allocate new RBF */ RBFNODE * advect_rbf(const FVECT invec, int lobe_lim) { @@ -375,9 +290,9 @@ advect_rbf(const FVECT invec, int lobe_lim) return(rbf); } #ifdef DEBUG - if (miga[0]->rbfv[0] != miga[2]->rbfv[0] | - miga[0]->rbfv[1] != miga[1]->rbfv[0] | - miga[1]->rbfv[1] != miga[2]->rbfv[1]) { + if ((miga[0]->rbfv[0] != miga[2]->rbfv[0]) | + (miga[0]->rbfv[1] != miga[1]->rbfv[0]) | + (miga[1]->rbfv[1] != miga[2]->rbfv[1])) { fprintf(stderr, "%s: Triangle vertex screw-up!\n", progname); exit(1); }
