1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: bsdfinterp.c,v 2.20 2014/10/26 17:35:53 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Interpolate BSDF data from radial basis functions in advection mesh. |
6 |
7 |
* G. Ward |
8 |
9 |
10 |
#define _USE_MATH_DEFINES |
11 |
#include <stdio.h> |
12 |
#include <stdlib.h> |
13 |
#include <string.h> |
14 |
#include <math.h> |
15 |
#include "bsdfrep.h" |
16 |
17 |
/* Insert vertex in ordered list */ |
18 |
static void |
19 |
insert_vert(RBFNODE **vlist, RBFNODE *v) |
20 |
21 |
int i, j; |
22 |
23 |
for (i = 0; vlist[i] != NULL; i++) { |
24 |
if (v == vlist[i]) |
25 |
return; |
26 |
if (v->ord < vlist[i]->ord) |
27 |
break; |
28 |
29 |
for (j = i; vlist[j] != NULL; j++) |
30 |
31 |
while (j > i) { |
32 |
vlist[j] = vlist[j-1]; |
33 |
--j; |
34 |
35 |
vlist[i] = v; |
36 |
37 |
38 |
/* Sort triangle edges in standard order */ |
39 |
static int |
40 |
order_triangle(MIGRATION *miga[3]) |
41 |
42 |
RBFNODE *vert[7]; |
43 |
MIGRATION *ord[3]; |
44 |
int i; |
45 |
/* order vertices, first */ |
46 |
memset(vert, 0, sizeof(vert)); |
47 |
for (i = 3; i--; ) { |
48 |
if (miga[i] == NULL) |
49 |
return(0); |
50 |
insert_vert(vert, miga[i]->rbfv[0]); |
51 |
insert_vert(vert, miga[i]->rbfv[1]); |
52 |
53 |
/* should be just 3 vertices */ |
54 |
if ((vert[2] == NULL) | (vert[3] != NULL)) |
55 |
return(0); |
56 |
/* identify edge 0 */ |
57 |
for (i = 3; i--; ) |
58 |
if (miga[i]->rbfv[0] == vert[0] && |
59 |
miga[i]->rbfv[1] == vert[1]) { |
60 |
ord[0] = miga[i]; |
61 |
break; |
62 |
63 |
if (i < 0) |
64 |
return(0); |
65 |
/* identify edge 1 */ |
66 |
67 |
if (miga[i]->rbfv[0] == vert[1] && |
68 |
miga[i]->rbfv[1] == vert[2]) { |
69 |
ord[1] = miga[i]; |
70 |
break; |
71 |
72 |
if (i < 0) |
73 |
return(0); |
74 |
/* identify edge 2 */ |
75 |
76 |
77 |
78 |
ord[2] = miga[i]; |
79 |
break; |
80 |
81 |
if (i < 0) |
82 |
return(0); |
83 |
/* reassign order */ |
84 |
miga[0] = ord[0]; miga[1] = ord[1]; miga[2] = ord[2]; |
85 |
return(1); |
86 |
87 |
88 |
/* Determine if we are close enough to an edge */ |
89 |
static int |
90 |
on_edge(const MIGRATION *ej, const FVECT ivec) |
91 |
92 |
double cos_a, cos_b, cos_c, cos_aplusb; |
93 |
/* use triangle inequality */ |
94 |
cos_a = DOT(ej->rbfv[0]->invec, ivec); |
95 |
if (cos_a <= 0) |
96 |
return(0); |
97 |
if (cos_a >= 1.) /* handles rounding error */ |
98 |
return(1); |
99 |
100 |
cos_b = DOT(ej->rbfv[1]->invec, ivec); |
101 |
if (cos_b <= 0) |
102 |
return(0); |
103 |
if (cos_b >= 1.) |
104 |
return(1); |
105 |
106 |
cos_aplusb = cos_a*cos_b - sqrt((1.-cos_a*cos_a)*(1.-cos_b*cos_b)); |
107 |
if (cos_aplusb <= 0) |
108 |
return(0); |
109 |
110 |
cos_c = DOT(ej->rbfv[0]->invec, ej->rbfv[1]->invec); |
111 |
112 |
return(cos_c - cos_aplusb < .001); |
113 |
114 |
115 |
/* Determine if we are inside the given triangle */ |
116 |
static int |
117 |
in_tri(const RBFNODE *v1, const RBFNODE *v2, const RBFNODE *v3, const FVECT p) |
118 |
119 |
FVECT vc; |
120 |
int sgn1, sgn2, sgn3; |
121 |
/* signed volume test */ |
122 |
VCROSS(vc, v1->invec, v2->invec); |
123 |
sgn1 = (DOT(p, vc) > 0); |
124 |
VCROSS(vc, v2->invec, v3->invec); |
125 |
sgn2 = (DOT(p, vc) > 0); |
126 |
if (sgn1 != sgn2) |
127 |
return(0); |
128 |
VCROSS(vc, v3->invec, v1->invec); |
129 |
sgn3 = (DOT(p, vc) > 0); |
130 |
return(sgn2 == sgn3); |
131 |
132 |
133 |
/* Test (and set) bitmap for edge */ |
134 |
static int |
135 |
check_edge(unsigned char *emap, int nedges, const MIGRATION *mig, int mark) |
136 |
137 |
int ejndx, bit2check; |
138 |
139 |
if (mig->rbfv[0]->ord > mig->rbfv[1]->ord) |
140 |
ejndx = mig->rbfv[1]->ord + (nedges-1)*mig->rbfv[0]->ord; |
141 |
else |
142 |
ejndx = mig->rbfv[0]->ord + (nedges-1)*mig->rbfv[1]->ord; |
143 |
144 |
bit2check = 1<<(ejndx&07); |
145 |
146 |
if (emap[ejndx>>3] & bit2check) |
147 |
return(0); |
148 |
if (mark) |
149 |
emap[ejndx>>3] |= bit2check; |
150 |
return(1); |
151 |
152 |
153 |
/* Compute intersection with the given position over remaining mesh */ |
154 |
static int |
155 |
in_mesh(MIGRATION *miga[3], unsigned char *emap, int nedges, |
156 |
const FVECT ivec, MIGRATION *mig) |
157 |
158 |
RBFNODE *tv[2]; |
159 |
MIGRATION *sej[2], *dej[2]; |
160 |
int i; |
161 |
/* check visitation record */ |
162 |
if (!check_edge(emap, nedges, mig, 1)) |
163 |
return(0); |
164 |
if (on_edge(mig, ivec)) { |
165 |
miga[0] = mig; /* close enough to edge */ |
166 |
return(1); |
167 |
168 |
if (!get_triangles(tv, mig)) /* do triangles either side? */ |
169 |
return(0); |
170 |
for (i = 2; i--; ) { /* identify edges to check */ |
171 |
MIGRATION *ej; |
172 |
sej[i] = dej[i] = NULL; |
173 |
if (tv[i] == NULL) |
174 |
continue; |
175 |
for (ej = tv[i]->ejl; ej != NULL; ej = nextedge(tv[i],ej)) { |
176 |
RBFNODE *rbfop = opp_rbf(tv[i],ej); |
177 |
if (rbfop == mig->rbfv[0]) { |
178 |
if (check_edge(emap, nedges, ej, 0)) |
179 |
sej[i] = ej; |
180 |
} else if (rbfop == mig->rbfv[1]) { |
181 |
182 |
dej[i] = ej; |
183 |
184 |
185 |
186 |
for (i = 2; i--; ) { /* check triangles just once */ |
187 |
if (sej[i] != NULL && in_mesh(miga, emap, nedges, ivec, sej[i])) |
188 |
return(1); |
189 |
if (dej[i] != NULL && in_mesh(miga, emap, nedges, ivec, dej[i])) |
190 |
return(1); |
191 |
if ((sej[i] == NULL) | (dej[i] == NULL)) |
192 |
continue; |
193 |
if (in_tri(mig->rbfv[0], mig->rbfv[1], tv[i], ivec)) { |
194 |
miga[0] = mig; |
195 |
miga[1] = sej[i]; |
196 |
miga[2] = dej[i]; |
197 |
return(1); |
198 |
199 |
200 |
return(0); /* not near this edge */ |
201 |
202 |
203 |
/* Find edge(s) for interpolating the given vector, applying symmetry */ |
204 |
int |
205 |
get_interp(MIGRATION *miga[3], FVECT invec) |
206 |
207 |
miga[0] = miga[1] = miga[2] = NULL; |
208 |
if (single_plane_incident) { /* isotropic BSDF? */ |
209 |
RBFNODE *rbf; /* find edge we're on */ |
210 |
for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) { |
211 |
if (input_orient*rbf->invec[2] < input_orient*invec[2]-FTINY) |
212 |
break; |
213 |
if (rbf->next != NULL && input_orient*rbf->next->invec[2] < |
214 |
input_orient*invec[2]+FTINY) { |
215 |
for (miga[0] = rbf->ejl; miga[0] != NULL; |
216 |
miga[0] = nextedge(rbf,miga[0])) |
217 |
if (opp_rbf(rbf,miga[0]) == rbf->next) { |
218 |
double nf = 1. - |
219 |
rbf->next->invec[2]*rbf->next->invec[2]; |
220 |
if (nf > FTINY) { /* rotate to match */ |
221 |
nf = sqrt((1.-invec[2]*invec[2])/nf); |
222 |
invec[0] = nf*rbf->next->invec[0]; |
223 |
invec[1] = nf*rbf->next->invec[1]; |
224 |
225 |
return(0); /* rotational symmetry */ |
226 |
227 |
break; |
228 |
229 |
230 |
return(-1); /* outside range! */ |
231 |
232 |
{ /* else use triangle mesh */ |
233 |
int sym = use_symmetry(invec); |
234 |
int nedges = 0; |
235 |
MIGRATION *mep; |
236 |
unsigned char *emap; |
237 |
/* clear visitation map */ |
238 |
for (mep = mig_list; mep != NULL; mep = mep->next) |
239 |
++nedges; |
240 |
emap = (unsigned char *)calloc((nedges*(nedges-1) + 7)>>3, 1); |
241 |
if (emap == NULL) { |
242 |
fprintf(stderr, "%s: Out of memory in get_interp()\n", |
243 |
progname); |
244 |
exit(1); |
245 |
246 |
/* identify intersection */ |
247 |
if (!in_mesh(miga, emap, nedges, invec, mig_list)) { |
248 |
#ifdef DEBUG |
249 |
fprintf(stderr, |
250 |
"Incident angle (%.1f,%.1f) deg. outside mesh\n", |
251 |
get_theta180(invec), get_phi360(invec)); |
252 |
#endif |
253 |
sym = -1; /* outside mesh */ |
254 |
} else if (miga[1] != NULL && |
255 |
(miga[2] == NULL || !order_triangle(miga))) { |
256 |
#ifdef DEBUG |
257 |
fputs("Munged triangle in get_interp()\n", stderr); |
258 |
#endif |
259 |
sym = -1; |
260 |
261 |
free(emap); |
262 |
return(sym); /* return in standard order */ |
263 |
264 |
265 |
266 |
/* Advect between recorded incident angles and allocate new RBF */ |
267 |
RBFNODE * |
268 |
advect_rbf(const FVECT invec, int lobe_lim) |
269 |
270 |
double cthresh = FTINY; |
271 |
FVECT sivec; |
272 |
MIGRATION *miga[3]; |
273 |
RBFNODE *rbf; |
274 |
int sym; |
275 |
float mbfact, mcfact; |
276 |
int n, i, j, k; |
277 |
FVECT v0, v1, v2; |
278 |
double s, t; |
279 |
280 |
VCOPY(sivec, invec); /* find triangle/edge */ |
281 |
sym = get_interp(miga, sivec); |
282 |
if (sym < 0) /* can't interpolate? */ |
283 |
return(def_rbf_spec(invec)); |
284 |
if (miga[1] == NULL) { /* advect along edge? */ |
285 |
rbf = e_advect_rbf(miga[0], sivec, lobe_lim); |
286 |
if (single_plane_incident) |
287 |
rotate_rbf(rbf, invec); |
288 |
else |
289 |
rev_rbf_symmetry(rbf, sym); |
290 |
return(rbf); |
291 |
292 |
#ifdef DEBUG |
293 |
if ((miga[0]->rbfv[0] != miga[2]->rbfv[0]) | |
294 |
(miga[0]->rbfv[1] != miga[1]->rbfv[0]) | |
295 |
(miga[1]->rbfv[1] != miga[2]->rbfv[1])) { |
296 |
fprintf(stderr, "%s: Triangle vertex screw-up!\n", progname); |
297 |
exit(1); |
298 |
299 |
#endif |
300 |
/* figure out position */ |
301 |
fcross(v0, miga[2]->rbfv[0]->invec, miga[2]->rbfv[1]->invec); |
302 |
normalize(v0); |
303 |
fcross(v2, miga[1]->rbfv[0]->invec, miga[1]->rbfv[1]->invec); |
304 |
normalize(v2); |
305 |
fcross(v1, sivec, miga[1]->rbfv[1]->invec); |
306 |
normalize(v1); |
307 |
s = acos(DOT(v0,v1)) / acos(DOT(v0,v2)); |
308 |
geodesic(v1, miga[0]->rbfv[0]->invec, miga[0]->rbfv[1]->invec, |
309 |
s, GEOD_REL); |
310 |
t = acos(DOT(v1,sivec)) / acos(DOT(v1,miga[1]->rbfv[1]->invec)); |
311 |
tryagain: |
312 |
n = 0; /* count migrating particles */ |
313 |
for (i = 0; i < mtx_nrows(miga[0]); i++) |
314 |
for (j = 0; j < mtx_ncols(miga[0]); j++) |
315 |
for (k = (mtx_coef(miga[0],i,j) > cthresh) * |
316 |
mtx_ncols(miga[2]); k--; ) |
317 |
n += (mtx_coef(miga[2],i,k) > cthresh || |
318 |
mtx_coef(miga[1],j,k) > cthresh); |
319 |
/* are we over our limit? */ |
320 |
if ((lobe_lim > 0) & (n > lobe_lim)) { |
321 |
cthresh = cthresh*2. + 10.*FTINY; |
322 |
goto tryagain; |
323 |
324 |
#ifdef DEBUG |
325 |
fprintf(stderr, "Input RBFs have %d, %d, %d nodes -> output has %d\n", |
326 |
miga[0]->rbfv[0]->nrbf, miga[0]->rbfv[1]->nrbf, |
327 |
miga[2]->rbfv[1]->nrbf, n); |
328 |
#endif |
329 |
rbf = (RBFNODE *)malloc(sizeof(RBFNODE) + sizeof(RBFVAL)*(n-1)); |
330 |
if (rbf == NULL) { |
331 |
fprintf(stderr, "%s: Out of memory in advect_rbf()\n", progname); |
332 |
exit(1); |
333 |
334 |
rbf->next = NULL; rbf->ejl = NULL; |
335 |
VCOPY(rbf->invec, sivec); |
336 |
rbf->nrbf = n; |
337 |
n = 0; /* compute RBF lobes */ |
338 |
mbfact = s * miga[0]->rbfv[1]->vtotal/miga[0]->rbfv[0]->vtotal * |
339 |
(1.-t + t*miga[1]->rbfv[1]->vtotal/miga[1]->rbfv[0]->vtotal); |
340 |
mcfact = (1.-s) * |
341 |
(1.-t + t*miga[2]->rbfv[1]->vtotal/miga[2]->rbfv[0]->vtotal); |
342 |
for (i = 0; i < mtx_nrows(miga[0]); i++) { |
343 |
const RBFVAL *rbf0i = &miga[0]->rbfv[0]->rbfa[i]; |
344 |
const float w0i = rbf0i->peak; |
345 |
const double rad0i = R2ANG(rbf0i->crad); |
346 |
C_COLOR cc0; |
347 |
ovec_from_pos(v0, rbf0i->gx, rbf0i->gy); |
348 |
c_decodeChroma(&cc0, rbf0i->chroma); |
349 |
for (j = 0; j < mtx_ncols(miga[0]); j++) { |
350 |
const float ma = mtx_coef(miga[0],i,j); |
351 |
const RBFVAL *rbf1j; |
352 |
C_COLOR ccs; |
353 |
double srad2; |
354 |
if (ma <= cthresh) |
355 |
continue; |
356 |
rbf1j = &miga[0]->rbfv[1]->rbfa[j]; |
357 |
c_decodeChroma(&ccs, rbf1j->chroma); |
358 |
c_cmix(&ccs, 1.-s, &cc0, s, &ccs); |
359 |
srad2 = R2ANG(rbf1j->crad); |
360 |
srad2 = (1.-s)*(1.-t)*rad0i*rad0i + s*(1.-t)*srad2*srad2; |
361 |
ovec_from_pos(v1, rbf1j->gx, rbf1j->gy); |
362 |
geodesic(v1, v0, v1, s, GEOD_REL); |
363 |
for (k = 0; k < mtx_ncols(miga[2]); k++) { |
364 |
float mb = mtx_coef(miga[1],j,k); |
365 |
float mc = mtx_coef(miga[2],i,k); |
366 |
const RBFVAL *rbf2k; |
367 |
double rad2; |
368 |
int pos[2]; |
369 |
if ((mb <= cthresh) & (mc <= cthresh)) |
370 |
continue; |
371 |
rbf2k = &miga[2]->rbfv[1]->rbfa[k]; |
372 |
rad2 = R2ANG(rbf2k->crad); |
373 |
rad2 = srad2 + t*rad2*rad2; |
374 |
rbf->rbfa[n].peak = w0i * ma * (mb*mbfact + mc*mcfact) * |
375 |
rad0i*rad0i/rad2; |
376 |
if (rbf_colorimetry == RBCtristimulus) { |
377 |
C_COLOR cres; |
378 |
c_decodeChroma(&cres, rbf2k->chroma); |
379 |
c_cmix(&cres, 1.-t, &ccs, t, &cres); |
380 |
rbf->rbfa[n].chroma = c_encodeChroma(&cres); |
381 |
} else |
382 |
rbf->rbfa[n].chroma = c_dfchroma; |
383 |
rbf->rbfa[n].crad = ANG2R(sqrt(rad2)); |
384 |
ovec_from_pos(v2, rbf2k->gx, rbf2k->gy); |
385 |
geodesic(v2, v1, v2, t, GEOD_REL); |
386 |
pos_from_vec(pos, v2); |
387 |
rbf->rbfa[n].gx = pos[0]; |
388 |
rbf->rbfa[n].gy = pos[1]; |
389 |
++n; |
390 |
391 |
392 |
393 |
rbf->vtotal = miga[0]->rbfv[0]->vtotal * (mbfact + mcfact); |
394 |
395 |
return(rbf); |
396 |
