root/radiance/ray/src/cv/bsdfinterp.c
Fri Jan 29 16:21:55 2016 UTC (8 years, 4 months ago) by greg
Changes since 2.20: +13 -1 lines
Diff to previous 2.20 , to selected 2.12
Sun Oct 26 17:35:53 2014 UTC (9 years, 7 months ago) by greg
CVS Tags: rad4R2P2, rad5R0
Changes since 2.19: +1 -3 lines
Diff to previous 2.19 , to selected 2.12
Thu Aug 21 10:33:48 2014 UTC (9 years, 9 months ago) by greg
CVS Tags: rad4R2P1
Changes since 2.18: +4 -2 lines
Diff to previous 2.18 , to selected 2.12
Mon Mar 24 17:22:33 2014 UTC (10 years, 2 months ago) by greg
CVS Tags: rad4R2
Changes since 2.17: +6 -5 lines
Diff to previous 2.17 , to selected 2.12
Major bug in isotropic material interpolation near normal
Wed Feb 19 05:16:06 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.16: +1 -87 lines
Eliminated redundant code added in last change to bsdfmesh.c
Tue Feb 18 16:06:51 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.15: +7 -7 lines
Added normal incidence interpolation for quadrilateral and radial symmetry
Wed Oct 23 03:41:39 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.14: +5 -1 lines
Fixed rounding error
Tue Oct 22 04:29:27 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.13: +16 -12 lines
Thu Sep 26 17:15:22 2013 UTC (10 years, 8 months ago) by greg
Changes since 2.12: +14 -6 lines
Diff to previous 2.12
Added limit to number of lobes for edge advection as well
Thu Sep 26 17:05:00 2013 UTC (10 years, 8 months ago) by greg
Changes since 2.11: +13 -7 lines
Added -l option to limit maximum number of RBF lobes for interpolation
Sat Jun 29 21:03:25 2013 UTC (10 years, 11 months ago) by greg
Fri Dec 14 23:16:43 2012 UTC (11 years, 5 months ago) by greg
Changes since 2.9: +19 -20 lines
Improved formatting
Fri Dec 14 22:41:44 2012 UTC (11 years, 5 months ago) by greg
Changes since 2.8: +40 -26 lines
Fixed missing interpolation value bug
Wed Dec 12 04:49:59 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.7: +8 -8 lines
Fixed main bug, which was forgetting Klems axis reversal
Mon Nov 26 07:02:20 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.6: +5 -6 lines
Fixed bug introduced during last change
Thu Nov 22 06:07:17 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.5: +11 -9 lines
Thu Nov 8 00:31:17 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.4: +15 -5 lines
Tue Oct 23 21:09:29 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.3: +62 -35 lines
First semi-working version
Tue Oct 23 05:10:42 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.2: +96 -184 lines
Hopeful bug fix in BSDF interpolation code
Sat Oct 20 07:02:00 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.1: +9 -9 lines
Bug fixes and minor improvements
Fri Oct 19 04:14:29 2012 UTC (11 years, 7 months ago) by greg
Diff to selected 2.12
