1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: bsdfinterp.c,v 2.1 2012/10/19 04:14:29 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Interpolate BSDF data from radial basis functions in advection mesh. |
6 |
7 |
* G. Ward |
8 |
9 |
10 |
#define _USE_MATH_DEFINES |
11 |
#include <stdio.h> |
12 |
#include <stdlib.h> |
13 |
#include <string.h> |
14 |
#include <math.h> |
15 |
#include "bsdfrep.h" |
16 |
/* migration edges drawn in raster fashion */ |
17 |
MIGRATION *mig_grid[GRIDRES][GRIDRES]; |
18 |
19 |
#ifdef DEBUG |
20 |
#include "random.h" |
21 |
#include "bmpfile.h" |
22 |
/* Hash pointer to byte value (must return 0 for NULL) */ |
23 |
static int |
24 |
byte_hash(const void *p) |
25 |
26 |
size_t h = (size_t)p; |
27 |
h ^= (size_t)p >> 8; |
28 |
h ^= (size_t)p >> 16; |
29 |
h ^= (size_t)p >> 24; |
30 |
return(h & 0xff); |
31 |
32 |
/* Write out BMP image showing edges */ |
33 |
static void |
34 |
write_edge_image(const char *fname) |
35 |
36 |
BMPHeader *hdr = BMPmappedHeader(GRIDRES, GRIDRES, 0, 256); |
37 |
BMPWriter *wtr; |
38 |
int i, j; |
39 |
40 |
fprintf(stderr, "Writing incident mesh drawing to '%s'\n", fname); |
41 |
hdr->compr = BI_RLE8; |
42 |
for (i = 256; --i; ) { /* assign random color map */ |
43 |
hdr->palette[i].r = random() & 0xff; |
44 |
hdr->palette[i].g = random() & 0xff; |
45 |
hdr->palette[i].b = random() & 0xff; |
46 |
/* reject dark colors */ |
47 |
i += (hdr->palette[i].r + hdr->palette[i].g + |
48 |
hdr->palette[i].b < 128); |
49 |
50 |
hdr->palette[0].r = hdr->palette[0].g = hdr->palette[0].b = 0; |
51 |
/* open output */ |
52 |
wtr = BMPopenOutputFile(fname, hdr); |
53 |
if (wtr == NULL) { |
54 |
free(hdr); |
55 |
return; |
56 |
57 |
for (i = 0; i < GRIDRES; i++) { /* write scanlines */ |
58 |
for (j = 0; j < GRIDRES; j++) |
59 |
wtr->scanline[j] = byte_hash(mig_grid[i][j]); |
60 |
if (BMPwriteScanline(wtr) != BIR_OK) |
61 |
break; |
62 |
63 |
BMPcloseOutput(wtr); /* close & clean up */ |
64 |
65 |
#endif |
66 |
67 |
/* Draw edge list into mig_grid array */ |
68 |
void |
69 |
draw_edges(void) |
70 |
71 |
int nnull = 0, ntot = 0; |
72 |
MIGRATION *ej; |
73 |
int p0[2], p1[2]; |
74 |
75 |
memset(mig_grid, 0, sizeof(mig_grid)); |
76 |
for (ej = mig_list; ej != NULL; ej = ej->next) { |
77 |
++ntot; |
78 |
pos_from_vec(p0, ej->rbfv[0]->invec); |
79 |
pos_from_vec(p1, ej->rbfv[1]->invec); |
80 |
if ((p0[0] == p1[0]) & (p0[1] == p1[1])) { |
81 |
++nnull; |
82 |
mig_grid[p0[0]][p0[1]] = ej; |
83 |
continue; |
84 |
85 |
if (abs(p1[0]-p0[0]) > abs(p1[1]-p0[1])) { |
86 |
const int xstep = 2*(p1[0] > p0[0]) - 1; |
87 |
const double ystep = (double)((p1[1]-p0[1])*xstep) / |
88 |
(double)(p1[0]-p0[0]); |
89 |
int x; |
90 |
double y; |
91 |
for (x = p0[0], y = p0[1]+.5; x != p1[0]; |
92 |
x += xstep, y += ystep) |
93 |
mig_grid[x][(int)y] = ej; |
94 |
95 |
} else { |
96 |
const int ystep = 2*(p1[1] > p0[1]) - 1; |
97 |
const double xstep = (double)((p1[0]-p0[0])*ystep) / |
98 |
(double)(p1[1]-p0[1]); |
99 |
int y; |
100 |
double x; |
101 |
for (y = p0[1], x = p0[0]+.5; y != p1[1]; |
102 |
y += ystep, x += xstep) |
103 |
mig_grid[(int)x][y] = ej; |
104 |
105 |
106 |
107 |
if (nnull) |
108 |
fprintf(stderr, "Warning: %d of %d edges are null\n", |
109 |
nnull, ntot); |
110 |
#ifdef DEBUG |
111 |
write_edge_image("bsdf_edges.bmp"); |
112 |
#endif |
113 |
114 |
115 |
/* Identify enclosing triangle for this position (flood fill raster check) */ |
116 |
static int |
117 |
identify_tri(MIGRATION *miga[3], unsigned char vmap[GRIDRES][(GRIDRES+7)/8], |
118 |
int px, int py) |
119 |
120 |
const int btest = 1<<(py&07); |
121 |
122 |
if (vmap[px][py>>3] & btest) /* already visited here? */ |
123 |
return(1); |
124 |
/* else mark it */ |
125 |
vmap[px][py>>3] |= btest; |
126 |
127 |
if (mig_grid[px][py] != NULL) { /* are we on an edge? */ |
128 |
int i; |
129 |
for (i = 0; i < 3; i++) { |
130 |
if (miga[i] == mig_grid[px][py]) |
131 |
return(1); |
132 |
if (miga[i] != NULL) |
133 |
continue; |
134 |
miga[i] = mig_grid[px][py]; |
135 |
return(1); |
136 |
137 |
return(0); /* outside triangle! */ |
138 |
139 |
/* check neighbors (flood) */ |
140 |
if (px > 0 && !identify_tri(miga, vmap, px-1, py)) |
141 |
return(0); |
142 |
if (px < GRIDRES-1 && !identify_tri(miga, vmap, px+1, py)) |
143 |
return(0); |
144 |
if (py > 0 && !identify_tri(miga, vmap, px, py-1)) |
145 |
return(0); |
146 |
if (py < GRIDRES-1 && !identify_tri(miga, vmap, px, py+1)) |
147 |
return(0); |
148 |
return(1); /* this neighborhood done */ |
149 |
150 |
151 |
/* Insert vertex in ordered list */ |
152 |
static void |
153 |
insert_vert(RBFNODE **vlist, RBFNODE *v) |
154 |
155 |
int i, j; |
156 |
157 |
for (i = 0; vlist[i] != NULL; i++) { |
158 |
if (v == vlist[i]) |
159 |
return; |
160 |
if (v->ord < vlist[i]->ord) |
161 |
break; |
162 |
163 |
for (j = i; vlist[j] != NULL; j++) |
164 |
165 |
while (j > i) { |
166 |
vlist[j] = vlist[j-1]; |
167 |
--j; |
168 |
169 |
vlist[i] = v; |
170 |
171 |
172 |
/* Sort triangle edges in standard order */ |
173 |
static int |
174 |
order_triangle(MIGRATION *miga[3]) |
175 |
176 |
RBFNODE *vert[7]; |
177 |
MIGRATION *ord[3]; |
178 |
int i; |
179 |
/* order vertices, first */ |
180 |
memset(vert, 0, sizeof(vert)); |
181 |
for (i = 3; i--; ) { |
182 |
if (miga[i] == NULL) |
183 |
return(0); |
184 |
insert_vert(vert, miga[i]->rbfv[0]); |
185 |
insert_vert(vert, miga[i]->rbfv[1]); |
186 |
187 |
/* should be just 3 vertices */ |
188 |
if ((vert[3] == NULL) | (vert[4] != NULL)) |
189 |
return(0); |
190 |
/* identify edge 0 */ |
191 |
for (i = 3; i--; ) |
192 |
if (miga[i]->rbfv[0] == vert[0] && |
193 |
miga[i]->rbfv[1] == vert[1]) { |
194 |
ord[0] = miga[i]; |
195 |
break; |
196 |
197 |
if (i < 0) |
198 |
return(0); |
199 |
/* identify edge 1 */ |
200 |
201 |
if (miga[i]->rbfv[0] == vert[1] && |
202 |
miga[i]->rbfv[1] == vert[2]) { |
203 |
ord[1] = miga[i]; |
204 |
break; |
205 |
206 |
if (i < 0) |
207 |
return(0); |
208 |
/* identify edge 2 */ |
209 |
210 |
211 |
212 |
ord[2] = miga[i]; |
213 |
break; |
214 |
215 |
if (i < 0) |
216 |
return(0); |
217 |
/* reassign order */ |
218 |
miga[0] = ord[0]; miga[1] = ord[1]; miga[2] = ord[2]; |
219 |
return(1); |
220 |
221 |
222 |
/* Find edge(s) for interpolating the given vector, applying symmetry */ |
223 |
int |
224 |
get_interp(MIGRATION *miga[3], FVECT invec) |
225 |
226 |
miga[0] = miga[1] = miga[2] = NULL; |
227 |
if (single_plane_incident) { /* isotropic BSDF? */ |
228 |
RBFNODE *rbf; /* find edge we're on */ |
229 |
for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) { |
230 |
if (input_orient*rbf->invec[2] < input_orient*invec[2]) |
231 |
break; |
232 |
if (rbf->next != NULL && |
233 |
input_orient*rbf->next->invec[2] < |
234 |
input_orient*invec[2]) { |
235 |
for (miga[0] = rbf->ejl; miga[0] != NULL; |
236 |
miga[0] = nextedge(rbf,miga[0])) |
237 |
if (opp_rbf(rbf,miga[0]) == rbf->next) |
238 |
return(0); |
239 |
break; |
240 |
241 |
242 |
return(-1); /* outside range! */ |
243 |
244 |
{ /* else use triangle mesh */ |
245 |
const int sym = use_symmetry(invec); |
246 |
unsigned char floodmap[GRIDRES][(GRIDRES+7)/8]; |
247 |
int pstart[2]; |
248 |
RBFNODE *vother; |
249 |
MIGRATION *ej; |
250 |
int i; |
251 |
252 |
pos_from_vec(pstart, invec); |
253 |
memset(floodmap, 0, sizeof(floodmap)); |
254 |
/* call flooding function */ |
255 |
if (!identify_tri(miga, floodmap, pstart[0], pstart[1])) |
256 |
return(-1); /* outside mesh */ |
257 |
if ((miga[0] == NULL) | (miga[2] == NULL)) |
258 |
return(-1); /* should never happen */ |
259 |
if (miga[1] == NULL) |
260 |
return(sym); /* on edge */ |
261 |
/* verify triangle */ |
262 |
if (!order_triangle(miga)) { |
263 |
#ifdef DEBUG |
264 |
fputs("Munged triangle in get_interp()\n", stderr); |
265 |
#endif |
266 |
vother = NULL; /* find triangle from edge */ |
267 |
268 |
RBFNODE *tpair[2]; |
269 |
if (get_triangles(tpair, miga[i]) && |
270 |
(vother = tpair[ is_rev_tri( |
271 |
miga[i]->rbfv[0]->invec, |
272 |
miga[i]->rbfv[1]->invec, |
273 |
invec) ]) != NULL) |
274 |
break; |
275 |
276 |
if (vother == NULL) { /* couldn't find 3rd vertex */ |
277 |
#ifdef DEBUG |
278 |
fputs("No triangle in get_interp()\n", stderr); |
279 |
#endif |
280 |
return(-1); |
281 |
282 |
/* reassign other two edges */ |
283 |
for (ej = vother->ejl; ej != NULL; |
284 |
ej = nextedge(vother,ej)) { |
285 |
RBFNODE *vorig = opp_rbf(vother,ej); |
286 |
if (vorig == miga[i]->rbfv[0]) |
287 |
miga[(i+1)%3] = ej; |
288 |
else if (vorig == miga[i]->rbfv[1]) |
289 |
miga[(i+2)%3] = ej; |
290 |
291 |
292 |
#ifdef DEBUG |
293 |
fputs("Bad triangle in get_interp()\n", stderr); |
294 |
#endif |
295 |
return(-1); |
296 |
297 |
298 |
return(sym); /* return in standard order */ |
299 |
300 |
301 |
302 |
/* Advect and allocate new RBF along edge */ |
303 |
static RBFNODE * |
304 |
e_advect_rbf(const MIGRATION *mig, const FVECT invec) |
305 |
306 |
RBFNODE *rbf; |
307 |
int n, i, j; |
308 |
double t, full_dist; |
309 |
/* get relative position */ |
310 |
t = acos(DOT(invec, mig->rbfv[0]->invec)); |
311 |
if (t < M_PI/GRIDRES) { /* near first DSF */ |
312 |
n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[0]->nrbf-1); |
313 |
rbf = (RBFNODE *)malloc(n); |
314 |
if (rbf == NULL) |
315 |
goto memerr; |
316 |
memcpy(rbf, mig->rbfv[0], n); /* just duplicate */ |
317 |
return(rbf); |
318 |
319 |
full_dist = acos(DOT(mig->rbfv[0]->invec, mig->rbfv[1]->invec)); |
320 |
if (t > full_dist-M_PI/GRIDRES) { /* near second DSF */ |
321 |
n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[1]->nrbf-1); |
322 |
323 |
if (rbf == NULL) |
324 |
goto memerr; |
325 |
memcpy(rbf, mig->rbfv[1], n); /* just duplicate */ |
326 |
return(rbf); |
327 |
328 |
t /= full_dist; |
329 |
n = 0; /* count migrating particles */ |
330 |
for (i = 0; i < mtx_nrows(mig); i++) |
331 |
for (j = 0; j < mtx_ncols(mig); j++) |
332 |
n += (mtx_coef(mig,i,j) > FTINY); |
333 |
#ifdef DEBUG |
334 |
fprintf(stderr, "Input RBFs have %d, %d nodes -> output has %d\n", |
335 |
mig->rbfv[0]->nrbf, mig->rbfv[1]->nrbf, n); |
336 |
#endif |
337 |
rbf = (RBFNODE *)malloc(sizeof(RBFNODE) + sizeof(RBFVAL)*(n-1)); |
338 |
if (rbf == NULL) |
339 |
goto memerr; |
340 |
rbf->next = NULL; rbf->ejl = NULL; |
341 |
VCOPY(rbf->invec, invec); |
342 |
rbf->nrbf = n; |
343 |
rbf->vtotal = 1.-t + t*mig->rbfv[1]->vtotal/mig->rbfv[0]->vtotal; |
344 |
n = 0; /* advect RBF lobes */ |
345 |
for (i = 0; i < mtx_nrows(mig); i++) { |
346 |
const RBFVAL *rbf0i = &mig->rbfv[0]->rbfa[i]; |
347 |
const float peak0 = rbf0i->peak; |
348 |
const double rad0 = R2ANG(rbf0i->crad); |
349 |
FVECT v0; |
350 |
float mv; |
351 |
ovec_from_pos(v0, rbf0i->gx, rbf0i->gy); |
352 |
353 |
if ((mv = mtx_coef(mig,i,j)) > FTINY) { |
354 |
const RBFVAL *rbf1j = &mig->rbfv[1]->rbfa[j]; |
355 |
double rad1 = R2ANG(rbf1j->crad); |
356 |
FVECT v; |
357 |
int pos[2]; |
358 |
rbf->rbfa[n].peak = peak0 * mv * rbf->vtotal; |
359 |
rbf->rbfa[n].crad = ANG2R(sqrt(rad0*rad0*(1.-t) + |
360 |
rad1*rad1*t)); |
361 |
ovec_from_pos(v, rbf1j->gx, rbf1j->gy); |
362 |
geodesic(v, v0, v, t, GEOD_REL); |
363 |
pos_from_vec(pos, v); |
364 |
rbf->rbfa[n].gx = pos[0]; |
365 |
rbf->rbfa[n].gy = pos[1]; |
366 |
++n; |
367 |
368 |
369 |
rbf->vtotal *= mig->rbfv[0]->vtotal; /* turn ratio into actual */ |
370 |
return(rbf); |
371 |
memerr: |
372 |
fprintf(stderr, "%s: Out of memory in e_advect_rbf()\n", progname); |
373 |
exit(1); |
374 |
return(NULL); /* pro forma return */ |
375 |
376 |
377 |
/* Partially advect between recorded incident angles and allocate new RBF */ |
378 |
RBFNODE * |
379 |
advect_rbf(const FVECT invec) |
380 |
381 |
FVECT sivec; |
382 |
MIGRATION *miga[3]; |
383 |
RBFNODE *rbf; |
384 |
int sym; |
385 |
float mbfact, mcfact; |
386 |
int n, i, j, k; |
387 |
FVECT v0, v1, v2; |
388 |
double s, t; |
389 |
390 |
VCOPY(sivec, invec); /* find triangle/edge */ |
391 |
sym = get_interp(miga, sivec); |
392 |
if (sym < 0) /* can't interpolate? */ |
393 |
return(NULL); |
394 |
if (miga[1] == NULL) { /* advect along edge? */ |
395 |
rbf = e_advect_rbf(miga[0], sivec); |
396 |
rev_rbf_symmetry(rbf, sym); |
397 |
return(rbf); |
398 |
399 |
#ifdef DEBUG |
400 |
if (miga[0]->rbfv[0] != miga[2]->rbfv[0] | |
401 |
miga[0]->rbfv[1] != miga[1]->rbfv[0] | |
402 |
miga[1]->rbfv[1] != miga[2]->rbfv[1]) { |
403 |
fprintf(stderr, "%s: Triangle vertex screw-up!\n", progname); |
404 |
exit(1); |
405 |
406 |
#endif |
407 |
/* figure out position */ |
408 |
fcross(v0, miga[2]->rbfv[0]->invec, miga[2]->rbfv[1]->invec); |
409 |
normalize(v0); |
410 |
fcross(v2, miga[1]->rbfv[0]->invec, miga[1]->rbfv[1]->invec); |
411 |
normalize(v2); |
412 |
fcross(v1, sivec, miga[1]->rbfv[1]->invec); |
413 |
normalize(v1); |
414 |
s = acos(DOT(v0,v1)) / acos(DOT(v0,v2)); |
415 |
geodesic(v1, miga[0]->rbfv[0]->invec, miga[0]->rbfv[1]->invec, |
416 |
s, GEOD_REL); |
417 |
t = acos(DOT(v1,sivec)) / acos(DOT(v1,miga[1]->rbfv[1]->invec)); |
418 |
419 |
for (i = 0; i < mtx_nrows(miga[0]); i++) |
420 |
for (j = 0; j < mtx_ncols(miga[0]); j++) |
421 |
for (k = (mtx_coef(miga[0],i,j) > FTINY) * |
422 |
mtx_ncols(miga[2]); k--; ) |
423 |
n += (mtx_coef(miga[2],i,k) > FTINY && |
424 |
mtx_coef(miga[1],j,k) > FTINY); |
425 |
#ifdef DEBUG |
426 |
fprintf(stderr, "Input RBFs have %d, %d, %d nodes -> output has %d\n", |
427 |
miga[0]->rbfv[0]->nrbf, miga[0]->rbfv[1]->nrbf, |
428 |
miga[2]->rbfv[1]->nrbf, n); |
429 |
#endif |
430 |
431 |
if (rbf == NULL) { |
432 |
fprintf(stderr, "%s: Out of memory in advect_rbf()\n", progname); |
433 |
exit(1); |
434 |
435 |
436 |
VCOPY(rbf->invec, sivec); |
437 |
rbf->nrbf = n; |
438 |
n = 0; /* compute RBF lobes */ |
439 |
mbfact = s * miga[0]->rbfv[1]->vtotal/miga[0]->rbfv[0]->vtotal * |
440 |
(1.-t + t*miga[1]->rbfv[1]->vtotal/miga[1]->rbfv[0]->vtotal); |
441 |
mcfact = (1.-s) * |
442 |
(1.-t + t*miga[2]->rbfv[1]->vtotal/miga[2]->rbfv[0]->vtotal); |
443 |
for (i = 0; i < mtx_nrows(miga[0]); i++) { |
444 |
const RBFVAL *rbf0i = &miga[0]->rbfv[0]->rbfa[i]; |
445 |
const float w0i = rbf0i->peak; |
446 |
const double rad0i = R2ANG(rbf0i->crad); |
447 |
448 |
for (j = 0; j < mtx_ncols(miga[0]); j++) { |
449 |
const float ma = mtx_coef(miga[0],i,j); |
450 |
const RBFVAL *rbf1j; |
451 |
double rad1j, srad2; |
452 |
if (ma <= FTINY) |
453 |
continue; |
454 |
rbf1j = &miga[0]->rbfv[1]->rbfa[j]; |
455 |
rad1j = R2ANG(rbf1j->crad); |
456 |
srad2 = (1.-s)*(1.-t)*rad0i*rad0i + s*(1.-t)*rad1j*rad1j; |
457 |
ovec_from_pos(v1, rbf1j->gx, rbf1j->gy); |
458 |
geodesic(v1, v0, v1, s, GEOD_REL); |
459 |
for (k = 0; k < mtx_ncols(miga[2]); k++) { |
460 |
float mb = mtx_coef(miga[1],j,k); |
461 |
float mc = mtx_coef(miga[2],i,k); |
462 |
const RBFVAL *rbf2k; |
463 |
double rad2k; |
464 |
FVECT vout; |
465 |
int pos[2]; |
466 |
if ((mb <= FTINY) | (mc <= FTINY)) |
467 |
continue; |
468 |
rbf2k = &miga[2]->rbfv[1]->rbfa[k]; |
469 |
rbf->rbfa[n].peak = w0i * ma * (mb*mbfact + mc*mcfact); |
470 |
rad2k = R2ANG(rbf2k->crad); |
471 |
rbf->rbfa[n].crad = ANG2R(sqrt(srad2 + t*rad2k*rad2k)); |
472 |
ovec_from_pos(v2, rbf2k->gx, rbf2k->gy); |
473 |
geodesic(vout, v1, v2, t, GEOD_REL); |
474 |
pos_from_vec(pos, vout); |
475 |
476 |
477 |
++n; |
478 |
479 |
480 |
481 |
rbf->vtotal = miga[0]->rbfv[0]->vtotal * (mbfact + mcfact); |
482 |
483 |
return(rbf); |
484 |
