| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.50 2020/05/11 20:26:58 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Load measured BSDF interpolant and write out as XML file with tensor tree.
| 6 |
| 7 |
* G. Ward
| 8 |
| 9 |
| 10 |
#define _USE_MATH_DEFINES
| 11 |
#include <stdlib.h>
| 12 |
#include <math.h>
| 13 |
#include "random.h"
| 14 |
#include "platform.h"
| 15 |
#include "paths.h"
| 16 |
#include "rtio.h"
| 17 |
#include "calcomp.h"
| 18 |
#include "bsdfrep.h"
| 19 |
/* global argv[0] */
| 20 |
char *progname;
| 21 |
/* reciprocity averaging option */
| 22 |
static const char *recip = " -a";
| 23 |
/* percentage to cull (<0 to turn off) */
| 24 |
static double pctcull = 90.;
| 25 |
/* sampling order */
| 26 |
static int samp_order = 6;
| 27 |
/* super-sampling threshold */
| 28 |
static double ssamp_thresh = 0.35;
| 29 |
/* number of super-samples */
| 30 |
#ifndef NSSAMP
| 31 |
#define NSSAMP 256
| 32 |
#endif
| 33 |
/* limit on number of RBF lobes */
| 34 |
static int lobe_lim = 15000;
| 35 |
/* progress bar length */
| 36 |
static int do_prog = 79;
| 37 |
| 38 |
#define MAXCARG 512 /* wrapBSDF command */
| 39 |
static char *wrapBSDF[MAXCARG] = {"wrapBSDF", "-U"};
| 40 |
static int wbsdfac = 2;
| 41 |
| 42 |
/* Add argument to wrapBSDF, allocating space if !isstatic */
| 43 |
static void
| 44 |
add_wbsdf(const char *arg, int isstatic)
| 45 |
| 46 |
if (arg == NULL)
| 47 |
return;
| 48 |
if (wbsdfac >= MAXCARG-1) {
| 49 |
fputs(progname, stderr);
| 50 |
fputs(": too many command arguments to wrapBSDF\n", stderr);
| 51 |
exit(1);
| 52 |
| 53 |
if (!*arg)
| 54 |
arg = "";
| 55 |
else if (!isstatic)
| 56 |
arg = savqstr((char *)arg);
| 57 |
| 58 |
wrapBSDF[wbsdfac++] = (char *)arg;
| 59 |
| 60 |
| 61 |
/* Create Yuv component file and add appropriate arguments */
| 62 |
static char *
| 63 |
create_component_file(int c)
| 64 |
| 65 |
static const char sname[3][6] = {"CIE-Y", "CIE-u", "CIE-v"};
| 66 |
static const char cname[4][4] = {"-rf", "-tf", "-tb", "-rb"};
| 67 |
char *tfname = mktemp(savqstr(TEMPLATE));
| 68 |
| 69 |
add_wbsdf("-s", 1); add_wbsdf(sname[c], 1);
| 70 |
add_wbsdf(cname[(input_orient>0)<<1 | (output_orient>0)], 1);
| 71 |
add_wbsdf(tfname, 1);
| 72 |
return(tfname);
| 73 |
| 74 |
| 75 |
/* Start new progress bar */
| 76 |
#define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else
| 77 |
| 78 |
/* Draw progress bar of the appropriate length */
| 79 |
static void
| 80 |
prog_show(double frac)
| 81 |
| 82 |
static unsigned call_cnt = 0;
| 83 |
static char lastc[] = "-\\|/";
| 84 |
char pbar[256];
| 85 |
int nchars;
| 86 |
| 87 |
if (do_prog <= 1) return;
| 88 |
if (do_prog > sizeof(pbar)-2)
| 89 |
do_prog = sizeof(pbar)-2;
| 90 |
if (frac < 0) frac = 0;
| 91 |
else if (frac >= 1) frac = .9999;
| 92 |
nchars = do_prog*frac;
| 93 |
pbar[0] = '\r';
| 94 |
memset(pbar+1, '*', nchars);
| 95 |
pbar[nchars+1] = lastc[call_cnt++ & 3];
| 96 |
memset(pbar+2+nchars, '-', do_prog-nchars-1);
| 97 |
pbar[do_prog+1] = '\0';
| 98 |
fputs(pbar, stderr);
| 99 |
| 100 |
| 101 |
/* Finish progress bar */
| 102 |
static void
| 103 |
prog_done(void)
| 104 |
| 105 |
int n = do_prog;
| 106 |
| 107 |
if (n <= 1) return;
| 108 |
fputc('\r', stderr);
| 109 |
while (n--)
| 110 |
fputc(' ', stderr);
| 111 |
| 112 |
| 113 |
| 114 |
/* Compute absolute relative difference */
| 115 |
static double
| 116 |
abs_diff(double v1, double v0)
| 117 |
| 118 |
if ((v0 < 0) | (v1 < 0))
| 119 |
return(.0);
| 120 |
v1 = (v1-v0)*2./(v0+v1+.0001);
| 121 |
if (v1 < 0)
| 122 |
return(-v1);
| 123 |
return(v1);
| 124 |
| 125 |
| 126 |
/* Interpolate and output isotropic BSDF data */
| 127 |
static void
| 128 |
eval_isotropic(char *funame)
| 129 |
| 130 |
const int sqres = 1<<samp_order;
| 131 |
const double sqfact = 1./(double)sqres;
| 132 |
float *val_last = NULL;
| 133 |
float *val_next = NULL;
| 134 |
SDValue *sdv_next = NULL;
| 135 |
FILE *ofp, *uvfp[2];
| 136 |
int assignD = 0;
| 137 |
char cmd[128];
| 138 |
int ix, ox, oy;
| 139 |
double iovec[6];
| 140 |
float bsdf, uv[2];
| 141 |
| 142 |
if (pctcull >= 0) {
| 143 |
sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
| 144 |
recip, pctcull, samp_order, create_component_file(0));
| 145 |
ofp = popen(cmd, "w");
| 146 |
if (ofp == NULL) {
| 147 |
fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
| 148 |
progname);
| 149 |
exit(1);
| 150 |
| 151 |
SET_FILE_BINARY(ofp);
| 152 |
#ifdef getc_unlocked /* avoid lock/unlock overhead */
| 153 |
flockfile(ofp);
| 154 |
#endif
| 155 |
if (rbf_colorimetry == RBCtristimulus) {
| 156 |
double uvcull = 100. - (100.-pctcull)*.25;
| 157 |
| 158 |
recip, uvcull, samp_order, create_component_file(1));
| 159 |
uvfp[0] = popen(cmd, "w");
| 160 |
| 161 |
recip, uvcull, samp_order, create_component_file(2));
| 162 |
uvfp[1] = popen(cmd, "w");
| 163 |
if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
| 164 |
fprintf(stderr, "%s: cannot open pipes to uv output\n",
| 165 |
progname);
| 166 |
exit(1);
| 167 |
| 168 |
SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
| 169 |
| 170 |
flockfile(uvfp[0]); flockfile(uvfp[1]);
| 171 |
#endif
| 172 |
| 173 |
} else {
| 174 |
ofp = fopen(create_component_file(0), "w");
| 175 |
if (ofp == NULL) {
| 176 |
fprintf(stderr, "%s: cannot create Y output file\n",
| 177 |
progname);
| 178 |
exit(1);
| 179 |
| 180 |
fputs("{\n", ofp);
| 181 |
| 182 |
uvfp[0] = fopen(create_component_file(1), "w");
| 183 |
uvfp[1] = fopen(create_component_file(2), "w");
| 184 |
| 185 |
fprintf(stderr, "%s: cannot create uv output file(s)\n",
| 186 |
progname);
| 187 |
exit(1);
| 188 |
| 189 |
fputs("{\n", uvfp[0]);
| 190 |
fputs("{\n", uvfp[1]);
| 191 |
| 192 |
| 193 |
if (funame != NULL) /* need to assign Dx, Dy, Dz? */
| 194 |
assignD = (fundefined(funame) < 6);
| 195 |
#if (NSSAMP > 0)
| 196 |
val_last = (float *)calloc(sqres, sizeof(float));
| 197 |
if (funame == NULL)
| 198 |
sdv_next = (SDValue *)malloc(sizeof(SDValue)*sqres);
| 199 |
else
| 200 |
val_next = (float *)malloc(sizeof(float)*sqres);
| 201 |
#endif
| 202 |
/* run through directions */
| 203 |
for (ix = 0; ix < sqres/2; ix++) {
| 204 |
const int zipsgn = (ix & 1)*2 - 1;
| 205 |
RBFNODE *rbf = NULL;
| 206 |
iovec[0] = 2.*sqfact*(ix+.5) - 1.;
| 207 |
iovec[1] = zipsgn*sqfact*.5;
| 208 |
iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]
| 209 |
- iovec[1]*iovec[1]);
| 210 |
if (funame == NULL)
| 211 |
rbf = advect_rbf(iovec, lobe_lim);
| 212 |
/* presample first row */
| 213 |
for (oy = 0; oy < sqres; oy++) {
| 214 |
SDsquare2disk(iovec+3, .5*sqfact, (oy+.5)*sqfact);
| 215 |
iovec[5] = output_orient *
| 216 |
sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
| 217 |
if (funame == NULL) {
| 218 |
eval_rbfcol(&sdv_next[oy], rbf, iovec+3);
| 219 |
} else {
| 220 |
if (assignD) {
| 221 |
varset("Dx", '=', -iovec[3]);
| 222 |
varset("Dy", '=', -iovec[4]);
| 223 |
varset("Dz", '=', -iovec[5]);
| 224 |
++eclock;
| 225 |
| 226 |
val_next[oy] = funvalue(funame, 6, iovec);
| 227 |
| 228 |
| 229 |
for (ox = 0; ox < sqres; ox++) {
| 230 |
| 231 |
* Super-sample when we detect a difference from before
| 232 |
* or after in this row, above or below.
| 233 |
| 234 |
| 235 |
if (ox < sqres-1) { /* keeping one row ahead... */
| 236 |
SDsquare2disk(iovec+3, (ox+1.5)*sqfact, (oy+.5)*sqfact);
| 237 |
| 238 |
| 239 |
| 240 |
| 241 |
SDValue sdv = sdv_next[oy];
| 242 |
bsdf = sdv.cieY;
| 243 |
if (ox < sqres-1)
| 244 |
| 245 |
#if (NSSAMP > 0)
| 246 |
if (abs_diff(bsdf, sdv_next[oy].cieY) > ssamp_thresh ||
| 247 |
(ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) ||
| 248 |
(oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) ||
| 249 |
(oy < sqres-1 &&
| 250 |
abs_diff(bsdf, sdv_next[oy+1].cieY) > ssamp_thresh)) {
| 251 |
int ssi;
| 252 |
double ssa[2], sum = 0, usum = 0, vsum = 0;
| 253 |
/* super-sample voxel */
| 254 |
for (ssi = NSSAMP; ssi--; ) {
| 255 |
SDmultiSamp(ssa, 2, (ssi+frandom()) *
| 256 |
(1./NSSAMP));
| 257 |
SDsquare2disk(iovec+3, (ox+ssa[0])*sqfact,
| 258 |
(oy+ssa[1])*sqfact);
| 259 |
| 260 |
| 261 |
eval_rbfcol(&sdv, rbf, iovec+3);
| 262 |
sum += sdv.cieY;
| 263 |
| 264 |
sdv.cieY /=
| 265 |
-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.;
| 266 |
usum += 4.*sdv.spec.cx * sdv.cieY;
| 267 |
vsum += 9.*sdv.spec.cy * sdv.cieY;
| 268 |
| 269 |
| 270 |
bsdf = sum * (1./NSSAMP);
| 271 |
| 272 |
uv[0] = usum / (sum+FTINY);
| 273 |
uv[1] = vsum / (sum+FTINY);
| 274 |
| 275 |
} else
| 276 |
#endif
| 277 |
| 278 |
uv[0] = uv[1] = 1. /
| 279 |
(-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
| 280 |
uv[0] *= 4.*sdv.spec.cx;
| 281 |
uv[1] *= 9.*sdv.spec.cy;
| 282 |
| 283 |
} else {
| 284 |
bsdf = val_next[oy];
| 285 |
if (ox < sqres-1) {
| 286 |
if (assignD) {
| 287 |
| 288 |
| 289 |
| 290 |
++eclock;
| 291 |
| 292 |
| 293 |
| 294 |
#if (NSSAMP > 0)
| 295 |
if (abs_diff(bsdf, val_next[oy]) > ssamp_thresh ||
| 296 |
| 297 |
| 298 |
(oy < sqres-1 &&
| 299 |
abs_diff(bsdf, val_next[oy+1]) > ssamp_thresh)) {
| 300 |
int ssi;
| 301 |
double ssa[4], ssvec[6], sum = 0;
| 302 |
| 303 |
| 304 |
SDmultiSamp(ssa, 4, (ssi+frandom()) *
| 305 |
(1./NSSAMP));
| 306 |
ssvec[0] = 2.*sqfact*(ix+ssa[0]) - 1.;
| 307 |
ssvec[1] = zipsgn*sqfact*ssa[1];
| 308 |
ssvec[2] = 1. - ssvec[0]*ssvec[0]
| 309 |
- ssvec[1]*ssvec[1];
| 310 |
if (ssvec[2] < .0) {
| 311 |
ssvec[1] = 0;
| 312 |
ssvec[2] = 1. - ssvec[0]*ssvec[0];
| 313 |
| 314 |
ssvec[2] = input_orient * sqrt(ssvec[2]);
| 315 |
SDsquare2disk(ssvec+3, (ox+ssa[2])*sqfact,
| 316 |
(oy+ssa[3])*sqfact);
| 317 |
ssvec[5] = output_orient *
| 318 |
sqrt(1. - ssvec[3]*ssvec[3] -
| 319 |
ssvec[4]*ssvec[4]);
| 320 |
if (assignD) {
| 321 |
varset("Dx", '=', -ssvec[3]);
| 322 |
varset("Dy", '=', -ssvec[4]);
| 323 |
varset("Dz", '=', -ssvec[5]);
| 324 |
++eclock;
| 325 |
| 326 |
sum += funvalue(funame, 6, ssvec);
| 327 |
| 328 |
| 329 |
| 330 |
#endif
| 331 |
| 332 |
if (pctcull >= 0)
| 333 |
putbinary(&bsdf, sizeof(bsdf), 1, ofp);
| 334 |
else
| 335 |
fprintf(ofp, "\t%.3e\n", bsdf);
| 336 |
| 337 |
| 338 |
if (pctcull >= 0) {
| 339 |
putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]);
| 340 |
putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]);
| 341 |
} else {
| 342 |
fprintf(uvfp[0], "\t%.3e\n", uv[0]);
| 343 |
fprintf(uvfp[1], "\t%.3e\n", uv[1]);
| 344 |
| 345 |
| 346 |
if (val_last != NULL)
| 347 |
val_last[oy] = bsdf;
| 348 |
| 349 |
| 350 |
if (rbf != NULL)
| 351 |
free(rbf);
| 352 |
prog_show((ix+1.)*(2.*sqfact));
| 353 |
| 354 |
prog_done();
| 355 |
if (val_last != NULL) {
| 356 |
free(val_last);
| 357 |
if (val_next != NULL) free(val_next);
| 358 |
if (sdv_next != NULL) free(sdv_next);
| 359 |
| 360 |
if (pctcull >= 0) { /* finish output */
| 361 |
if (pclose(ofp)) {
| 362 |
fprintf(stderr, "%s: error running rttree_reduce on Y\n",
| 363 |
progname);
| 364 |
exit(1);
| 365 |
| 366 |
if (rbf_colorimetry == RBCtristimulus &&
| 367 |
(pclose(uvfp[0]) || pclose(uvfp[1]))) {
| 368 |
fprintf(stderr, "%s: error running rttree_reduce on uv\n",
| 369 |
progname);
| 370 |
exit(1);
| 371 |
| 372 |
} else {
| 373 |
for (ix = sqres*sqres*sqres/2; ix--; )
| 374 |
fputs("\t0\n", ofp);
| 375 |
fputs("}\n", ofp);
| 376 |
if (fclose(ofp)) {
| 377 |
fprintf(stderr, "%s: error writing Y file\n",
| 378 |
progname);
| 379 |
exit(1);
| 380 |
| 381 |
| 382 |
for (ix = sqres*sqres*sqres/2; ix--; ) {
| 383 |
fputs("\t0\n", uvfp[0]);
| 384 |
fputs("\t0\n", uvfp[1]);
| 385 |
| 386 |
fputs("}\n", uvfp[0]);
| 387 |
fputs("}\n", uvfp[1]);
| 388 |
if (fclose(uvfp[0]) || fclose(uvfp[1])) {
| 389 |
fprintf(stderr, "%s: error writing uv file(s)\n",
| 390 |
progname);
| 391 |
exit(1);
| 392 |
| 393 |
| 394 |
| 395 |
| 396 |
| 397 |
/* Interpolate and output anisotropic BSDF data */
| 398 |
static void
| 399 |
eval_anisotropic(char *funame)
| 400 |
| 401 |
| 402 |
| 403 |
| 404 |
| 405 |
| 406 |
| 407 |
int assignD = 0;
| 408 |
char cmd[128];
| 409 |
int ix, iy, ox, oy;
| 410 |
double iovec[6];
| 411 |
float bsdf, uv[2];
| 412 |
| 413 |
if (pctcull >= 0) {
| 414 |
const char *avgopt = (input_orient>0 ^ output_orient>0)
| 415 |
? "" : recip;
| 416 |
sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
| 417 |
avgopt, pctcull, samp_order,
| 418 |
| 419 |
| 420 |
if (ofp == NULL) {
| 421 |
| 422 |
progname);
| 423 |
exit(1);
| 424 |
| 425 |
| 426 |
| 427 |
flockfile(ofp);
| 428 |
#endif
| 429 |
| 430 |
| 431 |
| 432 |
avgopt, uvcull, samp_order,
| 433 |
| 434 |
| 435 |
| 436 |
| 437 |
| 438 |
| 439 |
| 440 |
| 441 |
progname);
| 442 |
exit(1);
| 443 |
| 444 |
| 445 |
| 446 |
| 447 |
#endif
| 448 |
| 449 |
} else {
| 450 |
| 451 |
if (ofp == NULL) {
| 452 |
| 453 |
progname);
| 454 |
exit(1);
| 455 |
| 456 |
fputs("{\n", ofp);
| 457 |
| 458 |
| 459 |
| 460 |
| 461 |
| 462 |
progname);
| 463 |
exit(1);
| 464 |
| 465 |
| 466 |
| 467 |
| 468 |
| 469 |
| 470 |
| 471 |
#if (NSSAMP > 0)
| 472 |
| 473 |
if (funame == NULL)
| 474 |
| 475 |
else
| 476 |
| 477 |
#endif
| 478 |
| 479 |
for (ix = 0; ix < sqres; ix++)
| 480 |
for (iy = 0; iy < sqres; iy++) {
| 481 |
RBFNODE *rbf = NULL; /* Klems reversal */
| 482 |
SDsquare2disk(iovec, 1.-(ix+.5)*sqfact, 1.-(iy+.5)*sqfact);
| 483 |
| 484 |
sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]);
| 485 |
if (funame == NULL)
| 486 |
| 487 |
| 488 |
| 489 |
| 490 |
| 491 |
| 492 |
| 493 |
| 494 |
} else {
| 495 |
if (assignD) {
| 496 |
| 497 |
| 498 |
| 499 |
++eclock;
| 500 |
| 501 |
| 502 |
| 503 |
| 504 |
| 505 |
| 506 |
| 507 |
| 508 |
| 509 |
| 510 |
| 511 |
| 512 |
| 513 |
| 514 |
| 515 |
| 516 |
| 517 |
bsdf = sdv.cieY;
| 518 |
if (ox < sqres-1)
| 519 |
| 520 |
#if (NSSAMP > 0)
| 521 |
| 522 |
| 523 |
| 524 |
(oy < sqres-1 &&
| 525 |
| 526 |
int ssi;
| 527 |
| 528 |
| 529 |
| 530 |
| 531 |
(1./NSSAMP));
| 532 |
| 533 |
| 534 |
| 535 |
| 536 |
| 537 |
sum += sdv.cieY;
| 538 |
| 539 |
sdv.cieY /=
| 540 |
| 541 |
| 542 |
| 543 |
| 544 |
| 545 |
| 546 |
| 547 |
| 548 |
| 549 |
| 550 |
} else
| 551 |
#endif
| 552 |
| 553 |
| 554 |
| 555 |
| 556 |
| 557 |
| 558 |
} else {
| 559 |
| 560 |
if (ox < sqres-1) {
| 561 |
if (assignD) {
| 562 |
| 563 |
| 564 |
| 565 |
++eclock;
| 566 |
| 567 |
| 568 |
| 569 |
#if (NSSAMP > 0)
| 570 |
| 571 |
| 572 |
| 573 |
(oy < sqres-1 &&
| 574 |
| 575 |
int ssi;
| 576 |
| 577 |
| 578 |
| 579 |
| 580 |
(1./NSSAMP));
| 581 |
SDsquare2disk(ssvec, 1.-(ix+ssa[0])*sqfact,
| 582 |
1.-(iy+ssa[1])*sqfact);
| 583 |
| 584 |
sqrt(1. - ssvec[0]*ssvec[0] -
| 585 |
ssvec[1]*ssvec[1]);
| 586 |
| 587 |
| 588 |
| 589 |
| 590 |
ssvec[4]*ssvec[4]);
| 591 |
if (assignD) {
| 592 |
| 593 |
| 594 |
| 595 |
++eclock;
| 596 |
| 597 |
| 598 |
| 599 |
| 600 |
| 601 |
#endif
| 602 |
| 603 |
if (pctcull >= 0)
| 604 |
| 605 |
else
| 606 |
| 607 |
| 608 |
| 609 |
if (pctcull >= 0) {
| 610 |
| 611 |
| 612 |
} else {
| 613 |
| 614 |
| 615 |
| 616 |
| 617 |
| 618 |
| 619 |
| 620 |
| 621 |
if (rbf != NULL)
| 622 |
free(rbf);
| 623 |
prog_show((ix*sqres+iy+1.)/(sqres*sqres));
| 624 |
| 625 |
prog_done();
| 626 |
| 627 |
free(val_last);
| 628 |
| 629 |
| 630 |
| 631 |
| 632 |
if (pclose(ofp)) {
| 633 |
| 634 |
progname);
| 635 |
exit(1);
| 636 |
| 637 |
| 638 |
| 639 |
| 640 |
progname);
| 641 |
exit(1);
| 642 |
| 643 |
} else {
| 644 |
fputs("}\n", ofp);
| 645 |
if (fclose(ofp)) {
| 646 |
| 647 |
progname);
| 648 |
exit(1);
| 649 |
| 650 |
| 651 |
| 652 |
| 653 |
| 654 |
| 655 |
progname);
| 656 |
exit(1);
| 657 |
| 658 |
| 659 |
| 660 |
| 661 |
| 662 |
#if defined(_WIN32) || defined(_WIN64)
| 663 |
/* Execute wrapBSDF command (may never return) */
| 664 |
static int
| 665 |
wrap_up(void)
| 666 |
| 667 |
char cmd[8192];
| 668 |
| 669 |
if (bsdf_manuf[0]) {
| 670 |
add_wbsdf("-f", 1);
| 671 |
strcpy(cmd, "m=");
| 672 |
strcpy(cmd+2, bsdf_manuf);
| 673 |
add_wbsdf(cmd, 0);
| 674 |
| 675 |
if (bsdf_name[0]) {
| 676 |
add_wbsdf("-f", 1);
| 677 |
strcpy(cmd, "n=");
| 678 |
strcpy(cmd+2, bsdf_name);
| 679 |
add_wbsdf(cmd, 0);
| 680 |
| 681 |
if (!convert_commandline(cmd, sizeof(cmd), wrapBSDF)) {
| 682 |
| 683 |
fputs(": command line too long in wrap_up()\n", stderr);
| 684 |
return(1);
| 685 |
| 686 |
return(system(cmd));
| 687 |
| 688 |
#else
| 689 |
| 690 |
static int
| 691 |
wrap_up(void)
| 692 |
| 693 |
char buf[256];
| 694 |
char *compath = getpath((char *)wrapBSDF[0], getenv("PATH"), X_OK);
| 695 |
| 696 |
if (compath == NULL) {
| 697 |
fprintf(stderr, "%s: cannot locate %s\n", progname, wrapBSDF[0]);
| 698 |
return(1);
| 699 |
| 700 |
| 701 |
add_wbsdf("-f", 1);
| 702 |
strcpy(buf, "m=");
| 703 |
strcpy(buf+2, bsdf_manuf);
| 704 |
add_wbsdf(buf, 0);
| 705 |
| 706 |
if (bsdf_name[0]) {
| 707 |
add_wbsdf("-f", 1);
| 708 |
strcpy(buf, "n=");
| 709 |
strcpy(buf+2, bsdf_name);
| 710 |
add_wbsdf(buf, 0);
| 711 |
| 712 |
execv(compath, wrapBSDF); /* successful call never returns */
| 713 |
perror(compath);
| 714 |
return(1);
| 715 |
| 716 |
#endif
| 717 |
| 718 |
/* Read in BSDF and interpolate as tensor tree representation */
| 719 |
int
| 720 |
main(int argc, char *argv[])
| 721 |
| 722 |
static char tfmt[2][4] = {"t4", "t3"};
| 723 |
int dofwd = 0, dobwd = 1;
| 724 |
char buf[2048];
| 725 |
int i, na;
| 726 |
| 727 |
progname = argv[0];
| 728 |
esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
| 729 |
esupport &= ~(E_INCHAN|E_OUTCHAN);
| 730 |
scompile("PI:3.14159265358979323846", NULL, 0);
| 731 |
biggerlib();
| 732 |
for (i = 1; i < argc && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
| 733 |
switch (argv[i][1]) { /* get options */
| 734 |
case 'e':
| 735 |
scompile(argv[++i], NULL, 0);
| 736 |
if (single_plane_incident < 0)
| 737 |
single_plane_incident = 0;
| 738 |
break;
| 739 |
case 'f':
| 740 |
if (!argv[i][2]) {
| 741 |
if (strchr(argv[++i], '=') != NULL) {
| 742 |
add_wbsdf("-f", 1);
| 743 |
add_wbsdf(argv[i], 1);
| 744 |
} else {
| 745 |
char *fpath = getpath(argv[i],
| 746 |
getrlibpath(), 0);
| 747 |
if (fpath == NULL) {
| 748 |
fprintf(stderr,
| 749 |
"%s: cannot find file '%s'\n",
| 750 |
argv[0], argv[i]);
| 751 |
return(1);
| 752 |
| 753 |
fcompile(fpath);
| 754 |
| 755 |
| 756 |
| 757 |
} else
| 758 |
dofwd = (argv[i][0] == '+');
| 759 |
break;
| 760 |
case 'a':
| 761 |
recip = (argv[i][0] == '+') ? " -a" : "";
| 762 |
break;
| 763 |
case 'b':
| 764 |
dobwd = (argv[i][0] == '+');
| 765 |
break;
| 766 |
case 't':
| 767 |
switch (argv[i][2]) {
| 768 |
case '3':
| 769 |
single_plane_incident = 1;
| 770 |
break;
| 771 |
case '4':
| 772 |
| 773 |
break;
| 774 |
case '\0':
| 775 |
pctcull = atof(argv[++i]);
| 776 |
break;
| 777 |
default:
| 778 |
goto userr;
| 779 |
| 780 |
break;
| 781 |
case 'g':
| 782 |
samp_order = atoi(argv[++i]);
| 783 |
break;
| 784 |
case 'l':
| 785 |
lobe_lim = atoi(argv[++i]);
| 786 |
break;
| 787 |
case 'p':
| 788 |
do_prog = atoi(argv[i]+2);
| 789 |
break;
| 790 |
case 'W':
| 791 |
| 792 |
break;
| 793 |
case 'u':
| 794 |
case 'C':
| 795 |
| 796 |
add_wbsdf(argv[++i], 1);
| 797 |
break;
| 798 |
default:
| 799 |
goto userr;
| 800 |
| 801 |
strcpy(buf, "File produced by: ");
| 802 |
if (convert_commandline(buf+18, sizeof(buf)-18, argv) != NULL) {
| 803 |
add_wbsdf("-C", 1); add_wbsdf(buf, 0);
| 804 |
| 805 |
if (single_plane_incident >= 0) { /* function-based BSDF? */
| 806 |
void (*evf)(char *s) = single_plane_incident ?
| 807 |
eval_isotropic : eval_anisotropic;
| 808 |
if (i != argc-1 || fundefined(argv[i]) < 3) {
| 809 |
fprintf(stderr,
| 810 |
"%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
| 811 |
progname);
| 812 |
fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n");
| 813 |
goto userr;
| 814 |
| 815 |
++eclock;
| 816 |
ssamp_thresh *= 0.5; /* lower sampling threshold */
| 817 |
add_wbsdf("-a", 1);
| 818 |
add_wbsdf(tfmt[single_plane_incident], 1);
| 819 |
if (dofwd) {
| 820 |
input_orient = -1;
| 821 |
output_orient = -1;
| 822 |
prog_start("Evaluating outside reflectance");
| 823 |
(*evf)(argv[i]);
| 824 |
output_orient = 1;
| 825 |
prog_start("Evaluating outside->inside transmission");
| 826 |
(*evf)(argv[i]);
| 827 |
| 828 |
if (dobwd) {
| 829 |
input_orient = 1;
| 830 |
output_orient = 1;
| 831 |
prog_start("Evaluating inside reflectance");
| 832 |
(*evf)(argv[i]);
| 833 |
output_orient = -1;
| 834 |
prog_start("Evaluating inside->outside transmission");
| 835 |
(*evf)(argv[i]);
| 836 |
| 837 |
return(wrap_up());
| 838 |
| 839 |
if (i < argc) { /* open input files if given */
| 840 |
int nbsdf = 0;
| 841 |
for ( ; i < argc; i++) { /* interpolate each component */
| 842 |
char pbuf[256];
| 843 |
FILE *fpin = fopen(argv[i], "rb");
| 844 |
if (fpin == NULL) {
| 845 |
fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
| 846 |
progname, argv[i]);
| 847 |
return(1);
| 848 |
| 849 |
if (!load_bsdf_rep(fpin))
| 850 |
return(1);
| 851 |
fclose(fpin);
| 852 |
sprintf(pbuf, "Interpolating component '%s'", argv[i]);
| 853 |
prog_start(pbuf);
| 854 |
if (!nbsdf++) {
| 855 |
add_wbsdf("-a", 1);
| 856 |
| 857 |
| 858 |
if (single_plane_incident)
| 859 |
eval_isotropic(NULL);
| 860 |
else
| 861 |
eval_anisotropic(NULL);
| 862 |
| 863 |
return(wrap_up());
| 864 |
| 865 |
SET_FILE_BINARY(stdin); /* load from stdin */
| 866 |
if (!load_bsdf_rep(stdin))
| 867 |
return(1);
| 868 |
prog_start("Interpolating from standard input");
| 869 |
add_wbsdf("-a", 1);
| 870 |
| 871 |
if (single_plane_incident) /* resample dist. */
| 872 |
| 873 |
else
| 874 |
| 875 |
| 876 |
return(wrap_up());
| 877 |
userr:
| 878 |
fprintf(stderr,
| 879 |
"Usage: %s [{+|-}a][-g Nlog2][-t pctcull][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n",
| 880 |
progname);
| 881 |
fprintf(stderr,
| 882 |
" or: %s -t{3|4} [{+|-}a][-g Nlog2][-t pctcull][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
| 883 |
progname);
| 884 |
return(1);
| 885 |
