root/radiance/ray/src/cv/bsdf2ttree.c
Revision: 2.43
Committed: Fri May 4 23:56:49 2018 UTC (6 years, 10 months ago) by greg
Changes since 2.42: +13 -3 lines
2 static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.42 2018/01/04 23:28:54 greg Exp $";
5 * Load measured BSDF interpolant and write out as XML file with tensor tree.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdio.h>
12 #include <stdlib.h>
13 #include <math.h>
14 #include "random.h"
15 #include "platform.h"
16 #include "paths.h"
17 #include "rtio.h"
18 #include "calcomp.h"
19 #include "bsdfrep.h"
20 /* global argv[0] */
21 char *progname;
22 /* reciprocity averaging option */
23 static const char *recip = " -a";
24 /* percentage to cull (<0 to turn off) */
25 static double pctcull = 90.;
26 /* sampling order */
27 static int samp_order = 6;
28 /* super-sampling threshold */
29 const double ssamp_thresh = 0.35;
30 /* number of super-samples */
31 #ifndef NSSAMP
32 #define NSSAMP 64
33 #endif
34 /* limit on number of RBF lobes */
35 static int lobe_lim = 15000;
36 /* progress bar length */
37 static int do_prog = 79;
38
39 #define MAXCARG 512 /* wrapBSDF command */
40 static char *wrapBSDF[MAXCARG] = {"wrapBSDF", "-U"};
41 static int wbsdfac = 2;
42
43 /* Add argument to wrapBSDF, allocating space if !isstatic */
44 static void
45 add_wbsdf(const char *arg, int isstatic)
46 {
47 if (arg == NULL)
48 return;
49 if (wbsdfac >= MAXCARG-1) {
50 fputs(progname, stderr);
51 fputs(": too many command arguments to wrapBSDF\n", stderr);
52 exit(1);
53 }
54 if (!*arg)
55 arg = "";
56 else if (!isstatic)
57 arg = savqstr((char *)arg);
58
59 wrapBSDF[wbsdfac++] = (char *)arg;
60 }
61
62 /* Create Yuv component file and add appropriate arguments */
63 static char *
64 create_component_file(int c)
65 {
66 static const char sname[3][6] = {"CIE-Y", "CIE-u", "CIE-v"};
67 static const char cname[4][4] = {"-rf", "-tf", "-tb", "-rb"};
68 char *tfname = mktemp(savqstr(TEMPLATE));
69
70 add_wbsdf("-s", 1); add_wbsdf(sname[c], 1);
71 add_wbsdf(cname[(input_orient>0)<<1 | (output_orient>0)], 1);
72 add_wbsdf(tfname, 1);
73 return(tfname);
74 }
75
76 /* Start new progress bar */
77 #define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else
78
79 /* Draw progress bar of the appropriate length */
80 static void
81 prog_show(double frac)
82 {
83 static unsigned call_cnt = 0;
84 static char lastc[] = "-\\|/";
85 char pbar[256];
86 int nchars;
87
88 if (do_prog <= 1) return;
89 if (do_prog > sizeof(pbar)-2)
90 do_prog = sizeof(pbar)-2;
91 if (frac < 0) frac = 0;
92 else if (frac >= 1) frac = .9999;
93 nchars = do_prog*frac;
94 pbar[0] = '\r';
95 memset(pbar+1, '*', nchars);
96 pbar[nchars+1] = lastc[call_cnt++ & 3];
97 memset(pbar+2+nchars, '-', do_prog-nchars-1);
98 pbar[do_prog+1] = '\0';
99 fputs(pbar, stderr);
100 }
101
102 /* Finish progress bar */
103 static void
104 prog_done(void)
105 {
106 int n = do_prog;
107
108 if (n <= 1) return;
109 fputc('\r', stderr);
110 while (n--)
111 fputc(' ', stderr);
112 fputc('\r', stderr);
113 }
114
115 /* Compute absolute relative difference */
116 static double
117 abs_diff(double v1, double v0)
118 {
119 if ((v0 < 0) | (v1 < 0))
120 return(.0);
121 v1 = (v1-v0)*2./(v0+v1+.0001);
122 if (v1 < 0)
123 return(-v1);
124 return(v1);
125 }
126
127 /* Interpolate and output isotropic BSDF data */
128 static void
129 eval_isotropic(char *funame)
130 {
131 const int sqres = 1<<samp_order;
132 const double sqfact = 1./(double)sqres;
133 FILE *ofp, *uvfp[2];
134 int assignD = 0;
135 char cmd[128];
136 int ix, ox, oy;
137 double iovec[6];
138 float bsdf, uv[2];
139
140 if (pctcull >= 0) {
141 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
142 recip, pctcull, samp_order, create_component_file(0));
143 ofp = popen(cmd, "w");
144 if (ofp == NULL) {
145 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
146 progname);
147 exit(1);
148 }
149 SET_FILE_BINARY(ofp);
150 #ifdef getc_unlocked /* avoid lock/unlock overhead */
151 flockfile(ofp);
152 #endif
153 if (rbf_colorimetry == RBCtristimulus) {
154 double uvcull = 100. - (100.-pctcull)*.25;
155 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
156 recip, uvcull, samp_order, create_component_file(1));
157 uvfp[0] = popen(cmd, "w");
158 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
159 recip, uvcull, samp_order, create_component_file(2));
160 uvfp[1] = popen(cmd, "w");
161 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
162 fprintf(stderr, "%s: cannot open pipes to uv output\n",
163 progname);
164 exit(1);
165 }
166 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
167 #ifdef getc_unlocked
168 flockfile(uvfp[0]); flockfile(uvfp[1]);
169 #endif
170 }
171 } else {
172 ofp = fopen(create_component_file(0), "w");
173 if (ofp == NULL) {
174 fprintf(stderr, "%s: cannot create Y output file\n",
175 progname);
176 exit(1);
177 }
178 fputs("{\n", ofp);
179 if (rbf_colorimetry == RBCtristimulus) {
180 uvfp[0] = fopen(create_component_file(1), "w");
181 uvfp[1] = fopen(create_component_file(2), "w");
182 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
183 fprintf(stderr, "%s: cannot create uv output file(s)\n",
184 progname);
185 exit(1);
186 }
187 fputs("{\n", uvfp[0]);
188 fputs("{\n", uvfp[1]);
189 }
190 }
191 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
192 assignD = (fundefined(funame) < 6);
193 /* run through directions */
194 for (ix = 0; ix < sqres/2; ix++) {
195 RBFNODE *rbf = NULL;
196 iovec[0] = 2.*sqfact*(ix+.5) - 1.;
197 iovec[1] = .0;
198 iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]);
199 if (funame == NULL)
200 rbf = advect_rbf(iovec, lobe_lim);
201 for (ox = 0; ox < sqres; ox++) {
202 float last_bsdf = -1;
203 for (oy = 0; oy < sqres; oy++) {
204 SDsquare2disk(iovec+3, (ox+.5)*sqfact, (oy+.5)*sqfact);
205 iovec[5] = output_orient *
206 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
207 if (funame == NULL) {
208 SDValue sdv;
209 eval_rbfcol(&sdv, rbf, iovec+3);
210 bsdf = sdv.cieY;
211 #if (NSSAMP > 0)
212 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
213 int ssi;
214 double ssa[2], sum = 0, usum = 0, vsum = 0;
215 /* super-sample voxel */
216 for (ssi = NSSAMP; ssi--; ) {
217 SDmultiSamp(ssa, 2, (ssi+frandom()) *
218 (1./NSSAMP));
219 SDsquare2disk(iovec+3, (ox+ssa[0])*sqfact,
220 (oy+ssa[1])*sqfact);
221 iovec[5] = output_orient *
222 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
223 eval_rbfcol(&sdv, rbf, iovec+3);
224 sum += sdv.cieY;
225 if (rbf_colorimetry == RBCtristimulus) {
226 sdv.cieY /=
227 -2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.;
228 usum += 4.*sdv.spec.cx * sdv.cieY;
229 vsum += 9.*sdv.spec.cy * sdv.cieY;
230 }
231 }
232 bsdf = sum * (1./NSSAMP);
233 if (rbf_colorimetry == RBCtristimulus) {
234 uv[0] = usum / (sum+FTINY);
235 uv[1] = vsum / (sum+FTINY);
236 }
237 } else
238 #endif
239 if (rbf_colorimetry == RBCtristimulus) {
240 uv[0] = uv[1] = 1. /
241 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
242 uv[0] *= 4.*sdv.spec.cx;
243 uv[1] *= 9.*sdv.spec.cy;
244 }
245 } else {
246 if (assignD) {
247 varset("Dx", '=', -iovec[3]);
248 varset("Dy", '=', -iovec[4]);
249 varset("Dz", '=', -iovec[5]);
250 ++eclock;
251 }
252 bsdf = funvalue(funame, 6, iovec);
253 #if (NSSAMP > 0)
254 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
255 int ssi;
256 double ssa[3], ssvec[6], sum = 0;
257 /* super-sample voxel */
258 for (ssi = NSSAMP; ssi--; ) {
259 SDmultiSamp(ssa, 3, (ssi+frandom()) *
260 (1./NSSAMP));
261 ssvec[0] = 2.*sqfact*(ix+ssa[0]) - 1.;
262 ssvec[1] = .0;
263 ssvec[2] = input_orient *
264 sqrt(1. - ssvec[0]*ssvec[0]);
265 SDsquare2disk(ssvec+3, (ox+ssa[1])*sqfact,
266 (oy+ssa[2])*sqfact);
267 ssvec[5] = output_orient *
268 sqrt(1. - ssvec[3]*ssvec[3] -
269 ssvec[4]*ssvec[4]);
270 if (assignD) {
271 varset("Dx", '=', -ssvec[3]);
272 varset("Dy", '=', -ssvec[4]);
273 varset("Dz", '=', -ssvec[5]);
274 ++eclock;
275 }
276 sum += funvalue(funame, 6, ssvec);
277 }
278 bsdf = sum * (1./NSSAMP);
279 }
280 #endif
281 }
282 if (pctcull >= 0)
283 putbinary(&bsdf, sizeof(bsdf), 1, ofp);
284 else
285 fprintf(ofp, "\t%.3e\n", bsdf);
286
287 if (rbf_colorimetry == RBCtristimulus) {
288 if (pctcull >= 0) {
289 putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]);
290 putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]);
291 } else {
292 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
293 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
294 }
295 }
296 last_bsdf = bsdf;
297 }
298 }
299 if (rbf != NULL)
300 free(rbf);
301 prog_show((ix+1.)*(2.*sqfact));
302 }
303 prog_done();
304 if (pctcull >= 0) { /* finish output */
305 if (pclose(ofp)) {
306 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
307 progname);
308 exit(1);
309 }
310 if (rbf_colorimetry == RBCtristimulus &&
311 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
312 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
313 progname);
314 exit(1);
315 }
316 } else {
317 for (ix = sqres*sqres*sqres/2; ix--; )
318 fputs("\t0\n", ofp);
319 fputs("}\n", ofp);
320 if (fclose(ofp)) {
321 fprintf(stderr, "%s: error writing Y file\n",
322 progname);
323 exit(1);
324 }
325 if (rbf_colorimetry == RBCtristimulus) {
326 for (ix = sqres*sqres*sqres/2; ix--; ) {
327 fputs("\t0\n", uvfp[0]);
328 fputs("\t0\n", uvfp[1]);
329 }
330 fputs("}\n", uvfp[0]);
331 fputs("}\n", uvfp[1]);
332 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
333 fprintf(stderr, "%s: error writing uv file(s)\n",
334 progname);
335 exit(1);
336 }
337 }
338 }
339 }
340
341 /* Interpolate and output anisotropic BSDF data */
342 static void
343 eval_anisotropic(char *funame)
344 {
345 const int sqres = 1<<samp_order;
346 const double sqfact = 1./(double)sqres;
347 FILE *ofp, *uvfp[2];
348 int assignD = 0;
349 char cmd[128];
350 int ix, iy, ox, oy;
351 double iovec[6];
352 float bsdf, uv[2];
353
354 if (pctcull >= 0) {
355 const char *avgopt = (input_orient>0 ^ output_orient>0)
356 ? "" : recip;
357 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
358 avgopt, pctcull, samp_order,
359 create_component_file(0));
360 ofp = popen(cmd, "w");
361 if (ofp == NULL) {
362 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
363 progname);
364 exit(1);
365 }
366 SET_FILE_BINARY(ofp);
367 #ifdef getc_unlocked /* avoid lock/unlock overhead */
368 flockfile(ofp);
369 #endif
370 if (rbf_colorimetry == RBCtristimulus) {
371 double uvcull = 100. - (100.-pctcull)*.25;
372 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
373 avgopt, uvcull, samp_order,
374 create_component_file(1));
375 uvfp[0] = popen(cmd, "w");
376 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
377 avgopt, uvcull, samp_order,
378 create_component_file(2));
379 uvfp[1] = popen(cmd, "w");
380 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
381 fprintf(stderr, "%s: cannot open pipes to uv output\n",
382 progname);
383 exit(1);
384 }
385 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
386 #ifdef getc_unlocked
387 flockfile(uvfp[0]); flockfile(uvfp[1]);
388 #endif
389 }
390 } else {
391 ofp = fopen(create_component_file(0), "w");
392 if (ofp == NULL) {
393 fprintf(stderr, "%s: cannot create Y output file\n",
394 progname);
395 exit(1);
396 }
397 fputs("{\n", ofp);
398 if (rbf_colorimetry == RBCtristimulus) {
399 uvfp[0] = fopen(create_component_file(1), "w");
400 uvfp[1] = fopen(create_component_file(2), "w");
401 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
402 fprintf(stderr, "%s: cannot create uv output file(s)\n",
403 progname);
404 exit(1);
405 }
406 fputs("{\n", uvfp[0]);
407 fputs("{\n", uvfp[1]);
408 }
409 }
410 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
411 assignD = (fundefined(funame) < 6);
412 /* run through directions */
413 for (ix = 0; ix < sqres; ix++)
414 for (iy = 0; iy < sqres; iy++) {
415 RBFNODE *rbf = NULL; /* Klems reversal */
416 SDsquare2disk(iovec, 1.-(ix+.5)*sqfact, 1.-(iy+.5)*sqfact);
417 iovec[2] = input_orient *
418 sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]);
419 if (funame == NULL)
420 rbf = advect_rbf(iovec, lobe_lim);
421 for (ox = 0; ox < sqres; ox++) {
422 float last_bsdf = -1;
423 for (oy = 0; oy < sqres; oy++) {
424 SDsquare2disk(iovec+3, (ox+.5)*sqfact, (oy+.5)*sqfact);
425 iovec[5] = output_orient *
426 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
427 if (funame == NULL) {
428 SDValue sdv;
429 eval_rbfcol(&sdv, rbf, iovec+3);
430 bsdf = sdv.cieY;
431 #if (NSSAMP > 0)
432 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
433 int ssi;
434 double ssa[2], sum = 0, usum = 0, vsum = 0;
435 /* super-sample voxel */
436 for (ssi = NSSAMP; ssi--; ) {
437 SDmultiSamp(ssa, 2, (ssi+frandom()) *
438 (1./NSSAMP));
439 SDsquare2disk(iovec+3, (ox+ssa[0])*sqfact,
440 (oy+ssa[1])*sqfact);
441 iovec[5] = output_orient *
442 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
443 eval_rbfcol(&sdv, rbf, iovec+3);
444 sum += sdv.cieY;
445 if (rbf_colorimetry == RBCtristimulus) {
446 sdv.cieY /=
447 -2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.;
448 usum += 4.*sdv.spec.cx * sdv.cieY;
449 vsum += 9.*sdv.spec.cy * sdv.cieY;
450 }
451 }
452 bsdf = sum * (1./NSSAMP);
453 if (rbf_colorimetry == RBCtristimulus) {
454 uv[0] = usum / (sum+FTINY);
455 uv[1] = vsum / (sum+FTINY);
456 }
457 } else
458 #endif
459 if (rbf_colorimetry == RBCtristimulus) {
460 uv[0] = uv[1] = 1. /
461 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
462 uv[0] *= 4.*sdv.spec.cx;
463 uv[1] *= 9.*sdv.spec.cy;
464 }
465 } else {
466 if (assignD) {
467 varset("Dx", '=', -iovec[3]);
468 varset("Dy", '=', -iovec[4]);
469 varset("Dz", '=', -iovec[5]);
470 ++eclock;
471 }
472 bsdf = funvalue(funame, 6, iovec);
473 #if (NSSAMP > 0)
474 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
475 int ssi;
476 double ssa[4], ssvec[6], sum = 0;
477 /* super-sample voxel */
478 for (ssi = NSSAMP; ssi--; ) {
479 SDmultiSamp(ssa, 4, (ssi+frandom()) *
480 (1./NSSAMP));
481 SDsquare2disk(ssvec, 1.-(ix+ssa[0])*sqfact,
482 1.-(iy+ssa[1])*sqfact);
483 ssvec[2] = input_orient *
484 sqrt(1. - ssvec[0]*ssvec[0] -
485 ssvec[1]*ssvec[1]);
486 SDsquare2disk(ssvec+3, (ox+ssa[2])*sqfact,
487 (oy+ssa[3])*sqfact);
488 ssvec[5] = output_orient *
489 sqrt(1. - ssvec[3]*ssvec[3] -
490 ssvec[4]*ssvec[4]);
491 if (assignD) {
492 varset("Dx", '=', -ssvec[3]);
493 varset("Dy", '=', -ssvec[4]);
494 varset("Dz", '=', -ssvec[5]);
495 ++eclock;
496 }
497 sum += funvalue(funame, 6, ssvec);
498 }
499 bsdf = sum * (1./NSSAMP);
500 }
501 #endif
502 }
503 if (pctcull >= 0)
504 putbinary(&bsdf, sizeof(bsdf), 1, ofp);
505 else
506 fprintf(ofp, "\t%.3e\n", bsdf);
507
508 if (rbf_colorimetry == RBCtristimulus) {
509 if (pctcull >= 0) {
510 putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]);
511 putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]);
512 } else {
513 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
514 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
515 }
516 }
517 last_bsdf = bsdf;
518 }
519 }
520 if (rbf != NULL)
521 free(rbf);
522 prog_show((ix*sqres+iy+1.)/(sqres*sqres));
523 }
524 prog_done();
525 if (pctcull >= 0) { /* finish output */
526 if (pclose(ofp)) {
527 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
528 progname);
529 exit(1);
530 }
531 if (rbf_colorimetry == RBCtristimulus &&
532 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
533 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
534 progname);
535 exit(1);
536 }
537 } else {
538 fputs("}\n", ofp);
539 if (fclose(ofp)) {
540 fprintf(stderr, "%s: error writing Y file\n",
541 progname);
542 exit(1);
543 }
544 if (rbf_colorimetry == RBCtristimulus) {
545 fputs("}\n", uvfp[0]);
546 fputs("}\n", uvfp[1]);
547 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
548 fprintf(stderr, "%s: error writing uv file(s)\n",
549 progname);
550 exit(1);
551 }
552 }
553 }
554 }
555
556 #if defined(_WIN32) || defined(_WIN64)
557 /* Execute wrapBSDF command (may never return) */
558 static int
559 wrap_up(void)
560 {
561 char cmd[8192];
562
563 if (bsdf_manuf[0]) {
564 add_wbsdf("-f", 1);
565 strcpy(cmd, "m=");
566 strcpy(cmd+2, bsdf_manuf);
567 add_wbsdf(cmd, 0);
568 }
569 if (bsdf_name[0]) {
570 add_wbsdf("-f", 1);
571 strcpy(cmd, "n=");
572 strcpy(cmd+2, bsdf_name);
573 add_wbsdf(cmd, 0);
574 }
575 if (!convert_commandline(cmd, sizeof(cmd), wrapBSDF)) {
576 fputs(progname, stderr);
577 fputs(": command line too long in wrap_up()\n", stderr);
578 return(1);
579 }
580 return(system(cmd));
581 }
582 #else
583 /* Execute wrapBSDF command (may never return) */
584 static int
585 wrap_up(void)
586 {
587 char buf[256];
588 char *compath = getpath((char *)wrapBSDF[0], getenv("PATH"), X_OK);
589
590 if (compath == NULL) {
591 fprintf(stderr, "%s: cannot locate %s\n", progname, wrapBSDF[0]);
592 return(1);
593 }
594 if (bsdf_manuf[0]) {
595 add_wbsdf("-f", 1);
596 strcpy(buf, "m=");
597 strcpy(buf+2, bsdf_manuf);
598 add_wbsdf(buf, 0);
599 }
600 if (bsdf_name[0]) {
601 add_wbsdf("-f", 1);
602 strcpy(buf, "n=");
603 strcpy(buf+2, bsdf_name);
604 add_wbsdf(buf, 0);
605 }
606 execv(compath, wrapBSDF); /* successful call never returns */
607 perror(compath);
608 return(1);
609 }
610 #endif
611
612 /* Read in BSDF and interpolate as tensor tree representation */
613 int
614 main(int argc, char *argv[])
615 {
616 static char tfmt[2][4] = {"t4", "t3"};
617 int dofwd = 0, dobwd = 1;
618 char buf[2048];
619 int i, na;
620
621 progname = argv[0];
622 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
623 esupport &= ~(E_INCHAN|E_OUTCHAN);
624 scompile("PI:3.14159265358979323846", NULL, 0);
625 biggerlib();
626 for (i = 1; i < argc && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
627 switch (argv[i][1]) { /* get options */
628 case 'e':
629 scompile(argv[++i], NULL, 0);
630 break;
631 case 'f':
632 if (!argv[i][2]) {
633 if (strchr(argv[++i], '=') != NULL) {
634 add_wbsdf("-f", 1);
635 add_wbsdf(argv[i], 1);
636 } else {
637 char *fpath = getpath(argv[i],
638 getrlibpath(), 0);
639 if (fpath == NULL) {
640 fprintf(stderr,
641 "%s: cannot find file '%s'\n",
642 argv[0], argv[i]);
643 return(1);
644 }
645 fcompile(fpath);
646 single_plane_incident = 0;
647 }
648 } else
649 dofwd = (argv[i][0] == '+');
650 break;
651 case 'a':
652 recip = (argv[i][0] == '+') ? " -a" : "";
653 break;
654 case 'b':
655 dobwd = (argv[i][0] == '+');
656 break;
657 case 't':
658 switch (argv[i][2]) {
659 case '3':
660 single_plane_incident = 1;
661 break;
662 case '4':
663 single_plane_incident = 0;
664 break;
665 case '\0':
666 pctcull = atof(argv[++i]);
667 break;
668 default:
669 goto userr;
670 }
671 break;
672 case 'g':
673 samp_order = atoi(argv[++i]);
674 break;
675 case 'l':
676 lobe_lim = atoi(argv[++i]);
677 break;
678 case 'p':
679 do_prog = atoi(argv[i]+2);
680 break;
681 case 'W':
682 add_wbsdf(argv[i], 1);
683 break;
684 case 'u':
685 case 'C':
686 add_wbsdf(argv[i], 1);
687 add_wbsdf(argv[++i], 1);
688 break;
689 default:
690 goto userr;
691 }
692 strcpy(buf, "File produced by: ");
693 if (convert_commandline(buf+18, sizeof(buf)-18, argv) != NULL) {
694 add_wbsdf("-C", 1); add_wbsdf(buf, 0);
695 }
696 if (single_plane_incident >= 0) { /* function-based BSDF? */
697 void (*evf)(char *s) = single_plane_incident ?
698 eval_isotropic : eval_anisotropic;
699 if (i != argc-1 || fundefined(argv[i]) < 3) {
700 fprintf(stderr,
701 "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
702 progname);
703 fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n");
704 goto userr;
705 }
706 ++eclock;
707 add_wbsdf("-a", 1);
708 add_wbsdf(tfmt[single_plane_incident], 1);
709 if (dofwd) {
710 input_orient = -1;
711 output_orient = -1;
712 prog_start("Evaluating outside reflectance");
713 (*evf)(argv[i]);
714 output_orient = 1;
715 prog_start("Evaluating outside->inside transmission");
716 (*evf)(argv[i]);
717 }
718 if (dobwd) {
719 input_orient = 1;
720 output_orient = 1;
721 prog_start("Evaluating inside reflectance");
722 (*evf)(argv[i]);
723 output_orient = -1;
724 prog_start("Evaluating inside->outside transmission");
725 (*evf)(argv[i]);
726 }
727 return(wrap_up());
728 }
729 if (i < argc) { /* open input files if given */
730 int nbsdf = 0;
731 for ( ; i < argc; i++) { /* interpolate each component */
732 char pbuf[256];
733 FILE *fpin = fopen(argv[i], "rb");
734 if (fpin == NULL) {
735 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
736 progname, argv[i]);
737 return(1);
738 }
739 if (!load_bsdf_rep(fpin))
740 return(1);
741 fclose(fpin);
742 sprintf(pbuf, "Interpolating component '%s'", argv[i]);
743 prog_start(pbuf);
744 if (!nbsdf++) {
745 add_wbsdf("-a", 1);
746 add_wbsdf(tfmt[single_plane_incident], 1);
747 }
748 if (single_plane_incident)
749 eval_isotropic(NULL);
750 else
751 eval_anisotropic(NULL);
752 }
753 return(wrap_up());
754 }
755 SET_FILE_BINARY(stdin); /* load from stdin */
756 if (!load_bsdf_rep(stdin))
757 return(1);
758 prog_start("Interpolating from standard input");
759 add_wbsdf("-a", 1);
760 add_wbsdf(tfmt[single_plane_incident], 1);
761 if (single_plane_incident) /* resample dist. */
762 eval_isotropic(NULL);
763 else
764 eval_anisotropic(NULL);
765
766 return(wrap_up());
767 userr:
768 fprintf(stderr,
769 "Usage: %s [{+|-}a][-g Nlog2][-t pctcull][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n",
770 progname);
771 fprintf(stderr,
772 " or: %s -t{3|4} [{+|-}a][-g Nlog2][-t pctcull][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
773 progname);
774 return(1);
775 }
