| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.32 2016/02/02 18:02:32 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Load measured BSDF interpolant and write out as XML file with tensor tree.
| 6 |
| 7 |
* G. Ward
| 8 |
| 9 |
| 10 |
#define _USE_MATH_DEFINES
| 11 |
#include <stdio.h>
| 12 |
#include <stdlib.h>
| 13 |
#include <math.h>
| 14 |
#include "random.h"
| 15 |
#include "platform.h"
| 16 |
#include "paths.h"
| 17 |
#include "rtio.h"
| 18 |
#include "calcomp.h"
| 19 |
#include "bsdfrep.h"
| 20 |
/* global argv[0] */
| 21 |
char *progname;
| 22 |
/* percentage to cull (<0 to turn off) */
| 23 |
static double pctcull = 90.;
| 24 |
/* sampling order */
| 25 |
static int samp_order = 6;
| 26 |
/* super-sampling threshold */
| 27 |
const double ssamp_thresh = 0.35;
| 28 |
/* number of super-samples */
| 29 |
#ifndef NSSAMP
| 30 |
#define NSSAMP 100
| 31 |
#endif
| 32 |
/* limit on number of RBF lobes */
| 33 |
static int lobe_lim = 15000;
| 34 |
/* progress bar length */
| 35 |
static int do_prog = 79;
| 36 |
| 37 |
#define MAXCARG 512 /* wrapBSDF command */
| 38 |
static char *wrapBSDF[MAXCARG] = {"wrapBSDF", "-U"};
| 39 |
static int wbsdfac = 2;
| 40 |
| 41 |
/* Add argument to wrapBSDF, allocating space if isstatic */
| 42 |
static void
| 43 |
add_wbsdf(const char *arg, int isstatic)
| 44 |
| 45 |
if (arg == NULL)
| 46 |
return;
| 47 |
if (wbsdfac >= MAXCARG-1) {
| 48 |
fputs(progname, stderr);
| 49 |
fputs(": too many command arguments to wrapBSDF\n", stderr);
| 50 |
exit(1);
| 51 |
| 52 |
if (!*arg)
| 53 |
arg = "";
| 54 |
else if (!isstatic)
| 55 |
arg = savqstr((char *)arg);
| 56 |
| 57 |
wrapBSDF[wbsdfac++] = (char *)arg;
| 58 |
| 59 |
| 60 |
/* Create Yuv component file and add appropriate arguments */
| 61 |
static char *
| 62 |
create_component_file(int c)
| 63 |
| 64 |
static const char sname[3][6] = {"CIE-Y", "CIE-u", "CIE-v"};
| 65 |
static const char cname[4][4] = {"-rf", "-tf", "-tb", "-rb"};
| 66 |
char *tfname = mktemp(savqstr(TEMPLATE));
| 67 |
| 68 |
add_wbsdf("-s", 1); add_wbsdf(sname[c], 1);
| 69 |
add_wbsdf(cname[(input_orient>0)<<1 | (output_orient>0)], 1);
| 70 |
add_wbsdf(tfname, 1);
| 71 |
return(tfname);
| 72 |
| 73 |
| 74 |
/* Start new progress bar */
| 75 |
#define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else
| 76 |
| 77 |
/* Draw progress bar of the appropriate length */
| 78 |
static void
| 79 |
prog_show(double frac)
| 80 |
| 81 |
static unsigned call_cnt = 0;
| 82 |
static char lastc[] = "-\\|/";
| 83 |
char pbar[256];
| 84 |
int nchars;
| 85 |
| 86 |
if (do_prog <= 1) return;
| 87 |
if (do_prog > sizeof(pbar)-2)
| 88 |
do_prog = sizeof(pbar)-2;
| 89 |
if (frac < 0) frac = 0;
| 90 |
else if (frac >= 1) frac = .9999;
| 91 |
nchars = do_prog*frac;
| 92 |
pbar[0] = '\r';
| 93 |
memset(pbar+1, '*', nchars);
| 94 |
pbar[nchars+1] = lastc[call_cnt++ & 3];
| 95 |
memset(pbar+2+nchars, '-', do_prog-nchars-1);
| 96 |
pbar[do_prog+1] = '\0';
| 97 |
fputs(pbar, stderr);
| 98 |
| 99 |
| 100 |
/* Finish progress bar */
| 101 |
static void
| 102 |
prog_done(void)
| 103 |
| 104 |
int n = do_prog;
| 105 |
| 106 |
if (n <= 1) return;
| 107 |
fputc('\r', stderr);
| 108 |
while (n--)
| 109 |
fputc(' ', stderr);
| 110 |
| 111 |
| 112 |
| 113 |
/* Compute absolute relative difference */
| 114 |
static double
| 115 |
abs_diff(double v1, double v0)
| 116 |
| 117 |
if ((v0 < 0) | (v1 < 0))
| 118 |
return(.0);
| 119 |
v1 = (v1-v0)*2./(v0+v1+.0001);
| 120 |
if (v1 < 0)
| 121 |
return(-v1);
| 122 |
return(v1);
| 123 |
| 124 |
| 125 |
/* Interpolate and output isotropic BSDF data */
| 126 |
static void
| 127 |
eval_isotropic(char *funame)
| 128 |
| 129 |
const int sqres = 1<<samp_order;
| 130 |
FILE *ofp, *uvfp[2];
| 131 |
int assignD = 0;
| 132 |
char cmd[128];
| 133 |
int ix, ox, oy;
| 134 |
double iovec[6];
| 135 |
float bsdf, uv[2];
| 136 |
| 137 |
if (pctcull >= 0) {
| 138 |
sprintf(cmd, "rttree_reduce -a -h -ff -r 3 -t %f -g %d > %s",
| 139 |
pctcull, samp_order, create_component_file(0));
| 140 |
ofp = popen(cmd, "w");
| 141 |
if (ofp == NULL) {
| 142 |
fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
| 143 |
progname);
| 144 |
exit(1);
| 145 |
| 146 |
SET_FILE_BINARY(ofp);
| 147 |
#ifdef getc_unlocked /* avoid lock/unlock overhead */
| 148 |
flockfile(ofp);
| 149 |
#endif
| 150 |
if (rbf_colorimetry == RBCtristimulus) {
| 151 |
double uvcull = 100. - (100.-pctcull)*.25;
| 152 |
| 153 |
uvcull, samp_order, create_component_file(1));
| 154 |
uvfp[0] = popen(cmd, "w");
| 155 |
| 156 |
uvcull, samp_order, create_component_file(2));
| 157 |
uvfp[1] = popen(cmd, "w");
| 158 |
if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
| 159 |
fprintf(stderr, "%s: cannot open pipes to uv output\n",
| 160 |
progname);
| 161 |
exit(1);
| 162 |
| 163 |
SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
| 164 |
| 165 |
flockfile(uvfp[0]); flockfile(uvfp[1]);
| 166 |
#endif
| 167 |
| 168 |
} else {
| 169 |
ofp = fopen(create_component_file(0), "w");
| 170 |
if (ofp == NULL) {
| 171 |
fprintf(stderr, "%s: cannot create Y output file\n",
| 172 |
progname);
| 173 |
exit(1);
| 174 |
| 175 |
fputs("{\n", ofp);
| 176 |
| 177 |
uvfp[0] = fopen(create_component_file(1), "w");
| 178 |
uvfp[1] = fopen(create_component_file(2), "w");
| 179 |
| 180 |
fprintf(stderr, "%s: cannot create uv output file(s)\n",
| 181 |
progname);
| 182 |
exit(1);
| 183 |
| 184 |
fputs("{\n", uvfp[0]);
| 185 |
fputs("{\n", uvfp[1]);
| 186 |
| 187 |
| 188 |
/* need to assign Dx, Dy, Dz? */
| 189 |
if (funame != NULL)
| 190 |
assignD = (fundefined(funame) < 6);
| 191 |
/* run through directions */
| 192 |
for (ix = 0; ix < sqres/2; ix++) {
| 193 |
RBFNODE *rbf = NULL;
| 194 |
iovec[0] = 2.*(ix+.5)/sqres - 1.;
| 195 |
iovec[1] = .0;
| 196 |
iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]);
| 197 |
if (funame == NULL)
| 198 |
rbf = advect_rbf(iovec, lobe_lim);
| 199 |
for (ox = 0; ox < sqres; ox++) {
| 200 |
float last_bsdf = -1;
| 201 |
for (oy = 0; oy < sqres; oy++) {
| 202 |
SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres);
| 203 |
iovec[5] = output_orient *
| 204 |
sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
| 205 |
if (funame == NULL) {
| 206 |
SDValue sdv;
| 207 |
eval_rbfcol(&sdv, rbf, iovec+3);
| 208 |
bsdf = sdv.cieY;
| 209 |
| 210 |
c_ccvt(&sdv.spec, C_CSXY);
| 211 |
uv[0] = uv[1] = 1. /
| 212 |
(-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
| 213 |
uv[0] *= 4.*sdv.spec.cx;
| 214 |
uv[1] *= 9.*sdv.spec.cy;
| 215 |
| 216 |
} else {
| 217 |
if (assignD) {
| 218 |
varset("Dx", '=', -iovec[3]);
| 219 |
varset("Dy", '=', -iovec[4]);
| 220 |
varset("Dz", '=', -iovec[5]);
| 221 |
++eclock;
| 222 |
| 223 |
bsdf = funvalue(funame, 6, iovec);
| 224 |
#if (NSSAMP > 0)
| 225 |
if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
| 226 |
int ssi;
| 227 |
double ssa[3], ssvec[6], sum = 0;
| 228 |
/* super-sample voxel */
| 229 |
for (ssi = NSSAMP; ssi--; ) {
| 230 |
SDmultiSamp(ssa, 3, (ssi+frandom()) *
| 231 |
(1./NSSAMP));
| 232 |
ssvec[0] = 2.*(ix+ssa[0])/sqres - 1.;
| 233 |
ssvec[1] = .0;
| 234 |
ssvec[2] = input_orient *
| 235 |
sqrt(1. - ssvec[0]*ssvec[0]);
| 236 |
SDsquare2disk(ssvec+3, (ox+ssa[1])/sqres,
| 237 |
(oy+ssa[2])/sqres);
| 238 |
ssvec[5] = output_orient *
| 239 |
sqrt(1. - ssvec[3]*ssvec[3] -
| 240 |
ssvec[4]*ssvec[4]);
| 241 |
if (assignD) {
| 242 |
varset("Dx", '=', -ssvec[3]);
| 243 |
varset("Dy", '=', -ssvec[4]);
| 244 |
varset("Dz", '=', -ssvec[5]);
| 245 |
++eclock;
| 246 |
| 247 |
sum += funvalue(funame, 6, ssvec);
| 248 |
| 249 |
bsdf = sum/NSSAMP;
| 250 |
| 251 |
#endif
| 252 |
| 253 |
if (pctcull >= 0)
| 254 |
fwrite(&bsdf, sizeof(bsdf), 1, ofp);
| 255 |
else
| 256 |
fprintf(ofp, "\t%.3e\n", bsdf);
| 257 |
| 258 |
| 259 |
if (pctcull >= 0) {
| 260 |
fwrite(&uv[0], sizeof(*uv), 1, uvfp[0]);
| 261 |
fwrite(&uv[1], sizeof(*uv), 1, uvfp[1]);
| 262 |
} else {
| 263 |
fprintf(uvfp[0], "\t%.3e\n", uv[0]);
| 264 |
fprintf(uvfp[1], "\t%.3e\n", uv[1]);
| 265 |
| 266 |
| 267 |
last_bsdf = bsdf;
| 268 |
| 269 |
| 270 |
if (rbf != NULL)
| 271 |
free(rbf);
| 272 |
prog_show((ix+1.)*(2./sqres));
| 273 |
| 274 |
if (pctcull >= 0) { /* finish output */
| 275 |
if (pclose(ofp)) {
| 276 |
fprintf(stderr, "%s: error running rttree_reduce on Y\n",
| 277 |
progname);
| 278 |
exit(1);
| 279 |
| 280 |
if (rbf_colorimetry == RBCtristimulus &&
| 281 |
(pclose(uvfp[0]) || pclose(uvfp[1]))) {
| 282 |
fprintf(stderr, "%s: error running rttree_reduce on uv\n",
| 283 |
progname);
| 284 |
exit(1);
| 285 |
| 286 |
} else {
| 287 |
for (ix = sqres*sqres*sqres/2; ix--; )
| 288 |
fputs("\t0\n", ofp);
| 289 |
fputs("}\n", ofp);
| 290 |
if (fclose(ofp)) {
| 291 |
fprintf(stderr, "%s: error writing Y file\n",
| 292 |
progname);
| 293 |
exit(1);
| 294 |
| 295 |
| 296 |
for (ix = sqres*sqres*sqres/2; ix--; ) {
| 297 |
fputs("\t0\n", uvfp[0]);
| 298 |
fputs("\t0\n", uvfp[1]);
| 299 |
| 300 |
fputs("}\n", uvfp[0]);
| 301 |
fputs("}\n", uvfp[1]);
| 302 |
if (fclose(uvfp[0]) || fclose(uvfp[1])) {
| 303 |
fprintf(stderr, "%s: error writing uv file(s)\n",
| 304 |
progname);
| 305 |
exit(1);
| 306 |
| 307 |
| 308 |
| 309 |
prog_done();
| 310 |
| 311 |
| 312 |
/* Interpolate and output anisotropic BSDF data */
| 313 |
static void
| 314 |
eval_anisotropic(char *funame)
| 315 |
| 316 |
| 317 |
| 318 |
int assignD = 0;
| 319 |
char cmd[128];
| 320 |
int ix, iy, ox, oy;
| 321 |
double iovec[6];
| 322 |
float bsdf, uv[2];
| 323 |
| 324 |
if (pctcull >= 0) {
| 325 |
sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
| 326 |
(input_orient>0 ^ output_orient>0) ? "" : " -a",
| 327 |
| 328 |
| 329 |
if (ofp == NULL) {
| 330 |
| 331 |
progname);
| 332 |
exit(1);
| 333 |
| 334 |
| 335 |
| 336 |
flockfile(ofp);
| 337 |
#endif
| 338 |
| 339 |
| 340 |
| 341 |
| 342 |
| 343 |
| 344 |
| 345 |
| 346 |
| 347 |
| 348 |
| 349 |
| 350 |
progname);
| 351 |
exit(1);
| 352 |
| 353 |
| 354 |
| 355 |
| 356 |
#endif
| 357 |
| 358 |
} else {
| 359 |
| 360 |
if (ofp == NULL) {
| 361 |
| 362 |
progname);
| 363 |
exit(1);
| 364 |
| 365 |
fputs("{\n", ofp);
| 366 |
| 367 |
| 368 |
| 369 |
| 370 |
| 371 |
progname);
| 372 |
exit(1);
| 373 |
| 374 |
| 375 |
| 376 |
| 377 |
| 378 |
| 379 |
if (funame != NULL)
| 380 |
| 381 |
| 382 |
for (ix = 0; ix < sqres; ix++)
| 383 |
for (iy = 0; iy < sqres; iy++) {
| 384 |
RBFNODE *rbf = NULL; /* Klems reversal */
| 385 |
SDsquare2disk(iovec, 1.-(ix+.5)/sqres, 1.-(iy+.5)/sqres);
| 386 |
| 387 |
sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]);
| 388 |
if (funame == NULL)
| 389 |
| 390 |
| 391 |
| 392 |
| 393 |
| 394 |
| 395 |
| 396 |
| 397 |
SDValue sdv;
| 398 |
| 399 |
bsdf = sdv.cieY;
| 400 |
| 401 |
| 402 |
| 403 |
| 404 |
| 405 |
| 406 |
| 407 |
} else {
| 408 |
if (assignD) {
| 409 |
| 410 |
| 411 |
| 412 |
++eclock;
| 413 |
| 414 |
| 415 |
#if (NSSAMP > 0)
| 416 |
| 417 |
int ssi;
| 418 |
double ssa[4], ssvec[6], sum = 0;
| 419 |
| 420 |
| 421 |
SDmultiSamp(ssa, 4, (ssi+frandom()) *
| 422 |
(1./NSSAMP));
| 423 |
SDsquare2disk(ssvec, 1.-(ix+ssa[0])/sqres,
| 424 |
1.-(iy+ssa[1])/sqres);
| 425 |
| 426 |
sqrt(1. - ssvec[0]*ssvec[0] -
| 427 |
ssvec[1]*ssvec[1]);
| 428 |
SDsquare2disk(ssvec+3, (ox+ssa[2])/sqres,
| 429 |
(oy+ssa[3])/sqres);
| 430 |
| 431 |
| 432 |
ssvec[4]*ssvec[4]);
| 433 |
if (assignD) {
| 434 |
| 435 |
| 436 |
| 437 |
++eclock;
| 438 |
| 439 |
| 440 |
| 441 |
bsdf = sum/NSSAMP;
| 442 |
| 443 |
#endif
| 444 |
| 445 |
if (pctcull >= 0)
| 446 |
| 447 |
else
| 448 |
| 449 |
| 450 |
| 451 |
if (pctcull >= 0) {
| 452 |
| 453 |
| 454 |
} else {
| 455 |
| 456 |
| 457 |
| 458 |
| 459 |
last_bsdf = bsdf;
| 460 |
| 461 |
| 462 |
if (rbf != NULL)
| 463 |
free(rbf);
| 464 |
prog_show((ix*sqres+iy+1.)/(sqres*sqres));
| 465 |
| 466 |
| 467 |
if (pclose(ofp)) {
| 468 |
| 469 |
progname);
| 470 |
exit(1);
| 471 |
| 472 |
| 473 |
| 474 |
| 475 |
progname);
| 476 |
exit(1);
| 477 |
| 478 |
} else {
| 479 |
fputs("}\n", ofp);
| 480 |
if (fclose(ofp)) {
| 481 |
| 482 |
progname);
| 483 |
exit(1);
| 484 |
| 485 |
| 486 |
| 487 |
| 488 |
| 489 |
| 490 |
progname);
| 491 |
exit(1);
| 492 |
| 493 |
| 494 |
| 495 |
prog_done();
| 496 |
| 497 |
| 498 |
#ifdef _WIN32
| 499 |
/* Execute wrapBSDF command (may never return) */
| 500 |
static int
| 501 |
wrap_up(void)
| 502 |
| 503 |
char cmd[8192];
| 504 |
| 505 |
if (bsdf_manuf[0]) {
| 506 |
add_wbsdf("-f", 1);
| 507 |
strcpy(cmd, "m=");
| 508 |
strcpy(cmd+2, bsdf_manuf);
| 509 |
add_wbsdf(cmd, 0);
| 510 |
| 511 |
if (bsdf_name[0]) {
| 512 |
add_wbsdf("-f", 1);
| 513 |
strcpy(cmd, "n=");
| 514 |
strcpy(cmd+2, bsdf_name);
| 515 |
add_wbsdf(cmd, 0);
| 516 |
| 517 |
if (!convert_commandline(cmd, sizeof(cmd), wrapBSDF)) {
| 518 |
| 519 |
fputs(": command line too long in wrap_up()\n", stderr);
| 520 |
return(1);
| 521 |
| 522 |
return(system(cmd));
| 523 |
| 524 |
#else
| 525 |
| 526 |
static int
| 527 |
wrap_up(void)
| 528 |
| 529 |
char buf[256];
| 530 |
char *compath = getpath((char *)wrapBSDF[0], getenv("PATH"), X_OK);
| 531 |
| 532 |
if (compath == NULL) {
| 533 |
fprintf(stderr, "%s: cannot locate %s\n", progname, wrapBSDF[0]);
| 534 |
return(1);
| 535 |
| 536 |
| 537 |
add_wbsdf("-f", 1);
| 538 |
strcpy(buf, "m=");
| 539 |
strcpy(buf+2, bsdf_manuf);
| 540 |
add_wbsdf(buf, 0);
| 541 |
| 542 |
if (bsdf_name[0]) {
| 543 |
add_wbsdf("-f", 1);
| 544 |
strcpy(buf, "n=");
| 545 |
strcpy(buf+2, bsdf_name);
| 546 |
add_wbsdf(buf, 0);
| 547 |
| 548 |
execv(compath, wrapBSDF); /* successful call never returns */
| 549 |
perror(compath);
| 550 |
return(1);
| 551 |
| 552 |
#endif
| 553 |
| 554 |
/* Read in BSDF and interpolate as tensor tree representation */
| 555 |
int
| 556 |
main(int argc, char *argv[])
| 557 |
| 558 |
static char tfmt[2][4] = {"t4", "t3"};
| 559 |
int dofwd = 0, dobwd = 1;
| 560 |
char buf[2048];
| 561 |
int i, na;
| 562 |
| 563 |
progname = argv[0];
| 564 |
esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
| 565 |
esupport &= ~(E_INCHAN|E_OUTCHAN);
| 566 |
scompile("PI:3.14159265358979323846", NULL, 0);
| 567 |
biggerlib();
| 568 |
for (i = 1; i < argc-1 && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
| 569 |
switch (argv[i][1]) { /* get options */
| 570 |
case 'e':
| 571 |
scompile(argv[++i], NULL, 0);
| 572 |
break;
| 573 |
case 'f':
| 574 |
if (!argv[i][2]) {
| 575 |
if (strchr(argv[++i], '=') != NULL) {
| 576 |
add_wbsdf("-f", 1);
| 577 |
add_wbsdf(argv[i], 1);
| 578 |
} else
| 579 |
fcompile(argv[i]);
| 580 |
} else
| 581 |
dofwd = (argv[i][0] == '+');
| 582 |
break;
| 583 |
case 'b':
| 584 |
dobwd = (argv[i][0] == '+');
| 585 |
break;
| 586 |
case 't':
| 587 |
switch (argv[i][2]) {
| 588 |
case '3':
| 589 |
single_plane_incident = 1;
| 590 |
break;
| 591 |
case '4':
| 592 |
single_plane_incident = 0;
| 593 |
break;
| 594 |
case '\0':
| 595 |
pctcull = atof(argv[++i]);
| 596 |
break;
| 597 |
default:
| 598 |
goto userr;
| 599 |
| 600 |
break;
| 601 |
case 'g':
| 602 |
samp_order = atoi(argv[++i]);
| 603 |
break;
| 604 |
case 'l':
| 605 |
lobe_lim = atoi(argv[++i]);
| 606 |
break;
| 607 |
case 'p':
| 608 |
do_prog = atoi(argv[i]+2);
| 609 |
break;
| 610 |
case 'W':
| 611 |
| 612 |
break;
| 613 |
case 'u':
| 614 |
case 'C':
| 615 |
| 616 |
add_wbsdf(argv[++i], 1);
| 617 |
break;
| 618 |
default:
| 619 |
goto userr;
| 620 |
| 621 |
strcpy(buf, "File produced by: ");
| 622 |
if (convert_commandline(buf+18, sizeof(buf)-18, argv) != NULL) {
| 623 |
add_wbsdf("-C", 1); add_wbsdf(buf, 0);
| 624 |
| 625 |
if (single_plane_incident >= 0) { /* function-based BSDF? */
| 626 |
void (*evf)(char *s) = single_plane_incident ?
| 627 |
eval_isotropic : eval_anisotropic;
| 628 |
if (i != argc-1 || fundefined(argv[i]) < 3) {
| 629 |
fprintf(stderr,
| 630 |
"%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
| 631 |
progname);
| 632 |
fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n");
| 633 |
goto userr;
| 634 |
| 635 |
++eclock;
| 636 |
add_wbsdf("-a", 1);
| 637 |
add_wbsdf(tfmt[single_plane_incident], 1);
| 638 |
if (dofwd) {
| 639 |
input_orient = -1;
| 640 |
output_orient = -1;
| 641 |
prog_start("Evaluating outside reflectance");
| 642 |
(*evf)(argv[i]);
| 643 |
output_orient = 1;
| 644 |
prog_start("Evaluating outside->inside transmission");
| 645 |
(*evf)(argv[i]);
| 646 |
| 647 |
if (dobwd) {
| 648 |
input_orient = 1;
| 649 |
output_orient = 1;
| 650 |
prog_start("Evaluating inside reflectance");
| 651 |
(*evf)(argv[i]);
| 652 |
output_orient = -1;
| 653 |
prog_start("Evaluating inside->outside transmission");
| 654 |
(*evf)(argv[i]);
| 655 |
| 656 |
return(wrap_up());
| 657 |
| 658 |
if (i < argc) { /* open input files if given */
| 659 |
int nbsdf = 0;
| 660 |
for ( ; i < argc; i++) { /* interpolate each component */
| 661 |
char pbuf[256];
| 662 |
FILE *fpin = fopen(argv[i], "rb");
| 663 |
if (fpin == NULL) {
| 664 |
fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
| 665 |
progname, argv[i]);
| 666 |
return(1);
| 667 |
| 668 |
if (!load_bsdf_rep(fpin))
| 669 |
return(1);
| 670 |
fclose(fpin);
| 671 |
sprintf(pbuf, "Interpolating component '%s'", argv[i]);
| 672 |
prog_start(pbuf);
| 673 |
if (!nbsdf++) {
| 674 |
add_wbsdf("-a", 1);
| 675 |
| 676 |
| 677 |
if (single_plane_incident)
| 678 |
eval_isotropic(NULL);
| 679 |
else
| 680 |
eval_anisotropic(NULL);
| 681 |
| 682 |
return(wrap_up());
| 683 |
| 684 |
SET_FILE_BINARY(stdin); /* load from stdin */
| 685 |
if (!load_bsdf_rep(stdin))
| 686 |
return(1);
| 687 |
prog_start("Interpolating from standard input");
| 688 |
add_wbsdf("-a", 1);
| 689 |
| 690 |
if (single_plane_incident) /* resample dist. */
| 691 |
| 692 |
else
| 693 |
| 694 |
| 695 |
return(wrap_up());
| 696 |
userr:
| 697 |
fprintf(stderr,
| 698 |
"Usage: %s [-g Nlog2][-t pctcull][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n",
| 699 |
progname);
| 700 |
fprintf(stderr,
| 701 |
" or: %s -t{3|4} [-g Nlog2][-t pctcull][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
| 702 |
progname);
| 703 |
return(1);
| 704 |
