1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.31 2016/01/29 16:21:55 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Load measured BSDF interpolant and write out as XML file with tensor tree. |
6 |
7 |
* G. Ward |
8 |
9 |
10 |
#define _USE_MATH_DEFINES |
11 |
#include <stdio.h> |
12 |
#include <stdlib.h> |
13 |
#include <math.h> |
14 |
#include "random.h" |
15 |
#include "platform.h" |
16 |
#include "rtprocess.h" |
17 |
#include "calcomp.h" |
18 |
#include "bsdfrep.h" |
19 |
/* global argv[0] */ |
20 |
char *progname; |
21 |
/* percentage to cull (<0 to turn off) */ |
22 |
static double pctcull = 90.; |
23 |
/* sampling order */ |
24 |
static int samp_order = 6; |
25 |
/* super-sampling threshold */ |
26 |
const double ssamp_thresh = 0.35; |
27 |
/* number of super-samples */ |
28 |
#ifndef NSSAMP |
29 |
#define NSSAMP 100 |
30 |
#endif |
31 |
/* limit on number of RBF lobes */ |
32 |
static int lobe_lim = 15000; |
33 |
/* progress bar length */ |
34 |
static int do_prog = 79; |
35 |
36 |
37 |
/* Start new progress bar */ |
38 |
#define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else |
39 |
40 |
/* Draw progress bar of the appropriate length */ |
41 |
static void |
42 |
prog_show(double frac) |
43 |
44 |
static unsigned call_cnt = 0; |
45 |
static char lastc[] = "-\\|/"; |
46 |
char pbar[256]; |
47 |
int nchars; |
48 |
49 |
if (do_prog <= 1) return; |
50 |
if (do_prog > sizeof(pbar)-2) |
51 |
do_prog = sizeof(pbar)-2; |
52 |
if (frac < 0) frac = 0; |
53 |
else if (frac >= 1) frac = .9999; |
54 |
nchars = do_prog*frac; |
55 |
pbar[0] = '\r'; |
56 |
memset(pbar+1, '*', nchars); |
57 |
pbar[nchars+1] = lastc[call_cnt++ & 3]; |
58 |
memset(pbar+2+nchars, '-', do_prog-nchars-1); |
59 |
pbar[do_prog+1] = '\0'; |
60 |
fputs(pbar, stderr); |
61 |
62 |
63 |
/* Finish progress bar */ |
64 |
static void |
65 |
prog_done(void) |
66 |
67 |
int n = do_prog; |
68 |
69 |
if (n <= 1) return; |
70 |
fputc('\r', stderr); |
71 |
while (n--) |
72 |
fputc(' ', stderr); |
73 |
74 |
75 |
76 |
/* Output XML prologue to stdout */ |
77 |
static void |
78 |
xml_prologue(int ac, char *av[]) |
79 |
80 |
puts("<?xml version=\"1.0\" encoding=\"UTF-8\"?>"); |
81 |
puts("<WindowElement xmlns=\"http://windows.lbl.gov\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:schemaLocation=\"http://windows.lbl.gov/BSDF-v1.4.xsd\">"); |
82 |
fputs("<!-- File produced by:", stdout); |
83 |
while (ac-- > 0) { |
84 |
fputc(' ', stdout); |
85 |
fputs(*av++, stdout); |
86 |
87 |
puts(" -->"); |
88 |
puts("<WindowElementType>System</WindowElementType>"); |
89 |
puts("<FileType>BSDF</FileType>"); |
90 |
puts("<Optical>"); |
91 |
puts("<Layer>"); |
92 |
puts("\t<Material>"); |
93 |
printf("\t\t<Name>%s</Name>\n", bsdf_name[0] ? bsdf_name : "Unknown"); |
94 |
printf("\t\t<Manufacturer>%s</Manufacturer>\n", |
95 |
bsdf_manuf[0] ? bsdf_manuf : "Unknown"); |
96 |
puts("\t\t<DeviceType>Other</DeviceType>"); |
97 |
puts("\t</Material>"); |
98 |
puts("\t<DataDefinition>"); |
99 |
printf("\t\t<IncidentDataStructure>TensorTree%c</IncidentDataStructure>\n", |
100 |
single_plane_incident ? '3' : '4'); |
101 |
puts("\t</DataDefinition>"); |
102 |
103 |
104 |
/* Output XML data prologue to stdout */ |
105 |
static void |
106 |
data_prologue() |
107 |
108 |
static const char *bsdf_type[4] = { |
109 |
"Reflection Front", |
110 |
"Transmission Front", |
111 |
"Transmission Back", |
112 |
"Reflection Back" |
113 |
114 |
115 |
puts("\t<WavelengthData>"); |
116 |
puts("\t\t<LayerNumber>System</LayerNumber>"); |
117 |
puts("\t\t<Wavelength unit=\"Integral\">Visible</Wavelength>"); |
118 |
puts("\t\t<SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>"); |
119 |
puts("\t\t<DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>"); |
120 |
puts("\t\t<WavelengthDataBlock>"); |
121 |
printf("\t\t\t<WavelengthDataDirection>%s</WavelengthDataDirection>\n", |
122 |
bsdf_type[(input_orient>0)<<1 | (output_orient>0)]); |
123 |
puts("\t\t\t<AngleBasis>LBNL/Shirley-Chiu</AngleBasis>"); |
124 |
puts("\t\t\t<ScatteringDataType>BTDF</ScatteringDataType>"); |
125 |
puts("\t\t\t<ScatteringData>"); |
126 |
127 |
128 |
/* Output XML data epilogue to stdout */ |
129 |
static void |
130 |
data_epilogue(void) |
131 |
132 |
puts("\t\t\t</ScatteringData>"); |
133 |
puts("\t\t</WavelengthDataBlock>"); |
134 |
puts("\t</WavelengthData>"); |
135 |
136 |
137 |
/* Output XML epilogue to stdout */ |
138 |
static void |
139 |
xml_epilogue(void) |
140 |
141 |
puts("</Layer>"); |
142 |
puts("</Optical>"); |
143 |
puts("</WindowElement>"); |
144 |
145 |
146 |
/* Compute absolute relative difference */ |
147 |
static double |
148 |
abs_diff(double v1, double v0) |
149 |
150 |
if ((v0 < 0) | (v1 < 0)) |
151 |
return(.0); |
152 |
v1 = (v1-v0)*2./(v0+v1+.0001); |
153 |
if (v1 < 0) |
154 |
return(-v1); |
155 |
return(v1); |
156 |
157 |
158 |
/* Interpolate and output isotropic BSDF data */ |
159 |
static void |
160 |
eval_isotropic(char *funame) |
161 |
162 |
const int sqres = 1<<samp_order; |
163 |
FILE *ofp = NULL; |
164 |
int assignD = 0; |
165 |
char cmd[128]; |
166 |
int ix, ox, oy; |
167 |
double iovec[6]; |
168 |
float bsdf; |
169 |
170 |
data_prologue(); /* begin output */ |
171 |
if (pctcull >= 0) { |
172 |
sprintf(cmd, "rttree_reduce -a -h -ff -r 3 -t %f -g %d", |
173 |
pctcull, samp_order); |
174 |
fflush(stdout); |
175 |
ofp = popen(cmd, "w"); |
176 |
if (ofp == NULL) { |
177 |
fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n", |
178 |
progname); |
179 |
exit(1); |
180 |
181 |
SET_FILE_BINARY(ofp); |
182 |
#ifdef getc_unlocked /* avoid lock/unlock overhead */ |
183 |
flockfile(ofp); |
184 |
#endif |
185 |
} else |
186 |
fputs("{\n", stdout); |
187 |
/* need to assign Dx, Dy, Dz? */ |
188 |
if (funame != NULL) |
189 |
assignD = (fundefined(funame) < 6); |
190 |
/* run through directions */ |
191 |
for (ix = 0; ix < sqres/2; ix++) { |
192 |
RBFNODE *rbf = NULL; |
193 |
iovec[0] = 2.*(ix+.5)/sqres - 1.; |
194 |
iovec[1] = .0; |
195 |
iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]); |
196 |
if (funame == NULL) |
197 |
rbf = advect_rbf(iovec, lobe_lim); |
198 |
for (ox = 0; ox < sqres; ox++) { |
199 |
float last_bsdf = -1; |
200 |
for (oy = 0; oy < sqres; oy++) { |
201 |
SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres); |
202 |
iovec[5] = output_orient * |
203 |
sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]); |
204 |
205 |
bsdf = eval_rbfrep(rbf, iovec+3); |
206 |
else { |
207 |
if (assignD) { |
208 |
varset("Dx", '=', -iovec[3]); |
209 |
varset("Dy", '=', -iovec[4]); |
210 |
varset("Dz", '=', -iovec[5]); |
211 |
++eclock; |
212 |
213 |
bsdf = funvalue(funame, 6, iovec); |
214 |
#if (NSSAMP > 0) |
215 |
if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) { |
216 |
int ssi; |
217 |
double ssa[3], ssvec[6], sum = 0; |
218 |
/* super-sample voxel */ |
219 |
for (ssi = NSSAMP; ssi--; ) { |
220 |
SDmultiSamp(ssa, 3, (ssi+frandom()) * |
221 |
(1./NSSAMP)); |
222 |
ssvec[0] = 2.*(ix+ssa[0])/sqres - 1.; |
223 |
ssvec[1] = .0; |
224 |
ssvec[2] = input_orient * |
225 |
sqrt(1. - ssvec[0]*ssvec[0]); |
226 |
SDsquare2disk(ssvec+3, (ox+ssa[1])/sqres, |
227 |
(oy+ssa[2])/sqres); |
228 |
ssvec[5] = output_orient * |
229 |
sqrt(1. - ssvec[3]*ssvec[3] - |
230 |
ssvec[4]*ssvec[4]); |
231 |
if (assignD) { |
232 |
varset("Dx", '=', -ssvec[3]); |
233 |
varset("Dy", '=', -ssvec[4]); |
234 |
varset("Dz", '=', -ssvec[5]); |
235 |
++eclock; |
236 |
237 |
sum += funvalue(funame, 6, ssvec); |
238 |
239 |
bsdf = sum/NSSAMP; |
240 |
241 |
#endif |
242 |
243 |
if (pctcull >= 0) |
244 |
fwrite(&bsdf, sizeof(bsdf), 1, ofp); |
245 |
else |
246 |
printf("\t%.3e\n", bsdf); |
247 |
last_bsdf = bsdf; |
248 |
249 |
250 |
if (rbf != NULL) |
251 |
free(rbf); |
252 |
prog_show((ix+1.)*(2./sqres)); |
253 |
254 |
if (pctcull >= 0) { /* finish output */ |
255 |
if (pclose(ofp)) { |
256 |
fprintf(stderr, "%s: error running '%s'\n", |
257 |
progname, cmd); |
258 |
exit(1); |
259 |
260 |
} else { |
261 |
for (ix = sqres*sqres*sqres/2; ix--; ) |
262 |
fputs("\t0\n", stdout); |
263 |
fputs("}\n", stdout); |
264 |
265 |
data_epilogue(); |
266 |
prog_done(); |
267 |
268 |
269 |
/* Interpolate and output anisotropic BSDF data */ |
270 |
static void |
271 |
eval_anisotropic(char *funame) |
272 |
273 |
274 |
FILE *ofp = NULL; |
275 |
int assignD = 0; |
276 |
char cmd[128]; |
277 |
int ix, iy, ox, oy; |
278 |
double iovec[6]; |
279 |
float bsdf; |
280 |
281 |
282 |
283 |
sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d", |
284 |
(input_orient>0 ^ output_orient>0) ? "" : " -a", |
285 |
286 |
fflush(stdout); |
287 |
288 |
289 |
290 |
progname); |
291 |
exit(1); |
292 |
293 |
294 |
295 |
flockfile(ofp); |
296 |
#endif |
297 |
} else |
298 |
299 |
300 |
301 |
302 |
303 |
for (ix = 0; ix < sqres; ix++) |
304 |
for (iy = 0; iy < sqres; iy++) { |
305 |
RBFNODE *rbf = NULL; /* Klems reversal */ |
306 |
SDsquare2disk(iovec, 1.-(ix+.5)/sqres, 1.-(iy+.5)/sqres); |
307 |
iovec[2] = input_orient * |
308 |
sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]); |
309 |
310 |
311 |
312 |
313 |
314 |
315 |
316 |
317 |
318 |
319 |
else { |
320 |
if (assignD) { |
321 |
322 |
323 |
324 |
++eclock; |
325 |
326 |
327 |
#if (NSSAMP > 0) |
328 |
329 |
int ssi; |
330 |
double ssa[4], ssvec[6], sum = 0; |
331 |
332 |
333 |
SDmultiSamp(ssa, 4, (ssi+frandom()) * |
334 |
(1./NSSAMP)); |
335 |
SDsquare2disk(ssvec, 1.-(ix+ssa[0])/sqres, |
336 |
1.-(iy+ssa[1])/sqres); |
337 |
338 |
sqrt(1. - ssvec[0]*ssvec[0] - |
339 |
ssvec[1]*ssvec[1]); |
340 |
SDsquare2disk(ssvec+3, (ox+ssa[2])/sqres, |
341 |
(oy+ssa[3])/sqres); |
342 |
343 |
344 |
345 |
if (assignD) { |
346 |
347 |
348 |
349 |
++eclock; |
350 |
351 |
352 |
353 |
354 |
355 |
#endif |
356 |
357 |
if (pctcull >= 0) |
358 |
359 |
else |
360 |
361 |
last_bsdf = bsdf; |
362 |
363 |
364 |
if (rbf != NULL) |
365 |
free(rbf); |
366 |
prog_show((ix*sqres+iy+1.)/(sqres*sqres)); |
367 |
368 |
369 |
370 |
371 |
progname, cmd); |
372 |
exit(1); |
373 |
374 |
} else |
375 |
376 |
data_epilogue(); |
377 |
prog_done(); |
378 |
379 |
380 |
/* Read in BSDF and interpolate as tensor tree representation */ |
381 |
int |
382 |
main(int argc, char *argv[]) |
383 |
384 |
int dofwd = 0, dobwd = 1; |
385 |
int i, na; |
386 |
387 |
progname = argv[0]; |
388 |
esupport |= E_VARIABLE|E_FUNCTION|E_RCONST; |
389 |
esupport &= ~(E_INCHAN|E_OUTCHAN); |
390 |
scompile("PI:3.14159265358979323846", NULL, 0); |
391 |
biggerlib(); |
392 |
for (i = 1; i < argc-1 && (argv[i][0] == '-') | (argv[i][0] == '+'); i++) |
393 |
switch (argv[i][1]) { /* get options */ |
394 |
case 'e': |
395 |
scompile(argv[++i], NULL, 0); |
396 |
break; |
397 |
case 'f': |
398 |
if (!argv[i][2]) |
399 |
fcompile(argv[++i]); |
400 |
else |
401 |
dofwd = (argv[i][0] == '+'); |
402 |
break; |
403 |
case 'b': |
404 |
dobwd = (argv[i][0] == '+'); |
405 |
break; |
406 |
case 't': |
407 |
switch (argv[i][2]) { |
408 |
case '3': |
409 |
single_plane_incident = 1; |
410 |
break; |
411 |
case '4': |
412 |
single_plane_incident = 0; |
413 |
break; |
414 |
case '\0': |
415 |
pctcull = atof(argv[++i]); |
416 |
break; |
417 |
default: |
418 |
goto userr; |
419 |
420 |
break; |
421 |
case 'g': |
422 |
samp_order = atoi(argv[++i]); |
423 |
break; |
424 |
case 'l': |
425 |
lobe_lim = atoi(argv[++i]); |
426 |
break; |
427 |
case 'p': |
428 |
do_prog = atoi(argv[i]+2); |
429 |
break; |
430 |
default: |
431 |
goto userr; |
432 |
433 |
if (single_plane_incident >= 0) { /* function-based BSDF? */ |
434 |
void (*evf)(char *s) = single_plane_incident ? |
435 |
&eval_isotropic : &eval_anisotropic; |
436 |
if (i != argc-1 || fundefined(argv[i]) < 3) { |
437 |
fprintf(stderr, |
438 |
"%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n", |
439 |
progname); |
440 |
fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n"); |
441 |
goto userr; |
442 |
443 |
++eclock; |
444 |
xml_prologue(argc, argv); /* start XML output */ |
445 |
if (dofwd) { |
446 |
input_orient = -1; |
447 |
output_orient = -1; |
448 |
prog_start("Evaluating outside reflectance"); |
449 |
(*evf)(argv[i]); |
450 |
output_orient = 1; |
451 |
prog_start("Evaluating outside->inside transmission"); |
452 |
(*evf)(argv[i]); |
453 |
454 |
if (dobwd) { |
455 |
input_orient = 1; |
456 |
457 |
prog_start("Evaluating inside reflectance"); |
458 |
(*evf)(argv[i]); |
459 |
460 |
prog_start("Evaluating inside->outside transmission"); |
461 |
(*evf)(argv[i]); |
462 |
463 |
xml_epilogue(); /* finish XML output & exit */ |
464 |
return(0); |
465 |
466 |
if (i < argc) { /* open input files if given */ |
467 |
int nbsdf = 0; |
468 |
for ( ; i < argc; i++) { /* interpolate each component */ |
469 |
char pbuf[256]; |
470 |
FILE *fpin = fopen(argv[i], "rb"); |
471 |
if (fpin == NULL) { |
472 |
fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n", |
473 |
progname, argv[i]); |
474 |
return(1); |
475 |
476 |
if (!load_bsdf_rep(fpin)) |
477 |
return(1); |
478 |
fclose(fpin); |
479 |
if (!nbsdf++) /* start XML on first dist. */ |
480 |
xml_prologue(argc, argv); |
481 |
sprintf(pbuf, "Interpolating component '%s'", argv[i]); |
482 |
prog_start(pbuf); |
483 |
if (single_plane_incident) |
484 |
eval_isotropic(NULL); |
485 |
else |
486 |
eval_anisotropic(NULL); |
487 |
488 |
489 |
return(0); |
490 |
491 |
SET_FILE_BINARY(stdin); /* load from stdin */ |
492 |
if (!load_bsdf_rep(stdin)) |
493 |
return(1); |
494 |
495 |
prog_start("Interpolating from standard input"); |
496 |
if (single_plane_incident) /* resample dist. */ |
497 |
498 |
else |
499 |
500 |
501 |
return(0); |
502 |
userr: |
503 |
fprintf(stderr, |
504 |
"Usage: %s [-g Nlog2][-t pctcull][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n", |
505 |
progname); |
506 |
fprintf(stderr, |
507 |
" or: %s -t{3|4} [-g Nlog2][-t pctcull][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n", |
508 |
progname); |
509 |
return(1); |
510 |
