root/radiance/ray/src/cv/bsdf2ttree.c
Revision: 2.23
Committed: Tue Nov 26 17:35:59 2013 UTC (10 years, 6 months ago) by greg
Changes since 2.22: +4 -3 lines
Include random.h for Windows instead of calling drand48
2 static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.22 2013/11/26 17:33:55 greg Exp $";
5 * Load measured BSDF interpolant and write out as XML file with tensor tree.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdio.h>
12 #include <stdlib.h>
13 #include <math.h>
14 #include "random.h"
15 #include "platform.h"
16 #include "rtprocess.h"
17 #include "calcomp.h"
18 #include "bsdfrep.h"
19 /* global argv[0] */
20 char *progname;
21 /* percentage to cull (<0 to turn off) */
22 double pctcull = 90.;
23 /* sampling order */
24 int samp_order = 6;
25 /* super-sampling threshold */
26 const double ssamp_thresh = 0.35;
27 /* number of super-samples */
28 const int nssamp = 100;
29 /* limit on number of RBF lobes */
30 static int lobe_lim = 15000;
31
32 /* Output XML prologue to stdout */
33 static void
34 xml_prologue(int ac, char *av[])
35 {
36 puts("<?xml version=\"1.0\" encoding=\"UTF-8\"?>");
37 puts("<WindowElement xmlns=\"http://windows.lbl.gov\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:schemaLocation=\"http://windows.lbl.gov/BSDF-v1.4.xsd\">");
38 fputs("<!-- File produced by:", stdout);
39 while (ac-- > 0) {
40 fputc(' ', stdout);
41 fputs(*av++, stdout);
42 }
43 puts(" -->");
44 puts("<WindowElementType>System</WindowElementType>");
45 puts("<FileType>BSDF</FileType>");
46 puts("<Optical>");
47 puts("<Layer>");
48 puts("\t<Material>");
49 printf("\t\t<Name>%s</Name>\n", bsdf_name[0] ? bsdf_name : "Unknown");
50 printf("\t\t<Manufacturer>%s</Manufacturer>\n",
51 bsdf_manuf[0] ? bsdf_manuf : "Unknown");
52 puts("\t\t<DeviceType>Other</DeviceType>");
53 puts("\t</Material>");
54 puts("\t<DataDefinition>");
55 printf("\t\t<IncidentDataStructure>TensorTree%c</IncidentDataStructure>\n",
56 single_plane_incident ? '3' : '4');
57 puts("\t</DataDefinition>");
58 }
59
60 /* Output XML data prologue to stdout */
61 static void
62 data_prologue()
63 {
64 static const char *bsdf_type[4] = {
65 "Reflection Front",
66 "Transmission Front",
67 "Transmission Back",
68 "Reflection Back"
69 };
70
71 puts("\t<WavelengthData>");
72 puts("\t\t<LayerNumber>System</LayerNumber>");
73 puts("\t\t<Wavelength unit=\"Integral\">Visible</Wavelength>");
74 puts("\t\t<SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>");
75 puts("\t\t<DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>");
76 puts("\t\t<WavelengthDataBlock>");
77 printf("\t\t\t<WavelengthDataDirection>%s</WavelengthDataDirection>\n",
78 bsdf_type[(input_orient>0)<<1 | (output_orient>0)]);
79 puts("\t\t\t<AngleBasis>LBNL/Shirley-Chiu</AngleBasis>");
80 puts("\t\t\t<ScatteringDataType>BTDF</ScatteringDataType>");
81 puts("\t\t\t<ScatteringData>");
82 }
83
84 /* Output XML data epilogue to stdout */
85 static void
86 data_epilogue(void)
87 {
88 puts("\t\t\t</ScatteringData>");
89 puts("\t\t</WavelengthDataBlock>");
90 puts("\t</WavelengthData>");
91 }
92
93 /* Output XML epilogue to stdout */
94 static void
95 xml_epilogue(void)
96 {
97 puts("</Layer>");
98 puts("</Optical>");
99 puts("</WindowElement>");
100 }
101
102 /* Compute absolute relative difference */
103 static double
104 abs_diff(double v1, double v0)
105 {
106 if ((v0 < 0) | (v1 < 0))
107 return(.0);
108 v1 = (v1-v0)*2./(v0+v1+.0001);
109 if (v1 < 0)
110 return(-v1);
111 return(v1);
112 }
113
114 /* Interpolate and output isotropic BSDF data */
115 static void
116 eval_isotropic(char *funame)
117 {
118 const int sqres = 1<<samp_order;
119 FILE *ofp = NULL;
120 int assignD = 0;
121 char cmd[128];
122 int ix, ox, oy;
123 double iovec[6];
124 float bsdf;
125
126 data_prologue(); /* begin output */
127 if (pctcull >= 0) {
128 sprintf(cmd, "rttree_reduce -a -h -ff -r 3 -t %f -g %d",
129 pctcull, samp_order);
130 fflush(stdout);
131 ofp = popen(cmd, "w");
132 if (ofp == NULL) {
133 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
134 progname);
135 exit(1);
136 }
137 SET_FILE_BINARY(ofp);
138 } else
139 fputs("{\n", stdout);
140 /* need to assign Dx, Dy, Dz? */
141 if (funame != NULL)
142 assignD = (fundefined(funame) < 6);
143 /* run through directions */
144 for (ix = 0; ix < sqres/2; ix++) {
145 RBFNODE *rbf = NULL;
146 iovec[0] = 2.*(ix+.5)/sqres - 1.;
147 iovec[1] = .0;
148 iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]);
149 if (funame == NULL)
150 rbf = advect_rbf(iovec, lobe_lim);
151 for (ox = 0; ox < sqres; ox++) {
152 float last_bsdf = -1;
153 for (oy = 0; oy < sqres; oy++) {
154 SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres);
155 iovec[5] = output_orient *
156 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
157 if (funame == NULL)
158 bsdf = eval_rbfrep(rbf, iovec+3) *
159 output_orient/iovec[5];
160 else {
161 double ssa[3], ssvec[6], sum;
162 int ssi;
163 if (assignD) {
164 varset("Dx", '=', -iovec[3]);
165 varset("Dy", '=', -iovec[4]);
166 varset("Dz", '=', -iovec[5]);
167 ++eclock;
168 }
169 bsdf = funvalue(funame, 6, iovec);
170 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
171 sum = 0; /* super-sample voxel */
172 for (ssi = nssamp; ssi--; ) {
173 SDmultiSamp(ssa, 3, (ssi+frandom())/nssamp);
174 ssvec[0] = 2.*(ix+ssa[0])/sqres - 1.;
175 ssvec[1] = .0;
176 ssvec[2] = input_orient *
177 sqrt(1. - ssvec[0]*ssvec[0]);
178 SDsquare2disk(ssvec+3, (ox+ssa[1])/sqres,
179 (oy+ssa[2])/sqres);
180 ssvec[5] = output_orient *
181 sqrt(1. - ssvec[3]*ssvec[3] -
182 ssvec[4]*ssvec[4]);
183 if (assignD) {
184 varset("Dx", '=', -iovec[3]);
185 varset("Dy", '=', -iovec[4]);
186 varset("Dz", '=', -iovec[5]);
187 ++eclock;
188 }
189 sum += funvalue(funame, 6, ssvec);
190 }
191 bsdf = sum/nssamp;
192 }
193 }
194 if (pctcull >= 0)
195 fwrite(&bsdf, sizeof(bsdf), 1, ofp);
196 else
197 printf("\t%.3e\n", bsdf);
198 last_bsdf = bsdf;
199 }
200 }
201 if (rbf != NULL)
202 free(rbf);
203 }
204 if (pctcull >= 0) { /* finish output */
205 if (pclose(ofp)) {
206 fprintf(stderr, "%s: error running '%s'\n",
207 progname, cmd);
208 exit(1);
209 }
210 } else {
211 for (ix = sqres*sqres*sqres/2; ix--; )
212 fputs("\t0\n", stdout);
213 fputs("}\n", stdout);
214 }
215 data_epilogue();
216 }
217
218 /* Interpolate and output anisotropic BSDF data */
219 static void
220 eval_anisotropic(char *funame)
221 {
222 const int sqres = 1<<samp_order;
223 FILE *ofp = NULL;
224 int assignD = 0;
225 char cmd[128];
226 int ix, iy, ox, oy;
227 double iovec[6];
228 float bsdf;
229
230 data_prologue(); /* begin output */
231 if (pctcull >= 0) {
232 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d",
233 (input_orient>0 ^ output_orient>0) ? "" : " -a",
234 pctcull, samp_order);
235 fflush(stdout);
236 ofp = popen(cmd, "w");
237 if (ofp == NULL) {
238 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
239 progname);
240 exit(1);
241 }
242 } else
243 fputs("{\n", stdout);
244 /* need to assign Dx, Dy, Dz? */
245 if (funame != NULL)
246 assignD = (fundefined(funame) < 6);
247 /* run through directions */
248 for (ix = 0; ix < sqres; ix++)
249 for (iy = 0; iy < sqres; iy++) {
250 RBFNODE *rbf = NULL; /* Klems reversal */
251 SDsquare2disk(iovec, 1.-(ix+.5)/sqres, 1.-(iy+.5)/sqres);
252 iovec[2] = input_orient *
253 sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]);
254 if (funame == NULL)
255 rbf = advect_rbf(iovec, lobe_lim);
256 for (ox = 0; ox < sqres; ox++) {
257 float last_bsdf = -1;
258 for (oy = 0; oy < sqres; oy++) {
259 SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres);
260 iovec[5] = output_orient *
261 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
262 if (funame == NULL)
263 bsdf = eval_rbfrep(rbf, iovec+3) *
264 output_orient/iovec[5];
265 else {
266 double ssa[4], ssvec[6], sum;
267 int ssi;
268 if (assignD) {
269 varset("Dx", '=', -iovec[3]);
270 varset("Dy", '=', -iovec[4]);
271 varset("Dz", '=', -iovec[5]);
272 ++eclock;
273 }
274 bsdf = funvalue(funame, 6, iovec);
275 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
276 sum = 0; /* super-sample voxel */
277 for (ssi = nssamp; ssi--; ) {
278 SDmultiSamp(ssa, 4, (ssi+frandom())/nssamp);
279 SDsquare2disk(ssvec, 1.-(ix+ssa[0])/sqres,
280 1.-(iy+ssa[1])/sqres);
281 ssvec[2] = output_orient *
282 sqrt(1. - ssvec[0]*ssvec[0] -
283 ssvec[1]*ssvec[1]);
284 SDsquare2disk(ssvec+3, (ox+ssa[2])/sqres,
285 (oy+ssa[3])/sqres);
286 ssvec[5] = output_orient *
287 sqrt(1. - ssvec[3]*ssvec[3] -
288 ssvec[4]*ssvec[4]);
289 if (assignD) {
290 varset("Dx", '=', -iovec[3]);
291 varset("Dy", '=', -iovec[4]);
292 varset("Dz", '=', -iovec[5]);
293 ++eclock;
294 }
295 sum += funvalue(funame, 6, ssvec);
296 }
297 bsdf = sum/nssamp;
298 }
299 }
300 if (pctcull >= 0)
301 fwrite(&bsdf, sizeof(bsdf), 1, ofp);
302 else
303 printf("\t%.3e\n", bsdf);
304 last_bsdf = bsdf;
305 }
306 }
307 if (rbf != NULL)
308 free(rbf);
309 }
310 if (pctcull >= 0) { /* finish output */
311 if (pclose(ofp)) {
312 fprintf(stderr, "%s: error running '%s'\n",
313 progname, cmd);
314 exit(1);
315 }
316 } else
317 fputs("}\n", stdout);
318 data_epilogue();
319 }
320
321 /* Read in BSDF and interpolate as tensor tree representation */
322 int
323 main(int argc, char *argv[])
324 {
325 int dofwd = 0, dobwd = 1;
326 int i, na;
327
328 progname = argv[0];
329 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
330 esupport &= ~(E_INCHAN|E_OUTCHAN);
331 scompile("PI:3.14159265358979323846", NULL, 0);
332 biggerlib();
333 for (i = 1; i < argc-1 && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
334 switch (argv[i][1]) { /* get options */
335 case 'e':
336 scompile(argv[++i], NULL, 0);
337 break;
338 case 'f':
339 if (!argv[i][2])
340 fcompile(argv[++i]);
341 else
342 dofwd = (argv[i][0] == '+');
343 break;
344 case 'b':
345 dobwd = (argv[i][0] == '+');
346 break;
347 case 't':
348 switch (argv[i][2]) {
349 case '3':
350 single_plane_incident = 1;
351 break;
352 case '4':
353 single_plane_incident = 0;
354 break;
355 case '\0':
356 pctcull = atof(argv[++i]);
357 break;
358 default:
359 goto userr;
360 }
361 break;
362 case 'g':
363 samp_order = atoi(argv[++i]);
364 break;
365 case 'l':
366 lobe_lim = atoi(argv[++i]);
367 break;
368 default:
369 goto userr;
370 }
371 if (single_plane_incident >= 0) { /* function-based BSDF? */
372 void (*evf)(char *s) = single_plane_incident ?
373 &eval_isotropic : &eval_anisotropic;
374 if (i != argc-1 || fundefined(argv[i]) < 3) {
375 fprintf(stderr,
376 "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
377 progname);
378 fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n",
379 progname);
380 goto userr;
381 }
382 ++eclock;
383 xml_prologue(argc, argv); /* start XML output */
384 if (dofwd) {
385 input_orient = -1;
386 output_orient = -1;
387 (*evf)(argv[i]); /* outside reflectance */
388 output_orient = 1;
389 (*evf)(argv[i]); /* outside -> inside */
390 }
391 if (dobwd) {
392 input_orient = 1;
393 output_orient = 1;
394 (*evf)(argv[i]); /* inside reflectance */
395 output_orient = -1;
396 (*evf)(argv[i]); /* inside -> outside */
397 }
398 xml_epilogue(); /* finish XML output & exit */
399 return(0);
400 }
401 if (i < argc) { /* open input files if given */
402 int nbsdf = 0;
403 for ( ; i < argc; i++) { /* interpolate each component */
404 FILE *fpin = fopen(argv[i], "rb");
405 if (fpin == NULL) {
406 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
407 progname, argv[i]);
408 return(1);
409 }
410 if (!load_bsdf_rep(fpin))
411 return(1);
412 fclose(fpin);
413 if (!nbsdf++) /* start XML on first dist. */
414 xml_prologue(argc, argv);
415 if (single_plane_incident)
416 eval_isotropic(NULL);
417 else
418 eval_anisotropic(NULL);
419 }
420 xml_epilogue(); /* finish XML output & exit */
421 return(0);
422 }
423 SET_FILE_BINARY(stdin); /* load from stdin */
424 if (!load_bsdf_rep(stdin))
425 return(1);
426 xml_prologue(argc, argv); /* start XML output */
427 if (single_plane_incident) /* resample dist. */
428 eval_isotropic(NULL);
429 else
430 eval_anisotropic(NULL);
431 xml_epilogue(); /* finish XML output & exit */
432 return(0);
433 userr:
434 fprintf(stderr,
435 "Usage: %s [-g Nlog2][-t pctcull][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n",
436 progname);
437 fprintf(stderr,
438 " or: %s -t{3|4} [-g Nlog2][-t pctcull][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
439 progname);
440 return(1);
441 }
