root/radiance/ray/src/cv/bsdf2ttree.c
Revision: 2.22
Committed: Tue Nov 26 17:33:55 2013 UTC (10 years, 6 months ago) by greg
2 static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.21 2013/11/09 05:47:49 greg Exp $";
5 * Load measured BSDF interpolant and write out as XML file with tensor tree.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdio.h>
12 #include <stdlib.h>
13 #include <math.h>
14 #include "platform.h"
15 #include "rtprocess.h"
16 #include "calcomp.h"
17 #include "bsdfrep.h"
18 /* global argv[0] */
19 char *progname;
20 /* percentage to cull (<0 to turn off) */
21 double pctcull = 90.;
22 /* sampling order */
23 int samp_order = 6;
24 /* super-sampling threshold */
25 const double ssamp_thresh = 0.35;
26 /* number of super-samples */
27 const int nssamp = 100;
28 /* limit on number of RBF lobes */
29 static int lobe_lim = 15000;
30
31 /* Output XML prologue to stdout */
32 static void
33 xml_prologue(int ac, char *av[])
34 {
35 puts("<?xml version=\"1.0\" encoding=\"UTF-8\"?>");
36 puts("<WindowElement xmlns=\"http://windows.lbl.gov\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:schemaLocation=\"http://windows.lbl.gov/BSDF-v1.4.xsd\">");
37 fputs("<!-- File produced by:", stdout);
38 while (ac-- > 0) {
39 fputc(' ', stdout);
40 fputs(*av++, stdout);
41 }
42 puts(" -->");
43 puts("<WindowElementType>System</WindowElementType>");
44 puts("<FileType>BSDF</FileType>");
45 puts("<Optical>");
46 puts("<Layer>");
47 puts("\t<Material>");
48 printf("\t\t<Name>%s</Name>\n", bsdf_name[0] ? bsdf_name : "Unknown");
49 printf("\t\t<Manufacturer>%s</Manufacturer>\n",
50 bsdf_manuf[0] ? bsdf_manuf : "Unknown");
51 puts("\t\t<DeviceType>Other</DeviceType>");
52 puts("\t</Material>");
53 puts("\t<DataDefinition>");
54 printf("\t\t<IncidentDataStructure>TensorTree%c</IncidentDataStructure>\n",
55 single_plane_incident ? '3' : '4');
56 puts("\t</DataDefinition>");
57 }
58
59 /* Output XML data prologue to stdout */
60 static void
61 data_prologue()
62 {
63 static const char *bsdf_type[4] = {
64 "Reflection Front",
65 "Transmission Front",
66 "Transmission Back",
67 "Reflection Back"
68 };
69
70 puts("\t<WavelengthData>");
71 puts("\t\t<LayerNumber>System</LayerNumber>");
72 puts("\t\t<Wavelength unit=\"Integral\">Visible</Wavelength>");
73 puts("\t\t<SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>");
74 puts("\t\t<DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>");
75 puts("\t\t<WavelengthDataBlock>");
76 printf("\t\t\t<WavelengthDataDirection>%s</WavelengthDataDirection>\n",
77 bsdf_type[(input_orient>0)<<1 | (output_orient>0)]);
78 puts("\t\t\t<AngleBasis>LBNL/Shirley-Chiu</AngleBasis>");
79 puts("\t\t\t<ScatteringDataType>BTDF</ScatteringDataType>");
80 puts("\t\t\t<ScatteringData>");
81 }
82
83 /* Output XML data epilogue to stdout */
84 static void
85 data_epilogue(void)
86 {
87 puts("\t\t\t</ScatteringData>");
88 puts("\t\t</WavelengthDataBlock>");
89 puts("\t</WavelengthData>");
90 }
91
92 /* Output XML epilogue to stdout */
93 static void
94 xml_epilogue(void)
95 {
96 puts("</Layer>");
97 puts("</Optical>");
98 puts("</WindowElement>");
99 }
100
101 /* Compute absolute relative difference */
102 static double
103 abs_diff(double v1, double v0)
104 {
105 if ((v0 < 0) | (v1 < 0))
106 return(.0);
107 v1 = (v1-v0)*2./(v0+v1+.0001);
108 if (v1 < 0)
109 return(-v1);
110 return(v1);
111 }
112
113 /* Interpolate and output isotropic BSDF data */
114 static void
115 eval_isotropic(char *funame)
116 {
117 const int sqres = 1<<samp_order;
118 FILE *ofp = NULL;
119 int assignD = 0;
120 char cmd[128];
121 int ix, ox, oy;
122 double iovec[6];
123 float bsdf;
124
125 data_prologue(); /* begin output */
126 if (pctcull >= 0) {
127 sprintf(cmd, "rttree_reduce -a -h -ff -r 3 -t %f -g %d",
128 pctcull, samp_order);
129 fflush(stdout);
130 ofp = popen(cmd, "w");
131 if (ofp == NULL) {
132 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
133 progname);
134 exit(1);
135 }
136 SET_FILE_BINARY(ofp);
137 } else
138 fputs("{\n", stdout);
139 /* need to assign Dx, Dy, Dz? */
140 if (funame != NULL)
141 assignD = (fundefined(funame) < 6);
142 /* run through directions */
143 for (ix = 0; ix < sqres/2; ix++) {
144 RBFNODE *rbf = NULL;
145 iovec[0] = 2.*(ix+.5)/sqres - 1.;
146 iovec[1] = .0;
147 iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]);
148 if (funame == NULL)
149 rbf = advect_rbf(iovec, lobe_lim);
150 for (ox = 0; ox < sqres; ox++) {
151 float last_bsdf = -1;
152 for (oy = 0; oy < sqres; oy++) {
153 SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres);
154 iovec[5] = output_orient *
155 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
156 if (funame == NULL)
157 bsdf = eval_rbfrep(rbf, iovec+3) *
158 output_orient/iovec[5];
159 else {
160 double ssa[3], ssvec[6], sum;
161 int ssi;
162 if (assignD) {
163 varset("Dx", '=', -iovec[3]);
164 varset("Dy", '=', -iovec[4]);
165 varset("Dz", '=', -iovec[5]);
166 ++eclock;
167 }
168 bsdf = funvalue(funame, 6, iovec);
169 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
170 sum = 0; /* super-sample voxel */
171 for (ssi = nssamp; ssi--; ) {
172 SDmultiSamp(ssa, 3, (ssi+drand48())/nssamp);
173 ssvec[0] = 2.*(ix+ssa[0])/sqres - 1.;
174 ssvec[1] = .0;
175 ssvec[2] = input_orient *
176 sqrt(1. - ssvec[0]*ssvec[0]);
177 SDsquare2disk(ssvec+3, (ox+ssa[1])/sqres,
178 (oy+ssa[2])/sqres);
179 ssvec[5] = output_orient *
180 sqrt(1. - ssvec[3]*ssvec[3] -
181 ssvec[4]*ssvec[4]);
182 if (assignD) {
183 varset("Dx", '=', -iovec[3]);
184 varset("Dy", '=', -iovec[4]);
185 varset("Dz", '=', -iovec[5]);
186 ++eclock;
187 }
188 sum += funvalue(funame, 6, ssvec);
189 }
190 bsdf = sum/nssamp;
191 }
192 }
193 if (pctcull >= 0)
194 fwrite(&bsdf, sizeof(bsdf), 1, ofp);
195 else
196 printf("\t%.3e\n", bsdf);
197 last_bsdf = bsdf;
198 }
199 }
200 if (rbf != NULL)
201 free(rbf);
202 }
203 if (pctcull >= 0) { /* finish output */
204 if (pclose(ofp)) {
205 fprintf(stderr, "%s: error running '%s'\n",
206 progname, cmd);
207 exit(1);
208 }
209 } else {
210 for (ix = sqres*sqres*sqres/2; ix--; )
211 fputs("\t0\n", stdout);
212 fputs("}\n", stdout);
213 }
214 data_epilogue();
215 }
216
217 /* Interpolate and output anisotropic BSDF data */
218 static void
219 eval_anisotropic(char *funame)
220 {
221 const int sqres = 1<<samp_order;
222 FILE *ofp = NULL;
223 int assignD = 0;
224 char cmd[128];
225 int ix, iy, ox, oy;
226 double iovec[6];
227 float bsdf;
228
229 data_prologue(); /* begin output */
230 if (pctcull >= 0) {
231 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d",
232 (input_orient>0 ^ output_orient>0) ? "" : " -a",
233 pctcull, samp_order);
234 fflush(stdout);
235 ofp = popen(cmd, "w");
236 if (ofp == NULL) {
237 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
238 progname);
239 exit(1);
240 }
241 } else
242 fputs("{\n", stdout);
243 /* need to assign Dx, Dy, Dz? */
244 if (funame != NULL)
245 assignD = (fundefined(funame) < 6);
246 /* run through directions */
247 for (ix = 0; ix < sqres; ix++)
248 for (iy = 0; iy < sqres; iy++) {
249 RBFNODE *rbf = NULL; /* Klems reversal */
250 SDsquare2disk(iovec, 1.-(ix+.5)/sqres, 1.-(iy+.5)/sqres);
251 iovec[2] = input_orient *
252 sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]);
253 if (funame == NULL)
254 rbf = advect_rbf(iovec, lobe_lim);
255 for (ox = 0; ox < sqres; ox++) {
256 float last_bsdf = -1;
257 for (oy = 0; oy < sqres; oy++) {
258 SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres);
259 iovec[5] = output_orient *
260 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
261 if (funame == NULL)
262 bsdf = eval_rbfrep(rbf, iovec+3) *
263 output_orient/iovec[5];
264 else {
265 double ssa[4], ssvec[6], sum;
266 int ssi;
267 if (assignD) {
268 varset("Dx", '=', -iovec[3]);
269 varset("Dy", '=', -iovec[4]);
270 varset("Dz", '=', -iovec[5]);
271 ++eclock;
272 }
273 bsdf = funvalue(funame, 6, iovec);
274 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
275 sum = 0; /* super-sample voxel */
276 for (ssi = nssamp; ssi--; ) {
277 SDmultiSamp(ssa, 4, (ssi+drand48())/nssamp);
278 SDsquare2disk(ssvec, 1.-(ix+ssa[0])/sqres,
279 1.-(iy+ssa[1])/sqres);
280 ssvec[2] = output_orient *
281 sqrt(1. - ssvec[0]*ssvec[0] -
282 ssvec[1]*ssvec[1]);
283 SDsquare2disk(ssvec+3, (ox+ssa[2])/sqres,
284 (oy+ssa[3])/sqres);
285 ssvec[5] = output_orient *
286 sqrt(1. - ssvec[3]*ssvec[3] -
287 ssvec[4]*ssvec[4]);
288 if (assignD) {
289 varset("Dx", '=', -iovec[3]);
290 varset("Dy", '=', -iovec[4]);
291 varset("Dz", '=', -iovec[5]);
292 ++eclock;
293 }
294 sum += funvalue(funame, 6, ssvec);
295 }
296 bsdf = sum/nssamp;
297 }
298 }
299 if (pctcull >= 0)
300 fwrite(&bsdf, sizeof(bsdf), 1, ofp);
301 else
302 printf("\t%.3e\n", bsdf);
303 last_bsdf = bsdf;
304 }
305 }
306 if (rbf != NULL)
307 free(rbf);
308 }
309 if (pctcull >= 0) { /* finish output */
310 if (pclose(ofp)) {
311 fprintf(stderr, "%s: error running '%s'\n",
312 progname, cmd);
313 exit(1);
314 }
315 } else
316 fputs("}\n", stdout);
317 data_epilogue();
318 }
319
320 /* Read in BSDF and interpolate as tensor tree representation */
321 int
322 main(int argc, char *argv[])
323 {
324 int dofwd = 0, dobwd = 1;
325 int i, na;
326
327 progname = argv[0];
328 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
329 esupport &= ~(E_INCHAN|E_OUTCHAN);
330 scompile("PI:3.14159265358979323846", NULL, 0);
331 biggerlib();
332 for (i = 1; i < argc-1 && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
333 switch (argv[i][1]) { /* get options */
334 case 'e':
335 scompile(argv[++i], NULL, 0);
336 break;
337 case 'f':
338 if (!argv[i][2])
339 fcompile(argv[++i]);
340 else
341 dofwd = (argv[i][0] == '+');
342 break;
343 case 'b':
344 dobwd = (argv[i][0] == '+');
345 break;
346 case 't':
347 switch (argv[i][2]) {
348 case '3':
349 single_plane_incident = 1;
350 break;
351 case '4':
352 single_plane_incident = 0;
353 break;
354 case '\0':
355 pctcull = atof(argv[++i]);
356 break;
357 default:
358 goto userr;
359 }
360 break;
361 case 'g':
362 samp_order = atoi(argv[++i]);
363 break;
364 case 'l':
365 lobe_lim = atoi(argv[++i]);
366 break;
367 default:
368 goto userr;
369 }
370 if (single_plane_incident >= 0) { /* function-based BSDF? */
371 void (*evf)(char *s) = single_plane_incident ?
372 &eval_isotropic : &eval_anisotropic;
373 if (i != argc-1 || fundefined(argv[i]) < 3) {
374 fprintf(stderr,
375 "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
376 progname);
377 fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n",
378 progname);
379 goto userr;
380 }
381 ++eclock;
382 xml_prologue(argc, argv); /* start XML output */
383 if (dofwd) {
384 input_orient = -1;
385 output_orient = -1;
386 (*evf)(argv[i]); /* outside reflectance */
387 output_orient = 1;
388 (*evf)(argv[i]); /* outside -> inside */
389 }
390 if (dobwd) {
391 input_orient = 1;
392 output_orient = 1;
393 (*evf)(argv[i]); /* inside reflectance */
394 output_orient = -1;
395 (*evf)(argv[i]); /* inside -> outside */
396 }
397 xml_epilogue(); /* finish XML output & exit */
398 return(0);
399 }
400 if (i < argc) { /* open input files if given */
401 int nbsdf = 0;
402 for ( ; i < argc; i++) { /* interpolate each component */
403 FILE *fpin = fopen(argv[i], "rb");
404 if (fpin == NULL) {
405 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
406 progname, argv[i]);
407 return(1);
408 }
409 if (!load_bsdf_rep(fpin))
410 return(1);
411 fclose(fpin);
412 if (!nbsdf++) /* start XML on first dist. */
413 xml_prologue(argc, argv);
414 if (single_plane_incident)
415 eval_isotropic(NULL);
416 else
417 eval_anisotropic(NULL);
418 }
419 xml_epilogue(); /* finish XML output & exit */
420 return(0);
421 }
422 SET_FILE_BINARY(stdin); /* load from stdin */
423 if (!load_bsdf_rep(stdin))
424 return(1);
425 xml_prologue(argc, argv); /* start XML output */
426 if (single_plane_incident) /* resample dist. */
427 eval_isotropic(NULL);
428 else
429 eval_anisotropic(NULL);
430 xml_epilogue(); /* finish XML output & exit */
431 return(0);
432 userr:
433 fprintf(stderr,
434 "Usage: %s [-g Nlog2][-t pctcull][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n",
435 progname);
436 fprintf(stderr,
437 " or: %s -t{3|4} [-g Nlog2][-t pctcull][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
438 progname);
439 return(1);
440 }
