| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.18 2013/09/26 17:05:00 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Load measured BSDF interpolant and write out as XML file with tensor tree.
| 6 |
| 7 |
* G. Ward
| 8 |
| 9 |
| 10 |
#define _USE_MATH_DEFINES
| 11 |
#include <stdio.h>
| 12 |
#include <stdlib.h>
| 13 |
#include <math.h>
| 14 |
#include "platform.h"
| 15 |
#include "calcomp.h"
| 16 |
#include "bsdfrep.h"
| 17 |
/* global argv[0] */
| 18 |
char *progname;
| 19 |
/* percentage to cull (<0 to turn off) */
| 20 |
double pctcull = 90.;
| 21 |
/* sampling order */
| 22 |
int samp_order = 6;
| 23 |
/* super-sampling threshold */
| 24 |
const double ssamp_thresh = 0.35;
| 25 |
/* number of super-samples */
| 26 |
const int nssamp = 100;
| 27 |
/* limit on number of RBF lobes */
| 28 |
static int lobe_lim = 15000;
| 29 |
| 30 |
/* Output XML prologue to stdout */
| 31 |
static void
| 32 |
xml_prologue(int ac, char *av[])
| 33 |
| 34 |
puts("<?xml version=\"1.0\" encoding=\"UTF-8\"?>");
| 35 |
puts("<WindowElement xmlns=\"http://windows.lbl.gov\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:schemaLocation=\"http://windows.lbl.gov/BSDF-v1.4.xsd\">");
| 36 |
fputs("<!-- File produced by:", stdout);
| 37 |
while (ac-- > 0) {
| 38 |
fputc(' ', stdout);
| 39 |
fputs(*av++, stdout);
| 40 |
| 41 |
puts(" -->");
| 42 |
puts("<WindowElementType>System</WindowElementType>");
| 43 |
puts("<FileType>BSDF</FileType>");
| 44 |
puts("<Optical>");
| 45 |
puts("<Layer>");
| 46 |
puts("\t<Material>");
| 47 |
puts("\t\t<Name>Name</Name>");
| 48 |
puts("\t\t<Manufacturer>Manufacturer</Manufacturer>");
| 49 |
puts("\t\t<DeviceType>Other</DeviceType>");
| 50 |
puts("\t</Material>");
| 51 |
puts("\t<DataDefinition>");
| 52 |
printf("\t\t<IncidentDataStructure>TensorTree%c</IncidentDataStructure>\n",
| 53 |
single_plane_incident ? '3' : '4');
| 54 |
puts("\t</DataDefinition>");
| 55 |
| 56 |
| 57 |
/* Output XML data prologue to stdout */
| 58 |
static void
| 59 |
data_prologue()
| 60 |
| 61 |
static const char *bsdf_type[4] = {
| 62 |
"Reflection Front",
| 63 |
"Transmission Front",
| 64 |
"Transmission Back",
| 65 |
"Reflection Back"
| 66 |
| 67 |
| 68 |
puts("\t<WavelengthData>");
| 69 |
puts("\t\t<LayerNumber>System</LayerNumber>");
| 70 |
puts("\t\t<Wavelength unit=\"Integral\">Visible</Wavelength>");
| 71 |
puts("\t\t<SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>");
| 72 |
puts("\t\t<DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>");
| 73 |
puts("\t\t<WavelengthDataBlock>");
| 74 |
printf("\t\t\t<WavelengthDataDirection>%s</WavelengthDataDirection>\n",
| 75 |
bsdf_type[(input_orient>0)<<1 | (output_orient>0)]);
| 76 |
puts("\t\t\t<AngleBasis>LBNL/Shirley-Chiu</AngleBasis>");
| 77 |
puts("\t\t\t<ScatteringDataType>BTDF</ScatteringDataType>");
| 78 |
puts("\t\t\t<ScatteringData>");
| 79 |
| 80 |
| 81 |
/* Output XML data epilogue to stdout */
| 82 |
static void
| 83 |
data_epilogue(void)
| 84 |
| 85 |
puts("\t\t\t</ScatteringData>");
| 86 |
puts("\t\t</WavelengthDataBlock>");
| 87 |
puts("\t</WavelengthData>");
| 88 |
| 89 |
| 90 |
/* Output XML epilogue to stdout */
| 91 |
static void
| 92 |
xml_epilogue(void)
| 93 |
| 94 |
puts("</Layer>");
| 95 |
puts("</Optical>");
| 96 |
puts("</WindowElement>");
| 97 |
| 98 |
| 99 |
/* Compute absolute relative difference */
| 100 |
static double
| 101 |
abs_diff(double v1, double v0)
| 102 |
| 103 |
if ((v0 < 0) | (v1 < 0))
| 104 |
return(.0);
| 105 |
v1 = (v1-v0)*2./(v0+v1+.0001);
| 106 |
if (v1 < 0)
| 107 |
return(-v1);
| 108 |
return(v1);
| 109 |
| 110 |
| 111 |
/* Interpolate and output isotropic BSDF data */
| 112 |
static void
| 113 |
eval_isotropic(char *funame)
| 114 |
| 115 |
const int sqres = 1<<samp_order;
| 116 |
FILE *ofp = NULL;
| 117 |
int assignD = 0;
| 118 |
char cmd[128];
| 119 |
int ix, ox, oy;
| 120 |
double iovec[6];
| 121 |
float bsdf;
| 122 |
| 123 |
data_prologue(); /* begin output */
| 124 |
if (pctcull >= 0) {
| 125 |
sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d",
| 126 |
(input_orient>0 ^ output_orient>0) ? "" : " -a",
| 127 |
pctcull, samp_order);
| 128 |
fflush(stdout);
| 129 |
ofp = popen(cmd, "w");
| 130 |
if (ofp == NULL) {
| 131 |
fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
| 132 |
progname);
| 133 |
exit(1);
| 134 |
| 135 |
SET_FILE_BINARY(ofp);
| 136 |
} else
| 137 |
fputs("{\n", stdout);
| 138 |
/* need to assign Dx, Dy, Dz? */
| 139 |
if (funame != NULL)
| 140 |
assignD = (fundefined(funame) < 6);
| 141 |
/* run through directions */
| 142 |
for (ix = 0; ix < sqres/2; ix++) {
| 143 |
RBFNODE *rbf = NULL;
| 144 |
iovec[0] = 2.*(ix+.5)/sqres - 1.;
| 145 |
iovec[1] = .0;
| 146 |
iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]);
| 147 |
if (funame == NULL)
| 148 |
rbf = advect_rbf(iovec, lobe_lim);
| 149 |
for (ox = 0; ox < sqres; ox++) {
| 150 |
float last_bsdf = -1;
| 151 |
for (oy = 0; oy < sqres; oy++) {
| 152 |
SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres);
| 153 |
iovec[5] = output_orient *
| 154 |
sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
| 155 |
if (funame == NULL)
| 156 |
bsdf = eval_rbfrep(rbf, iovec+3) *
| 157 |
output_orient/iovec[5];
| 158 |
else {
| 159 |
double ssa[3], ssvec[6], sum;
| 160 |
int ssi;
| 161 |
if (assignD) {
| 162 |
varset("Dx", '=', -iovec[3]);
| 163 |
varset("Dy", '=', -iovec[4]);
| 164 |
varset("Dz", '=', -iovec[5]);
| 165 |
++eclock;
| 166 |
| 167 |
bsdf = funvalue(funame, 6, iovec);
| 168 |
if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
| 169 |
sum = 0; /* super-sample voxel */
| 170 |
for (ssi = nssamp; ssi--; ) {
| 171 |
SDmultiSamp(ssa, 3, (ssi+drand48())/nssamp);
| 172 |
ssvec[0] = 2.*(ix+ssa[0])/sqres - 1.;
| 173 |
ssvec[1] = .0;
| 174 |
ssvec[2] = input_orient *
| 175 |
sqrt(1. - ssvec[0]*ssvec[0]);
| 176 |
SDsquare2disk(ssvec+3, (ox+ssa[1])/sqres,
| 177 |
(oy+ssa[2])/sqres);
| 178 |
ssvec[5] = output_orient *
| 179 |
sqrt(1. - ssvec[3]*ssvec[3] -
| 180 |
ssvec[4]*ssvec[4]);
| 181 |
if (assignD) {
| 182 |
| 183 |
| 184 |
| 185 |
++eclock;
| 186 |
| 187 |
sum += funvalue(funame, 6, ssvec);
| 188 |
| 189 |
bsdf = sum/nssamp;
| 190 |
| 191 |
| 192 |
if (pctcull >= 0)
| 193 |
fwrite(&bsdf, sizeof(bsdf), 1, ofp);
| 194 |
else
| 195 |
printf("\t%.3e\n", bsdf);
| 196 |
last_bsdf = bsdf;
| 197 |
| 198 |
| 199 |
if (rbf != NULL)
| 200 |
free(rbf);
| 201 |
| 202 |
if (pctcull >= 0) { /* finish output */
| 203 |
if (pclose(ofp)) {
| 204 |
fprintf(stderr, "%s: error running '%s'\n",
| 205 |
progname, cmd);
| 206 |
exit(1);
| 207 |
| 208 |
} else {
| 209 |
for (ix = sqres*sqres*sqres/2; ix--; )
| 210 |
fputs("\t0\n", stdout);
| 211 |
fputs("}\n", stdout);
| 212 |
| 213 |
data_epilogue();
| 214 |
| 215 |
| 216 |
/* Interpolate and output anisotropic BSDF data */
| 217 |
static void
| 218 |
eval_anisotropic(char *funame)
| 219 |
| 220 |
| 221 |
FILE *ofp = NULL;
| 222 |
int assignD = 0;
| 223 |
char cmd[128];
| 224 |
int ix, iy, ox, oy;
| 225 |
double iovec[6];
| 226 |
float bsdf;
| 227 |
| 228 |
| 229 |
if (pctcull >= 0) {
| 230 |
sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d",
| 231 |
| 232 |
| 233 |
fflush(stdout);
| 234 |
| 235 |
if (ofp == NULL) {
| 236 |
| 237 |
progname);
| 238 |
exit(1);
| 239 |
| 240 |
} else
| 241 |
| 242 |
| 243 |
if (funame != NULL)
| 244 |
| 245 |
| 246 |
for (ix = 0; ix < sqres; ix++)
| 247 |
for (iy = 0; iy < sqres; iy++) {
| 248 |
RBFNODE *rbf = NULL; /* Klems reversal */
| 249 |
SDsquare2disk(iovec, 1.-(ix+.5)/sqres, 1.-(iy+.5)/sqres);
| 250 |
| 251 |
sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]);
| 252 |
if (funame == NULL)
| 253 |
| 254 |
| 255 |
| 256 |
| 257 |
| 258 |
| 259 |
| 260 |
if (funame == NULL)
| 261 |
| 262 |
| 263 |
else {
| 264 |
double ssa[4], ssvec[6], sum;
| 265 |
int ssi;
| 266 |
if (assignD) {
| 267 |
| 268 |
| 269 |
| 270 |
++eclock;
| 271 |
| 272 |
| 273 |
| 274 |
| 275 |
| 276 |
SDmultiSamp(ssa, 4, (ssi+drand48())/nssamp);
| 277 |
SDsquare2disk(ssvec, 1.-(ix+ssa[0])/sqres,
| 278 |
1.-(iy+ssa[1])/sqres);
| 279 |
ssvec[2] = output_orient *
| 280 |
sqrt(1. - ssvec[0]*ssvec[0] -
| 281 |
ssvec[1]*ssvec[1]);
| 282 |
SDsquare2disk(ssvec+3, (ox+ssa[2])/sqres,
| 283 |
(oy+ssa[3])/sqres);
| 284 |
| 285 |
| 286 |
ssvec[4]*ssvec[4]);
| 287 |
if (assignD) {
| 288 |
| 289 |
| 290 |
| 291 |
++eclock;
| 292 |
| 293 |
| 294 |
| 295 |
bsdf = sum/nssamp;
| 296 |
| 297 |
| 298 |
if (pctcull >= 0)
| 299 |
| 300 |
else
| 301 |
| 302 |
last_bsdf = bsdf;
| 303 |
| 304 |
| 305 |
if (rbf != NULL)
| 306 |
free(rbf);
| 307 |
| 308 |
| 309 |
if (pclose(ofp)) {
| 310 |
| 311 |
progname, cmd);
| 312 |
exit(1);
| 313 |
| 314 |
} else
| 315 |
| 316 |
data_epilogue();
| 317 |
| 318 |
| 319 |
/* Read in BSDF and interpolate as tensor tree representation */
| 320 |
int
| 321 |
main(int argc, char *argv[])
| 322 |
| 323 |
int dofwd = 0, dobwd = 1;
| 324 |
int i, na;
| 325 |
| 326 |
progname = argv[0];
| 327 |
esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
| 328 |
esupport &= ~(E_INCHAN|E_OUTCHAN);
| 329 |
scompile("PI:3.14159265358979323846", NULL, 0);
| 330 |
biggerlib();
| 331 |
for (i = 1; i < argc-1 && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
| 332 |
switch (argv[i][1]) { /* get options */
| 333 |
case 'e':
| 334 |
scompile(argv[++i], NULL, 0);
| 335 |
break;
| 336 |
case 'f':
| 337 |
if (!argv[i][2])
| 338 |
fcompile(argv[++i]);
| 339 |
else
| 340 |
dofwd = (argv[i][0] == '+');
| 341 |
break;
| 342 |
case 'b':
| 343 |
dobwd = (argv[i][0] == '+');
| 344 |
break;
| 345 |
case 't':
| 346 |
switch (argv[i][2]) {
| 347 |
case '3':
| 348 |
single_plane_incident = 1;
| 349 |
break;
| 350 |
case '4':
| 351 |
single_plane_incident = 0;
| 352 |
break;
| 353 |
case '\0':
| 354 |
pctcull = atof(argv[++i]);
| 355 |
break;
| 356 |
default:
| 357 |
goto userr;
| 358 |
| 359 |
break;
| 360 |
case 'g':
| 361 |
samp_order = atoi(argv[++i]);
| 362 |
break;
| 363 |
case 'l':
| 364 |
lobe_lim = atoi(argv[++i]);
| 365 |
break;
| 366 |
default:
| 367 |
goto userr;
| 368 |
| 369 |
if (single_plane_incident >= 0) { /* function-based BSDF? */
| 370 |
void (*evf)(char *s) = single_plane_incident ?
| 371 |
&eval_isotropic : &eval_anisotropic;
| 372 |
if (i != argc-1 || fundefined(argv[i]) < 3) {
| 373 |
fprintf(stderr,
| 374 |
"%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
| 375 |
progname);
| 376 |
fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n",
| 377 |
progname);
| 378 |
goto userr;
| 379 |
| 380 |
++eclock;
| 381 |
xml_prologue(argc, argv); /* start XML output */
| 382 |
if (dofwd) {
| 383 |
input_orient = -1;
| 384 |
output_orient = -1;
| 385 |
(*evf)(argv[i]); /* outside reflectance */
| 386 |
output_orient = 1;
| 387 |
(*evf)(argv[i]); /* outside -> inside */
| 388 |
| 389 |
if (dobwd) {
| 390 |
input_orient = 1;
| 391 |
output_orient = 1;
| 392 |
(*evf)(argv[i]); /* inside reflectance */
| 393 |
output_orient = -1;
| 394 |
(*evf)(argv[i]); /* inside -> outside */
| 395 |
| 396 |
xml_epilogue(); /* finish XML output & exit */
| 397 |
return(0);
| 398 |
| 399 |
if (i < argc) { /* open input files if given */
| 400 |
int nbsdf = 0;
| 401 |
for ( ; i < argc; i++) { /* interpolate each component */
| 402 |
FILE *fpin = fopen(argv[i], "rb");
| 403 |
if (fpin == NULL) {
| 404 |
fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
| 405 |
progname, argv[i]);
| 406 |
return(1);
| 407 |
| 408 |
if (!load_bsdf_rep(fpin))
| 409 |
return(1);
| 410 |
fclose(fpin);
| 411 |
if (!nbsdf++) /* start XML on first dist. */
| 412 |
| 413 |
if (single_plane_incident)
| 414 |
eval_isotropic(NULL);
| 415 |
else
| 416 |
eval_anisotropic(NULL);
| 417 |
| 418 |
| 419 |
return(0);
| 420 |
| 421 |
SET_FILE_BINARY(stdin); /* load from stdin */
| 422 |
if (!load_bsdf_rep(stdin))
| 423 |
return(1);
| 424 |
| 425 |
if (single_plane_incident) /* resample dist. */
| 426 |
| 427 |
else
| 428 |
| 429 |
| 430 |
return(0);
| 431 |
userr:
| 432 |
fprintf(stderr,
| 433 |
"Usage: %s [-g Nlog2][-t pctcull][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n",
| 434 |
progname);
| 435 |
fprintf(stderr,
| 436 |
" or: %s -t{3|4} [-g Nlog2][-t pctcull][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
| 437 |
progname);
| 438 |
return(1);
| 439 |
