root/radiance/ray/src/cv/bsdf2ttree.c
Revision: 2.18
Committed: Thu Sep 26 17:05:00 2013 UTC (11 years, 8 months ago) by greg
Changes since 2.17: +9 -4 lines
Added -l option to limit maximum number of RBF lobes for interpolation
2 static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.17 2013/08/02 20:56:19 greg Exp $";
5 * Load measured BSDF interpolant and write out as XML file with tensor tree.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdio.h>
12 #include <stdlib.h>
13 #include <math.h>
14 #include "platform.h"
15 #include "calcomp.h"
16 #include "bsdfrep.h"
17 /* global argv[0] */
18 char *progname;
19 /* percentage to cull (<0 to turn off) */
20 double pctcull = 90.;
21 /* sampling order */
22 int samp_order = 6;
23 /* super-sampling threshold */
24 const double ssamp_thresh = 0.35;
25 /* number of super-samples */
26 const int nssamp = 100;
27 /* limit on number of RBF lobes */
28 static int lobe_lim = 15000;
29
30 /* Output XML prologue to stdout */
31 static void
32 xml_prologue(int ac, char *av[])
33 {
34 puts("<?xml version=\"1.0\" encoding=\"UTF-8\"?>");
35 puts("<WindowElement xmlns=\"http://windows.lbl.gov\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:schemaLocation=\"http://windows.lbl.gov/BSDF-v1.4.xsd\">");
36 fputs("<!-- File produced by:", stdout);
37 while (ac-- > 0) {
38 fputc(' ', stdout);
39 fputs(*av++, stdout);
40 }
41 puts(" -->");
42 puts("<WindowElementType>System</WindowElementType>");
43 puts("<FileType>BSDF</FileType>");
44 puts("<Optical>");
45 puts("<Layer>");
46 puts("\t<Material>");
47 puts("\t\t<Name>Name</Name>");
48 puts("\t\t<Manufacturer>Manufacturer</Manufacturer>");
49 puts("\t\t<DeviceType>Other</DeviceType>");
50 puts("\t</Material>");
51 puts("\t<DataDefinition>");
52 printf("\t\t<IncidentDataStructure>TensorTree%c</IncidentDataStructure>\n",
53 single_plane_incident ? '3' : '4');
54 puts("\t</DataDefinition>");
55 }
56
57 /* Output XML data prologue to stdout */
58 static void
59 data_prologue()
60 {
61 static const char *bsdf_type[4] = {
62 "Reflection Front",
63 "Transmission Front",
64 "Transmission Back",
65 "Reflection Back"
66 };
67
68 puts("\t<WavelengthData>");
69 puts("\t\t<LayerNumber>System</LayerNumber>");
70 puts("\t\t<Wavelength unit=\"Integral\">Visible</Wavelength>");
71 puts("\t\t<SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>");
72 puts("\t\t<DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>");
73 puts("\t\t<WavelengthDataBlock>");
74 printf("\t\t\t<WavelengthDataDirection>%s</WavelengthDataDirection>\n",
75 bsdf_type[(input_orient>0)<<1 | (output_orient>0)]);
76 puts("\t\t\t<AngleBasis>LBNL/Shirley-Chiu</AngleBasis>");
77 puts("\t\t\t<ScatteringDataType>BTDF</ScatteringDataType>");
78 puts("\t\t\t<ScatteringData>");
79 }
80
81 /* Output XML data epilogue to stdout */
82 static void
83 data_epilogue(void)
84 {
85 puts("\t\t\t</ScatteringData>");
86 puts("\t\t</WavelengthDataBlock>");
87 puts("\t</WavelengthData>");
88 }
89
90 /* Output XML epilogue to stdout */
91 static void
92 xml_epilogue(void)
93 {
94 puts("</Layer>");
95 puts("</Optical>");
96 puts("</WindowElement>");
97 }
98
99 /* Compute absolute relative difference */
100 static double
101 abs_diff(double v1, double v0)
102 {
103 if ((v0 < 0) | (v1 < 0))
104 return(.0);
105 v1 = (v1-v0)*2./(v0+v1+.0001);
106 if (v1 < 0)
107 return(-v1);
108 return(v1);
109 }
110
111 /* Interpolate and output isotropic BSDF data */
112 static void
113 eval_isotropic(char *funame)
114 {
115 const int sqres = 1<<samp_order;
116 FILE *ofp = NULL;
117 int assignD = 0;
118 char cmd[128];
119 int ix, ox, oy;
120 double iovec[6];
121 float bsdf;
122
123 data_prologue(); /* begin output */
124 if (pctcull >= 0) {
125 sprintf(cmd, "rttree_reduce -h -a -ff -r 3 -t %f -g %d",
126 pctcull, samp_order);
127 fflush(stdout);
128 ofp = popen(cmd, "w");
129 if (ofp == NULL) {
130 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
131 progname);
132 exit(1);
133 }
134 SET_FILE_BINARY(ofp);
135 } else
136 fputs("{\n", stdout);
137 /* need to assign Dx, Dy, Dz? */
138 if (funame != NULL)
139 assignD = (fundefined(funame) < 6);
140 /* run through directions */
141 for (ix = 0; ix < sqres/2; ix++) {
142 RBFNODE *rbf = NULL;
143 iovec[0] = 2.*(ix+.5)/sqres - 1.;
144 iovec[1] = .0;
145 iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]);
146 if (funame == NULL)
147 rbf = advect_rbf(iovec, lobe_lim);
148 for (ox = 0; ox < sqres; ox++) {
149 float last_bsdf = -1;
150 for (oy = 0; oy < sqres; oy++) {
151 SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres);
152 iovec[5] = output_orient *
153 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
154 if (funame == NULL)
155 bsdf = eval_rbfrep(rbf, iovec+3) *
156 output_orient/iovec[5];
157 else {
158 double ssa[3], ssvec[6], sum;
159 int ssi;
160 if (assignD) {
161 varset("Dx", '=', -iovec[3]);
162 varset("Dy", '=', -iovec[4]);
163 varset("Dz", '=', -iovec[5]);
164 ++eclock;
165 }
166 bsdf = funvalue(funame, 6, iovec);
167 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
168 sum = 0; /* super-sample voxel */
169 for (ssi = nssamp; ssi--; ) {
170 SDmultiSamp(ssa, 3, (ssi+drand48())/nssamp);
171 ssvec[0] = 2.*(ix+ssa[0])/sqres - 1.;
172 ssvec[1] = .0;
173 ssvec[2] = input_orient *
174 sqrt(1. - ssvec[0]*ssvec[0]);
175 SDsquare2disk(ssvec+3, (ox+ssa[1])/sqres,
176 (oy+ssa[2])/sqres);
177 ssvec[5] = output_orient *
178 sqrt(1. - ssvec[3]*ssvec[3] -
179 ssvec[4]*ssvec[4]);
180 if (assignD) {
181 varset("Dx", '=', -iovec[3]);
182 varset("Dy", '=', -iovec[4]);
183 varset("Dz", '=', -iovec[5]);
184 ++eclock;
185 }
186 sum += funvalue(funame, 6, ssvec);
187 }
188 bsdf = sum/nssamp;
189 }
190 }
191 if (pctcull >= 0)
192 fwrite(&bsdf, sizeof(bsdf), 1, ofp);
193 else
194 printf("\t%.3e\n", bsdf);
195 last_bsdf = bsdf;
196 }
197 }
198 if (rbf != NULL)
199 free(rbf);
200 }
201 if (pctcull >= 0) { /* finish output */
202 if (pclose(ofp)) {
203 fprintf(stderr, "%s: error running '%s'\n",
204 progname, cmd);
205 exit(1);
206 }
207 } else {
208 for (ix = sqres*sqres*sqres/2; ix--; )
209 fputs("\t0\n", stdout);
210 fputs("}\n", stdout);
211 }
212 data_epilogue();
213 }
214
215 /* Interpolate and output anisotropic BSDF data */
216 static void
217 eval_anisotropic(char *funame)
218 {
219 const int sqres = 1<<samp_order;
220 FILE *ofp = NULL;
221 int assignD = 0;
222 char cmd[128];
223 int ix, iy, ox, oy;
224 double iovec[6];
225 float bsdf;
226
227 data_prologue(); /* begin output */
228 if (pctcull >= 0) {
229 sprintf(cmd, "rttree_reduce -h -a -ff -r 4 -t %f -g %d",
230 pctcull, samp_order);
231 fflush(stdout);
232 ofp = popen(cmd, "w");
233 if (ofp == NULL) {
234 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
235 progname);
236 exit(1);
237 }
238 } else
239 fputs("{\n", stdout);
240 /* need to assign Dx, Dy, Dz? */
241 if (funame != NULL)
242 assignD = (fundefined(funame) < 6);
243 /* run through directions */
244 for (ix = 0; ix < sqres; ix++)
245 for (iy = 0; iy < sqres; iy++) {
246 RBFNODE *rbf = NULL; /* Klems reversal */
247 SDsquare2disk(iovec, 1.-(ix+.5)/sqres, 1.-(iy+.5)/sqres);
248 iovec[2] = input_orient *
249 sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]);
250 if (funame == NULL)
251 rbf = advect_rbf(iovec, lobe_lim);
252 for (ox = 0; ox < sqres; ox++) {
253 float last_bsdf = -1;
254 for (oy = 0; oy < sqres; oy++) {
255 SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres);
256 iovec[5] = output_orient *
257 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
258 if (funame == NULL)
259 bsdf = eval_rbfrep(rbf, iovec+3) *
260 output_orient/iovec[5];
261 else {
262 double ssa[4], ssvec[6], sum;
263 int ssi;
264 if (assignD) {
265 varset("Dx", '=', -iovec[3]);
266 varset("Dy", '=', -iovec[4]);
267 varset("Dz", '=', -iovec[5]);
268 ++eclock;
269 }
270 bsdf = funvalue(funame, 6, iovec);
271 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
272 sum = 0; /* super-sample voxel */
273 for (ssi = nssamp; ssi--; ) {
274 SDmultiSamp(ssa, 4, (ssi+drand48())/nssamp);
275 SDsquare2disk(ssvec, 1.-(ix+ssa[0])/sqres,
276 1.-(iy+ssa[1])/sqres);
277 ssvec[2] = output_orient *
278 sqrt(1. - ssvec[0]*ssvec[0] -
279 ssvec[1]*ssvec[1]);
280 SDsquare2disk(ssvec+3, (ox+ssa[2])/sqres,
281 (oy+ssa[3])/sqres);
282 ssvec[5] = output_orient *
283 sqrt(1. - ssvec[3]*ssvec[3] -
284 ssvec[4]*ssvec[4]);
285 if (assignD) {
286 varset("Dx", '=', -iovec[3]);
287 varset("Dy", '=', -iovec[4]);
288 varset("Dz", '=', -iovec[5]);
289 ++eclock;
290 }
291 sum += funvalue(funame, 6, ssvec);
292 }
293 bsdf = sum/nssamp;
294 }
295 }
296 if (pctcull >= 0)
297 fwrite(&bsdf, sizeof(bsdf), 1, ofp);
298 else
299 printf("\t%.3e\n", bsdf);
300 last_bsdf = bsdf;
301 }
302 }
303 if (rbf != NULL)
304 free(rbf);
305 }
306 if (pctcull >= 0) { /* finish output */
307 if (pclose(ofp)) {
308 fprintf(stderr, "%s: error running '%s'\n",
309 progname, cmd);
310 exit(1);
311 }
312 } else
313 fputs("}\n", stdout);
314 data_epilogue();
315 }
316
317 /* Read in BSDF and interpolate as tensor tree representation */
318 int
319 main(int argc, char *argv[])
320 {
321 int dofwd = 0, dobwd = 1;
322 int i, na;
323
324 progname = argv[0];
325 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
326 esupport &= ~(E_INCHAN|E_OUTCHAN);
327 scompile("PI:3.14159265358979323846", NULL, 0);
328 biggerlib();
329 for (i = 1; i < argc-1 && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
330 switch (argv[i][1]) { /* get options */
331 case 'e':
332 scompile(argv[++i], NULL, 0);
333 break;
334 case 'f':
335 if (!argv[i][2])
336 fcompile(argv[++i]);
337 else
338 dofwd = (argv[i][0] == '+');
339 break;
340 case 'b':
341 dobwd = (argv[i][0] == '+');
342 break;
343 case 't':
344 switch (argv[i][2]) {
345 case '3':
346 single_plane_incident = 1;
347 break;
348 case '4':
349 single_plane_incident = 0;
350 break;
351 case '\0':
352 pctcull = atof(argv[++i]);
353 break;
354 default:
355 goto userr;
356 }
357 break;
358 case 'g':
359 samp_order = atoi(argv[++i]);
360 break;
361 case 'l':
362 lobe_lim = atoi(argv[++i]);
363 break;
364 default:
365 goto userr;
366 }
367 if (single_plane_incident >= 0) { /* function-based BSDF? */
368 void (*evf)(char *s) = single_plane_incident ?
369 &eval_isotropic : &eval_anisotropic;
370 if (i != argc-1 || fundefined(argv[i]) < 3) {
371 fprintf(stderr,
372 "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
373 progname);
374 fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n",
375 progname);
376 goto userr;
377 }
378 ++eclock;
379 xml_prologue(argc, argv); /* start XML output */
380 if (dofwd) {
381 input_orient = -1;
382 output_orient = -1;
383 (*evf)(argv[i]); /* outside reflectance */
384 output_orient = 1;
385 (*evf)(argv[i]); /* outside -> inside */
386 }
387 if (dobwd) {
388 input_orient = 1;
389 output_orient = 1;
390 (*evf)(argv[i]); /* inside reflectance */
391 output_orient = -1;
392 (*evf)(argv[i]); /* inside -> outside */
393 }
394 xml_epilogue(); /* finish XML output & exit */
395 return(0);
396 }
397 if (i < argc) { /* open input files if given */
398 int nbsdf = 0;
399 for ( ; i < argc; i++) { /* interpolate each component */
400 FILE *fpin = fopen(argv[i], "rb");
401 if (fpin == NULL) {
402 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
403 progname, argv[i]);
404 return(1);
405 }
406 if (!load_bsdf_rep(fpin))
407 return(1);
408 fclose(fpin);
409 if (!nbsdf++) /* start XML on first dist. */
410 xml_prologue(argc, argv);
411 if (single_plane_incident)
412 eval_isotropic(NULL);
413 else
414 eval_anisotropic(NULL);
415 }
416 xml_epilogue(); /* finish XML output & exit */
417 return(0);
418 }
419 SET_FILE_BINARY(stdin); /* load from stdin */
420 if (!load_bsdf_rep(stdin))
421 return(1);
422 xml_prologue(argc, argv); /* start XML output */
423 if (single_plane_incident) /* resample dist. */
424 eval_isotropic(NULL);
425 else
426 eval_anisotropic(NULL);
427 xml_epilogue(); /* finish XML output & exit */
428 return(0);
429 userr:
430 fprintf(stderr,
431 "Usage: %s [-g Nlog2][-t pctcull][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n",
432 progname);
433 fprintf(stderr,
434 " or: %s -t{3|4} [-g Nlog2][-t pctcull][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
435 progname);
436 return(1);
437 }
