1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.14 2013/03/23 04:14:50 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Load measured BSDF interpolant and write out as XML file with tensor tree. |
6 |
7 |
* G. Ward |
8 |
9 |
10 |
#define _USE_MATH_DEFINES |
11 |
#include <stdio.h> |
12 |
#include <stdlib.h> |
13 |
#include <math.h> |
14 |
#include "platform.h" |
15 |
#include "calcomp.h" |
16 |
#include "bsdfrep.h" |
17 |
/* global argv[0] */ |
18 |
char *progname; |
19 |
/* percentage to cull (<0 to turn off) */ |
20 |
double pctcull = 90.; |
21 |
/* sampling order */ |
22 |
int samp_order = 6; |
23 |
/* super-sampling threshold */ |
24 |
const double ssamp_thresh = 0.35; |
25 |
/* number of super-samples */ |
26 |
const int nssamp = 100; |
27 |
28 |
/* Output XML prologue to stdout */ |
29 |
static void |
30 |
xml_prologue(int ac, char *av[]) |
31 |
32 |
puts("<?xml version=\"1.0\" encoding=\"UTF-8\"?>"); |
33 |
puts("<WindowElement xmlns=\"http://windows.lbl.gov\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:schemaLocation=\"http://windows.lbl.gov/BSDF-v1.4.xsd\">"); |
34 |
fputs("<!-- File produced by:", stdout); |
35 |
while (ac-- > 0) { |
36 |
fputc(' ', stdout); |
37 |
fputs(*av++, stdout); |
38 |
39 |
puts(" -->"); |
40 |
puts("<WindowElementType>System</WindowElementType>"); |
41 |
puts("<FileType>BSDF</FileType>"); |
42 |
puts("<Optical>"); |
43 |
puts("<Layer>"); |
44 |
puts("\t<Material>"); |
45 |
puts("\t\t<Name>Name</Name>"); |
46 |
puts("\t\t<Manufacturer>Manufacturer</Manufacturer>"); |
47 |
puts("\t\t<DeviceType>Other</DeviceType>"); |
48 |
puts("\t</Material>"); |
49 |
puts("\t<DataDefinition>"); |
50 |
printf("\t\t<IncidentDataStructure>TensorTree%c</IncidentDataStructure>\n", |
51 |
single_plane_incident ? '3' : '4'); |
52 |
puts("\t</DataDefinition>"); |
53 |
54 |
55 |
/* Output XML data prologue to stdout */ |
56 |
static void |
57 |
data_prologue() |
58 |
59 |
static const char *bsdf_type[4] = { |
60 |
"Reflection Front", |
61 |
"Transmission Front", |
62 |
"Transmission Back", |
63 |
"Reflection Back" |
64 |
65 |
66 |
puts("\t<WavelengthData>"); |
67 |
puts("\t\t<LayerNumber>System</LayerNumber>"); |
68 |
puts("\t\t<Wavelength unit=\"Integral\">Visible</Wavelength>"); |
69 |
puts("\t\t<SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>"); |
70 |
puts("\t\t<DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>"); |
71 |
puts("\t\t<WavelengthDataBlock>"); |
72 |
printf("\t\t\t<WavelengthDataDirection>%s</WavelengthDataDirection>\n", |
73 |
bsdf_type[(input_orient>0)<<1 | (output_orient>0)]); |
74 |
puts("\t\t\t<AngleBasis>LBNL/Shirley-Chiu</AngleBasis>"); |
75 |
puts("\t\t\t<ScatteringDataType>BTDF</ScatteringDataType>"); |
76 |
puts("\t\t\t<ScatteringData>"); |
77 |
78 |
79 |
/* Output XML data epilogue to stdout */ |
80 |
static void |
81 |
data_epilogue(void) |
82 |
83 |
puts("\t\t\t</ScatteringData>"); |
84 |
puts("\t\t</WavelengthDataBlock>"); |
85 |
puts("\t</WavelengthData>"); |
86 |
87 |
88 |
/* Output XML epilogue to stdout */ |
89 |
static void |
90 |
xml_epilogue(void) |
91 |
92 |
puts("</Layer>"); |
93 |
puts("</Optical>"); |
94 |
puts("</WindowElement>"); |
95 |
96 |
97 |
/* Compute absolute relative difference */ |
98 |
static double |
99 |
abs_diff(double v1, double v0) |
100 |
101 |
if ((v0 < 0) | (v1 < 0)) |
102 |
return(.0); |
103 |
v1 = (v1-v0)*2./(v0+v1+.0001); |
104 |
if (v1 < 0) |
105 |
return(-v1); |
106 |
return(v1); |
107 |
108 |
109 |
/* Interpolate and output isotropic BSDF data */ |
110 |
static void |
111 |
eval_isotropic(char *funame) |
112 |
113 |
const int sqres = 1<<samp_order; |
114 |
FILE *ofp = NULL; |
115 |
char cmd[128]; |
116 |
int ix, ox, oy; |
117 |
double iovec[6]; |
118 |
float bsdf; |
119 |
120 |
data_prologue(); /* begin output */ |
121 |
if (pctcull >= 0) { |
122 |
sprintf(cmd, "rttree_reduce -h -a -ff -r 3 -t %f -g %d", |
123 |
pctcull, samp_order); |
124 |
fflush(stdout); |
125 |
ofp = popen(cmd, "w"); |
126 |
if (ofp == NULL) { |
127 |
fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n", |
128 |
progname); |
129 |
exit(1); |
130 |
131 |
SET_FILE_BINARY(ofp); |
132 |
} else |
133 |
fputs("{\n", stdout); |
134 |
/* run through directions */ |
135 |
for (ix = 0; ix < sqres/2; ix++) { |
136 |
RBFNODE *rbf = NULL; |
137 |
iovec[0] = 2.*(ix+.5)/sqres - 1.; |
138 |
iovec[1] = .0; |
139 |
iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]); |
140 |
if (funame == NULL) |
141 |
rbf = advect_rbf(iovec); |
142 |
for (ox = 0; ox < sqres; ox++) { |
143 |
float last_bsdf = -1; |
144 |
for (oy = 0; oy < sqres; oy++) { |
145 |
SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres); |
146 |
iovec[5] = output_orient * |
147 |
sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]); |
148 |
149 |
bsdf = eval_rbfrep(rbf, iovec+3) * |
150 |
output_orient/iovec[5]; |
151 |
else { |
152 |
double ssa[3], ssvec[6]; |
153 |
int ssi; |
154 |
bsdf = funvalue(funame, 6, iovec); |
155 |
if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) { |
156 |
bsdf = 0; /* super-sample voxel */ |
157 |
for (ssi = nssamp; ssi--; ) { |
158 |
SDmultiSamp(ssa, 3, (ssi+drand48())/nssamp); |
159 |
ssvec[0] = 2.*(ix+ssa[0])/sqres - 1.; |
160 |
ssvec[1] = .0; |
161 |
ssvec[2] = input_orient * |
162 |
sqrt(1. - ssvec[0]*ssvec[0]); |
163 |
SDsquare2disk(ssvec+3, (ox+ssa[1])/sqres, |
164 |
(oy+ssa[2])/sqres); |
165 |
ssvec[5] = output_orient * |
166 |
sqrt(1. - ssvec[3]*ssvec[3] - |
167 |
ssvec[4]*ssvec[4]); |
168 |
bsdf += funvalue(funame, 6, ssvec); |
169 |
170 |
bsdf /= (float)nssamp; |
171 |
172 |
173 |
if (pctcull >= 0) |
174 |
fwrite(&bsdf, sizeof(bsdf), 1, ofp); |
175 |
else |
176 |
printf("\t%.3e\n", bsdf); |
177 |
last_bsdf = bsdf; |
178 |
179 |
180 |
if (rbf != NULL) |
181 |
free(rbf); |
182 |
183 |
if (pctcull >= 0) { /* finish output */ |
184 |
if (pclose(ofp)) { |
185 |
fprintf(stderr, "%s: error running '%s'\n", |
186 |
progname, cmd); |
187 |
exit(1); |
188 |
189 |
} else { |
190 |
for (ix = sqres*sqres*sqres/2; ix--; ) |
191 |
fputs("\t0\n", stdout); |
192 |
fputs("}\n", stdout); |
193 |
194 |
data_epilogue(); |
195 |
196 |
197 |
/* Interpolate and output anisotropic BSDF data */ |
198 |
static void |
199 |
eval_anisotropic(char *funame) |
200 |
201 |
202 |
FILE *ofp = NULL; |
203 |
char cmd[128]; |
204 |
int ix, iy, ox, oy; |
205 |
double iovec[6]; |
206 |
float bsdf; |
207 |
208 |
209 |
210 |
sprintf(cmd, "rttree_reduce -h -a -ff -r 4 -t %f -g %d", |
211 |
212 |
fflush(stdout); |
213 |
214 |
215 |
216 |
progname); |
217 |
exit(1); |
218 |
219 |
} else |
220 |
221 |
222 |
for (ix = 0; ix < sqres; ix++) |
223 |
for (iy = 0; iy < sqres; iy++) { |
224 |
RBFNODE *rbf = NULL; /* Klems reversal */ |
225 |
SDsquare2disk(iovec, 1.-(ix+.5)/sqres, 1.-(iy+.5)/sqres); |
226 |
iovec[2] = input_orient * |
227 |
sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]); |
228 |
229 |
230 |
231 |
232 |
233 |
234 |
235 |
236 |
237 |
238 |
239 |
else { |
240 |
double ssa[4], ssvec[6]; |
241 |
int ssi; |
242 |
243 |
244 |
245 |
246 |
SDmultiSamp(ssa, 4, (ssi+drand48())/nssamp); |
247 |
SDsquare2disk(ssvec, 1.-(ix+ssa[0])/sqres, |
248 |
1.-(iy+ssa[1])/sqres); |
249 |
ssvec[2] = output_orient * |
250 |
sqrt(1. - ssvec[0]*ssvec[0] - |
251 |
ssvec[1]*ssvec[1]); |
252 |
SDsquare2disk(ssvec+3, (ox+ssa[2])/sqres, |
253 |
(oy+ssa[3])/sqres); |
254 |
255 |
256 |
257 |
258 |
259 |
260 |
261 |
262 |
if (pctcull >= 0) |
263 |
264 |
else |
265 |
266 |
last_bsdf = bsdf; |
267 |
268 |
269 |
if (rbf != NULL) |
270 |
free(rbf); |
271 |
272 |
273 |
274 |
275 |
progname, cmd); |
276 |
exit(1); |
277 |
278 |
} else |
279 |
280 |
data_epilogue(); |
281 |
282 |
283 |
/* Read in BSDF and interpolate as tensor tree representation */ |
284 |
int |
285 |
main(int argc, char *argv[]) |
286 |
287 |
int dofwd = 0, dobwd = 1; |
288 |
int i, na; |
289 |
290 |
progname = argv[0]; |
291 |
esupport |= E_VARIABLE|E_FUNCTION|E_RCONST; |
292 |
esupport &= ~(E_INCHAN|E_OUTCHAN); |
293 |
scompile("PI:3.14159265358979323846", NULL, 0); |
294 |
biggerlib(); |
295 |
for (i = 1; i < argc-1 && (argv[i][0] == '-') | (argv[i][0] == '+'); i++) |
296 |
switch (argv[i][1]) { /* get options */ |
297 |
case 'e': |
298 |
scompile(argv[++i], NULL, 0); |
299 |
break; |
300 |
case 'f': |
301 |
if (!argv[i][2]) |
302 |
fcompile(argv[++i]); |
303 |
else |
304 |
dofwd = (argv[i][0] == '+'); |
305 |
break; |
306 |
case 'b': |
307 |
dobwd = (argv[i][0] == '+'); |
308 |
break; |
309 |
case 't': |
310 |
switch (argv[i][2]) { |
311 |
case '3': |
312 |
single_plane_incident = 1; |
313 |
break; |
314 |
case '4': |
315 |
single_plane_incident = 0; |
316 |
break; |
317 |
case '\0': |
318 |
pctcull = atof(argv[++i]); |
319 |
break; |
320 |
default: |
321 |
goto userr; |
322 |
323 |
break; |
324 |
case 'g': |
325 |
samp_order = atoi(argv[++i]); |
326 |
break; |
327 |
default: |
328 |
goto userr; |
329 |
330 |
if (single_plane_incident >= 0) { /* function-based BSDF? */ |
331 |
void (*evf)(char *s) = single_plane_incident ? |
332 |
&eval_isotropic : &eval_anisotropic; |
333 |
if (i != argc-1 || fundefined(argv[i]) != 6) { |
334 |
fprintf(stderr, |
335 |
"%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n", |
336 |
progname); |
337 |
goto userr; |
338 |
339 |
xml_prologue(argc, argv); /* start XML output */ |
340 |
if (dofwd) { |
341 |
input_orient = -1; |
342 |
output_orient = -1; |
343 |
(*evf)(argv[i]); /* outside reflectance */ |
344 |
output_orient = 1; |
345 |
(*evf)(argv[i]); /* outside -> inside */ |
346 |
347 |
if (dobwd) { |
348 |
input_orient = 1; |
349 |
350 |
(*evf)(argv[i]); /* inside reflectance */ |
351 |
352 |
(*evf)(argv[i]); /* inside -> outside */ |
353 |
354 |
xml_epilogue(); /* finish XML output & exit */ |
355 |
return(0); |
356 |
357 |
if (i < argc) { /* open input files if given */ |
358 |
int nbsdf = 0; |
359 |
for ( ; i < argc; i++) { /* interpolate each component */ |
360 |
FILE *fpin = fopen(argv[i], "rb"); |
361 |
if (fpin == NULL) { |
362 |
fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n", |
363 |
progname, argv[i]); |
364 |
return(1); |
365 |
366 |
if (!load_bsdf_rep(fpin)) |
367 |
return(1); |
368 |
fclose(fpin); |
369 |
if (!nbsdf++) /* start XML on first dist. */ |
370 |
xml_prologue(argc, argv); |
371 |
if (single_plane_incident) |
372 |
eval_isotropic(NULL); |
373 |
else |
374 |
eval_anisotropic(NULL); |
375 |
376 |
377 |
return(0); |
378 |
379 |
SET_FILE_BINARY(stdin); /* load from stdin */ |
380 |
if (!load_bsdf_rep(stdin)) |
381 |
return(1); |
382 |
383 |
if (single_plane_incident) /* resample dist. */ |
384 |
385 |
else |
386 |
387 |
388 |
return(0); |
389 |
userr: |
390 |
fprintf(stderr, |
391 |
"Usage: %s [-g Nlog2][-t pctcull] [bsdf.sir ..] > bsdf.xml\n", |
392 |
progname); |
393 |
fprintf(stderr, |
394 |
" or: %s -t{3|4} [-g Nlog2][-t pctcull][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n", |
395 |
progname); |
396 |
return(1); |
397 |
