root/radiance/ray/src/cv/bsdf2ttree.c
Fri Feb 23 03:47:57 2024 UTC (3 months, 3 weeks ago) by greg
Changes since 2.60: +2 -1 lines
Diff to previous 2.60 , to selected 2.34
Tue Sep 12 16:40:57 2023 UTC (9 months ago) by greg
Diff to previous 2.59 , to selected 2.34
perf(bsdf2ttree): BREAKING CHANGE - changed reciprocity averaging default from "on" (+a) to "off" (-a)
Wed Jul 26 15:50:03 2023 UTC (10 months, 3 weeks ago) by greg
Diff to previous 2.58 , to selected 2.34
fix: made it so '+f' works as '+forward' instead of trying to load file
Wed Dec 15 01:38:50 2021 UTC (2 years, 6 months ago) by greg
Changes since 2.57: +13 -13 lines
Diff to previous 2.57 , to selected 2.34
refactor: removed prefix from SDdisk2square() and SDsquare2disk() & made consistent
Mon Mar 29 17:40:21 2021 UTC (3 years, 2 months ago) by greg
Changes since 2.56: +3 -5 lines
Diff to previous 2.56 , to selected 2.34
style: line returns where they didn't belong
Fri Nov 13 19:21:11 2020 UTC (3 years, 7 months ago) by greg
Changes since 2.55: +62 -57 lines
Diff to previous 2.55 , to selected 2.34
feat(bsdf2ttree): made it so options/parameters may differ per input SIR
Wed Oct 28 18:54:21 2020 UTC (3 years, 7 months ago) by greg
Diff to previous 2.54 , to selected 2.34
fix(bsdf2klems, bsdf2ttree): increased command-line buffer to accommodate comments in Windows
Mon Oct 26 21:28:18 2020 UTC (3 years, 7 months ago) by greg
Changes since 2.53: +5 -1 lines
Diff to previous 2.53 , to selected 2.34
fix(bsdf2klems, bsdf2ttree): preventing issues on Windows with newlines in commands
Mon Oct 26 21:12:20 2020 UTC (3 years, 7 months ago) by greg
Changes since 2.52: +39 -1 lines
Diff to previous 2.52 , to selected 2.34
feat(bsdf2klems, bsdf2ttree): added XML header comments copying useful information from SIR inputs
Mon May 18 20:08:57 2020 UTC (4 years ago) by greg
Changes since 2.51: +30 -35 lines
Diff to previous 2.51 , to selected 2.34
Added -n and -s options to bsdf2ttree to control super-sampling
Fri May 15 03:02:32 2020 UTC (4 years, 1 month ago) by greg
Diff to previous 2.50 , to selected 2.34
Fixed curly bracket in the wrong place (loop is WAAY too long!)
Mon May 11 20:26:58 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.49: +83 -77 lines
Diff to previous 2.49 , to selected 2.34
Hopefully final sampling improvement -- tests for differences on all sides
Fri May 8 22:34:21 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.48: +17 -3 lines
Diff to previous 2.48 , to selected 2.34
Forgot to clear the flags from previous row
Thu May 7 16:54:10 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.47: +3 -2 lines
Diff to previous 2.47 , to selected 2.34
Different thresholds for interpolant data versus function specification
Thu May 7 02:36:37 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.46: +113 -33 lines
Diff to previous 2.46 , to selected 2.34
Various improvements to adaptive sampling method
Wed May 6 02:28:21 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.45: +5 -3 lines
Diff to previous 2.45 , to selected 2.34
Increased super-sampling amount and sensitivity
Wed May 6 01:30:00 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.44: +20 -12 lines
Diff to previous 2.44 , to selected 2.34
Improved finding of peak in isotropic function (and RBF) input
Sat Dec 28 18:05:14 2019 UTC (4 years, 5 months ago) by greg
Changes since 2.43: +1 -2 lines
Diff to previous 2.43 , to selected 2.34
Fri May 4 23:56:49 2018 UTC (6 years, 1 month ago) by greg
Changes since 2.42: +13 -3 lines
Diff to previous 2.42 , to selected 2.34
Thu Jan 4 23:28:54 2018 UTC (6 years, 5 months ago) by greg
Changes since 2.41: +73 -15 lines
Diff to previous 2.41 , to selected 2.34
Added super-sampling for peaky radial basis functions
Wed May 31 17:25:21 2017 UTC (7 years ago) by greg
Changes since 2.40: +16 -11 lines
Diff to previous 2.40 , to selected 2.34
Fri Feb 17 22:31:49 2017 UTC (7 years, 3 months ago) by greg
Changes since 2.39: +1 -3 lines
Diff to previous 2.39 , to selected 2.34
Removed unnecessary calls to c_ccvt()
Thu Oct 13 16:59:29 2016 UTC (7 years, 8 months ago) by greg
Diff to previous 2.38 , to selected 2.34
Minor cosmetic fixes
Wed Oct 12 17:36:11 2016 UTC (7 years, 8 months ago) by greg
Diff to previous 2.37 , to selected 2.34
Decreased number of super-samples to improve speed
Thu Aug 18 00:52:48 2016 UTC (7 years, 9 months ago) by greg
Changes since 2.36: +7 -7 lines
Diff to previous 2.36 , to selected 2.34
Sun Mar 6 01:13:17 2016 UTC (8 years, 3 months ago) by schorsch
Diff to previous 2.35 , to selected 2.34
Thu Feb 4 00:45:47 2016 UTC (8 years, 4 months ago) by greg
Changes since 2.34: +13 -13 lines
Diff to previous 2.34
Minor cleanup and fixes
Revision 2.34 - (view) (download) (annotate) - [selected]
Tue Feb 2 22:34:00 2016 UTC (8 years, 4 months ago) by greg
Changes since 2.33: +314 -120 lines
Diff to previous 2.33
Refactored bsdf2ttree for Yuv representation
Tue Feb 2 18:08:32 2016 UTC (8 years, 4 months ago) by greg
Changes since 2.32: +70 -1 lines
Diff to previous 2.32 , to selected 2.34
Fixing premature and accidental check-in
Tue Feb 2 18:02:32 2016 UTC (8 years, 4 months ago) by greg
Changes since 2.31: +2 -71 lines
Diff to previous 2.31 , to selected 2.34
Fri Jan 29 16:21:55 2016 UTC (8 years, 4 months ago) by greg
Diff to previous 2.30 , to selected 2.34
Tue May 5 22:16:49 2015 UTC (9 years, 1 month ago) by greg
Changes since 2.29: +10 -7 lines
Diff to previous 2.29 , to selected 2.34
Improved progress bar feedback
Thu Aug 21 10:33:48 2014 UTC (9 years, 9 months ago) by greg
CVS Tags: rad4R2P1, rad4R2P2
Changes since 2.28: +3 -5 lines
Diff to previous 2.28 , to selected 2.34
Mon Mar 24 03:50:28 2014 UTC (10 years, 2 months ago) by greg
CVS Tags: rad4R2
Changes since 2.27: +29 -21 lines
Diff to previous 2.27 , to selected 2.34
Fixed one minor and one major bug in super-sampling (major bug in transmission)
Wed Mar 12 22:24:59 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.26: +12 -2 lines
Diff to previous 2.26 , to selected 2.34
Changed progress bar to erase itself when done
Wed Mar 12 21:15:31 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.25: +49 -5 lines
Diff to previous 2.25 , to selected 2.34
Disabled DEBUG statements in BSDF programs and added progress bars
Tue Mar 11 19:37:45 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.24: +8 -1 lines
Diff to previous 2.24 , to selected 2.34
Added flockfile calls to reduce i/o overhead
Sat Mar 8 01:05:00 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.23: +2 -3 lines
Diff to previous 2.23 , to selected 2.34
Fixed compiler warnings
Tue Nov 26 17:35:59 2013 UTC (10 years, 6 months ago) by greg
Changes since 2.22: +4 -3 lines
Diff to previous 2.22 , to selected 2.34
Include random.h for Windows instead of calling drand48
Tue Nov 26 17:33:55 2013 UTC (10 years, 6 months ago) by greg
Diff to previous 2.21 , to selected 2.34
Sat Nov 9 05:47:49 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.20: +4 -3 lines
Diff to previous 2.20 , to selected 2.34
Thu Oct 3 17:27:41 2013 UTC (10 years, 8 months ago) by greg
Changes since 2.19: +2 -3 lines
Diff to previous 2.19 , to selected 2.34
Re-allowed rttree_reduce -a option for isotropic transmission
Thu Oct 3 17:01:02 2013 UTC (10 years, 8 months ago) by greg
Changes since 2.18: +5 -3 lines
Diff to previous 2.18 , to selected 2.34
Fixed call to rttree_reduce to avoid -a on transmitted components
Thu Sep 26 17:05:00 2013 UTC (10 years, 8 months ago) by greg
Changes since 2.17: +9 -4 lines
Diff to previous 2.17 , to selected 2.34
Added -l option to limit maximum number of RBF lobes for interpolation
Fri Aug 2 20:56:19 2013 UTC (10 years, 10 months ago) by greg
Changes since 2.16: +37 -2 lines
Diff to previous 2.16 , to selected 2.34
Added ability to use Dx, Dy and Dz instead of last 3 function parameters
Wed May 15 17:29:30 2013 UTC (11 years, 1 month ago) by greg
Diff to previous 2.15 , to selected 2.34
Switched float to double for summing variable
Wed May 15 03:22:31 2013 UTC (11 years, 1 month ago) by greg
Changes since 2.14: +75 -21 lines
Diff to previous 2.14 , to selected 2.34
Added super-sampling at peaks
Sat Mar 23 04:14:50 2013 UTC (11 years, 2 months ago) by greg
Diff to previous 2.13 , to selected 2.34
Fixed different bug in -t3 option
Sat Mar 23 02:21:14 2013 UTC (11 years, 2 months ago) by greg
Diff to previous 2.12 , to selected 2.34
Fixed bug in -t3/-t4 option
Fri Mar 22 16:39:00 2013 UTC (11 years, 2 months ago) by greg
Changes since 2.11: +9 -3 lines
Diff to previous 2.11 , to selected 2.34
Fixed bug for BSDF file input and added further error messages
Fri Mar 22 02:15:06 2013 UTC (11 years, 2 months ago) by greg
Changes since 2.10: +195 -105 lines
Diff to previous 2.10 , to selected 2.34
Added ability to generate tensor tree directly from function
Wed Dec 12 04:49:59 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.9: +3 -2 lines
Diff to previous 2.9 , to selected 2.34
Fixed main bug, which was forgetting Klems axis reversal
Thu Nov 22 06:07:17 2012 UTC (11 years, 6 months ago) by greg
Diff to previous 2.8 , to selected 2.34
Tue Nov 13 04:23:38 2012 UTC (11 years, 7 months ago) by greg
Diff to previous 2.7 , to selected 2.34
Tried to improve convergence of RBF fit
Sat Nov 10 19:47:42 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.6: +10 -10 lines
Diff to previous 2.6 , to selected 2.34
Minor bug fixes
Fri Nov 9 02:25:32 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.5: +26 -45 lines
Diff to previous 2.5 , to selected 2.34
Made code a little more readable
Fri Nov 9 02:16:29 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.4: +91 -15 lines
Diff to previous 2.4 , to selected 2.34
Added data to complete XML file output
Wed Nov 7 03:04:23 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.3: +5 -5 lines
Diff to previous 2.3 , to selected 2.34
Added GRIDRES to saved BSDF representation
Tue Oct 23 05:10:42 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.2: +5 -4 lines
Diff to previous 2.2 , to selected 2.34
Hopeful bug fix in BSDF interpolation code
Sat Oct 20 17:01:26 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.1: +8 -3 lines
Diff to previous 2.1 , to selected 2.34
Bug fixes in loading BSDF interpolant data
Fri Oct 19 04:14:29 2012 UTC (11 years, 7 months ago) by greg
Diff to selected 2.34
