--- ray/src/cv/bsdf2ttree.c 2014/03/11 19:37:45 2.25 +++ ray/src/cv/bsdf2ttree.c 2014/03/24 03:50:28 2.28 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.25 2014/03/11 19:37:45 greg Exp $"; +static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.28 2014/03/24 03:50:28 greg Exp $"; #endif /* * Load measured BSDF interpolant and write out as XML file with tensor tree. @@ -25,10 +25,51 @@ int samp_order = 6; /* super-sampling threshold */ const double ssamp_thresh = 0.35; /* number of super-samples */ -const int nssamp = 100; +#ifndef NSSAMP +#define NSSAMP 100 +#endif /* limit on number of RBF lobes */ static int lobe_lim = 15000; + /* progress bar length */ +static int do_prog = 79; + +/* Start new progress bar */ +#define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else + +/* Draw progress bar of the appropriate length */ +static void +prog_show(double frac) +{ + char pbar[256]; + int nchars; + + if (do_prog <= 0) return; + if (do_prog > sizeof(pbar)-2) + do_prog = sizeof(pbar)-2; + if (frac < 0) frac = 0; + else if (frac > 1) frac = 1; + nchars = do_prog*frac + .5; + pbar[0] = '\r'; + memset(pbar+1, '*', nchars); + memset(pbar+1+nchars, '-', do_prog-nchars); + pbar[do_prog+1] = '\0'; + fputs(pbar, stderr); +} + +/* Finish progress bar */ +static void +prog_done(void) +{ + int n = do_prog; + + if (n <= 1) return; + fputc('\r', stderr); + while (n--) + fputc(' ', stderr); + fputc('\r', stderr); +} + /* Output XML prologue to stdout */ static void xml_prologue(int ac, char *av[]) @@ -161,8 +202,6 @@ eval_isotropic(char *funame) bsdf = eval_rbfrep(rbf, iovec+3) * output_orient/iovec[5]; else { - double ssa[3], ssvec[6], sum; - int ssi; if (assignD) { varset("Dx", '=', -iovec[3]); varset("Dy", '=', -iovec[4]); @@ -170,10 +209,14 @@ eval_isotropic(char *funame) ++eclock; } bsdf = funvalue(funame, 6, iovec); +#if (NSSAMP > 0) if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) { - sum = 0; /* super-sample voxel */ - for (ssi = nssamp; ssi--; ) { - SDmultiSamp(ssa, 3, (ssi+frandom())/nssamp); + int ssi; + double ssa[3], ssvec[6], sum = 0; + /* super-sample voxel */ + for (ssi = NSSAMP; ssi--; ) { + SDmultiSamp(ssa, 3, (ssi+frandom()) * + (1./NSSAMP)); ssvec[0] = 2.*(ix+ssa[0])/sqres - 1.; ssvec[1] = .0; ssvec[2] = input_orient * @@ -184,15 +227,16 @@ eval_isotropic(char *funame) sqrt(1. - ssvec[3]*ssvec[3] - ssvec[4]*ssvec[4]); if (assignD) { - varset("Dx", '=', -iovec[3]); - varset("Dy", '=', -iovec[4]); - varset("Dz", '=', -iovec[5]); + varset("Dx", '=', -ssvec[3]); + varset("Dy", '=', -ssvec[4]); + varset("Dz", '=', -ssvec[5]); ++eclock; } sum += funvalue(funame, 6, ssvec); } - bsdf = sum/nssamp; + bsdf = sum/NSSAMP; } +#endif } if (pctcull >= 0) fwrite(&bsdf, sizeof(bsdf), 1, ofp); @@ -203,6 +247,7 @@ eval_isotropic(char *funame) } if (rbf != NULL) free(rbf); + prog_show((ix+1.)*(2./sqres)); } if (pctcull >= 0) { /* finish output */ if (pclose(ofp)) { @@ -216,6 +261,7 @@ eval_isotropic(char *funame) fputs("}\n", stdout); } data_epilogue(); + prog_done(); } /* Interpolate and output anisotropic BSDF data */ @@ -270,8 +316,6 @@ eval_anisotropic(char *funame) bsdf = eval_rbfrep(rbf, iovec+3) * output_orient/iovec[5]; else { - double ssa[4], ssvec[6], sum; - int ssi; if (assignD) { varset("Dx", '=', -iovec[3]); varset("Dy", '=', -iovec[4]); @@ -279,13 +323,17 @@ eval_anisotropic(char *funame) ++eclock; } bsdf = funvalue(funame, 6, iovec); +#if (NSSAMP > 0) if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) { - sum = 0; /* super-sample voxel */ - for (ssi = nssamp; ssi--; ) { - SDmultiSamp(ssa, 4, (ssi+frandom())/nssamp); + int ssi; + double ssa[4], ssvec[6], sum = 0; + /* super-sample voxel */ + for (ssi = NSSAMP; ssi--; ) { + SDmultiSamp(ssa, 4, (ssi+frandom()) * + (1./NSSAMP)); SDsquare2disk(ssvec, 1.-(ix+ssa[0])/sqres, 1.-(iy+ssa[1])/sqres); - ssvec[2] = output_orient * + ssvec[2] = input_orient * sqrt(1. - ssvec[0]*ssvec[0] - ssvec[1]*ssvec[1]); SDsquare2disk(ssvec+3, (ox+ssa[2])/sqres, @@ -294,15 +342,16 @@ eval_anisotropic(char *funame) sqrt(1. - ssvec[3]*ssvec[3] - ssvec[4]*ssvec[4]); if (assignD) { - varset("Dx", '=', -iovec[3]); - varset("Dy", '=', -iovec[4]); - varset("Dz", '=', -iovec[5]); + varset("Dx", '=', -ssvec[3]); + varset("Dy", '=', -ssvec[4]); + varset("Dz", '=', -ssvec[5]); ++eclock; } sum += funvalue(funame, 6, ssvec); } - bsdf = sum/nssamp; + bsdf = sum/NSSAMP; } +#endif } if (pctcull >= 0) fwrite(&bsdf, sizeof(bsdf), 1, ofp); @@ -313,6 +362,7 @@ eval_anisotropic(char *funame) } if (rbf != NULL) free(rbf); + prog_show((ix*sqres+iy+1.)/(sqres*sqres)); } if (pctcull >= 0) { /* finish output */ if (pclose(ofp)) { @@ -323,6 +373,7 @@ eval_anisotropic(char *funame) } else fputs("}\n", stdout); data_epilogue(); + prog_done(); } /* Read in BSDF and interpolate as tensor tree representation */ @@ -372,6 +423,9 @@ main(int argc, char *argv[]) case 'l': lobe_lim = atoi(argv[++i]); break; + case 'p': + do_prog = atoi(argv[i]+2); + break; default: goto userr; } @@ -390,16 +444,20 @@ main(int argc, char *argv[]) if (dofwd) { input_orient = -1; output_orient = -1; - (*evf)(argv[i]); /* outside reflectance */ + prog_start("Evaluating outside reflectance"); + (*evf)(argv[i]); output_orient = 1; - (*evf)(argv[i]); /* outside -> inside */ + prog_start("Evaluating outside->inside transmission"); + (*evf)(argv[i]); } if (dobwd) { input_orient = 1; output_orient = 1; - (*evf)(argv[i]); /* inside reflectance */ + prog_start("Evaluating inside reflectance"); + (*evf)(argv[i]); output_orient = -1; - (*evf)(argv[i]); /* inside -> outside */ + prog_start("Evaluating inside->outside transmission"); + (*evf)(argv[i]); } xml_epilogue(); /* finish XML output & exit */ return(0); @@ -407,6 +465,7 @@ main(int argc, char *argv[]) if (i < argc) { /* open input files if given */ int nbsdf = 0; for ( ; i < argc; i++) { /* interpolate each component */ + char pbuf[256]; FILE *fpin = fopen(argv[i], "rb"); if (fpin == NULL) { fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n", @@ -418,6 +477,8 @@ main(int argc, char *argv[]) fclose(fpin); if (!nbsdf++) /* start XML on first dist. */ xml_prologue(argc, argv); + sprintf(pbuf, "Interpolating component '%s'", argv[i]); + prog_start(pbuf); if (single_plane_incident) eval_isotropic(NULL); else @@ -430,6 +491,7 @@ main(int argc, char *argv[]) if (!load_bsdf_rep(stdin)) return(1); xml_prologue(argc, argv); /* start XML output */ + prog_start("Interpolating from standard input"); if (single_plane_incident) /* resample dist. */ eval_isotropic(NULL); else
