--- ray/src/cv/bsdf2ttree.c 2013/10/03 17:27:41 2.20 +++ ray/src/cv/bsdf2ttree.c 2014/03/12 21:15:31 2.26 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.20 2013/10/03 17:27:41 greg Exp $"; +static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.26 2014/03/12 21:15:31 greg Exp $"; #endif /* * Load measured BSDF interpolant and write out as XML file with tensor tree. @@ -11,7 +11,9 @@ static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.20 #include #include #include +#include "random.h" #include "platform.h" +#include "rtprocess.h" #include "calcomp.h" #include "bsdfrep.h" /* global argv[0] */ @@ -26,7 +28,36 @@ const double ssamp_thresh = 0.35; const int nssamp = 100; /* limit on number of RBF lobes */ static int lobe_lim = 15000; + /* progress bar length */ +static int do_prog = 79; + +/* Start new progress bar */ +#define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else + +/* Draw progress bar of the appropriate length */ +static void +prog_show(double frac) +{ + char pbar[256]; + int nchars; + + if (do_prog <= 0) return; + if (do_prog > sizeof(pbar)-2) + do_prog = sizeof(pbar)-2; + if (frac < 0) frac = 0; + else if (frac > 1) frac = 1; + nchars = do_prog*frac + .5; + pbar[0] = '\r'; + memset(pbar+1, '*', nchars); + memset(pbar+1+nchars, '-', do_prog-nchars); + pbar[do_prog+1] = '\0'; + fputs(pbar, stderr); +} + +/* Finish progress bar */ +#define prog_done() if (do_prog) fputc('\n',stderr); else + /* Output XML prologue to stdout */ static void xml_prologue(int ac, char *av[]) @@ -44,8 +75,9 @@ xml_prologue(int ac, char *av[]) puts(""); puts(""); puts("\t"); - puts("\t\tName"); - puts("\t\tManufacturer"); + printf("\t\t%s\n", bsdf_name[0] ? bsdf_name : "Unknown"); + printf("\t\t%s\n", + bsdf_manuf[0] ? bsdf_manuf : "Unknown"); puts("\t\tOther"); puts("\t"); puts("\t"); @@ -132,6 +164,9 @@ eval_isotropic(char *funame) exit(1); } SET_FILE_BINARY(ofp); +#ifdef getc_unlocked /* avoid lock/unlock overhead */ + flockfile(ofp); +#endif } else fputs("{\n", stdout); /* need to assign Dx, Dy, Dz? */ @@ -167,7 +202,7 @@ eval_isotropic(char *funame) if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) { sum = 0; /* super-sample voxel */ for (ssi = nssamp; ssi--; ) { - SDmultiSamp(ssa, 3, (ssi+drand48())/nssamp); + SDmultiSamp(ssa, 3, (ssi+frandom())/nssamp); ssvec[0] = 2.*(ix+ssa[0])/sqres - 1.; ssvec[1] = .0; ssvec[2] = input_orient * @@ -197,6 +232,7 @@ eval_isotropic(char *funame) } if (rbf != NULL) free(rbf); + prog_show((ix+1.)*(2./sqres)); } if (pctcull >= 0) { /* finish output */ if (pclose(ofp)) { @@ -210,6 +246,7 @@ eval_isotropic(char *funame) fputs("}\n", stdout); } data_epilogue(); + prog_done(); } /* Interpolate and output anisotropic BSDF data */ @@ -236,6 +273,10 @@ eval_anisotropic(char *funame) progname); exit(1); } + SET_FILE_BINARY(ofp); +#ifdef getc_unlocked /* avoid lock/unlock overhead */ + flockfile(ofp); +#endif } else fputs("{\n", stdout); /* need to assign Dx, Dy, Dz? */ @@ -272,7 +313,7 @@ eval_anisotropic(char *funame) if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) { sum = 0; /* super-sample voxel */ for (ssi = nssamp; ssi--; ) { - SDmultiSamp(ssa, 4, (ssi+drand48())/nssamp); + SDmultiSamp(ssa, 4, (ssi+frandom())/nssamp); SDsquare2disk(ssvec, 1.-(ix+ssa[0])/sqres, 1.-(iy+ssa[1])/sqres); ssvec[2] = output_orient * @@ -303,6 +344,7 @@ eval_anisotropic(char *funame) } if (rbf != NULL) free(rbf); + prog_show((ix*sqres+iy+1.)/(sqres*sqres)); } if (pctcull >= 0) { /* finish output */ if (pclose(ofp)) { @@ -313,6 +355,7 @@ eval_anisotropic(char *funame) } else fputs("}\n", stdout); data_epilogue(); + prog_done(); } /* Read in BSDF and interpolate as tensor tree representation */ @@ -362,6 +405,9 @@ main(int argc, char *argv[]) case 'l': lobe_lim = atoi(argv[++i]); break; + case 'p': + do_prog = atoi(argv[i]+2); + break; default: goto userr; } @@ -372,8 +418,7 @@ main(int argc, char *argv[]) fprintf(stderr, "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n", progname); - fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n", - progname); + fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n"); goto userr; } ++eclock; @@ -381,16 +426,20 @@ main(int argc, char *argv[]) if (dofwd) { input_orient = -1; output_orient = -1; - (*evf)(argv[i]); /* outside reflectance */ + prog_start("Evaluating outside reflectance"); + (*evf)(argv[i]); output_orient = 1; - (*evf)(argv[i]); /* outside -> inside */ + prog_start("Evaluating outside->inside transmission"); + (*evf)(argv[i]); } if (dobwd) { input_orient = 1; output_orient = 1; - (*evf)(argv[i]); /* inside reflectance */ + prog_start("Evaluating inside reflectance"); + (*evf)(argv[i]); output_orient = -1; - (*evf)(argv[i]); /* inside -> outside */ + prog_start("Evaluating inside->outside transmission"); + (*evf)(argv[i]); } xml_epilogue(); /* finish XML output & exit */ return(0); @@ -398,6 +447,7 @@ main(int argc, char *argv[]) if (i < argc) { /* open input files if given */ int nbsdf = 0; for ( ; i < argc; i++) { /* interpolate each component */ + char pbuf[256]; FILE *fpin = fopen(argv[i], "rb"); if (fpin == NULL) { fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n", @@ -409,6 +459,8 @@ main(int argc, char *argv[]) fclose(fpin); if (!nbsdf++) /* start XML on first dist. */ xml_prologue(argc, argv); + sprintf(pbuf, "Interpolating component '%s'", argv[i]); + prog_start(pbuf); if (single_plane_incident) eval_isotropic(NULL); else @@ -421,6 +473,7 @@ main(int argc, char *argv[]) if (!load_bsdf_rep(stdin)) return(1); xml_prologue(argc, argv); /* start XML output */ + prog_start("Interpolating from standard input"); if (single_plane_incident) /* resample dist. */ eval_isotropic(NULL); else
