root/radiance/ray/src/cv/bsdf2ttree.c
Revision: 2.50
Committed: Mon May 11 20:26:58 2020 UTC (4 years, 11 months ago) by greg
Changes since 2.49: +83 -77 lines
Hopefully final sampling improvement -- tests for differences on all sides
2 static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.49 2020/05/08 22:34:21 greg Exp $";
5 * Load measured BSDF interpolant and write out as XML file with tensor tree.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdlib.h>
12 #include <math.h>
13 #include "random.h"
14 #include "platform.h"
15 #include "paths.h"
16 #include "rtio.h"
17 #include "calcomp.h"
18 #include "bsdfrep.h"
19 /* global argv[0] */
20 char *progname;
21 /* reciprocity averaging option */
22 static const char *recip = " -a";
23 /* percentage to cull (<0 to turn off) */
24 static double pctcull = 90.;
25 /* sampling order */
26 static int samp_order = 6;
27 /* super-sampling threshold */
28 static double ssamp_thresh = 0.35;
29 /* number of super-samples */
30 #ifndef NSSAMP
31 #define NSSAMP 256
32 #endif
33 /* limit on number of RBF lobes */
34 static int lobe_lim = 15000;
35 /* progress bar length */
36 static int do_prog = 79;
37
38 #define MAXCARG 512 /* wrapBSDF command */
39 static char *wrapBSDF[MAXCARG] = {"wrapBSDF", "-U"};
40 static int wbsdfac = 2;
41
42 /* Add argument to wrapBSDF, allocating space if !isstatic */
43 static void
44 add_wbsdf(const char *arg, int isstatic)
45 {
46 if (arg == NULL)
47 return;
48 if (wbsdfac >= MAXCARG-1) {
49 fputs(progname, stderr);
50 fputs(": too many command arguments to wrapBSDF\n", stderr);
51 exit(1);
52 }
53 if (!*arg)
54 arg = "";
55 else if (!isstatic)
56 arg = savqstr((char *)arg);
57
58 wrapBSDF[wbsdfac++] = (char *)arg;
59 }
60
61 /* Create Yuv component file and add appropriate arguments */
62 static char *
63 create_component_file(int c)
64 {
65 static const char sname[3][6] = {"CIE-Y", "CIE-u", "CIE-v"};
66 static const char cname[4][4] = {"-rf", "-tf", "-tb", "-rb"};
67 char *tfname = mktemp(savqstr(TEMPLATE));
68
69 add_wbsdf("-s", 1); add_wbsdf(sname[c], 1);
70 add_wbsdf(cname[(input_orient>0)<<1 | (output_orient>0)], 1);
71 add_wbsdf(tfname, 1);
72 return(tfname);
73 }
74
75 /* Start new progress bar */
76 #define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else
77
78 /* Draw progress bar of the appropriate length */
79 static void
80 prog_show(double frac)
81 {
82 static unsigned call_cnt = 0;
83 static char lastc[] = "-\\|/";
84 char pbar[256];
85 int nchars;
86
87 if (do_prog <= 1) return;
88 if (do_prog > sizeof(pbar)-2)
89 do_prog = sizeof(pbar)-2;
90 if (frac < 0) frac = 0;
91 else if (frac >= 1) frac = .9999;
92 nchars = do_prog*frac;
93 pbar[0] = '\r';
94 memset(pbar+1, '*', nchars);
95 pbar[nchars+1] = lastc[call_cnt++ & 3];
96 memset(pbar+2+nchars, '-', do_prog-nchars-1);
97 pbar[do_prog+1] = '\0';
98 fputs(pbar, stderr);
99 }
100
101 /* Finish progress bar */
102 static void
103 prog_done(void)
104 {
105 int n = do_prog;
106
107 if (n <= 1) return;
108 fputc('\r', stderr);
109 while (n--)
110 fputc(' ', stderr);
111 fputc('\r', stderr);
112 }
113
114 /* Compute absolute relative difference */
115 static double
116 abs_diff(double v1, double v0)
117 {
118 if ((v0 < 0) | (v1 < 0))
119 return(.0);
120 v1 = (v1-v0)*2./(v0+v1+.0001);
121 if (v1 < 0)
122 return(-v1);
123 return(v1);
124 }
125
126 /* Interpolate and output isotropic BSDF data */
127 static void
128 eval_isotropic(char *funame)
129 {
130 const int sqres = 1<<samp_order;
131 const double sqfact = 1./(double)sqres;
132 float *val_last = NULL;
133 float *val_next = NULL;
134 SDValue *sdv_next = NULL;
135 FILE *ofp, *uvfp[2];
136 int assignD = 0;
137 char cmd[128];
138 int ix, ox, oy;
139 double iovec[6];
140 float bsdf, uv[2];
141
142 if (pctcull >= 0) {
143 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
144 recip, pctcull, samp_order, create_component_file(0));
145 ofp = popen(cmd, "w");
146 if (ofp == NULL) {
147 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
148 progname);
149 exit(1);
150 }
151 SET_FILE_BINARY(ofp);
152 #ifdef getc_unlocked /* avoid lock/unlock overhead */
153 flockfile(ofp);
154 #endif
155 if (rbf_colorimetry == RBCtristimulus) {
156 double uvcull = 100. - (100.-pctcull)*.25;
157 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
158 recip, uvcull, samp_order, create_component_file(1));
159 uvfp[0] = popen(cmd, "w");
160 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
161 recip, uvcull, samp_order, create_component_file(2));
162 uvfp[1] = popen(cmd, "w");
163 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
164 fprintf(stderr, "%s: cannot open pipes to uv output\n",
165 progname);
166 exit(1);
167 }
168 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
169 #ifdef getc_unlocked
170 flockfile(uvfp[0]); flockfile(uvfp[1]);
171 #endif
172 }
173 } else {
174 ofp = fopen(create_component_file(0), "w");
175 if (ofp == NULL) {
176 fprintf(stderr, "%s: cannot create Y output file\n",
177 progname);
178 exit(1);
179 }
180 fputs("{\n", ofp);
181 if (rbf_colorimetry == RBCtristimulus) {
182 uvfp[0] = fopen(create_component_file(1), "w");
183 uvfp[1] = fopen(create_component_file(2), "w");
184 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
185 fprintf(stderr, "%s: cannot create uv output file(s)\n",
186 progname);
187 exit(1);
188 }
189 fputs("{\n", uvfp[0]);
190 fputs("{\n", uvfp[1]);
191 }
192 }
193 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
194 assignD = (fundefined(funame) < 6);
195 #if (NSSAMP > 0)
196 val_last = (float *)calloc(sqres, sizeof(float));
197 if (funame == NULL)
198 sdv_next = (SDValue *)malloc(sizeof(SDValue)*sqres);
199 else
200 val_next = (float *)malloc(sizeof(float)*sqres);
201 #endif
202 /* run through directions */
203 for (ix = 0; ix < sqres/2; ix++) {
204 const int zipsgn = (ix & 1)*2 - 1;
205 RBFNODE *rbf = NULL;
206 iovec[0] = 2.*sqfact*(ix+.5) - 1.;
207 iovec[1] = zipsgn*sqfact*.5;
208 iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]
209 - iovec[1]*iovec[1]);
210 if (funame == NULL)
211 rbf = advect_rbf(iovec, lobe_lim);
212 /* presample first row */
213 for (oy = 0; oy < sqres; oy++) {
214 SDsquare2disk(iovec+3, .5*sqfact, (oy+.5)*sqfact);
215 iovec[5] = output_orient *
216 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
217 if (funame == NULL) {
218 eval_rbfcol(&sdv_next[oy], rbf, iovec+3);
219 } else {
220 if (assignD) {
221 varset("Dx", '=', -iovec[3]);
222 varset("Dy", '=', -iovec[4]);
223 varset("Dz", '=', -iovec[5]);
224 ++eclock;
225 }
226 val_next[oy] = funvalue(funame, 6, iovec);
227 }
228 }
229 for (ox = 0; ox < sqres; ox++) {
230 /*
231 * Super-sample when we detect a difference from before
232 * or after in this row, above or below.
233 */
234 for (oy = 0; oy < sqres; oy++) {
235 if (ox < sqres-1) { /* keeping one row ahead... */
236 SDsquare2disk(iovec+3, (ox+1.5)*sqfact, (oy+.5)*sqfact);
237 iovec[5] = output_orient *
238 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
239 }
240 if (funame == NULL) {
241 SDValue sdv = sdv_next[oy];
242 bsdf = sdv.cieY;
243 if (ox < sqres-1)
244 eval_rbfcol(&sdv_next[oy], rbf, iovec+3);
245 #if (NSSAMP > 0)
246 if (abs_diff(bsdf, sdv_next[oy].cieY) > ssamp_thresh ||
247 (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) ||
248 (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) ||
249 (oy < sqres-1 &&
250 abs_diff(bsdf, sdv_next[oy+1].cieY) > ssamp_thresh)) {
251 int ssi;
252 double ssa[2], sum = 0, usum = 0, vsum = 0;
253 /* super-sample voxel */
254 for (ssi = NSSAMP; ssi--; ) {
255 SDmultiSamp(ssa, 2, (ssi+frandom()) *
256 (1./NSSAMP));
257 SDsquare2disk(iovec+3, (ox+ssa[0])*sqfact,
258 (oy+ssa[1])*sqfact);
259 iovec[5] = output_orient *
260 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
261 eval_rbfcol(&sdv, rbf, iovec+3);
262 sum += sdv.cieY;
263 if (rbf_colorimetry == RBCtristimulus) {
264 sdv.cieY /=
265 -2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.;
266 usum += 4.*sdv.spec.cx * sdv.cieY;
267 vsum += 9.*sdv.spec.cy * sdv.cieY;
268 }
269 }
270 bsdf = sum * (1./NSSAMP);
271 if (rbf_colorimetry == RBCtristimulus) {
272 uv[0] = usum / (sum+FTINY);
273 uv[1] = vsum / (sum+FTINY);
274 }
275 } else
276 #endif
277 if (rbf_colorimetry == RBCtristimulus) {
278 uv[0] = uv[1] = 1. /
279 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
280 uv[0] *= 4.*sdv.spec.cx;
281 uv[1] *= 9.*sdv.spec.cy;
282 }
283 } else {
284 bsdf = val_next[oy];
285 if (ox < sqres-1) {
286 if (assignD) {
287 varset("Dx", '=', -iovec[3]);
288 varset("Dy", '=', -iovec[4]);
289 varset("Dz", '=', -iovec[5]);
290 ++eclock;
291 }
292 val_next[oy] = funvalue(funame, 6, iovec);
293 }
294 #if (NSSAMP > 0)
295 if (abs_diff(bsdf, val_next[oy]) > ssamp_thresh ||
296 (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) ||
297 (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) ||
298 (oy < sqres-1 &&
299 abs_diff(bsdf, val_next[oy+1]) > ssamp_thresh)) {
300 int ssi;
301 double ssa[4], ssvec[6], sum = 0;
302 /* super-sample voxel */
303 for (ssi = NSSAMP; ssi--; ) {
304 SDmultiSamp(ssa, 4, (ssi+frandom()) *
305 (1./NSSAMP));
306 ssvec[0] = 2.*sqfact*(ix+ssa[0]) - 1.;
307 ssvec[1] = zipsgn*sqfact*ssa[1];
308 ssvec[2] = 1. - ssvec[0]*ssvec[0]
309 - ssvec[1]*ssvec[1];
310 if (ssvec[2] < .0) {
311 ssvec[1] = 0;
312 ssvec[2] = 1. - ssvec[0]*ssvec[0];
313 }
314 ssvec[2] = input_orient * sqrt(ssvec[2]);
315 SDsquare2disk(ssvec+3, (ox+ssa[2])*sqfact,
316 (oy+ssa[3])*sqfact);
317 ssvec[5] = output_orient *
318 sqrt(1. - ssvec[3]*ssvec[3] -
319 ssvec[4]*ssvec[4]);
320 if (assignD) {
321 varset("Dx", '=', -ssvec[3]);
322 varset("Dy", '=', -ssvec[4]);
323 varset("Dz", '=', -ssvec[5]);
324 ++eclock;
325 }
326 sum += funvalue(funame, 6, ssvec);
327 }
328 bsdf = sum * (1./NSSAMP);
329 }
330 #endif
331 }
332 if (pctcull >= 0)
333 putbinary(&bsdf, sizeof(bsdf), 1, ofp);
334 else
335 fprintf(ofp, "\t%.3e\n", bsdf);
336
337 if (rbf_colorimetry == RBCtristimulus) {
338 if (pctcull >= 0) {
339 putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]);
340 putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]);
341 } else {
342 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
343 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
344 }
345 }
346 if (val_last != NULL)
347 val_last[oy] = bsdf;
348 }
349 }
350 if (rbf != NULL)
351 free(rbf);
352 prog_show((ix+1.)*(2.*sqfact));
353 }
354 prog_done();
355 if (val_last != NULL) {
356 free(val_last);
357 if (val_next != NULL) free(val_next);
358 if (sdv_next != NULL) free(sdv_next);
359 }
360 if (pctcull >= 0) { /* finish output */
361 if (pclose(ofp)) {
362 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
363 progname);
364 exit(1);
365 }
366 if (rbf_colorimetry == RBCtristimulus &&
367 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
368 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
369 progname);
370 exit(1);
371 }
372 } else {
373 for (ix = sqres*sqres*sqres/2; ix--; )
374 fputs("\t0\n", ofp);
375 fputs("}\n", ofp);
376 if (fclose(ofp)) {
377 fprintf(stderr, "%s: error writing Y file\n",
378 progname);
379 exit(1);
380 }
381 if (rbf_colorimetry == RBCtristimulus) {
382 for (ix = sqres*sqres*sqres/2; ix--; ) {
383 fputs("\t0\n", uvfp[0]);
384 fputs("\t0\n", uvfp[1]);
385 }
386 fputs("}\n", uvfp[0]);
387 fputs("}\n", uvfp[1]);
388 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
389 fprintf(stderr, "%s: error writing uv file(s)\n",
390 progname);
391 exit(1);
392 }
393 }
394 }
395 }
396
397 /* Interpolate and output anisotropic BSDF data */
398 static void
399 eval_anisotropic(char *funame)
400 {
401 const int sqres = 1<<samp_order;
402 const double sqfact = 1./(double)sqres;
403 float *val_last = NULL;
404 float *val_next = NULL;
405 SDValue *sdv_next = NULL;
406 FILE *ofp, *uvfp[2];
407 int assignD = 0;
408 char cmd[128];
409 int ix, iy, ox, oy;
410 double iovec[6];
411 float bsdf, uv[2];
412
413 if (pctcull >= 0) {
414 const char *avgopt = (input_orient>0 ^ output_orient>0)
415 ? "" : recip;
416 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
417 avgopt, pctcull, samp_order,
418 create_component_file(0));
419 ofp = popen(cmd, "w");
420 if (ofp == NULL) {
421 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
422 progname);
423 exit(1);
424 }
425 SET_FILE_BINARY(ofp);
426 #ifdef getc_unlocked /* avoid lock/unlock overhead */
427 flockfile(ofp);
428 #endif
429 if (rbf_colorimetry == RBCtristimulus) {
430 double uvcull = 100. - (100.-pctcull)*.25;
431 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
432 avgopt, uvcull, samp_order,
433 create_component_file(1));
434 uvfp[0] = popen(cmd, "w");
435 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
436 avgopt, uvcull, samp_order,
437 create_component_file(2));
438 uvfp[1] = popen(cmd, "w");
439 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
440 fprintf(stderr, "%s: cannot open pipes to uv output\n",
441 progname);
442 exit(1);
443 }
444 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
445 #ifdef getc_unlocked
446 flockfile(uvfp[0]); flockfile(uvfp[1]);
447 #endif
448 }
449 } else {
450 ofp = fopen(create_component_file(0), "w");
451 if (ofp == NULL) {
452 fprintf(stderr, "%s: cannot create Y output file\n",
453 progname);
454 exit(1);
455 }
456 fputs("{\n", ofp);
457 if (rbf_colorimetry == RBCtristimulus) {
458 uvfp[0] = fopen(create_component_file(1), "w");
459 uvfp[1] = fopen(create_component_file(2), "w");
460 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
461 fprintf(stderr, "%s: cannot create uv output file(s)\n",
462 progname);
463 exit(1);
464 }
465 fputs("{\n", uvfp[0]);
466 fputs("{\n", uvfp[1]);
467 }
468 }
469 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
470 assignD = (fundefined(funame) < 6);
471 #if (NSSAMP > 0)
472 val_last = (float *)calloc(sqres, sizeof(float));
473 if (funame == NULL)
474 sdv_next = (SDValue *)malloc(sizeof(SDValue)*sqres);
475 else
476 val_next = (float *)malloc(sizeof(float)*sqres);
477 #endif
478 /* run through directions */
479 for (ix = 0; ix < sqres; ix++)
480 for (iy = 0; iy < sqres; iy++) {
481 RBFNODE *rbf = NULL; /* Klems reversal */
482 SDsquare2disk(iovec, 1.-(ix+.5)*sqfact, 1.-(iy+.5)*sqfact);
483 iovec[2] = input_orient *
484 sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]);
485 if (funame == NULL)
486 rbf = advect_rbf(iovec, lobe_lim);
487 /* presample first row */
488 for (oy = 0; oy < sqres; oy++) {
489 SDsquare2disk(iovec+3, .5*sqfact, (oy+.5)*sqfact);
490 iovec[5] = output_orient *
491 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
492 if (funame == NULL) {
493 eval_rbfcol(&sdv_next[oy], rbf, iovec+3);
494 } else {
495 if (assignD) {
496 varset("Dx", '=', -iovec[3]);
497 varset("Dy", '=', -iovec[4]);
498 varset("Dz", '=', -iovec[5]);
499 ++eclock;
500 }
501 val_next[oy] = funvalue(funame, 6, iovec);
502 }
503 }
504 for (ox = 0; ox < sqres; ox++) {
505 /*
506 * Super-sample when we detect a difference from before
507 * or after in this row, above or below.
508 */
509 for (oy = 0; oy < sqres; oy++) {
510 if (ox < sqres-1) { /* keeping one row ahead... */
511 SDsquare2disk(iovec+3, (ox+1.5)*sqfact, (oy+.5)*sqfact);
512 iovec[5] = output_orient *
513 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
514 }
515 if (funame == NULL) {
516 SDValue sdv = sdv_next[oy];
517 bsdf = sdv.cieY;
518 if (ox < sqres-1)
519 eval_rbfcol(&sdv_next[oy], rbf, iovec+3);
520 #if (NSSAMP > 0)
521 if (abs_diff(bsdf, sdv_next[oy].cieY) > ssamp_thresh ||
522 (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) ||
523 (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) ||
524 (oy < sqres-1 &&
525 abs_diff(bsdf, sdv_next[oy+1].cieY) > ssamp_thresh)) {
526 int ssi;
527 double ssa[2], sum = 0, usum = 0, vsum = 0;
528 /* super-sample voxel */
529 for (ssi = NSSAMP; ssi--; ) {
530 SDmultiSamp(ssa, 2, (ssi+frandom()) *
531 (1./NSSAMP));
532 SDsquare2disk(iovec+3, (ox+ssa[0])*sqfact,
533 (oy+ssa[1])*sqfact);
534 iovec[5] = output_orient *
535 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
536 eval_rbfcol(&sdv, rbf, iovec+3);
537 sum += sdv.cieY;
538 if (rbf_colorimetry == RBCtristimulus) {
539 sdv.cieY /=
540 -2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.;
541 usum += 4.*sdv.spec.cx * sdv.cieY;
542 vsum += 9.*sdv.spec.cy * sdv.cieY;
543 }
544 }
545 bsdf = sum * (1./NSSAMP);
546 if (rbf_colorimetry == RBCtristimulus) {
547 uv[0] = usum / (sum+FTINY);
548 uv[1] = vsum / (sum+FTINY);
549 }
550 } else
551 #endif
552 if (rbf_colorimetry == RBCtristimulus) {
553 uv[0] = uv[1] = 1. /
554 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
555 uv[0] *= 4.*sdv.spec.cx;
556 uv[1] *= 9.*sdv.spec.cy;
557 }
558 } else {
559 bsdf = val_next[oy];
560 if (ox < sqres-1) {
561 if (assignD) {
562 varset("Dx", '=', -iovec[3]);
563 varset("Dy", '=', -iovec[4]);
564 varset("Dz", '=', -iovec[5]);
565 ++eclock;
566 }
567 val_next[oy] = funvalue(funame, 6, iovec);
568 }
569 #if (NSSAMP > 0)
570 if (abs_diff(bsdf, val_next[oy]) > ssamp_thresh ||
571 (ox && abs_diff(bsdf, val_last[oy]) > ssamp_thresh) ||
572 (oy && abs_diff(bsdf, val_last[oy-1]) > ssamp_thresh) ||
573 (oy < sqres-1 &&
574 abs_diff(bsdf, val_next[oy+1]) > ssamp_thresh)) {
575 int ssi;
576 double ssa[4], ssvec[6], sum = 0;
577 /* super-sample voxel */
578 for (ssi = NSSAMP; ssi--; ) {
579 SDmultiSamp(ssa, 4, (ssi+frandom()) *
580 (1./NSSAMP));
581 SDsquare2disk(ssvec, 1.-(ix+ssa[0])*sqfact,
582 1.-(iy+ssa[1])*sqfact);
583 ssvec[2] = input_orient *
584 sqrt(1. - ssvec[0]*ssvec[0] -
585 ssvec[1]*ssvec[1]);
586 SDsquare2disk(ssvec+3, (ox+ssa[2])*sqfact,
587 (oy+ssa[3])*sqfact);
588 ssvec[5] = output_orient *
589 sqrt(1. - ssvec[3]*ssvec[3] -
590 ssvec[4]*ssvec[4]);
591 if (assignD) {
592 varset("Dx", '=', -ssvec[3]);
593 varset("Dy", '=', -ssvec[4]);
594 varset("Dz", '=', -ssvec[5]);
595 ++eclock;
596 }
597 sum += funvalue(funame, 6, ssvec);
598 }
599 bsdf = sum * (1./NSSAMP);
600 }
601 #endif
602 }
603 if (pctcull >= 0)
604 putbinary(&bsdf, sizeof(bsdf), 1, ofp);
605 else
606 fprintf(ofp, "\t%.3e\n", bsdf);
607
608 if (rbf_colorimetry == RBCtristimulus) {
609 if (pctcull >= 0) {
610 putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]);
611 putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]);
612 } else {
613 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
614 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
615 }
616 }
617 if (val_last != NULL)
618 val_last[oy] = bsdf;
619 }
620 if (rbf != NULL)
621 free(rbf);
622 prog_show((ix*sqres+iy+1.)/(sqres*sqres));
623 }
624 }
625 prog_done();
626 if (val_last != NULL) {
627 free(val_last);
628 if (val_next != NULL) free(val_next);
629 if (sdv_next != NULL) free(sdv_next);
630 }
631 if (pctcull >= 0) { /* finish output */
632 if (pclose(ofp)) {
633 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
634 progname);
635 exit(1);
636 }
637 if (rbf_colorimetry == RBCtristimulus &&
638 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
639 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
640 progname);
641 exit(1);
642 }
643 } else {
644 fputs("}\n", ofp);
645 if (fclose(ofp)) {
646 fprintf(stderr, "%s: error writing Y file\n",
647 progname);
648 exit(1);
649 }
650 if (rbf_colorimetry == RBCtristimulus) {
651 fputs("}\n", uvfp[0]);
652 fputs("}\n", uvfp[1]);
653 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
654 fprintf(stderr, "%s: error writing uv file(s)\n",
655 progname);
656 exit(1);
657 }
658 }
659 }
660 }
661
662 #if defined(_WIN32) || defined(_WIN64)
663 /* Execute wrapBSDF command (may never return) */
664 static int
665 wrap_up(void)
666 {
667 char cmd[8192];
668
669 if (bsdf_manuf[0]) {
670 add_wbsdf("-f", 1);
671 strcpy(cmd, "m=");
672 strcpy(cmd+2, bsdf_manuf);
673 add_wbsdf(cmd, 0);
674 }
675 if (bsdf_name[0]) {
676 add_wbsdf("-f", 1);
677 strcpy(cmd, "n=");
678 strcpy(cmd+2, bsdf_name);
679 add_wbsdf(cmd, 0);
680 }
681 if (!convert_commandline(cmd, sizeof(cmd), wrapBSDF)) {
682 fputs(progname, stderr);
683 fputs(": command line too long in wrap_up()\n", stderr);
684 return(1);
685 }
686 return(system(cmd));
687 }
688 #else
689 /* Execute wrapBSDF command (may never return) */
690 static int
691 wrap_up(void)
692 {
693 char buf[256];
694 char *compath = getpath((char *)wrapBSDF[0], getenv("PATH"), X_OK);
695
696 if (compath == NULL) {
697 fprintf(stderr, "%s: cannot locate %s\n", progname, wrapBSDF[0]);
698 return(1);
699 }
700 if (bsdf_manuf[0]) {
701 add_wbsdf("-f", 1);
702 strcpy(buf, "m=");
703 strcpy(buf+2, bsdf_manuf);
704 add_wbsdf(buf, 0);
705 }
706 if (bsdf_name[0]) {
707 add_wbsdf("-f", 1);
708 strcpy(buf, "n=");
709 strcpy(buf+2, bsdf_name);
710 add_wbsdf(buf, 0);
711 }
712 execv(compath, wrapBSDF); /* successful call never returns */
713 perror(compath);
714 return(1);
715 }
716 #endif
717
718 /* Read in BSDF and interpolate as tensor tree representation */
719 int
720 main(int argc, char *argv[])
721 {
722 static char tfmt[2][4] = {"t4", "t3"};
723 int dofwd = 0, dobwd = 1;
724 char buf[2048];
725 int i, na;
726
727 progname = argv[0];
728 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
729 esupport &= ~(E_INCHAN|E_OUTCHAN);
730 scompile("PI:3.14159265358979323846", NULL, 0);
731 biggerlib();
732 for (i = 1; i < argc && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
733 switch (argv[i][1]) { /* get options */
734 case 'e':
735 scompile(argv[++i], NULL, 0);
736 if (single_plane_incident < 0)
737 single_plane_incident = 0;
738 break;
739 case 'f':
740 if (!argv[i][2]) {
741 if (strchr(argv[++i], '=') != NULL) {
742 add_wbsdf("-f", 1);
743 add_wbsdf(argv[i], 1);
744 } else {
745 char *fpath = getpath(argv[i],
746 getrlibpath(), 0);
747 if (fpath == NULL) {
748 fprintf(stderr,
749 "%s: cannot find file '%s'\n",
750 argv[0], argv[i]);
751 return(1);
752 }
753 fcompile(fpath);
754 if (single_plane_incident < 0)
755 single_plane_incident = 0;
756 }
757 } else
758 dofwd = (argv[i][0] == '+');
759 break;
760 case 'a':
761 recip = (argv[i][0] == '+') ? " -a" : "";
762 break;
763 case 'b':
764 dobwd = (argv[i][0] == '+');
765 break;
766 case 't':
767 switch (argv[i][2]) {
768 case '3':
769 single_plane_incident = 1;
770 break;
771 case '4':
772 single_plane_incident = 0;
773 break;
774 case '\0':
775 pctcull = atof(argv[++i]);
776 break;
777 default:
778 goto userr;
779 }
780 break;
781 case 'g':
782 samp_order = atoi(argv[++i]);
783 break;
784 case 'l':
785 lobe_lim = atoi(argv[++i]);
786 break;
787 case 'p':
788 do_prog = atoi(argv[i]+2);
789 break;
790 case 'W':
791 add_wbsdf(argv[i], 1);
792 break;
793 case 'u':
794 case 'C':
795 add_wbsdf(argv[i], 1);
796 add_wbsdf(argv[++i], 1);
797 break;
798 default:
799 goto userr;
800 }
801 strcpy(buf, "File produced by: ");
802 if (convert_commandline(buf+18, sizeof(buf)-18, argv) != NULL) {
803 add_wbsdf("-C", 1); add_wbsdf(buf, 0);
804 }
805 if (single_plane_incident >= 0) { /* function-based BSDF? */
806 void (*evf)(char *s) = single_plane_incident ?
807 eval_isotropic : eval_anisotropic;
808 if (i != argc-1 || fundefined(argv[i]) < 3) {
809 fprintf(stderr,
810 "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
811 progname);
812 fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n");
813 goto userr;
814 }
815 ++eclock;
816 ssamp_thresh *= 0.5; /* lower sampling threshold */
817 add_wbsdf("-a", 1);
818 add_wbsdf(tfmt[single_plane_incident], 1);
819 if (dofwd) {
820 input_orient = -1;
821 output_orient = -1;
822 prog_start("Evaluating outside reflectance");
823 (*evf)(argv[i]);
824 output_orient = 1;
825 prog_start("Evaluating outside->inside transmission");
826 (*evf)(argv[i]);
827 }
828 if (dobwd) {
829 input_orient = 1;
830 output_orient = 1;
831 prog_start("Evaluating inside reflectance");
832 (*evf)(argv[i]);
833 output_orient = -1;
834 prog_start("Evaluating inside->outside transmission");
835 (*evf)(argv[i]);
836 }
837 return(wrap_up());
838 }
839 if (i < argc) { /* open input files if given */
840 int nbsdf = 0;
841 for ( ; i < argc; i++) { /* interpolate each component */
842 char pbuf[256];
843 FILE *fpin = fopen(argv[i], "rb");
844 if (fpin == NULL) {
845 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
846 progname, argv[i]);
847 return(1);
848 }
849 if (!load_bsdf_rep(fpin))
850 return(1);
851 fclose(fpin);
852 sprintf(pbuf, "Interpolating component '%s'", argv[i]);
853 prog_start(pbuf);
854 if (!nbsdf++) {
855 add_wbsdf("-a", 1);
856 add_wbsdf(tfmt[single_plane_incident], 1);
857 }
858 if (single_plane_incident)
859 eval_isotropic(NULL);
860 else
861 eval_anisotropic(NULL);
862 }
863 return(wrap_up());
864 }
865 SET_FILE_BINARY(stdin); /* load from stdin */
866 if (!load_bsdf_rep(stdin))
867 return(1);
868 prog_start("Interpolating from standard input");
869 add_wbsdf("-a", 1);
870 add_wbsdf(tfmt[single_plane_incident], 1);
871 if (single_plane_incident) /* resample dist. */
872 eval_isotropic(NULL);
873 else
874 eval_anisotropic(NULL);
875
876 return(wrap_up());
877 userr:
878 fprintf(stderr,
879 "Usage: %s [{+|-}a][-g Nlog2][-t pctcull][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n",
880 progname);
881 fprintf(stderr,
882 " or: %s -t{3|4} [{+|-}a][-g Nlog2][-t pctcull][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
883 progname);
884 return(1);
885 }
