root/radiance/ray/src/cv/bsdf2ttree.c
Revision: 2.47
Committed: Thu May 7 02:36:37 2020 UTC (5 years, 3 months ago) by greg
Changes since 2.46: +113 -33 lines
Various improvements to adaptive sampling method
2 static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.46 2020/05/06 02:28:21 greg Exp $";
5 * Load measured BSDF interpolant and write out as XML file with tensor tree.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdlib.h>
12 #include <math.h>
13 #include "random.h"
14 #include "platform.h"
15 #include "paths.h"
16 #include "rtio.h"
17 #include "calcomp.h"
18 #include "bsdfrep.h"
19 /* global argv[0] */
20 char *progname;
21 /* reciprocity averaging option */
22 static const char *recip = " -a";
23 /* percentage to cull (<0 to turn off) */
24 static double pctcull = 90.;
25 /* sampling order */
26 static int samp_order = 6;
27 /* super-sampling threshold */
28 const double ssamp_thresh = 0.30;
29 /* number of super-samples */
30 #ifndef NSSAMP
31 #define NSSAMP 256
32 #endif
33 /* limit on number of RBF lobes */
34 static int lobe_lim = 15000;
35 /* progress bar length */
36 static int do_prog = 79;
37
38 #define MAXCARG 512 /* wrapBSDF command */
39 static char *wrapBSDF[MAXCARG] = {"wrapBSDF", "-U"};
40 static int wbsdfac = 2;
41
42 /* Add argument to wrapBSDF, allocating space if !isstatic */
43 static void
44 add_wbsdf(const char *arg, int isstatic)
45 {
46 if (arg == NULL)
47 return;
48 if (wbsdfac >= MAXCARG-1) {
49 fputs(progname, stderr);
50 fputs(": too many command arguments to wrapBSDF\n", stderr);
51 exit(1);
52 }
53 if (!*arg)
54 arg = "";
55 else if (!isstatic)
56 arg = savqstr((char *)arg);
57
58 wrapBSDF[wbsdfac++] = (char *)arg;
59 }
60
61 /* Create Yuv component file and add appropriate arguments */
62 static char *
63 create_component_file(int c)
64 {
65 static const char sname[3][6] = {"CIE-Y", "CIE-u", "CIE-v"};
66 static const char cname[4][4] = {"-rf", "-tf", "-tb", "-rb"};
67 char *tfname = mktemp(savqstr(TEMPLATE));
68
69 add_wbsdf("-s", 1); add_wbsdf(sname[c], 1);
70 add_wbsdf(cname[(input_orient>0)<<1 | (output_orient>0)], 1);
71 add_wbsdf(tfname, 1);
72 return(tfname);
73 }
74
75 /* Start new progress bar */
76 #define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else
77
78 /* Draw progress bar of the appropriate length */
79 static void
80 prog_show(double frac)
81 {
82 static unsigned call_cnt = 0;
83 static char lastc[] = "-\\|/";
84 char pbar[256];
85 int nchars;
86
87 if (do_prog <= 1) return;
88 if (do_prog > sizeof(pbar)-2)
89 do_prog = sizeof(pbar)-2;
90 if (frac < 0) frac = 0;
91 else if (frac >= 1) frac = .9999;
92 nchars = do_prog*frac;
93 pbar[0] = '\r';
94 memset(pbar+1, '*', nchars);
95 pbar[nchars+1] = lastc[call_cnt++ & 3];
96 memset(pbar+2+nchars, '-', do_prog-nchars-1);
97 pbar[do_prog+1] = '\0';
98 fputs(pbar, stderr);
99 }
100
101 /* Finish progress bar */
102 static void
103 prog_done(void)
104 {
105 int n = do_prog;
106
107 if (n <= 1) return;
108 fputc('\r', stderr);
109 while (n--)
110 fputc(' ', stderr);
111 fputc('\r', stderr);
112 }
113
114 /* Compute absolute relative difference */
115 static double
116 abs_diff(double v1, double v0)
117 {
118 if ((v0 < 0) | (v1 < 0))
119 return(.0);
120 v1 = (v1-v0)*2./(v0+v1+.0001);
121 if (v1 < 0)
122 return(-v1);
123 return(v1);
124 }
125
126 /* Interpolate and output isotropic BSDF data */
127 static void
128 eval_isotropic(char *funame)
129 {
130 const int sqres = 1<<samp_order;
131 const double sqfact = 1./(double)sqres;
132 float *ryval = NULL;
133 char *rtrip = NULL;
134 FILE *ofp, *uvfp[2];
135 int assignD = 0;
136 char cmd[128];
137 int ix, ox, oy;
138 double iovec[6];
139 float bsdf, uv[2];
140
141 if (pctcull >= 0) {
142 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
143 recip, pctcull, samp_order, create_component_file(0));
144 ofp = popen(cmd, "w");
145 if (ofp == NULL) {
146 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
147 progname);
148 exit(1);
149 }
150 SET_FILE_BINARY(ofp);
151 #ifdef getc_unlocked /* avoid lock/unlock overhead */
152 flockfile(ofp);
153 #endif
154 if (rbf_colorimetry == RBCtristimulus) {
155 double uvcull = 100. - (100.-pctcull)*.25;
156 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
157 recip, uvcull, samp_order, create_component_file(1));
158 uvfp[0] = popen(cmd, "w");
159 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
160 recip, uvcull, samp_order, create_component_file(2));
161 uvfp[1] = popen(cmd, "w");
162 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
163 fprintf(stderr, "%s: cannot open pipes to uv output\n",
164 progname);
165 exit(1);
166 }
167 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
168 #ifdef getc_unlocked
169 flockfile(uvfp[0]); flockfile(uvfp[1]);
170 #endif
171 }
172 } else {
173 ofp = fopen(create_component_file(0), "w");
174 if (ofp == NULL) {
175 fprintf(stderr, "%s: cannot create Y output file\n",
176 progname);
177 exit(1);
178 }
179 fputs("{\n", ofp);
180 if (rbf_colorimetry == RBCtristimulus) {
181 uvfp[0] = fopen(create_component_file(1), "w");
182 uvfp[1] = fopen(create_component_file(2), "w");
183 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
184 fprintf(stderr, "%s: cannot create uv output file(s)\n",
185 progname);
186 exit(1);
187 }
188 fputs("{\n", uvfp[0]);
189 fputs("{\n", uvfp[1]);
190 }
191 }
192 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
193 assignD = (fundefined(funame) < 6);
194 #if (NSSAMP > 0)
195 rtrip = (char *)calloc(sqres, 1); /* track sample triggerings */
196 ryval = (float *)calloc(sqres, sizeof(float));
197 #endif
198 /* run through directions */
199 for (ix = 0; ix < sqres/2; ix++) {
200 const int zipsgn = (ix & 1)*2 - 1;
201 RBFNODE *rbf = NULL;
202 iovec[0] = 2.*sqfact*(ix+.5) - 1.;
203 iovec[1] = zipsgn*sqfact*.5;
204 iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]
205 - iovec[1]*iovec[1]);
206 if (funame == NULL)
207 rbf = advect_rbf(iovec, lobe_lim);
208 for (ox = 0; ox < sqres; ox++) {
209 SDValue sdv_next;
210 SDsquare2disk(iovec+3, (ox+.5)*sqfact, .5*sqfact);
211 iovec[5] = output_orient *
212 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
213 if (funame == NULL) {
214 eval_rbfcol(&sdv_next, rbf, iovec+3);
215 } else {
216 sdv_next.spec = c_dfcolor;
217 if (assignD) {
218 varset("Dx", '=', -iovec[3]);
219 varset("Dy", '=', -iovec[4]);
220 varset("Dz", '=', -iovec[5]);
221 ++eclock;
222 }
223 sdv_next.cieY = funvalue(funame, 6, iovec);
224 }
225 for (oy = 0; oy < sqres; oy++) {
226 int trip;
227 bsdf = sdv_next.cieY; /* keeping one step ahead... */
228 if (oy < sqres-1) {
229 SDsquare2disk(iovec+3, (ox+.5)*sqfact, (oy+1.5)*sqfact);
230 iovec[5] = output_orient *
231 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
232 }
233 if (funame == NULL) {
234 SDValue sdv = sdv_next;
235 if (oy < sqres-1)
236 eval_rbfcol(&sdv_next, rbf, iovec+3);
237 #if (NSSAMP > 0)
238 trip = (abs_diff(bsdf, sdv_next.cieY) > ssamp_thresh ||
239 (ox && abs_diff(bsdf, ryval[oy]) > ssamp_thresh) ||
240 (oy && abs_diff(bsdf, ryval[oy-1]) > ssamp_thresh));
241 if (trip | rtrip[oy] || (oy && rtrip[oy-1])) {
242 int ssi;
243 double ssa[2], sum = 0, usum = 0, vsum = 0;
244 /* super-sample voxel */
245 for (ssi = NSSAMP; ssi--; ) {
246 SDmultiSamp(ssa, 2, (ssi+frandom()) *
247 (1./NSSAMP));
248 SDsquare2disk(iovec+3, (ox+ssa[0])*sqfact,
249 (oy+ssa[1])*sqfact);
250 iovec[5] = output_orient *
251 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
252 eval_rbfcol(&sdv, rbf, iovec+3);
253 sum += sdv.cieY;
254 if (rbf_colorimetry == RBCtristimulus) {
255 sdv.cieY /=
256 -2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.;
257 usum += 4.*sdv.spec.cx * sdv.cieY;
258 vsum += 9.*sdv.spec.cy * sdv.cieY;
259 }
260 }
261 bsdf = sum * (1./NSSAMP);
262 if (rbf_colorimetry == RBCtristimulus) {
263 uv[0] = usum / (sum+FTINY);
264 uv[1] = vsum / (sum+FTINY);
265 }
266 } else
267 #endif
268 if (rbf_colorimetry == RBCtristimulus) {
269 uv[0] = uv[1] = 1. /
270 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
271 uv[0] *= 4.*sdv.spec.cx;
272 uv[1] *= 9.*sdv.spec.cy;
273 }
274 } else {
275 if (oy < sqres-1) {
276 if (assignD) {
277 varset("Dx", '=', -iovec[3]);
278 varset("Dy", '=', -iovec[4]);
279 varset("Dz", '=', -iovec[5]);
280 ++eclock;
281 }
282 sdv_next.cieY = funvalue(funame, 6, iovec);
283 }
284 #if (NSSAMP > 0)
285 trip = (abs_diff(bsdf, sdv_next.cieY) > ssamp_thresh ||
286 (ox && abs_diff(bsdf, ryval[oy]) > ssamp_thresh) ||
287 (oy && abs_diff(bsdf, ryval[oy-1]) > ssamp_thresh));
288 if (trip | rtrip[oy] || (oy && rtrip[oy-1])) {
289 int ssi;
290 double ssa[4], ssvec[6], sum = 0;
291 /* super-sample voxel */
292 for (ssi = NSSAMP; ssi--; ) {
293 SDmultiSamp(ssa, 4, (ssi+frandom()) *
294 (1./NSSAMP));
295 ssvec[0] = 2.*sqfact*(ix+ssa[0]) - 1.;
296 ssvec[1] = zipsgn*sqfact*ssa[1];
297 ssvec[2] = 1. - ssvec[0]*ssvec[0]
298 - ssvec[1]*ssvec[1];
299 if (ssvec[2] < .0) {
300 ssvec[1] = 0;
301 ssvec[2] = 1. - ssvec[0]*ssvec[0];
302 }
303 ssvec[2] = input_orient * sqrt(ssvec[2]);
304 SDsquare2disk(ssvec+3, (ox+ssa[2])*sqfact,
305 (oy+ssa[3])*sqfact);
306 ssvec[5] = output_orient *
307 sqrt(1. - ssvec[3]*ssvec[3] -
308 ssvec[4]*ssvec[4]);
309 if (assignD) {
310 varset("Dx", '=', -ssvec[3]);
311 varset("Dy", '=', -ssvec[4]);
312 varset("Dz", '=', -ssvec[5]);
313 ++eclock;
314 }
315 sum += funvalue(funame, 6, ssvec);
316 }
317 bsdf = sum * (1./NSSAMP);
318 }
319 #endif
320 }
321 if (pctcull >= 0)
322 putbinary(&bsdf, sizeof(bsdf), 1, ofp);
323 else
324 fprintf(ofp, "\t%.3e\n", bsdf);
325
326 if (rbf_colorimetry == RBCtristimulus) {
327 if (pctcull >= 0) {
328 putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]);
329 putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]);
330 } else {
331 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
332 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
333 }
334 }
335 if (ryval != NULL) {
336 rtrip[oy] = trip;
337 ryval[oy] = bsdf;
338 }
339 }
340 }
341 if (rbf != NULL)
342 free(rbf);
343 prog_show((ix+1.)*(2.*sqfact));
344 }
345 prog_done();
346 if (ryval != NULL) {
347 free(rtrip);
348 free(ryval);
349 }
350 if (pctcull >= 0) { /* finish output */
351 if (pclose(ofp)) {
352 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
353 progname);
354 exit(1);
355 }
356 if (rbf_colorimetry == RBCtristimulus &&
357 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
358 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
359 progname);
360 exit(1);
361 }
362 } else {
363 for (ix = sqres*sqres*sqres/2; ix--; )
364 fputs("\t0\n", ofp);
365 fputs("}\n", ofp);
366 if (fclose(ofp)) {
367 fprintf(stderr, "%s: error writing Y file\n",
368 progname);
369 exit(1);
370 }
371 if (rbf_colorimetry == RBCtristimulus) {
372 for (ix = sqres*sqres*sqres/2; ix--; ) {
373 fputs("\t0\n", uvfp[0]);
374 fputs("\t0\n", uvfp[1]);
375 }
376 fputs("}\n", uvfp[0]);
377 fputs("}\n", uvfp[1]);
378 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
379 fprintf(stderr, "%s: error writing uv file(s)\n",
380 progname);
381 exit(1);
382 }
383 }
384 }
385 }
386
387 /* Interpolate and output anisotropic BSDF data */
388 static void
389 eval_anisotropic(char *funame)
390 {
391 const int sqres = 1<<samp_order;
392 const double sqfact = 1./(double)sqres;
393 float *ryval = NULL;
394 char *rtrip = NULL;
395 FILE *ofp, *uvfp[2];
396 int assignD = 0;
397 char cmd[128];
398 int ix, iy, ox, oy;
399 double iovec[6];
400 float bsdf, uv[2];
401
402 if (pctcull >= 0) {
403 const char *avgopt = (input_orient>0 ^ output_orient>0)
404 ? "" : recip;
405 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
406 avgopt, pctcull, samp_order,
407 create_component_file(0));
408 ofp = popen(cmd, "w");
409 if (ofp == NULL) {
410 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
411 progname);
412 exit(1);
413 }
414 SET_FILE_BINARY(ofp);
415 #ifdef getc_unlocked /* avoid lock/unlock overhead */
416 flockfile(ofp);
417 #endif
418 if (rbf_colorimetry == RBCtristimulus) {
419 double uvcull = 100. - (100.-pctcull)*.25;
420 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
421 avgopt, uvcull, samp_order,
422 create_component_file(1));
423 uvfp[0] = popen(cmd, "w");
424 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
425 avgopt, uvcull, samp_order,
426 create_component_file(2));
427 uvfp[1] = popen(cmd, "w");
428 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
429 fprintf(stderr, "%s: cannot open pipes to uv output\n",
430 progname);
431 exit(1);
432 }
433 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
434 #ifdef getc_unlocked
435 flockfile(uvfp[0]); flockfile(uvfp[1]);
436 #endif
437 }
438 } else {
439 ofp = fopen(create_component_file(0), "w");
440 if (ofp == NULL) {
441 fprintf(stderr, "%s: cannot create Y output file\n",
442 progname);
443 exit(1);
444 }
445 fputs("{\n", ofp);
446 if (rbf_colorimetry == RBCtristimulus) {
447 uvfp[0] = fopen(create_component_file(1), "w");
448 uvfp[1] = fopen(create_component_file(2), "w");
449 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
450 fprintf(stderr, "%s: cannot create uv output file(s)\n",
451 progname);
452 exit(1);
453 }
454 fputs("{\n", uvfp[0]);
455 fputs("{\n", uvfp[1]);
456 }
457 }
458 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
459 assignD = (fundefined(funame) < 6);
460 #if (NSSAMP > 0)
461 rtrip = (char *)calloc(sqres, 1); /* track sample triggerings */
462 ryval = (float *)calloc(sqres, sizeof(float));
463 #endif
464 /* run through directions */
465 for (ix = 0; ix < sqres; ix++)
466 for (iy = 0; iy < sqres; iy++) {
467 RBFNODE *rbf = NULL; /* Klems reversal */
468 SDsquare2disk(iovec, 1.-(ix+.5)*sqfact, 1.-(iy+.5)*sqfact);
469 iovec[2] = input_orient *
470 sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]);
471 if (funame == NULL)
472 rbf = advect_rbf(iovec, lobe_lim);
473 for (ox = 0; ox < sqres; ox++) {
474 SDValue sdv_next;
475 SDsquare2disk(iovec+3, (ox+.5)*sqfact, .5*sqfact);
476 iovec[5] = output_orient *
477 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
478 if (funame == NULL) {
479 eval_rbfcol(&sdv_next, rbf, iovec+3);
480 } else {
481 sdv_next.spec = c_dfcolor;
482 if (assignD) {
483 varset("Dx", '=', -iovec[3]);
484 varset("Dy", '=', -iovec[4]);
485 varset("Dz", '=', -iovec[5]);
486 ++eclock;
487 }
488 sdv_next.cieY = funvalue(funame, 6, iovec);
489 }
490 for (oy = 0; oy < sqres; oy++) {
491 int trip;
492 bsdf = sdv_next.cieY; /* keeping one step ahead... */
493 if (oy < sqres-1) {
494 SDsquare2disk(iovec+3, (ox+.5)*sqfact, (oy+1.5)*sqfact);
495 iovec[5] = output_orient *
496 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
497 }
498 if (funame == NULL) {
499 SDValue sdv = sdv_next;
500 if (oy < sqres-1)
501 eval_rbfcol(&sdv_next, rbf, iovec+3);
502 #if (NSSAMP > 0)
503 trip = (abs_diff(bsdf, sdv_next.cieY) > ssamp_thresh ||
504 (ox && abs_diff(bsdf, ryval[oy]) > ssamp_thresh) ||
505 (oy && abs_diff(bsdf, ryval[oy-1]) > ssamp_thresh));
506 if (trip | rtrip[oy] || (oy && rtrip[oy-1])) {
507 int ssi;
508 double ssa[2], sum = 0, usum = 0, vsum = 0;
509 /* super-sample voxel */
510 for (ssi = NSSAMP; ssi--; ) {
511 SDmultiSamp(ssa, 2, (ssi+frandom()) *
512 (1./NSSAMP));
513 SDsquare2disk(iovec+3, (ox+ssa[0])*sqfact,
514 (oy+ssa[1])*sqfact);
515 iovec[5] = output_orient *
516 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
517 eval_rbfcol(&sdv, rbf, iovec+3);
518 sum += sdv.cieY;
519 if (rbf_colorimetry == RBCtristimulus) {
520 sdv.cieY /=
521 -2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.;
522 usum += 4.*sdv.spec.cx * sdv.cieY;
523 vsum += 9.*sdv.spec.cy * sdv.cieY;
524 }
525 }
526 bsdf = sum * (1./NSSAMP);
527 if (rbf_colorimetry == RBCtristimulus) {
528 uv[0] = usum / (sum+FTINY);
529 uv[1] = vsum / (sum+FTINY);
530 }
531 } else
532 #endif
533 if (rbf_colorimetry == RBCtristimulus) {
534 uv[0] = uv[1] = 1. /
535 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
536 uv[0] *= 4.*sdv.spec.cx;
537 uv[1] *= 9.*sdv.spec.cy;
538 }
539 } else {
540 if (oy < sqres-1) {
541 if (assignD) {
542 varset("Dx", '=', -iovec[3]);
543 varset("Dy", '=', -iovec[4]);
544 varset("Dz", '=', -iovec[5]);
545 ++eclock;
546 }
547 sdv_next.cieY = funvalue(funame, 6, iovec);
548 }
549 #if (NSSAMP > 0)
550 trip = (abs_diff(bsdf, sdv_next.cieY) > ssamp_thresh ||
551 (ox && abs_diff(bsdf, ryval[oy]) > ssamp_thresh) ||
552 (oy && abs_diff(bsdf, ryval[oy-1]) > ssamp_thresh));
553 if (trip | rtrip[oy] || (oy && rtrip[oy-1])) {
554 int ssi;
555 double ssa[4], ssvec[6], sum = 0;
556 /* super-sample voxel */
557 for (ssi = NSSAMP; ssi--; ) {
558 SDmultiSamp(ssa, 4, (ssi+frandom()) *
559 (1./NSSAMP));
560 SDsquare2disk(ssvec, 1.-(ix+ssa[0])*sqfact,
561 1.-(iy+ssa[1])*sqfact);
562 ssvec[2] = input_orient *
563 sqrt(1. - ssvec[0]*ssvec[0] -
564 ssvec[1]*ssvec[1]);
565 SDsquare2disk(ssvec+3, (ox+ssa[2])*sqfact,
566 (oy+ssa[3])*sqfact);
567 ssvec[5] = output_orient *
568 sqrt(1. - ssvec[3]*ssvec[3] -
569 ssvec[4]*ssvec[4]);
570 if (assignD) {
571 varset("Dx", '=', -ssvec[3]);
572 varset("Dy", '=', -ssvec[4]);
573 varset("Dz", '=', -ssvec[5]);
574 ++eclock;
575 }
576 sum += funvalue(funame, 6, ssvec);
577 }
578 bsdf = sum * (1./NSSAMP);
579 }
580 #endif
581 }
582 if (pctcull >= 0)
583 putbinary(&bsdf, sizeof(bsdf), 1, ofp);
584 else
585 fprintf(ofp, "\t%.3e\n", bsdf);
586
587 if (rbf_colorimetry == RBCtristimulus) {
588 if (pctcull >= 0) {
589 putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]);
590 putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]);
591 } else {
592 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
593 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
594 }
595 }
596 if (ryval != NULL) {
597 rtrip[oy] = trip;
598 ryval[oy] = bsdf;
599 }
600 }
601 if (rbf != NULL)
602 free(rbf);
603 prog_show((ix*sqres+iy+1.)/(sqres*sqres));
604 }
605 }
606 prog_done();
607 if (ryval != NULL) {
608 free(rtrip);
609 free(ryval);
610 }
611 if (pctcull >= 0) { /* finish output */
612 if (pclose(ofp)) {
613 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
614 progname);
615 exit(1);
616 }
617 if (rbf_colorimetry == RBCtristimulus &&
618 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
619 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
620 progname);
621 exit(1);
622 }
623 } else {
624 fputs("}\n", ofp);
625 if (fclose(ofp)) {
626 fprintf(stderr, "%s: error writing Y file\n",
627 progname);
628 exit(1);
629 }
630 if (rbf_colorimetry == RBCtristimulus) {
631 fputs("}\n", uvfp[0]);
632 fputs("}\n", uvfp[1]);
633 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
634 fprintf(stderr, "%s: error writing uv file(s)\n",
635 progname);
636 exit(1);
637 }
638 }
639 }
640 }
641
642 #if defined(_WIN32) || defined(_WIN64)
643 /* Execute wrapBSDF command (may never return) */
644 static int
645 wrap_up(void)
646 {
647 char cmd[8192];
648
649 if (bsdf_manuf[0]) {
650 add_wbsdf("-f", 1);
651 strcpy(cmd, "m=");
652 strcpy(cmd+2, bsdf_manuf);
653 add_wbsdf(cmd, 0);
654 }
655 if (bsdf_name[0]) {
656 add_wbsdf("-f", 1);
657 strcpy(cmd, "n=");
658 strcpy(cmd+2, bsdf_name);
659 add_wbsdf(cmd, 0);
660 }
661 if (!convert_commandline(cmd, sizeof(cmd), wrapBSDF)) {
662 fputs(progname, stderr);
663 fputs(": command line too long in wrap_up()\n", stderr);
664 return(1);
665 }
666 return(system(cmd));
667 }
668 #else
669 /* Execute wrapBSDF command (may never return) */
670 static int
671 wrap_up(void)
672 {
673 char buf[256];
674 char *compath = getpath((char *)wrapBSDF[0], getenv("PATH"), X_OK);
675
676 if (compath == NULL) {
677 fprintf(stderr, "%s: cannot locate %s\n", progname, wrapBSDF[0]);
678 return(1);
679 }
680 if (bsdf_manuf[0]) {
681 add_wbsdf("-f", 1);
682 strcpy(buf, "m=");
683 strcpy(buf+2, bsdf_manuf);
684 add_wbsdf(buf, 0);
685 }
686 if (bsdf_name[0]) {
687 add_wbsdf("-f", 1);
688 strcpy(buf, "n=");
689 strcpy(buf+2, bsdf_name);
690 add_wbsdf(buf, 0);
691 }
692 execv(compath, wrapBSDF); /* successful call never returns */
693 perror(compath);
694 return(1);
695 }
696 #endif
697
698 /* Read in BSDF and interpolate as tensor tree representation */
699 int
700 main(int argc, char *argv[])
701 {
702 static char tfmt[2][4] = {"t4", "t3"};
703 int dofwd = 0, dobwd = 1;
704 char buf[2048];
705 int i, na;
706
707 progname = argv[0];
708 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
709 esupport &= ~(E_INCHAN|E_OUTCHAN);
710 scompile("PI:3.14159265358979323846", NULL, 0);
711 biggerlib();
712 for (i = 1; i < argc && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
713 switch (argv[i][1]) { /* get options */
714 case 'e':
715 scompile(argv[++i], NULL, 0);
716 if (single_plane_incident < 0)
717 single_plane_incident = 0;
718 break;
719 case 'f':
720 if (!argv[i][2]) {
721 if (strchr(argv[++i], '=') != NULL) {
722 add_wbsdf("-f", 1);
723 add_wbsdf(argv[i], 1);
724 } else {
725 char *fpath = getpath(argv[i],
726 getrlibpath(), 0);
727 if (fpath == NULL) {
728 fprintf(stderr,
729 "%s: cannot find file '%s'\n",
730 argv[0], argv[i]);
731 return(1);
732 }
733 fcompile(fpath);
734 if (single_plane_incident < 0)
735 single_plane_incident = 0;
736 }
737 } else
738 dofwd = (argv[i][0] == '+');
739 break;
740 case 'a':
741 recip = (argv[i][0] == '+') ? " -a" : "";
742 break;
743 case 'b':
744 dobwd = (argv[i][0] == '+');
745 break;
746 case 't':
747 switch (argv[i][2]) {
748 case '3':
749 single_plane_incident = 1;
750 break;
751 case '4':
752 single_plane_incident = 0;
753 break;
754 case '\0':
755 pctcull = atof(argv[++i]);
756 break;
757 default:
758 goto userr;
759 }
760 break;
761 case 'g':
762 samp_order = atoi(argv[++i]);
763 break;
764 case 'l':
765 lobe_lim = atoi(argv[++i]);
766 break;
767 case 'p':
768 do_prog = atoi(argv[i]+2);
769 break;
770 case 'W':
771 add_wbsdf(argv[i], 1);
772 break;
773 case 'u':
774 case 'C':
775 add_wbsdf(argv[i], 1);
776 add_wbsdf(argv[++i], 1);
777 break;
778 default:
779 goto userr;
780 }
781 strcpy(buf, "File produced by: ");
782 if (convert_commandline(buf+18, sizeof(buf)-18, argv) != NULL) {
783 add_wbsdf("-C", 1); add_wbsdf(buf, 0);
784 }
785 if (single_plane_incident >= 0) { /* function-based BSDF? */
786 void (*evf)(char *s) = single_plane_incident ?
787 eval_isotropic : eval_anisotropic;
788 if (i != argc-1 || fundefined(argv[i]) < 3) {
789 fprintf(stderr,
790 "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
791 progname);
792 fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n");
793 goto userr;
794 }
795 ++eclock;
796 add_wbsdf("-a", 1);
797 add_wbsdf(tfmt[single_plane_incident], 1);
798 if (dofwd) {
799 input_orient = -1;
800 output_orient = -1;
801 prog_start("Evaluating outside reflectance");
802 (*evf)(argv[i]);
803 output_orient = 1;
804 prog_start("Evaluating outside->inside transmission");
805 (*evf)(argv[i]);
806 }
807 if (dobwd) {
808 input_orient = 1;
809 output_orient = 1;
810 prog_start("Evaluating inside reflectance");
811 (*evf)(argv[i]);
812 output_orient = -1;
813 prog_start("Evaluating inside->outside transmission");
814 (*evf)(argv[i]);
815 }
816 return(wrap_up());
817 }
818 if (i < argc) { /* open input files if given */
819 int nbsdf = 0;
820 for ( ; i < argc; i++) { /* interpolate each component */
821 char pbuf[256];
822 FILE *fpin = fopen(argv[i], "rb");
823 if (fpin == NULL) {
824 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
825 progname, argv[i]);
826 return(1);
827 }
828 if (!load_bsdf_rep(fpin))
829 return(1);
830 fclose(fpin);
831 sprintf(pbuf, "Interpolating component '%s'", argv[i]);
832 prog_start(pbuf);
833 if (!nbsdf++) {
834 add_wbsdf("-a", 1);
835 add_wbsdf(tfmt[single_plane_incident], 1);
836 }
837 if (single_plane_incident)
838 eval_isotropic(NULL);
839 else
840 eval_anisotropic(NULL);
841 }
842 return(wrap_up());
843 }
844 SET_FILE_BINARY(stdin); /* load from stdin */
845 if (!load_bsdf_rep(stdin))
846 return(1);
847 prog_start("Interpolating from standard input");
848 add_wbsdf("-a", 1);
849 add_wbsdf(tfmt[single_plane_incident], 1);
850 if (single_plane_incident) /* resample dist. */
851 eval_isotropic(NULL);
852 else
853 eval_anisotropic(NULL);
854
855 return(wrap_up());
856 userr:
857 fprintf(stderr,
858 "Usage: %s [{+|-}a][-g Nlog2][-t pctcull][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n",
859 progname);
860 fprintf(stderr,
861 " or: %s -t{3|4} [{+|-}a][-g Nlog2][-t pctcull][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
862 progname);
863 return(1);
864 }
