root/radiance/ray/src/cv/bsdf2ttree.c
Revision: 2.35
Committed: Thu Feb 4 00:45:47 2016 UTC (8 years, 4 months ago) by greg
Changes since 2.34: +13 -13 lines
Minor cleanup and fixes
2 static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.34 2016/02/02 22:34:00 greg Exp $";
5 * Load measured BSDF interpolant and write out as XML file with tensor tree.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdio.h>
12 #include <stdlib.h>
13 #include <math.h>
14 #include "random.h"
15 #include "platform.h"
16 #include "paths.h"
17 #include "rtio.h"
18 #include "calcomp.h"
19 #include "bsdfrep.h"
20 /* global argv[0] */
21 char *progname;
22 /* percentage to cull (<0 to turn off) */
23 static double pctcull = 90.;
24 /* sampling order */
25 static int samp_order = 6;
26 /* super-sampling threshold */
27 const double ssamp_thresh = 0.35;
28 /* number of super-samples */
29 #ifndef NSSAMP
30 #define NSSAMP 100
31 #endif
32 /* limit on number of RBF lobes */
33 static int lobe_lim = 15000;
34 /* progress bar length */
35 static int do_prog = 79;
36
37 #define MAXCARG 512 /* wrapBSDF command */
38 static char *wrapBSDF[MAXCARG] = {"wrapBSDF", "-U"};
39 static int wbsdfac = 2;
40
41 /* Add argument to wrapBSDF, allocating space if isstatic */
42 static void
43 add_wbsdf(const char *arg, int isstatic)
44 {
45 if (arg == NULL)
46 return;
47 if (wbsdfac >= MAXCARG-1) {
48 fputs(progname, stderr);
49 fputs(": too many command arguments to wrapBSDF\n", stderr);
50 exit(1);
51 }
52 if (!*arg)
53 arg = "";
54 else if (!isstatic)
55 arg = savqstr((char *)arg);
56
57 wrapBSDF[wbsdfac++] = (char *)arg;
58 }
59
60 /* Create Yuv component file and add appropriate arguments */
61 static char *
62 create_component_file(int c)
63 {
64 static const char sname[3][6] = {"CIE-Y", "CIE-u", "CIE-v"};
65 static const char cname[4][4] = {"-rf", "-tf", "-tb", "-rb"};
66 char *tfname = mktemp(savqstr(TEMPLATE));
67
68 add_wbsdf("-s", 1); add_wbsdf(sname[c], 1);
69 add_wbsdf(cname[(input_orient>0)<<1 | (output_orient>0)], 1);
70 add_wbsdf(tfname, 1);
71 return(tfname);
72 }
73
74 /* Start new progress bar */
75 #define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else
76
77 /* Draw progress bar of the appropriate length */
78 static void
79 prog_show(double frac)
80 {
81 static unsigned call_cnt = 0;
82 static char lastc[] = "-\\|/";
83 char pbar[256];
84 int nchars;
85
86 if (do_prog <= 1) return;
87 if (do_prog > sizeof(pbar)-2)
88 do_prog = sizeof(pbar)-2;
89 if (frac < 0) frac = 0;
90 else if (frac >= 1) frac = .9999;
91 nchars = do_prog*frac;
92 pbar[0] = '\r';
93 memset(pbar+1, '*', nchars);
94 pbar[nchars+1] = lastc[call_cnt++ & 3];
95 memset(pbar+2+nchars, '-', do_prog-nchars-1);
96 pbar[do_prog+1] = '\0';
97 fputs(pbar, stderr);
98 }
99
100 /* Finish progress bar */
101 static void
102 prog_done(void)
103 {
104 int n = do_prog;
105
106 if (n <= 1) return;
107 fputc('\r', stderr);
108 while (n--)
109 fputc(' ', stderr);
110 fputc('\r', stderr);
111 }
112
113 /* Compute absolute relative difference */
114 static double
115 abs_diff(double v1, double v0)
116 {
117 if ((v0 < 0) | (v1 < 0))
118 return(.0);
119 v1 = (v1-v0)*2./(v0+v1+.0001);
120 if (v1 < 0)
121 return(-v1);
122 return(v1);
123 }
124
125 /* Interpolate and output isotropic BSDF data */
126 static void
127 eval_isotropic(char *funame)
128 {
129 const int sqres = 1<<samp_order;
130 FILE *ofp, *uvfp[2];
131 int assignD = 0;
132 char cmd[128];
133 int ix, ox, oy;
134 double iovec[6];
135 float bsdf, uv[2];
136
137 if (pctcull >= 0) {
138 sprintf(cmd, "rttree_reduce -a -h -ff -r 3 -t %f -g %d > %s",
139 pctcull, samp_order, create_component_file(0));
140 ofp = popen(cmd, "w");
141 if (ofp == NULL) {
142 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
143 progname);
144 exit(1);
145 }
146 SET_FILE_BINARY(ofp);
147 #ifdef getc_unlocked /* avoid lock/unlock overhead */
148 flockfile(ofp);
149 #endif
150 if (rbf_colorimetry == RBCtristimulus) {
151 double uvcull = 100. - (100.-pctcull)*.25;
152 sprintf(cmd, "rttree_reduce -a -h -ff -r 3 -t %f -g %d > %s",
153 uvcull, samp_order, create_component_file(1));
154 uvfp[0] = popen(cmd, "w");
155 sprintf(cmd, "rttree_reduce -a -h -ff -r 3 -t %f -g %d > %s",
156 uvcull, samp_order, create_component_file(2));
157 uvfp[1] = popen(cmd, "w");
158 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
159 fprintf(stderr, "%s: cannot open pipes to uv output\n",
160 progname);
161 exit(1);
162 }
163 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
164 #ifdef getc_unlocked
165 flockfile(uvfp[0]); flockfile(uvfp[1]);
166 #endif
167 }
168 } else {
169 ofp = fopen(create_component_file(0), "w");
170 if (ofp == NULL) {
171 fprintf(stderr, "%s: cannot create Y output file\n",
172 progname);
173 exit(1);
174 }
175 fputs("{\n", ofp);
176 if (rbf_colorimetry == RBCtristimulus) {
177 uvfp[0] = fopen(create_component_file(1), "w");
178 uvfp[1] = fopen(create_component_file(2), "w");
179 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
180 fprintf(stderr, "%s: cannot create uv output file(s)\n",
181 progname);
182 exit(1);
183 }
184 fputs("{\n", uvfp[0]);
185 fputs("{\n", uvfp[1]);
186 }
187 }
188 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
189 assignD = (fundefined(funame) < 6);
190 /* run through directions */
191 for (ix = 0; ix < sqres/2; ix++) {
192 RBFNODE *rbf = NULL;
193 iovec[0] = 2.*(ix+.5)/sqres - 1.;
194 iovec[1] = .0;
195 iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]);
196 if (funame == NULL)
197 rbf = advect_rbf(iovec, lobe_lim);
198 for (ox = 0; ox < sqres; ox++) {
199 float last_bsdf = -1;
200 for (oy = 0; oy < sqres; oy++) {
201 SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres);
202 iovec[5] = output_orient *
203 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
204 if (funame == NULL) {
205 SDValue sdv;
206 eval_rbfcol(&sdv, rbf, iovec+3);
207 bsdf = sdv.cieY;
208 if (rbf_colorimetry == RBCtristimulus) {
209 c_ccvt(&sdv.spec, C_CSXY);
210 uv[0] = uv[1] = 1. /
211 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
212 uv[0] *= 4.*sdv.spec.cx;
213 uv[1] *= 9.*sdv.spec.cy;
214 }
215 } else {
216 if (assignD) {
217 varset("Dx", '=', -iovec[3]);
218 varset("Dy", '=', -iovec[4]);
219 varset("Dz", '=', -iovec[5]);
220 ++eclock;
221 }
222 bsdf = funvalue(funame, 6, iovec);
223 #if (NSSAMP > 0)
224 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
225 int ssi;
226 double ssa[3], ssvec[6], sum = 0;
227 /* super-sample voxel */
228 for (ssi = NSSAMP; ssi--; ) {
229 SDmultiSamp(ssa, 3, (ssi+frandom()) *
230 (1./NSSAMP));
231 ssvec[0] = 2.*(ix+ssa[0])/sqres - 1.;
232 ssvec[1] = .0;
233 ssvec[2] = input_orient *
234 sqrt(1. - ssvec[0]*ssvec[0]);
235 SDsquare2disk(ssvec+3, (ox+ssa[1])/sqres,
236 (oy+ssa[2])/sqres);
237 ssvec[5] = output_orient *
238 sqrt(1. - ssvec[3]*ssvec[3] -
239 ssvec[4]*ssvec[4]);
240 if (assignD) {
241 varset("Dx", '=', -ssvec[3]);
242 varset("Dy", '=', -ssvec[4]);
243 varset("Dz", '=', -ssvec[5]);
244 ++eclock;
245 }
246 sum += funvalue(funame, 6, ssvec);
247 }
248 bsdf = sum/NSSAMP;
249 }
250 #endif
251 }
252 if (pctcull >= 0)
253 fwrite(&bsdf, sizeof(bsdf), 1, ofp);
254 else
255 fprintf(ofp, "\t%.3e\n", bsdf);
256
257 if (rbf_colorimetry == RBCtristimulus) {
258 if (pctcull >= 0) {
259 fwrite(&uv[0], sizeof(*uv), 1, uvfp[0]);
260 fwrite(&uv[1], sizeof(*uv), 1, uvfp[1]);
261 } else {
262 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
263 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
264 }
265 }
266 last_bsdf = bsdf;
267 }
268 }
269 if (rbf != NULL)
270 free(rbf);
271 prog_show((ix+1.)*(2./sqres));
272 }
273 prog_done();
274 if (pctcull >= 0) { /* finish output */
275 if (pclose(ofp)) {
276 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
277 progname);
278 exit(1);
279 }
280 if (rbf_colorimetry == RBCtristimulus &&
281 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
282 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
283 progname);
284 exit(1);
285 }
286 } else {
287 for (ix = sqres*sqres*sqres/2; ix--; )
288 fputs("\t0\n", ofp);
289 fputs("}\n", ofp);
290 if (fclose(ofp)) {
291 fprintf(stderr, "%s: error writing Y file\n",
292 progname);
293 exit(1);
294 }
295 if (rbf_colorimetry == RBCtristimulus) {
296 for (ix = sqres*sqres*sqres/2; ix--; ) {
297 fputs("\t0\n", uvfp[0]);
298 fputs("\t0\n", uvfp[1]);
299 }
300 fputs("}\n", uvfp[0]);
301 fputs("}\n", uvfp[1]);
302 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
303 fprintf(stderr, "%s: error writing uv file(s)\n",
304 progname);
305 exit(1);
306 }
307 }
308 }
309 }
310
311 /* Interpolate and output anisotropic BSDF data */
312 static void
313 eval_anisotropic(char *funame)
314 {
315 const int sqres = 1<<samp_order;
316 FILE *ofp, *uvfp[2];
317 int assignD = 0;
318 char cmd[128];
319 int ix, iy, ox, oy;
320 double iovec[6];
321 float bsdf, uv[2];
322
323 if (pctcull >= 0) {
324 const char *avgopt = (input_orient>0 ^ output_orient>0)
325 ? "" : " -a";
326 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
327 avgopt, pctcull, samp_order,
328 create_component_file(0));
329 ofp = popen(cmd, "w");
330 if (ofp == NULL) {
331 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
332 progname);
333 exit(1);
334 }
335 SET_FILE_BINARY(ofp);
336 #ifdef getc_unlocked /* avoid lock/unlock overhead */
337 flockfile(ofp);
338 #endif
339 if (rbf_colorimetry == RBCtristimulus) {
340 double uvcull = 100. - (100.-pctcull)*.25;
341 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
342 avgopt, uvcull, samp_order,
343 create_component_file(1));
344 uvfp[0] = popen(cmd, "w");
345 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
346 avgopt, uvcull, samp_order,
347 create_component_file(2));
348 uvfp[1] = popen(cmd, "w");
349 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
350 fprintf(stderr, "%s: cannot open pipes to uv output\n",
351 progname);
352 exit(1);
353 }
354 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
355 #ifdef getc_unlocked
356 flockfile(uvfp[0]); flockfile(uvfp[1]);
357 #endif
358 }
359 } else {
360 ofp = fopen(create_component_file(0), "w");
361 if (ofp == NULL) {
362 fprintf(stderr, "%s: cannot create Y output file\n",
363 progname);
364 exit(1);
365 }
366 fputs("{\n", ofp);
367 if (rbf_colorimetry == RBCtristimulus) {
368 uvfp[0] = fopen(create_component_file(1), "w");
369 uvfp[1] = fopen(create_component_file(2), "w");
370 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
371 fprintf(stderr, "%s: cannot create uv output file(s)\n",
372 progname);
373 exit(1);
374 }
375 fputs("{\n", uvfp[0]);
376 fputs("{\n", uvfp[1]);
377 }
378 }
379 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
380 assignD = (fundefined(funame) < 6);
381 /* run through directions */
382 for (ix = 0; ix < sqres; ix++)
383 for (iy = 0; iy < sqres; iy++) {
384 RBFNODE *rbf = NULL; /* Klems reversal */
385 SDsquare2disk(iovec, 1.-(ix+.5)/sqres, 1.-(iy+.5)/sqres);
386 iovec[2] = input_orient *
387 sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]);
388 if (funame == NULL)
389 rbf = advect_rbf(iovec, lobe_lim);
390 for (ox = 0; ox < sqres; ox++) {
391 float last_bsdf = -1;
392 for (oy = 0; oy < sqres; oy++) {
393 SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres);
394 iovec[5] = output_orient *
395 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
396 if (funame == NULL) {
397 SDValue sdv;
398 eval_rbfcol(&sdv, rbf, iovec+3);
399 bsdf = sdv.cieY;
400 if (rbf_colorimetry == RBCtristimulus) {
401 c_ccvt(&sdv.spec, C_CSXY);
402 uv[0] = uv[1] = 1. /
403 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
404 uv[0] *= 4.*sdv.spec.cx;
405 uv[1] *= 9.*sdv.spec.cy;
406 }
407 } else {
408 if (assignD) {
409 varset("Dx", '=', -iovec[3]);
410 varset("Dy", '=', -iovec[4]);
411 varset("Dz", '=', -iovec[5]);
412 ++eclock;
413 }
414 bsdf = funvalue(funame, 6, iovec);
415 #if (NSSAMP > 0)
416 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
417 int ssi;
418 double ssa[4], ssvec[6], sum = 0;
419 /* super-sample voxel */
420 for (ssi = NSSAMP; ssi--; ) {
421 SDmultiSamp(ssa, 4, (ssi+frandom()) *
422 (1./NSSAMP));
423 SDsquare2disk(ssvec, 1.-(ix+ssa[0])/sqres,
424 1.-(iy+ssa[1])/sqres);
425 ssvec[2] = input_orient *
426 sqrt(1. - ssvec[0]*ssvec[0] -
427 ssvec[1]*ssvec[1]);
428 SDsquare2disk(ssvec+3, (ox+ssa[2])/sqres,
429 (oy+ssa[3])/sqres);
430 ssvec[5] = output_orient *
431 sqrt(1. - ssvec[3]*ssvec[3] -
432 ssvec[4]*ssvec[4]);
433 if (assignD) {
434 varset("Dx", '=', -ssvec[3]);
435 varset("Dy", '=', -ssvec[4]);
436 varset("Dz", '=', -ssvec[5]);
437 ++eclock;
438 }
439 sum += funvalue(funame, 6, ssvec);
440 }
441 bsdf = sum/NSSAMP;
442 }
443 #endif
444 }
445 if (pctcull >= 0)
446 fwrite(&bsdf, sizeof(bsdf), 1, ofp);
447 else
448 fprintf(ofp, "\t%.3e\n", bsdf);
449
450 if (rbf_colorimetry == RBCtristimulus) {
451 if (pctcull >= 0) {
452 fwrite(&uv[0], sizeof(*uv), 1, uvfp[0]);
453 fwrite(&uv[1], sizeof(*uv), 1, uvfp[1]);
454 } else {
455 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
456 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
457 }
458 }
459 last_bsdf = bsdf;
460 }
461 }
462 if (rbf != NULL)
463 free(rbf);
464 prog_show((ix*sqres+iy+1.)/(sqres*sqres));
465 }
466 prog_done();
467 if (pctcull >= 0) { /* finish output */
468 if (pclose(ofp)) {
469 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
470 progname);
471 exit(1);
472 }
473 if (rbf_colorimetry == RBCtristimulus &&
474 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
475 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
476 progname);
477 exit(1);
478 }
479 } else {
480 fputs("}\n", ofp);
481 if (fclose(ofp)) {
482 fprintf(stderr, "%s: error writing Y file\n",
483 progname);
484 exit(1);
485 }
486 if (rbf_colorimetry == RBCtristimulus) {
487 fputs("}\n", uvfp[0]);
488 fputs("}\n", uvfp[1]);
489 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
490 fprintf(stderr, "%s: error writing uv file(s)\n",
491 progname);
492 exit(1);
493 }
494 }
495 }
496 }
497
498 #ifdef _WIN32
499 /* Execute wrapBSDF command (may never return) */
500 static int
501 wrap_up(void)
502 {
503 char cmd[8192];
504
505 if (bsdf_manuf[0]) {
506 add_wbsdf("-f", 1);
507 strcpy(cmd, "m=");
508 strcpy(cmd+2, bsdf_manuf);
509 add_wbsdf(cmd, 0);
510 }
511 if (bsdf_name[0]) {
512 add_wbsdf("-f", 1);
513 strcpy(cmd, "n=");
514 strcpy(cmd+2, bsdf_name);
515 add_wbsdf(cmd, 0);
516 }
517 if (!convert_commandline(cmd, sizeof(cmd), wrapBSDF)) {
518 fputs(progname, stderr);
519 fputs(": command line too long in wrap_up()\n", stderr);
520 return(1);
521 }
522 return(system(cmd));
523 }
524 #else
525 /* Execute wrapBSDF command (may never return) */
526 static int
527 wrap_up(void)
528 {
529 char buf[256];
530 char *compath = getpath((char *)wrapBSDF[0], getenv("PATH"), X_OK);
531
532 if (compath == NULL) {
533 fprintf(stderr, "%s: cannot locate %s\n", progname, wrapBSDF[0]);
534 return(1);
535 }
536 if (bsdf_manuf[0]) {
537 add_wbsdf("-f", 1);
538 strcpy(buf, "m=");
539 strcpy(buf+2, bsdf_manuf);
540 add_wbsdf(buf, 0);
541 }
542 if (bsdf_name[0]) {
543 add_wbsdf("-f", 1);
544 strcpy(buf, "n=");
545 strcpy(buf+2, bsdf_name);
546 add_wbsdf(buf, 0);
547 }
548 execv(compath, wrapBSDF); /* successful call never returns */
549 perror(compath);
550 return(1);
551 }
552 #endif
553
554 /* Read in BSDF and interpolate as tensor tree representation */
555 int
556 main(int argc, char *argv[])
557 {
558 static char tfmt[2][4] = {"t4", "t3"};
559 int dofwd = 0, dobwd = 1;
560 char buf[2048];
561 int i, na;
562
563 progname = argv[0];
564 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
565 esupport &= ~(E_INCHAN|E_OUTCHAN);
566 scompile("PI:3.14159265358979323846", NULL, 0);
567 biggerlib();
568 for (i = 1; i < argc-1 && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
569 switch (argv[i][1]) { /* get options */
570 case 'e':
571 scompile(argv[++i], NULL, 0);
572 break;
573 case 'f':
574 if (!argv[i][2]) {
575 if (strchr(argv[++i], '=') != NULL) {
576 add_wbsdf("-f", 1);
577 add_wbsdf(argv[i], 1);
578 } else
579 fcompile(argv[i]);
580 } else
581 dofwd = (argv[i][0] == '+');
582 break;
583 case 'b':
584 dobwd = (argv[i][0] == '+');
585 break;
586 case 't':
587 switch (argv[i][2]) {
588 case '3':
589 single_plane_incident = 1;
590 break;
591 case '4':
592 single_plane_incident = 0;
593 break;
594 case '\0':
595 pctcull = atof(argv[++i]);
596 break;
597 default:
598 goto userr;
599 }
600 break;
601 case 'g':
602 samp_order = atoi(argv[++i]);
603 break;
604 case 'l':
605 lobe_lim = atoi(argv[++i]);
606 break;
607 case 'p':
608 do_prog = atoi(argv[i]+2);
609 break;
610 case 'W':
611 add_wbsdf(argv[i], 1);
612 break;
613 case 'u':
614 case 'C':
615 add_wbsdf(argv[i], 1);
616 add_wbsdf(argv[++i], 1);
617 break;
618 default:
619 goto userr;
620 }
621 strcpy(buf, "File produced by: ");
622 if (convert_commandline(buf+18, sizeof(buf)-18, argv) != NULL) {
623 add_wbsdf("-C", 1); add_wbsdf(buf, 0);
624 }
625 if (single_plane_incident >= 0) { /* function-based BSDF? */
626 void (*evf)(char *s) = single_plane_incident ?
627 eval_isotropic : eval_anisotropic;
628 if (i != argc-1 || fundefined(argv[i]) < 3) {
629 fprintf(stderr,
630 "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
631 progname);
632 fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n");
633 goto userr;
634 }
635 ++eclock;
636 add_wbsdf("-a", 1);
637 add_wbsdf(tfmt[single_plane_incident], 1);
638 if (dofwd) {
639 input_orient = -1;
640 output_orient = -1;
641 prog_start("Evaluating outside reflectance");
642 (*evf)(argv[i]);
643 output_orient = 1;
644 prog_start("Evaluating outside->inside transmission");
645 (*evf)(argv[i]);
646 }
647 if (dobwd) {
648 input_orient = 1;
649 output_orient = 1;
650 prog_start("Evaluating inside reflectance");
651 (*evf)(argv[i]);
652 output_orient = -1;
653 prog_start("Evaluating inside->outside transmission");
654 (*evf)(argv[i]);
655 }
656 return(wrap_up());
657 }
658 if (i < argc) { /* open input files if given */
659 int nbsdf = 0;
660 for ( ; i < argc; i++) { /* interpolate each component */
661 char pbuf[256];
662 FILE *fpin = fopen(argv[i], "rb");
663 if (fpin == NULL) {
664 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
665 progname, argv[i]);
666 return(1);
667 }
668 if (!load_bsdf_rep(fpin))
669 return(1);
670 fclose(fpin);
671 sprintf(pbuf, "Interpolating component '%s'", argv[i]);
672 prog_start(pbuf);
673 if (!nbsdf++) {
674 add_wbsdf("-a", 1);
675 add_wbsdf(tfmt[single_plane_incident], 1);
676 }
677 if (single_plane_incident)
678 eval_isotropic(NULL);
679 else
680 eval_anisotropic(NULL);
681 }
682 return(wrap_up());
683 }
684 SET_FILE_BINARY(stdin); /* load from stdin */
685 if (!load_bsdf_rep(stdin))
686 return(1);
687 prog_start("Interpolating from standard input");
688 add_wbsdf("-a", 1);
689 add_wbsdf(tfmt[single_plane_incident], 1);
690 if (single_plane_incident) /* resample dist. */
691 eval_isotropic(NULL);
692 else
693 eval_anisotropic(NULL);
694
695 return(wrap_up());
696 userr:
697 fprintf(stderr,
698 "Usage: %s [-g Nlog2][-t pctcull][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n",
699 progname);
700 fprintf(stderr,
701 " or: %s -t{3|4} [-g Nlog2][-t pctcull][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
702 progname);
703 return(1);
704 }
