root/radiance/ray/src/cv/bsdf2ttree.c
Revision: 2.41
Committed: Wed May 31 17:25:21 2017 UTC (7 years, 11 months ago) by greg
Changes since 2.40: +16 -11 lines
2 static const char RCSid[] = "$Id: bsdf2ttree.c,v 2.40 2017/02/17 22:31:49 greg Exp $";
5 * Load measured BSDF interpolant and write out as XML file with tensor tree.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdio.h>
12 #include <stdlib.h>
13 #include <math.h>
14 #include "random.h"
15 #include "platform.h"
16 #include "paths.h"
17 #include "rtio.h"
18 #include "calcomp.h"
19 #include "bsdfrep.h"
20 /* global argv[0] */
21 char *progname;
22 /* reciprocity averaging option */
23 static const char *recip = " -a";
24 /* percentage to cull (<0 to turn off) */
25 static double pctcull = 90.;
26 /* sampling order */
27 static int samp_order = 6;
28 /* super-sampling threshold */
29 const double ssamp_thresh = 0.35;
30 /* number of super-samples */
31 #ifndef NSSAMP
32 #define NSSAMP 64
33 #endif
34 /* limit on number of RBF lobes */
35 static int lobe_lim = 15000;
36 /* progress bar length */
37 static int do_prog = 79;
38
39 #define MAXCARG 512 /* wrapBSDF command */
40 static char *wrapBSDF[MAXCARG] = {"wrapBSDF", "-U"};
41 static int wbsdfac = 2;
42
43 /* Add argument to wrapBSDF, allocating space if !isstatic */
44 static void
45 add_wbsdf(const char *arg, int isstatic)
46 {
47 if (arg == NULL)
48 return;
49 if (wbsdfac >= MAXCARG-1) {
50 fputs(progname, stderr);
51 fputs(": too many command arguments to wrapBSDF\n", stderr);
52 exit(1);
53 }
54 if (!*arg)
55 arg = "";
56 else if (!isstatic)
57 arg = savqstr((char *)arg);
58
59 wrapBSDF[wbsdfac++] = (char *)arg;
60 }
61
62 /* Create Yuv component file and add appropriate arguments */
63 static char *
64 create_component_file(int c)
65 {
66 static const char sname[3][6] = {"CIE-Y", "CIE-u", "CIE-v"};
67 static const char cname[4][4] = {"-rf", "-tf", "-tb", "-rb"};
68 char *tfname = mktemp(savqstr(TEMPLATE));
69
70 add_wbsdf("-s", 1); add_wbsdf(sname[c], 1);
71 add_wbsdf(cname[(input_orient>0)<<1 | (output_orient>0)], 1);
72 add_wbsdf(tfname, 1);
73 return(tfname);
74 }
75
76 /* Start new progress bar */
77 #define prog_start(s) if (do_prog) fprintf(stderr, "%s: %s...\n", progname, s); else
78
79 /* Draw progress bar of the appropriate length */
80 static void
81 prog_show(double frac)
82 {
83 static unsigned call_cnt = 0;
84 static char lastc[] = "-\\|/";
85 char pbar[256];
86 int nchars;
87
88 if (do_prog <= 1) return;
89 if (do_prog > sizeof(pbar)-2)
90 do_prog = sizeof(pbar)-2;
91 if (frac < 0) frac = 0;
92 else if (frac >= 1) frac = .9999;
93 nchars = do_prog*frac;
94 pbar[0] = '\r';
95 memset(pbar+1, '*', nchars);
96 pbar[nchars+1] = lastc[call_cnt++ & 3];
97 memset(pbar+2+nchars, '-', do_prog-nchars-1);
98 pbar[do_prog+1] = '\0';
99 fputs(pbar, stderr);
100 }
101
102 /* Finish progress bar */
103 static void
104 prog_done(void)
105 {
106 int n = do_prog;
107
108 if (n <= 1) return;
109 fputc('\r', stderr);
110 while (n--)
111 fputc(' ', stderr);
112 fputc('\r', stderr);
113 }
114
115 /* Compute absolute relative difference */
116 static double
117 abs_diff(double v1, double v0)
118 {
119 if ((v0 < 0) | (v1 < 0))
120 return(.0);
121 v1 = (v1-v0)*2./(v0+v1+.0001);
122 if (v1 < 0)
123 return(-v1);
124 return(v1);
125 }
126
127 /* Interpolate and output isotropic BSDF data */
128 static void
129 eval_isotropic(char *funame)
130 {
131 const int sqres = 1<<samp_order;
132 FILE *ofp, *uvfp[2];
133 int assignD = 0;
134 char cmd[128];
135 int ix, ox, oy;
136 double iovec[6];
137 float bsdf, uv[2];
138
139 if (pctcull >= 0) {
140 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
141 recip, pctcull, samp_order, create_component_file(0));
142 ofp = popen(cmd, "w");
143 if (ofp == NULL) {
144 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
145 progname);
146 exit(1);
147 }
148 SET_FILE_BINARY(ofp);
149 #ifdef getc_unlocked /* avoid lock/unlock overhead */
150 flockfile(ofp);
151 #endif
152 if (rbf_colorimetry == RBCtristimulus) {
153 double uvcull = 100. - (100.-pctcull)*.25;
154 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
155 recip, uvcull, samp_order, create_component_file(1));
156 uvfp[0] = popen(cmd, "w");
157 sprintf(cmd, "rttree_reduce%s -h -ff -r 3 -t %f -g %d > %s",
158 recip, uvcull, samp_order, create_component_file(2));
159 uvfp[1] = popen(cmd, "w");
160 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
161 fprintf(stderr, "%s: cannot open pipes to uv output\n",
162 progname);
163 exit(1);
164 }
165 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
166 #ifdef getc_unlocked
167 flockfile(uvfp[0]); flockfile(uvfp[1]);
168 #endif
169 }
170 } else {
171 ofp = fopen(create_component_file(0), "w");
172 if (ofp == NULL) {
173 fprintf(stderr, "%s: cannot create Y output file\n",
174 progname);
175 exit(1);
176 }
177 fputs("{\n", ofp);
178 if (rbf_colorimetry == RBCtristimulus) {
179 uvfp[0] = fopen(create_component_file(1), "w");
180 uvfp[1] = fopen(create_component_file(2), "w");
181 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
182 fprintf(stderr, "%s: cannot create uv output file(s)\n",
183 progname);
184 exit(1);
185 }
186 fputs("{\n", uvfp[0]);
187 fputs("{\n", uvfp[1]);
188 }
189 }
190 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
191 assignD = (fundefined(funame) < 6);
192 /* run through directions */
193 for (ix = 0; ix < sqres/2; ix++) {
194 RBFNODE *rbf = NULL;
195 iovec[0] = 2.*(ix+.5)/sqres - 1.;
196 iovec[1] = .0;
197 iovec[2] = input_orient * sqrt(1. - iovec[0]*iovec[0]);
198 if (funame == NULL)
199 rbf = advect_rbf(iovec, lobe_lim);
200 for (ox = 0; ox < sqres; ox++) {
201 float last_bsdf = -1;
202 for (oy = 0; oy < sqres; oy++) {
203 SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres);
204 iovec[5] = output_orient *
205 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
206 if (funame == NULL) {
207 SDValue sdv;
208 eval_rbfcol(&sdv, rbf, iovec+3);
209 bsdf = sdv.cieY;
210 if (rbf_colorimetry == RBCtristimulus) {
211 uv[0] = uv[1] = 1. /
212 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
213 uv[0] *= 4.*sdv.spec.cx;
214 uv[1] *= 9.*sdv.spec.cy;
215 }
216 } else {
217 if (assignD) {
218 varset("Dx", '=', -iovec[3]);
219 varset("Dy", '=', -iovec[4]);
220 varset("Dz", '=', -iovec[5]);
221 ++eclock;
222 }
223 bsdf = funvalue(funame, 6, iovec);
224 #if (NSSAMP > 0)
225 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
226 int ssi;
227 double ssa[3], ssvec[6], sum = 0;
228 /* super-sample voxel */
229 for (ssi = NSSAMP; ssi--; ) {
230 SDmultiSamp(ssa, 3, (ssi+frandom()) *
231 (1./NSSAMP));
232 ssvec[0] = 2.*(ix+ssa[0])/sqres - 1.;
233 ssvec[1] = .0;
234 ssvec[2] = input_orient *
235 sqrt(1. - ssvec[0]*ssvec[0]);
236 SDsquare2disk(ssvec+3, (ox+ssa[1])/sqres,
237 (oy+ssa[2])/sqres);
238 ssvec[5] = output_orient *
239 sqrt(1. - ssvec[3]*ssvec[3] -
240 ssvec[4]*ssvec[4]);
241 if (assignD) {
242 varset("Dx", '=', -ssvec[3]);
243 varset("Dy", '=', -ssvec[4]);
244 varset("Dz", '=', -ssvec[5]);
245 ++eclock;
246 }
247 sum += funvalue(funame, 6, ssvec);
248 }
249 bsdf = sum/NSSAMP;
250 }
251 #endif
252 }
253 if (pctcull >= 0)
254 putbinary(&bsdf, sizeof(bsdf), 1, ofp);
255 else
256 fprintf(ofp, "\t%.3e\n", bsdf);
257
258 if (rbf_colorimetry == RBCtristimulus) {
259 if (pctcull >= 0) {
260 putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]);
261 putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]);
262 } else {
263 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
264 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
265 }
266 }
267 last_bsdf = bsdf;
268 }
269 }
270 if (rbf != NULL)
271 free(rbf);
272 prog_show((ix+1.)*(2./sqres));
273 }
274 prog_done();
275 if (pctcull >= 0) { /* finish output */
276 if (pclose(ofp)) {
277 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
278 progname);
279 exit(1);
280 }
281 if (rbf_colorimetry == RBCtristimulus &&
282 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
283 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
284 progname);
285 exit(1);
286 }
287 } else {
288 for (ix = sqres*sqres*sqres/2; ix--; )
289 fputs("\t0\n", ofp);
290 fputs("}\n", ofp);
291 if (fclose(ofp)) {
292 fprintf(stderr, "%s: error writing Y file\n",
293 progname);
294 exit(1);
295 }
296 if (rbf_colorimetry == RBCtristimulus) {
297 for (ix = sqres*sqres*sqres/2; ix--; ) {
298 fputs("\t0\n", uvfp[0]);
299 fputs("\t0\n", uvfp[1]);
300 }
301 fputs("}\n", uvfp[0]);
302 fputs("}\n", uvfp[1]);
303 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
304 fprintf(stderr, "%s: error writing uv file(s)\n",
305 progname);
306 exit(1);
307 }
308 }
309 }
310 }
311
312 /* Interpolate and output anisotropic BSDF data */
313 static void
314 eval_anisotropic(char *funame)
315 {
316 const int sqres = 1<<samp_order;
317 FILE *ofp, *uvfp[2];
318 int assignD = 0;
319 char cmd[128];
320 int ix, iy, ox, oy;
321 double iovec[6];
322 float bsdf, uv[2];
323
324 if (pctcull >= 0) {
325 const char *avgopt = (input_orient>0 ^ output_orient>0)
326 ? "" : recip;
327 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
328 avgopt, pctcull, samp_order,
329 create_component_file(0));
330 ofp = popen(cmd, "w");
331 if (ofp == NULL) {
332 fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
333 progname);
334 exit(1);
335 }
336 SET_FILE_BINARY(ofp);
337 #ifdef getc_unlocked /* avoid lock/unlock overhead */
338 flockfile(ofp);
339 #endif
340 if (rbf_colorimetry == RBCtristimulus) {
341 double uvcull = 100. - (100.-pctcull)*.25;
342 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
343 avgopt, uvcull, samp_order,
344 create_component_file(1));
345 uvfp[0] = popen(cmd, "w");
346 sprintf(cmd, "rttree_reduce%s -h -ff -r 4 -t %f -g %d > %s",
347 avgopt, uvcull, samp_order,
348 create_component_file(2));
349 uvfp[1] = popen(cmd, "w");
350 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
351 fprintf(stderr, "%s: cannot open pipes to uv output\n",
352 progname);
353 exit(1);
354 }
355 SET_FILE_BINARY(uvfp[0]); SET_FILE_BINARY(uvfp[1]);
356 #ifdef getc_unlocked
357 flockfile(uvfp[0]); flockfile(uvfp[1]);
358 #endif
359 }
360 } else {
361 ofp = fopen(create_component_file(0), "w");
362 if (ofp == NULL) {
363 fprintf(stderr, "%s: cannot create Y output file\n",
364 progname);
365 exit(1);
366 }
367 fputs("{\n", ofp);
368 if (rbf_colorimetry == RBCtristimulus) {
369 uvfp[0] = fopen(create_component_file(1), "w");
370 uvfp[1] = fopen(create_component_file(2), "w");
371 if ((uvfp[0] == NULL) | (uvfp[1] == NULL)) {
372 fprintf(stderr, "%s: cannot create uv output file(s)\n",
373 progname);
374 exit(1);
375 }
376 fputs("{\n", uvfp[0]);
377 fputs("{\n", uvfp[1]);
378 }
379 }
380 if (funame != NULL) /* need to assign Dx, Dy, Dz? */
381 assignD = (fundefined(funame) < 6);
382 /* run through directions */
383 for (ix = 0; ix < sqres; ix++)
384 for (iy = 0; iy < sqres; iy++) {
385 RBFNODE *rbf = NULL; /* Klems reversal */
386 SDsquare2disk(iovec, 1.-(ix+.5)/sqres, 1.-(iy+.5)/sqres);
387 iovec[2] = input_orient *
388 sqrt(1. - iovec[0]*iovec[0] - iovec[1]*iovec[1]);
389 if (funame == NULL)
390 rbf = advect_rbf(iovec, lobe_lim);
391 for (ox = 0; ox < sqres; ox++) {
392 float last_bsdf = -1;
393 for (oy = 0; oy < sqres; oy++) {
394 SDsquare2disk(iovec+3, (ox+.5)/sqres, (oy+.5)/sqres);
395 iovec[5] = output_orient *
396 sqrt(1. - iovec[3]*iovec[3] - iovec[4]*iovec[4]);
397 if (funame == NULL) {
398 SDValue sdv;
399 eval_rbfcol(&sdv, rbf, iovec+3);
400 bsdf = sdv.cieY;
401 if (rbf_colorimetry == RBCtristimulus) {
402 uv[0] = uv[1] = 1. /
403 (-2.*sdv.spec.cx + 12.*sdv.spec.cy + 3.);
404 uv[0] *= 4.*sdv.spec.cx;
405 uv[1] *= 9.*sdv.spec.cy;
406 }
407 } else {
408 if (assignD) {
409 varset("Dx", '=', -iovec[3]);
410 varset("Dy", '=', -iovec[4]);
411 varset("Dz", '=', -iovec[5]);
412 ++eclock;
413 }
414 bsdf = funvalue(funame, 6, iovec);
415 #if (NSSAMP > 0)
416 if (abs_diff(bsdf, last_bsdf) > ssamp_thresh) {
417 int ssi;
418 double ssa[4], ssvec[6], sum = 0;
419 /* super-sample voxel */
420 for (ssi = NSSAMP; ssi--; ) {
421 SDmultiSamp(ssa, 4, (ssi+frandom()) *
422 (1./NSSAMP));
423 SDsquare2disk(ssvec, 1.-(ix+ssa[0])/sqres,
424 1.-(iy+ssa[1])/sqres);
425 ssvec[2] = input_orient *
426 sqrt(1. - ssvec[0]*ssvec[0] -
427 ssvec[1]*ssvec[1]);
428 SDsquare2disk(ssvec+3, (ox+ssa[2])/sqres,
429 (oy+ssa[3])/sqres);
430 ssvec[5] = output_orient *
431 sqrt(1. - ssvec[3]*ssvec[3] -
432 ssvec[4]*ssvec[4]);
433 if (assignD) {
434 varset("Dx", '=', -ssvec[3]);
435 varset("Dy", '=', -ssvec[4]);
436 varset("Dz", '=', -ssvec[5]);
437 ++eclock;
438 }
439 sum += funvalue(funame, 6, ssvec);
440 }
441 bsdf = sum/NSSAMP;
442 }
443 #endif
444 }
445 if (pctcull >= 0)
446 putbinary(&bsdf, sizeof(bsdf), 1, ofp);
447 else
448 fprintf(ofp, "\t%.3e\n", bsdf);
449
450 if (rbf_colorimetry == RBCtristimulus) {
451 if (pctcull >= 0) {
452 putbinary(&uv[0], sizeof(*uv), 1, uvfp[0]);
453 putbinary(&uv[1], sizeof(*uv), 1, uvfp[1]);
454 } else {
455 fprintf(uvfp[0], "\t%.3e\n", uv[0]);
456 fprintf(uvfp[1], "\t%.3e\n", uv[1]);
457 }
458 }
459 last_bsdf = bsdf;
460 }
461 }
462 if (rbf != NULL)
463 free(rbf);
464 prog_show((ix*sqres+iy+1.)/(sqres*sqres));
465 }
466 prog_done();
467 if (pctcull >= 0) { /* finish output */
468 if (pclose(ofp)) {
469 fprintf(stderr, "%s: error running rttree_reduce on Y\n",
470 progname);
471 exit(1);
472 }
473 if (rbf_colorimetry == RBCtristimulus &&
474 (pclose(uvfp[0]) || pclose(uvfp[1]))) {
475 fprintf(stderr, "%s: error running rttree_reduce on uv\n",
476 progname);
477 exit(1);
478 }
479 } else {
480 fputs("}\n", ofp);
481 if (fclose(ofp)) {
482 fprintf(stderr, "%s: error writing Y file\n",
483 progname);
484 exit(1);
485 }
486 if (rbf_colorimetry == RBCtristimulus) {
487 fputs("}\n", uvfp[0]);
488 fputs("}\n", uvfp[1]);
489 if (fclose(uvfp[0]) || fclose(uvfp[1])) {
490 fprintf(stderr, "%s: error writing uv file(s)\n",
491 progname);
492 exit(1);
493 }
494 }
495 }
496 }
497
498 #if defined(_WIN32) || defined(_WIN64)
499 /* Execute wrapBSDF command (may never return) */
500 static int
501 wrap_up(void)
502 {
503 char cmd[8192];
504
505 if (bsdf_manuf[0]) {
506 add_wbsdf("-f", 1);
507 strcpy(cmd, "m=");
508 strcpy(cmd+2, bsdf_manuf);
509 add_wbsdf(cmd, 0);
510 }
511 if (bsdf_name[0]) {
512 add_wbsdf("-f", 1);
513 strcpy(cmd, "n=");
514 strcpy(cmd+2, bsdf_name);
515 add_wbsdf(cmd, 0);
516 }
517 if (!convert_commandline(cmd, sizeof(cmd), wrapBSDF)) {
518 fputs(progname, stderr);
519 fputs(": command line too long in wrap_up()\n", stderr);
520 return(1);
521 }
522 return(system(cmd));
523 }
524 #else
525 /* Execute wrapBSDF command (may never return) */
526 static int
527 wrap_up(void)
528 {
529 char buf[256];
530 char *compath = getpath((char *)wrapBSDF[0], getenv("PATH"), X_OK);
531
532 if (compath == NULL) {
533 fprintf(stderr, "%s: cannot locate %s\n", progname, wrapBSDF[0]);
534 return(1);
535 }
536 if (bsdf_manuf[0]) {
537 add_wbsdf("-f", 1);
538 strcpy(buf, "m=");
539 strcpy(buf+2, bsdf_manuf);
540 add_wbsdf(buf, 0);
541 }
542 if (bsdf_name[0]) {
543 add_wbsdf("-f", 1);
544 strcpy(buf, "n=");
545 strcpy(buf+2, bsdf_name);
546 add_wbsdf(buf, 0);
547 }
548 execv(compath, wrapBSDF); /* successful call never returns */
549 perror(compath);
550 return(1);
551 }
552 #endif
553
554 /* Read in BSDF and interpolate as tensor tree representation */
555 int
556 main(int argc, char *argv[])
557 {
558 static char tfmt[2][4] = {"t4", "t3"};
559 int dofwd = 0, dobwd = 1;
560 char buf[2048];
561 int i, na;
562
563 progname = argv[0];
564 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
565 esupport &= ~(E_INCHAN|E_OUTCHAN);
566 scompile("PI:3.14159265358979323846", NULL, 0);
567 biggerlib();
568 for (i = 1; i < argc && (argv[i][0] == '-') | (argv[i][0] == '+'); i++)
569 switch (argv[i][1]) { /* get options */
570 case 'e':
571 scompile(argv[++i], NULL, 0);
572 break;
573 case 'f':
574 if (!argv[i][2]) {
575 if (strchr(argv[++i], '=') != NULL) {
576 add_wbsdf("-f", 1);
577 add_wbsdf(argv[i], 1);
578 } else
579 fcompile(argv[i]);
580 } else
581 dofwd = (argv[i][0] == '+');
582 break;
583 case 'a':
584 recip = (argv[i][0] == '+') ? " -a" : "";
585 break;
586 case 'b':
587 dobwd = (argv[i][0] == '+');
588 break;
589 case 't':
590 switch (argv[i][2]) {
591 case '3':
592 single_plane_incident = 1;
593 break;
594 case '4':
595 single_plane_incident = 0;
596 break;
597 case '\0':
598 pctcull = atof(argv[++i]);
599 break;
600 default:
601 goto userr;
602 }
603 break;
604 case 'g':
605 samp_order = atoi(argv[++i]);
606 break;
607 case 'l':
608 lobe_lim = atoi(argv[++i]);
609 break;
610 case 'p':
611 do_prog = atoi(argv[i]+2);
612 break;
613 case 'W':
614 add_wbsdf(argv[i], 1);
615 break;
616 case 'u':
617 case 'C':
618 add_wbsdf(argv[i], 1);
619 add_wbsdf(argv[++i], 1);
620 break;
621 default:
622 goto userr;
623 }
624 strcpy(buf, "File produced by: ");
625 if (convert_commandline(buf+18, sizeof(buf)-18, argv) != NULL) {
626 add_wbsdf("-C", 1); add_wbsdf(buf, 0);
627 }
628 if (single_plane_incident >= 0) { /* function-based BSDF? */
629 void (*evf)(char *s) = single_plane_incident ?
630 eval_isotropic : eval_anisotropic;
631 if (i != argc-1 || fundefined(argv[i]) < 3) {
632 fprintf(stderr,
633 "%s: need single function with 6 arguments: bsdf(ix,iy,iz,ox,oy,oz)\n",
634 progname);
635 fprintf(stderr, "\tor 3 arguments using Dx,Dy,Dz: bsdf(ix,iy,iz)\n");
636 goto userr;
637 }
638 ++eclock;
639 add_wbsdf("-a", 1);
640 add_wbsdf(tfmt[single_plane_incident], 1);
641 if (dofwd) {
642 input_orient = -1;
643 output_orient = -1;
644 prog_start("Evaluating outside reflectance");
645 (*evf)(argv[i]);
646 output_orient = 1;
647 prog_start("Evaluating outside->inside transmission");
648 (*evf)(argv[i]);
649 }
650 if (dobwd) {
651 input_orient = 1;
652 output_orient = 1;
653 prog_start("Evaluating inside reflectance");
654 (*evf)(argv[i]);
655 output_orient = -1;
656 prog_start("Evaluating inside->outside transmission");
657 (*evf)(argv[i]);
658 }
659 return(wrap_up());
660 }
661 if (i < argc) { /* open input files if given */
662 int nbsdf = 0;
663 for ( ; i < argc; i++) { /* interpolate each component */
664 char pbuf[256];
665 FILE *fpin = fopen(argv[i], "rb");
666 if (fpin == NULL) {
667 fprintf(stderr, "%s: cannot open BSDF interpolant '%s'\n",
668 progname, argv[i]);
669 return(1);
670 }
671 if (!load_bsdf_rep(fpin))
672 return(1);
673 fclose(fpin);
674 sprintf(pbuf, "Interpolating component '%s'", argv[i]);
675 prog_start(pbuf);
676 if (!nbsdf++) {
677 add_wbsdf("-a", 1);
678 add_wbsdf(tfmt[single_plane_incident], 1);
679 }
680 if (single_plane_incident)
681 eval_isotropic(NULL);
682 else
683 eval_anisotropic(NULL);
684 }
685 return(wrap_up());
686 }
687 SET_FILE_BINARY(stdin); /* load from stdin */
688 if (!load_bsdf_rep(stdin))
689 return(1);
690 prog_start("Interpolating from standard input");
691 add_wbsdf("-a", 1);
692 add_wbsdf(tfmt[single_plane_incident], 1);
693 if (single_plane_incident) /* resample dist. */
694 eval_isotropic(NULL);
695 else
696 eval_anisotropic(NULL);
697
698 return(wrap_up());
699 userr:
700 fprintf(stderr,
701 "Usage: %s [{+|-}a][-g Nlog2][-t pctcull][-l maxlobes] [bsdf.sir ..] > bsdf.xml\n",
702 progname);
703 fprintf(stderr,
704 " or: %s -t{3|4} [{+|-}a][-g Nlog2][-t pctcull][{+|-}for[ward]][{+|-}b[ackward]][-e expr][-f file] bsdf_func > bsdf.xml\n",
705 progname);
706 return(1);
707 }
